PDA
View Full Version : A8 / S8 (D3 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
  1. MMI firmware updates
  2. getAudiparts.com | Genuine OEM Audi Parts + FREE SHIPPING on Most Orders $299+!!!
  3. 2006 A8 Taillights
  4. Engine mounts DIY
  5. Control Arm Ride Height
  6. 04' A8 check engine light
  7. Brakes
  8. Suspension Compressor
  9. Intro: purchased my d306 A8L 5 days ago
  10. Leather upgrade
  11. Tire Sealant into Air Strut (Front)
  12. Front rigth torque mount
  13. 5.2 V10 Intake Manifold
  14. have an ugly MMI panel with areas worn white,etc ?
  15. I think I might have a vac leak p2179
  16. High beams
  17. NEW D1s/2s/3s Xenon Bulbs | Front Turns | Error Free Reverse LEDs | Interior LEDs!
  18. VCDS asking for Password in Engine Module
  19. 8k for a nice used 08 S6?
  20. 05 Audi A8L rev's up and will not go into gear
  21. 2005 Audi A8l o ring for right front air spring
  22. W12 High negative fuel trim
  23. 2008 D3 A8 Trunk Issue
  24. How to drain W12 engine BLOCK from coolant?
  25. Door weatherstripping
  26. MMI Issues 2006 Audi A8
  27. 2005 Audi A8 Air Ride Not Working
  28. Cost input on 4.2 FSI oil leak at dealer
  29. 2008 V10 Engine drop, mild tear down, reseal, exhaust work,POV videos
  30. Restoring my headlights
  31. Window goes down but not up
  32. Do I have the latest nav version?
  33. Leaking washer pipe
  34. anyone replaced the foam drivers seat cushions?
  35. S8 With Ceramic Brakes, Rim fitting
  36. Looking at my 3rd A8, W12 this time
  37. Soft Close Trunk Fix (Update)
  38. Sunlight and Rain Sensor
  39. Seat cover replacement
  40. Audi a-8 passenger headlight assembly removal
  41. No heat, questions before replacing
  42. reverse cameras on A8 stopped working.
  43. D3 w12 Trunk won’t open
  44. Considering buying '09 - '10 A8
  45. Front bumper compatability
  46. 19” tires and pothole blowouts
  47. 2009 S8 Trunk Malfunction After Manually Closing Lid By Hand
  48. Audi A8 D3 4.2 p0022 and p1534 fault code
  49. V10 intake manifold
  50. Best fitting travel mug
  51. Can I safely use an air hammer on the center axle bolt with ceramic brake rotors
  52. Considering 07 S8 purchase:
  53. It's my turn... left and rear left vents hot, right side cold
  54. Buying a8 w/123,000 miles
  55. MMI Screen Questions
  56. A/c problem
  57. Anybody have repair manual in PDF
  58. Rebuilding a Starter
  59. where is 'level control pressure sensor' (G291) ?
  60. oil leak
  61. Battery Charger - Part 2
  62. Compressor Mounting Bolts
  63. Recall 26J2 Catalyst replacement
  64. WANTED: (1) 19" 5-spoke "Sport" rim
  65. Did a litle mod today.
  66. RF Strut Leak Question
  67. Sagging driver's door
  68. Intake cleaners
  69. Installed the plate delete filler
  70. Here's my noisy bushings
  71. 2006 S8 Engine Remanufacture
  72. Type oil and quantity for Audi A8L, 2008
  73. What is this part called - While doing body work this fell out
  74. Trunk Opening Problem - Not the latch problem`
  75. Bose amp replacement question
  76. New Wheels
  77. Front marker lens options
  78. Vag-com modification for a more responsive throttle?
  79. Wired FM Modulator Installation Questions
  80. S8 O2 sensor help please
  81. Left front level sensor - air suspension problem
  82. Headrest Monitor
  83. Atf operating temperature?
  84. 2009 D3 4.2 Post on vag com forum
  85. Secondary air injection system insufficient flow
  86. Non- Adaptive stock headlights fit stock Adaptive system?
  87. Preventative maintenance while W12 engine dropped
  88. 2008 A8L Driver Side Trunk Lid Taillight
  89. Audi A8 d3 ambient lighting retrofit
  90. Unable to Access Codes From Address 17: Instruments
  91. anyone know how Euro MMI remote control works?
