- S8: Back From the Paint & Wheel Shop (Photos)
- How to prevent carbon buildup
- Antenna!!
- Well, I got an American car
- Navigation map stuck at destination
- How cold is it where you are?
- Service light - 2007 S8
- new wheels maybe
- Please be careful driving our A8 this winter...
- steering column lock actuator fault
- No remote starter on a $80k car, seriously???
- S8 a/c Problem?
- Fresh scan-What's it gonna take to clear my MIL?
- Seat heater question
- Rear Headrests
- oil change $
- Air Compressor or Another Part Failing?
- little brake squeak
- Just ordered NGK BKR6EIX Iridium IX Spark Plugs
- Key fob distance.
- Just bought an a8 but no tv signal and start button doesnt work. just
- Parked Next To A D4 Tonight - It's GRANT.
- WTB: 2007/2008 A8
- Backup Camera Retrofit
- Suspension squeaks and steering noises at 40F
- Suspension Settings on MMI - missing.
- Looking for a 12V switched power wire under dash
- traded my D3 for an A7
- S8 Exhaust Upgrade?
- all data diy?
- Wheel off centre after hitting curb
- Found Some 18" Wheels Like New
- Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - December 16th - 21st 2013
- i know another stinking led ?
- Spare Parts to keep on hand???
- Some electronic issues
- Test driving an 2007 Audi A8 4.2 Quattro
- Tint
- NEED A GOOD SALES REP-SO CAL
- Odd headlight movement
- Boot/Trunk question
- Goodbye 2008 A8L- Hello BMW 750LI Xdrive
- Changing Tyres
- Black Friday Special @ DetailersDomain.com
- New Tire Selection Buying Advice
- Disable city lights
- Can anyone identify this part?
- Air Suspension problem!
- 2007 A8 Rear Armrest/Cupholder and Side Holder on Door
- User ID / Fingerprint memory
- CP-Component Protection and Add-on devices
- Battery control module 61 no response
- Bose Amp
- :: ECS Tuning :: 9th Annual Customer Appreciation Holiday Sale & Giveaway!!
- help freezing feet
- Odd Spinning Noise
- Anyone put Flowmaster mufflers on their 4.2?
- BMW 7 series wheels on A8???
- Pre-Black Friday Special at Detailer's Domain - Limited Time Offers
- Pre facelift vs Facelift ambient lighting?
- New Member - New S8 Owner
- Thinking of Selling...
- Terminal 30 Errors
- Ski/Snowboard rack advice requested
- New ownership concerns
- Are our turn signal & wiper stalks supposed to illuminate?
- Canadian A8 07 4.2L - Should it have a block heater?
- Used 2004 cheap, but rough
- TPMS Issues
- a8 d3 4.2 v8 o2 sensor reoval bank 1 sensor 2
- Lights issue
- AC is not working after ac vents replacement
- Random Electrical Problem
- rear brake job
- Wheel bearing replacement cost?
- Timing belt tools
- Will this wheel work for my winter setup?
- Hofele grill on - need some advice on more mods
- Trying to Get Group Buy on Billet Oil Filter Housing Caps
- Hub Rings 07 S8
- MMI Console Button Backlites Out
- rear lid closing assist drive motor problem
- Enabled secret menu - TFFS (filesystem) - Looks like VxWorks
- Battery vcds pic - 40% SOC - Replace?
- a8 4.2 engine cut out problem
- Winter shoes pic - and lug bolt cap question
- A8 cranking but not starting
- 07 Intermittent ticking sound from glove compartment (cd changer?)
- Rough Riding
- Trunk Hinge...trunk lid too high
- Looking for oil filter on 2007 not the same as 04-06
- MMI update!!
- Suspension.advise please
- Bose speaker hole
- Swapping MMI control board anything I should know??
- 19x9.5 5x112 ET45 Wheels
- 2007 A8 4.2 TRANSMISSION FLUID
- steering wheel creaking
- Tie Rod Replacement
- New owner Intro
- Level Controller Help
- Finally pulled the trigger
- 2009 A8L spark plugs replacement
- Rear park sensor part # A8 D3
- Proud owner of a 06' Audi A8L
- AUDI A8L 4.2q 2006
- Door adjar in display
- creaking noise while steering at low speed
- Looking for Premium Start/Stop Switch
- 'secondary air pump' code...
- battery question
- Installing ACC on facelift 2008-> A8, do i need clusterswap?
- Changing Battery. Anything I should need to watch for?
- Instrument-Cluster goes spastic, then dark
- Question about estimated cost for repair
- 06 mmi control board work for an 04??
- Looking for 07 control module for mmi
- Will a 275-40-20 tire work on our S8's for a winter tire?
- Floor mat causes sudden acceleration
- A D3 W12 TDI ? Really ???
- Upgrade Update!
- 20" S8 A8 OEM wheels for sale
- What could these parking sensor fault codes indicate?
- TPMS VALVE Size Question
- secondary air pump relay and fuse
- Audi China
- B&O tweeter won't stay up
- New (to us) A8... what do I need to know?
