- suspension height change/question
- WTH happened to my seat? Turned gray!
- Heated LEDs for D3?
- Air Suspension - Limp Mode - Lights Flashing
- Shockingly low numbers
- How warm should the heated steering wheel be?
- Help bringing her back from dead. Immobilizer and suspension?
- air suspension diagnosis- dealer stated
- Adaptive headlight repair - Audi A8L D3
- 09 a8 brakes
- A6 rear headrests mod.
- Love this car!
- Multitronic Info?
- Flashing red brake light
- DIY: EVO-XR 2.0 Projector swap (headlight junkies / lighting addicts)
- Rain & Light Sensor Adaptation Help
- VCDS scan of my good deal A8
- Fuel injector connector will not lock onto injector 2005 w12
- VCDS Questions
- VCDS Questions
- Hazard button illuminated all the time
- Warning on Dash
- Cracked Rotors
- Adaptive Headlight Defect After Replacing Bulb
- 2008 S8 Self Braking Issue - Braking on its own
- Timing Belt, Water Pump, T-Stat, Coolant Pipe, Oil Filter Housing, VC Gasket.......
- NEW MMI board
- What function does the engine splash shield provide?
- D3 Audi A8
- Brake pad light
- MMI QUESTIONS AND VCDS QUESTIONS
- Side sill trim repair / replacement
- Additional / replacement key
- 07 Audi A8 4.2 FSI: Not sure what’s wrong with my audi
- Hi people i have a8 problems
- D3 S8 weird DTC, anyone see this before?
- No sound
- My Old Faithful A8L
- Video: DIY carbon clean, injector reseal, manifold removal, POV
- Any idea whats the solution to this? 4.2 Engine backfires/sluggish/unstable
- My turn for W12 air filters and ignitions coils
- Oil return hose on 07 (BVJ)
- USA: Component protection manager disable workaround?
- Well I just joined your family
- Flashing BRAKE light-- no codes, good pressure, strange scenario.
- Suspension emergency lock mode
- suspension height lower after driving
- HVAC temperature readings
- 04 Audi A8 Wont Start Key Not Being Recognized
- Instrument Cluster LED? Information Center Dead 2006 A8
- Telephone / Lights Issue
- Can you code the MMI screen to be closed on startup
- Making the jump from D2 to D3?
- Suspension failure please read this
- Air suspension fault-any ideas?
- Intake air temp Sensor fault after air filter service
- Help coding window?
- Carista, another OBD2 Scanner for iOS and Android
- No tire pressure system showing up in the MMI
- Thinking of buying a 2009 Audi A8L.
- Passenger side headlight wont turn on
- Traded my 2010 A8L for 2015 CPO Mercedes S550
- Air suspension issue
- Keyless entry problem
- Parking brake/rear brake problem
- Levelling problem?
- Control Head issue
- Engine Issue
- How do you know if you're compressor is on its way out?
- Part inside oil filter housing broke. Need Help
- Brake pads
- Great value Bluetooth phone and A2DP solution
- First long road trip, only one failure!
- S8 Fuel Pressure Issue
- Roof drain exit
- age related forgetfulness
- Low voltage battery caused; no crank, no start
- Intermittent issue, fuel pump or other stuff fails due to hot weather?
- Stupid question, I assume I have a GEN2 MMI in my 2007?
- any way to opt out of ACC and function like reg CC ?
- Major throttle problem!
- Audi a8 D3 2006 antifreeze leak
- Now there's two of them......
- Yaw Sensor Replacement
- Jumping into the A8 D3 world
- Cleaning garage
- A8- D3 timing belt replacement, 4.2
- Unusual problem with interior heat
- 05 A8 Buy or Avoid? 180K miles
- Thinking bad injector? Missfire at higher RPMs.
- Here is a Fuel Injector replace procedure.
- Seat calibration?
- D3 problem with heating and ECU removal
- 2004 Valve covers
- gearbox
- Fault codes : P1577/P1573
- Oil pressure sensor connector
- 07 A8 Rear Air Suspension Issues after Jacking
- Back again! 07 A8L
- Celebrate 6 years and 55k miles on my 2006 A8L 4.2
- Bank 1 sensor 1
- Engine swap to an older van idea
- D3 Owner's manual
- Audi S6 Vs S8 V10
- Brake Pads?
- Jump start location in front
- Auxiliary Brake pump fuse
- Air Conditioning fault codes - 00065 - 00066
- Brake Fault code - 01826
- Rebuild rear suspension
- 2009 S8 Totalled - Cost of Ownership Breakdown Over 4+ Years
- Having the cats replaced and the dealer is suggesting the following:
- Intake Manifold CEL codes
- Dash Camera
- Audi is trying to kill me with throttle
- Hood "open" & possible faulty MAF
- 07 S8
- face lift fog light/grille to '06 A8 and visa versa ?
- Yet Another Suspension Air Compressor Issue. 00668 - Supply Voltage Terminal 30 009
- any info about seller deAutoLED that has ad on AW?
- Window programming
- 2004 Audi a8l 4E
- Totaled my D3
- Auxiliary brake pump diagram
- how long did it take you to R&R blower motor ?
- Audi Christmas
- Misfire when fuel level is high. O2 B1 S1 No signal
- Alignment is out after hit curb on RR side
- Battery Code / Coding / Replace
- A8 No crank
- 2008 D3 4.2 MMI Programming
- A8 "Heal thyself"
- Audi Took a Hit
- Oil cooler pipe help
- Yellow suspension light off again after outside temperatures turn positive
- Upper control-arm replacement Qs?