  92. OBDEleven for Android People
  93. Acc/Start Auth Module S/W Coding
  94. A8L D3 Temp Sensor or Thermostat?
  95. Yet Another Suspension Thread
  96. Detailed car report
  97. ASB engine manual
  98. Oil Pressure Sensor
  99. Is it possible to convert xenon to LED
  100. RPMs bouncing | Fuel too lean | Battery not charging
  101. 2008 S8
  102. I've been a bit of a d**khead lol, maybe that will benefit someone else... (:
  103. TPMS system malfunction: While driving I got a dipped beam code, The power steering
  104. My engine oil analysis
  105. Call me Mr Thicky but can somebody explain the logic behind this please...??!
  106. mirrors folded via key command or handle touch
  107. AUDI A8L 4.2L Gasoline, AUTOMATIC TRANSMISSION problem
  108. Audi A8 Headphone
  109. Audi A8 Headphone
  110. Compressor removal.
  111. May have shorted my headlights! One foglight is all that works now...
  112. **Help** I removed my light/rain sensor... Car will not start
  113. Dino's 2010 A8L Thread
  114. Fan is running hard
  115. Audi A8 D3 N/S wing mirror indicator not working - please help
  116. Headlight Range Control Defective/Light Sensor defective ('04- A8L)
  117. !!! Help Rear end slammed after 402 mod !!!
