- New LED no more error message on my 07
- Newbe Here - looking at an S8
- Sirius/XM module swap
- AMI Update
- Glovebox vibration driving me crazy
- Please Help. Still Battling Noise
- 2005 A8 spare wheel...? which one?
- Somewhat related to air compressor post...
- Unknown Audi wheel
- Front 2007 S8 bumper
- some type of air pump from front left does not shut off
- Error code free LED lights
- Ramp Project
- Seafoam carbon treatment, can I?
- Level Control -34 will not save adaptation
- Exhaust mod yet again...does anyone know if
- Jack upgrade
- Audi Music Interface for sale
- Fuel pump replacement - notes
- rear bumper cover removal
- Not A8 I am afraid but interesting....
- need cam aligning help
- 2004 Audi A8 4.2 L - Gray/Black - Hillsboro OR
- FINALLY!!! PICTURES ARE HERE
- 2005 A8 Tranny Problems
- Best 19" wheels for S8
- Orange electronics - TPMS sensors
- 2004 Audi A8 4.2 - Beige/Beige - Ohio
- Need some brake help urgently
- need brakes all way round. want low dust.
- part number for XM module - '05 A8?
- Considering A8
- radio, cd, nav cutting in and out
- Trans "hoot" - possible at a standstill?
- Sirius cuts in/out.. any know issues?
- Need to Stock up on your Detailing Gear! Free Shipping at DD till 5/1/12
- Service interval reset problem
- A8 Intake Actuator Arms
- Engine surge and rough idle
- Help with Audi Bluetooth Adapter for MMI
- headlight/bulb confusion
- 2007 S8 grillie
- Oriental rug style floor mats - crazy or not?
- Arnott Inc Air compressor
- fuel filter replacement
- Pinch Your Nipples: D3 Style
- 2007 S8 fog light part #
- Any pics of debadged D3 rumps??
- upgrade to HID's
- No dash warning lights in "Dynamic" mode, until "Standard" mode.
- D3 bleeding procedure
- Great Audi Service/Loaner
- D3 timing belt - notes
- D3 Headlight out... now what?
- Footrest PN?
- Wheel offset question
- '05 relay roller part # - timing belt job
- VAG guru's...need your help..went in to code
- So before I buy a new air compressor for my car
- Steering Wheel Noise
- dash half out for mmi gear change....need some help now!
- oil change interval??
- front bumper conversion question
- Question about the Service Indicator
- Broken window, pass. side front; no apparent cause
- Smell associated with bad suspension compressor and or relay
- Long shot : Anyone have to time to drive my car some where btw Melville LI and West?
- crank lock tool 4.2
- 2005 A8 suspension compressor relay
- fuel filter tool?
- S8 - Seat Cooling / Massage
- Mud Flaps / Spash Guards D3 pics?
- 2005 (very rarely) fails to start on the first attempt - should I be worried?
- anyone ever have a P1874 code ?
- YATT - Yet another Tire Thread
- Sound quality -CD vs AMI + usb
- Any decent indie shops in NY?
- 07 S8 Impressions
- The D3 picture thread
- 06 a8 SWB, new member - air susp behavior question
- some vac issues
- Dead 2004 A8
- HID Fog Light Alternative
- Few thoughts on oil
- Tint anyone?
- VagCom?
- 3M headlight polishing kit. Before and afters.... (and link)
- MMI Update ?
- you can tell Spring is really here...
- Anyone had C63 then switched over to S8?
- Hello everyone! New member, looking forward to the experience!
- Time and Date Memory Loss
- LED Foglight or Front Blinker bulbs anyone?
- 2009 S8 Transmission Issues?
- my solution for the parking(city/standing)light
- Honest opinions needed..,wheels
- The look that compliments performance. HRE Wheels for your A8, from AWE Tuning.
- considering 2008/9 certified A8..questions...
- cheapest place to buy s8 tail-lights
- OIL COOLER LEAKING COOLANT
- D3 headlight lens removal?
- A/C recharge ?
- Speed bumps and air suspension
- 2007/8 S8 door mirror finish.. pictures?
- Passenger Seat Switch
- Need A8l passenger mirror -- any suggestions?
- A8 Map update
- A8/S8 VAG COM Lowering Video?
- Need Help Dead A8
- Second complete failure on my 2004 which made the car not drivable.
- Just picked up a 08 A8L - roof racks?
- Experience with Ipod/AMI?
- Audi Care for $1550
- MMI
- Valve for Torque Support Mount
- A8, 2007 front brake pads replacement
- Sunroof Switch Illumination
- Interior Trim Replacement Parts
- Where can I identify Model year on Audi A8
- Passenger mirror stuck down when car is in reverse.
- 06 A8 to S8 bumper conversion
- 2004 A8L Drivers Mirror Drawing
- Possibly upgrading to a D3 tomorrow (2007 SWB); Some Questions
- slow speed transmission shifts
- Aftermarket Non Milltek (too much $) exhaust options..<more>
- Stuck Side Shade?