- 08 fog lights
- Post in the Classifieds a 2008 A8L in Kansas City
- What is this button???
- Understanding how the Mmi system works
- most common front lower control arm failuress
- Stabilizer Bar Size
- Cognac Exclusive Interior - Stunning
- Guess I better buy a sturdy hat for any D4 future ideas...
- Greetings from Finland!
- Fan Wont turn off
- Trunk open/close issue
- Just got an A8
- spacer question
- Bluetooth Streaming in a 2007 S8?
- HELP!!! NEED AIR COMPRESSOR AND STRUT SOURCE FOR 2008 S8
- Getting close to buying
- Change that ATF! Picture of my fluid
- Winter wheels and tires
- What hose should I use to introduce Seafoam
- Another MMI Control board question Please HELP thanks
- Passed the 200,000 mile mark-how much longer do these cars last
- 15% off for the next 48 hours at DetailersDomain.com
- Uneven tire wear?
- A8 at drive-in
- remote trunk closing now possible...
- Price to good to be true?
- Repainting Drip Rails
- Transfer Case Tire Tread relationship
- A8 D3 dial sweep
- Air Suspension Problems
- EPC light
- What does this button do...
- Is Pentosin CHF 202 the same as the OE fluid for a 2008 A8L
- Incompatible brake pad connector
- WABCO Woes
- Cup Holder Drama
- Urgent! How to bleed ABS?
- Audi A8L W12 Oil pressure
- Comfort vs. Dynamic
- Squeaking drivers side front. Bushings or entire control arm assembly?
- RecommendedTransmission fluid for Audi A8
- Power Steering Went Out??
- Water in my car... need help asap
- What's wrong with my A8 L's headlight?
- **Don Nguyen | Vinyl roof wrapping, tail light tinting, black out chrome trim install
- Picture of Staggered fit wheels
- Is there a way to auto-retract side mirrors?
- D3 S8 wheel issues
- Common misfire cause on 4.2?
- anyone installed a Kufatec trunk module?
- VAG adaptation for flashing brake lights ?
- Fuel Pump Fuse Location
- Is it worth it to upgrade to s8??
- Remote Window Control Doesn't Work After Changing The Battery
- How many years did you get out of the original battery??
- D3 A8 Coolant leak
- Front Control Arms/Tie Rods replaced. Car feels worse than before.
- AMI/Bluetooth in 05 A8
- Brake Replacement
- deck lid non-opening issue solved at last !!!
- anyone installed a KUNSET module...
- 2005 Audi A8 6.0 W12 Breaking for spares
- Steering Wheel won't tilt or scope...
- Automatic Headlights Automatic Wipers Defective
- 04' A8 Suspension Question?
- Changing the center console volume knob
- new tyres
- OFF TOPIC: VW B5 Passat GLX for sale in Denver
- VAG COM interface cable
- Just found a small number of the Audi OE AMI to AD2P add on kits
- Radiator Fan Control Module
- IPhone 4 music through MMI
- Transmission coding?
- 2007 Audi S8 Exhaust valve solenoid location
- strange noise from engine
- Control Module Power Supply Relay (J271)
- remote control for rear passenger
- Engine Light
- MMI Doesn't switch to camera mode...
- Check engine light and OBD-II Trouble Codes
- D3 S8 wheel fitment
- 2005 a8 to play dvds via MMI
- Adding iPhone/iPod/Android to 2006 A8L
- Soft close door install
- Filler plate and TPMS sensors installed
- how to remove rear bumper on A8 W12
- Thanks to MP4.2!!!
- Where Do You Get Spare Parts
- brights stay on constantly
- 04 A8L Parking Module upgrade problem
- 06 camera retrofit
- Genuine Audi take-off wheels at great prices!!!
- PLEASE help.. A8 conversion 2005 to 2007 Headlight PROBLEM
- PLEASE help.. A
- Love to merge on coming traffic with my A8
- auto light problem
- Factory Bluetooth Phone Help
- Driver's seat 'automatic' relocation
- 2009 S8 - Help with codes
- For those who actually considered painting their calipers red...
- Sticky: How to program VCDS to have your DRL as foglights.
- trunk lid issue
- Humid air when AC starts
- 07 A8: How do I stop navigation mid route?
- AMI Installed
- headlight bulb
- A8 Transmission vs Q7 Transmission
- Oil leak on my 4.2L
- A/C SETUP MENU ON MMI AFTER UPDATE
- Hooking up foglights as DRL or Parklights
- rear lead light is on
- 04 A8 Bluetooth retrofit
- Newbie here!! Just want to say hello to everybody
- Ashtray swap for a storage tray?
- Key Fob Battery?
- 2007 a8 suspension relay location
- Double o-ring coolant leak
- Vag-Com Info for S8 Please !
- New A8 Owners + IB10AU Acoustic Elegance Review
- Recent Audi A8 A/C fix experience (cheap/maybe DIY if you know about it)