  118. VNS media "AMI" disappointment
  119. lights on steering wheel blink
  120. Power Steering Hoses Replacement
  121. Audi A8 AMI 2g
  122. Check oil temperature, possible?
  123. A little help for a couple of issues pretty please (:
  124. Transmission leak - What parts are these?
  125. Battery Level Issues | Displays 0%; battery full
  126. Lighting
  127. Decisions, decisions... D3 vs D4?
  128. Best child seat protector for an Audi A8L
  129. Fuel Injector(s) replacement
  130. Audi A8 2006 4.2 TDI
  131. Xenon HID headlight flickering out after 15 seconds
  132. Air Suspension
  133. Need help with an intermittent smell of gas
  134. suspension setting missing on mmi
  135. Nice to knock off some maintenance items on my S8 finally
  136. How To Search Audiworld For Your Audi Specific Problem
  137. Collapsing REAR suspension on W12, help welcomed..
  138. Disabling MMI screen from moving up and down question
  139. All D3s in the US have MMI 2G correct?
  140. Blower motor control question
  141. What is under passenger carpet?
  142. Crankshaft Bolt Removal
  143. Light sensor change
  144. Witch is my MMI?
  145. Heated seat retrofit problem
  146. 2006 A8L headlight swap with 2005
  147. MMI Issue
  148. Parking brake motor
  149. Looking for Verification on Suspension Issue
  150. S bar bushings from other Audi/VW models fit D3 ?
  151. Wiper Operation Question
  152. W12 maintenance suggestion (Intake manifold removal)
  153. Help with coding...
  154. Trying to resurrect a dead A8
  155. D3 A8L Suspension Problems
  156. Audi A8 2003 - Air Suspension Problem - Water from compressor
  157. what size is the subwoofer
  158. 08 A8L D3 suspension jack mode not working
  159. Engine cover
  160. How to control A8 D3 Interface Module. To know if it's working or not
  161. Random car battery drainage?
  162. H7 Center light replacement questions
  163. Replace headlight housing lens
  164. question for a member with a Euro spec face lift A8
  165. Mister Bally needs your help, please
  166. Emissions Recall 26J2 - Catalysts
  167. What do you think is a fair price for this car?
  168. Problem with background lights.
  169. Problem with background lights.
  170. Do RMT Struts Still Suck?
  171. It's my turn for tie rod ends
  172. 08 A8L suspension issues
  173. TPMS for aftermarket Wheels
  174. Knocking sound in steering wheel.
  175. It's 123k miles oil change, again
  176. Xenon bulb replaced, still doesn't work
  177. Transmission Flush Opinion Question - Should I or Shouldn't I?
  178. Strange first start missfire
  179. Where is my coolant going?
  180. A curious case of Audi's trunk motor
  181. S8 5.2L Cat Temperatures
  182. Well.... removed my intake.
  183. AMI box number / Android ideas
  184. My First VCDS report!!! Please explain some of my questions.
  185. Miles to service indicator
  186. 2008 D3 4.2 brake issue - What could it be?
  187. VCDS DTC Question, MMI Upgrade, Sharp Metal in Window Well, and Tires!
  188. Just got rosstech tool / vcds S8 /07 mods questions
  189. Front & Rear Center Jacking Points?
  190. Automatic Folding Mirror setting
  191. adjusting windshield squirters
  192. 2008 A8 SWB Condensation at sun visors area`
  193. 07 A8 D3 4.2 Radio/Audio clicking on and off
  194. Audi A8 - trouble code circus
  195. Indy Repair in NW Indiana/South Chicago
  196. battery charger
  197. 2006 Audi A8 jack mode greyed out on MMI but need to change a flat tire.
  198. Brake kits for 08-08 D3 S8, but not 07 S8? Why
  199. 2006 A8L... New to Audi. Lost in spaceship options
  200. 2006 A8 MMI Powers on then off
  201. 2004 A8 ESP light ON, ABS working
  202. Air suspension compressor drawing too many amps & engine mount "leaking" ?
  203. My Gear indicator on my dash is all the way lit up
  204. My Gear indicator on my dash is all the way lit up
  205. Replacing steering wheel
  206. New College Car??
  207. front end damage = $3300
  208. 2009 A8L MMI Issue
  209. Oil filler cover holes clogged, lots of build up - opinions?
  210. A8 (D3) rear air shocks replacin
  211. Euro tails fit our us spec cars?
  212. TPMS new battery experiments ANYONE?
  213. Multiple Faults Related to ABS/ESP
  214. Wheel size fitment ??
  215. ever push the accelerator and get no response ?
  216. 2016 Navigation Disc Install - Questions and Tips?
  217. Adaptive Air Suspension Green(constant)/Yellow & EPC Lights (in cold)?
  218. Cant park my car in dynamic mode....
  219. Replace 2007 S8 Steering Rack with 2008 A8 Rack
  220. LHD: Is bank 2 driver's side on Audi S8?
  221. Looking at wheels, opinions please.
  222. 2007 A8L Right Inner Tail Light Stumpper
  223. 2008 S8 FLY-BY-WIRE THROTTLE ISSUES
  224. Recommended Tools for 2010 A8L
  225. Parking Brake Warning Light
  226. Just joined the family w/ a 2004 A8L D3! A few questions!
  227. A8 BHT W12 2004 AIR SUSPENSION PROBLEM
  228. sirius radio canceled
  229. How to program remote windows up/down.
  230. made it to 110k on the same timing belt
  231. Upgrading my MMI
  232. Blind spot module location?
  233. Issues. One side hot...randomly. And some other issues.
  234. Picking up my 2010 A8L tomorrow
  235. S8 fuel injectors
  236. A8L DIY Brake pad replacement front and rear
  237. A8 DIY cupholder insert
  238. Weird noise from rear wheel when car turns off
  239. My brand new second hand D3
  240. Keyless\proximity sensor ,and timekeeping question
  241. 07 S8 taillight update - question
  242. 2008 S8 INTAKE MANIFOLD REPLACEMENT UPDATE
  243. Air Suspension
  244. Weird keyless entry issue
  245. Is the leather in A8s urethane coated like most all
  246. Considering 2005-2009 A8 W12
  247. Anyone know where I
  248. 2007 A8l W12
  249. Parked on a angle!
  250. How to add own service records to carfax ?