- Spacers...08 SWB w/sport susp and 20's ok for 12mm
- Noise from Passenger Seat Back
- Side mirror strip LED change
- Question for S8 Gurus
- Help! Help! adaptive air suspension
- Sticky Accelerator
- photo shop favor
- This is, ah, different!
- steering
- ventilated seats
- Stock up on your detailing gear 1st Day of Spring Special at DD
- Anybody has BOSE amp pinout?
- AC recharge. Is vag-com needed?
- Mismatched vavona/birch(?) dash/console question
- Hose from bottom of air cleaner, was is dis? (2004 4.2)
- 2004 4.2 is not FSI, correct?
- I'm Back!!
- How to read the Varta battery code?
- Longevity of D2S replacement bulbs
- Switch on driver's door jamb?
- what models use ZF's HP24 transmission?
- Annoying Noise In Rear
- Rear Rotor size 2005 A8
- License Plate Frame Suggestions
- Cup Holder solution... I have a cunning plan...
- 2006 a8 parts for sale
- Looking at an 06 A8- What's the difference between A8 and A8L?
- New type key for old
- 2008 A8 Newbie - Sunroof
- Car shopping: '06-'07 Audi A8L vs. BMW 750Li vs. ?
- Sage Green
- Do the headlights self-adjust? (2004 A8L)
- Hardwiring passport radar on 04 Audi a8
- "AIR BAG" light came on : here's the solution
- Easily upgradable features?
- New here 2005 A8 trans Problems. Help!
- License plate lens bulb
- Procedure for turning MMI battery level and instruments back on after 4610 upgrade
- Disable TPMS with VAG-COM
- Is there really a "Slate" color in 2004?
- Engine Movement
- Remove sport height settings
- 2005 D3 headlight exploded diagram?
- Bridgestone Potenza RE970AS Pole Position??
- MMI 1070->4610 upgrade & NAV v4->v8 Complete! No issues!
- RE: Sticky: Missed the race? There’s an App for that! [FREE]
- D3 Brake rotors, which one?
- N80 Evap purge valve
- CF Trim Set '07 S8
- F/S 07 S8
- Humming noise from rear; increase with speed
- Can't find accessory wire! Please help
- Noise from right wheel
- 2004 Audi A8L value?
- Anyone looking for a non-FSI motor A8 mine is for sale in the classifieds
- Problem with 4.2 FSI engines ?
- Sirius / FM incompatibility?
- Navigation Update?
- W12 gearbox oil
- Couple of '05 electrical issues, CD and Steering column
- Cracked exhaust pipe
- Urgent! Cant access MMI
- FS: 2003 Audi S8 Quattro - Silver/Red - Bradenton, FL
- Hydraulic oil level
- Did my vag-com...now way
- Anyone tried red cable with AMI?
- Fuel Filter Replacement
- I have sports car fever. Listed my A8 sport
- FS: 2005 Audi A8 4.2 - Blue/Brown - Cleveland, TN
- Starter going, or just a gremlin?
- What floor mats do you use?
- Upgrade debate as these cars get older: SAT vs. AMI ?
- Possible AMI alternative
- Where do I buy a spare key?
- 2004 A8 What should I look for?
- Remove Phonebook entries?
- Faint clicking in cowl (under hood) car off & parked
- Last Day to Pre Order the Griots 6 inch Orbital Polisher Kit at Intro Price
- Invoxia "AudiOffice"
- Is it possible to keep MMI down?
- Sirius Radio Help
- Gruven Intake Links
- Vacuum Exhaust Opening
- Emissions light on??
- Cleaning Engine
- Need front filler panel - have license bracket (2004/05)
- Keys locked in car 08 S8
- Amazing wheels
- dish display help please hmmm
- Sick Car
- Next Issue
- Riddle me this...
- Retrofit--Electric Side Blinds
- A8 eating battery
- Do your air vent illuminate?
- problem with mmi
- Cup Holder Solution
- Info Request: Prospective Buyer of A8
- Flickering Headlight problem!?! SEE PICS
- Dealer Trouble Diagnosing. Please Help!
- Interior Lighting
- New to me S8
- Difference between window switches?
- Traction Control question -
- surround in '09 A8?
- A8 MMI stuck in bootloader mode
- Another MMI menu issue.... can't access hidden menu either..
- Digital Speed Reading
- MMI problem or battery problem?
- Best way to get out coins 'behind' drink holders?
- I want to use the phone.
- MMI Screen Keeps Receding - Any Clues?
- So I am able to use Etka again
- Replacing all 4 tires at once?
- Small LCD display stopped working correctly.
- Will 08 tail lights fit a 06 ?
- Anyone know of a A8 parts car?-need MMI control module
- Ignition coil question...
- Door Closing Motor Sounds Strange
- Suspension Compressor Failure?
- Lowering oddities...
- Interested in 2004-05 A8L - advice on purchasing
- FOUND! multiple factory 'seconds' A8 single grille bumpers..
- continued issues with heated steering wheel install