- Audi A8 D3 2007 model RHD Driver's side bonnet stuck
- Oil leak
- ABS Issue
- How to swap out EVAP Canister Purge Solenoid Valve (N115) 04 A8 4.2L
- Signs of a milkshake
- Gas/Fuel Smell?
- Buh-Bye 2006 A8
- Adaptive Air Suspension and other issues
- 07-S8 door unlock proximity sensor questions and more questions! Sorry
- NO TV Tuner without "A" HU and RVC controller enable?
- Parking Brake Fun!!! Help needed
- New to us 05 A8 - Questions
- 21” X 10.5” ET45 wrapped in 275/35/21 on 2008 D3 A8
- 07 s8 proximity unlock doesn't work
- Which strut is the right one?
- Arnott or not?
- Checked fuses and now 2006 a8 wont start???
- Satellite Radio
- INTRO PRICE / Group Buy: *NEW* LED Fog technology: 1 LED 4 modes: WHITE/YELLOW/STROBE
- spare tire TPMS question...
- Winter time: dash vents hot and cold
- 2008 4.2L coolant leak near heater hoses
- MMI Occasionally does not open
- The dreaded yellow suspension light
- 2007 Audi A8L - Adaptive Air Suspension - Yellow Light Glows Constantly.
- 19mm Axle Bolt Part #
- Audi A8 D3 MMI upgrades
- 2008 D3 Gear Cluster Lit up/Loss of Power
- Lower Control Arm Thrust bushing squeak
- MMI STUCK IN BOOTLOADER MODE 04 AUDI A8
- Coolant leak after catalyst recall
- 2004 A8 erratic starting
- MMI stuck in bootloader mode
- Battery voltage issues; lights dim, RPMs drop w/ window buttons (#s included)
- T9T9 Ibis White (S8) - journal
- UNSOLVABLE SUSPENSION PROBLEM ?
- Loose lug bolt damage?
- Best 20" all year tires
- Air Suspension data needed/Help, please
- Is g13 coolant bad for Cars?
- One problem solved, two new ones in its place
- Parking brake issue tonight - a particularly COLD night - and BRAKE MIL remaining on
- Proper coolant flush instructions
- Oil cooler pipe leak
- S8 Throttle Body Alignment
- fuel level is fixed on maximum?
- 04 A8 D3 EVAP Purge Valve Location 4.2
- Headlight restoration and cleaning
- MMI Display replacement gears.
- A8 d3 windshield washer not working
- Stop Leak
- Code help
- getAudiparts.com | Black Friday - Cyber Monday: Lower Pricing + FREE Shipping!!!
- audi a8 mmi2g and original md player - how
- Rear controls for seat heater and cig. ligher
- Do these wheels have a name, are they worth anything?
- Imagine suspension issues
- Any alternative CD players I can use?
- Just venting about the dealership
- Europrice.us Black Friday Deals are almost here...
- Adding music streaming to 04 A8L
- Carbon Cleaning Adapter 2.0T, 3.0T, 3.2L, 4.0T, 4.2L, 5.2L, etc
- 2007 S8 TPMS help/advice please
- Johnny's Facelift Taillights Confusion, Euro vs. US
- Bank 2 sensor 1
- Changed all Plugs and Coil Packs and now...
- Sunroof problem
- Replacing OnStar with Bluetooth Module (2004 D3)
- Ac line always cold?
- CHECK ENGINE LIGHT - FAULTS INCLUDED
- could not find a Youtube tutorial on valve block R&R
- any one done the R&R of air compressor in W12 A8?
- Re-building compressor tomorrow...have a question
- Where does this line connect to?
- People messing with your car
- Front Brake Upgrade A8/S8
- System Fault (Major) 07 4.2FSI
- Trunk stuck open
- Head gasket leak
- Battery coding won't save!
- lost bluetooth
- PROJECT: WHITE SATINE... S8L BUILD.
- Part# for ATF line bracket stud
- Any idea to repair or buy kessy ecu 4E0 907 181B on my audi A8L 2.8 year 2008
- Wiper dont start
- Serpentine belt and idler roller pulley and tensioner replacement
- S6/S8 auto trans and engine as a donor car
- Oil choice - timing adjuster chain noise?
- Help - Cold-weather behavior- my A8 is acting up this winter, again!
- Battery Drain
- MMI short
- Castrol Oil Weight - Audi vs Castrol
- Common Symptoms of Bad Control Arms?
- 2006 a8
- W12 - keep or repair
- EPC Light and then Check Engine Light
- 07 Bent Valves???
- 2004 A8L Ticking, sticking, groaning, growling, whining, whistling and wheezing sound
- Suspension Problem Clueless meachanic
- 2005 A8L 4.2 - Refresh
- EGR replacement
- Is 4610 the most recent MMI software?
- 2008 A8 L Steering not centering
- 2008 A8 LED Taillights
- Subwoofer AMP - can it take down the Audio Buss??
- 2007 S8 ECT?
- Who Needs New D3 LWB OEM Audi A8 logo Rubber Winter Mats?
- 2007 S8 clicking noise fro engine
- Headlight Upgrade
- Engine Waffle sound when decelerate A6
- What is this part? Its making hooting sound.
- Where is 2005 W12 air suspension pump?
- Upper Control Arm replacement Torques
- 06 6speed tiptronic fluid change advice needed
