- 2006 A8 Bose subwoofer problem
- One Year Anniversary... and Still...
- Radiator pressure theory questions
- S8 Gas mileage... what are you guys getting?
- Subwoofer with fridge option
- electronic hand brake will not release
- using an A8 motorized lcd assembly for...
- Has anyone put D4 20" wheels on a D3?
- Anyone here have good knowledge of A6 (05-08)?
- 2008 s8 v10 power steering failure
- Hood latch cable snap, how to route to footwell?
- Hesitation - Fuel pump?
- SUSPENSION PROBLEM
- Card Holder in Dash
- gel like oil filter..????
- solenoid
- solenoidN111
- A8L solenoidN111
- A8L in Dakar mode
- 2003 A8 Boot Lid Problem - Help
- Help Needed...check engine
- help, all 4 windows wont.go.down
- Valve Cover Gasket Replacement
- Wanted: B&O pop-up tweeter, dead or alive
- New VCDS upgrades for 06-10 compared to 04-05
- FLOOD IN MY CAR
- long island independent mechanic
- Recurring O2 sensor on W12
- Rear parking sensor can't be fixed
- Steering wheel tilt
- Fault Code 08342 - What am I missing?
- familiar with the tweeters in the B&O system?
- Rear floor heat
- Check engine light yet again...
- Does anyone remember the S8 coolant capacity off hand?
- Just Finished MMI Gear replacement...
- Power Steering Leak
- Beloved A8 left me stranded, what the problem be?
- Powerflex bushings... what's the squeaking consensus?
- S8 d3 big problem please help me
- Replacing front marker light -07 A8
- navigation problem
- Remap, anyone had one? Is it worth it?
- Drip from underside of gearbox.
- ANOTHER blown tire :(
- Interior cleaning adventure!
- Buying a 2004 or 2006 Audi A8
- Totalled my 04 A8L. Pictures. Airbags saved my life
- Help with seat fault codes
- Odd Transmission Issue
- 2008 fsi model reliability?
- :: ECS Tuning :: Billet Aluminum Oil Filter Housing Cap For 4.2 V8 FSI
- Aftermarket Wiper Blades?
- Illuminated Door Sills Installed
- Updated nose details
- Cost of replacing oil cooler
- Battery Energy Module question...
- Vcds scan on my d3 s8
- Air Suspension Fault
- E-brake Problem
- Secondary Air Pump test
- Hit a snow bank
- Almost back in my hands
- cant identify this tiny piece can the GURUS help pls !
- Questions for Wheel Hub/Bearing/Rotor and Comfort Control Module
- Mmi issues
- replaced hinges today...
- any vag-com users with hex near Metro NY?
- New owner pics, experience and comments 2007 A8L
- engine oil level check light every other day???
- Idler pulley
- Power Steering line leak
- W12 tranny service at 100K; general appearance
- For MarksA8L
- Door Mystery
- OT..a bit...Overspray on Headlight plex
- Brought her home tonite..a few questions including fixes and warranties
- Smallest wheel size that clears S8 / W12 brakes?
- Feeling the winter time blues? Here is a 20% off Promo Code to get better.
- Brake Pad Question
- 2007 Facelift Side Mirrors
- MMI Components
- Hello Great Forum
- Audi 2004 A8L
- Intermittent Climate Control
- wiper motor?
- Heated black steering wheel swap(possible trade from someone on here)
- Another iPod question
- 07 S* audio system
- 06 A8L Newbie Questions
- P1136 & P1138 System too lean (add)
- A8 D3 4.2 V8
- CD vs iPod
- Control Arms or Bushings
- Dealer Could not diagnose
- about to take the plunge
- Pads for my 2007 S8
- Looking at an 03 A8 with trans problems
- 2006 MMI Help....Please
- right side hinge broke in half today...
- Anyone de-chrome their A8/S8, I am going to do mine but would love to see pics first?
- Tech Guru Thing
- Rear suspension feels loose when passing over uneven ground
- Timing Belt Question
- VCDS Not Detecting Modules
- My new D3 Toy Pics!!(Very Rare Color, Must See!!)
- "Low Coolant Temperature" message
- Warranty company is trying to deny my suspension issue, do I have a dog in this fight
- Can You Use Wheel Spacers on the A8?
- Buying a 2004 D3 with blown gearbox
- air suspension reliability
- D3 Transmission won't cooperate! What am I missing?
- BEM (battery energy mgmnt) SW update ?
- Inspection advice on 05 A8
- Clean Up The Tan Leather
- Security switch for extra security
- What I Learned in the Snow Today
- AUDI MECHANIC IN THE SF/Bay Area CA
- driver side front window replacement
- '06 A8 timing belt controversy
- 0 to 60
- a8 miles per gallon
- Few small problems with my 07 A8 with 13k miles....pls help
- S8 Wheel Clearance
- 07 A8 lift mode is grayed out
- all electronics have stopped working
- Lowered front end
- Is this the right size oil filter? Seems a little small
- Q re: VAG COM after battery replacement
- This is my next wheel setup, if they fit?
- Clunk from front wheel well
- Stereo problems on cold morning
- My New Nose
- a8 ... either bluetooth/aux
- TPMS PROGRAMMING?
- P0456 code
- engine belt (s?) '07 A8 4.2
- Blown tire, need to replace all 4?
- WHAT WILL IT LOOK LIKE ? RIM QUESTION
- Problems to look for when buying
- 04 A8 4.2 Starter Problem
- 2009 D3: both front passenger door BO speakers are dead
- OEM Wheels Paint
- multiple bulbs out
- question about VAG COM lowered cars...
- Sound Quality
- First Service Visit..
- know how to turn an image into a DVD?
- A8L Remote Range
- Will XM radio module work in another Audi?
- Emissions Control System light
- My 2004 A8 3.7 D3 Quattro
- D3 V8 Petrol intake manifold flaps
- '07 A8 thermostast replacement
- Rain Wiping Sensors - How good do they work on your D3?
- Faint buzzing noise coming from the rear.
- Auto Light Sensor Defective / Side Mirrors Dimmed / Homelink not working
- window visors
- interior dash lights not working on auto
- Solution shared for frustuting A8 D3 ZF gearbox
- Unexplainble issue with D3 suspension
- Where is this thing? Parking Aid Warning Chime (H15) Open or Short to Ground
- Tail light/ Head light warning error during the day
- Headlight Washer Question
- VCDS Compressor Log
- 2014 LED headlights vs. 2005 halogens
- Roller Rocker Lever O-ring
- License Plate Bulb Problem
- S8 Audi service plan best option
- Will these clear on a 07 S8, 21x10.5 et28 tires are 285-30-21?
- Suspension compressor bypass?
- Old member, new car...
- Thoughts on Vossen CVT's?
- Strut leaks only when it's cold???
- Headlight issue and possible replacement.
- suspension problem. please help
- 2005 A8 MMI Dead
- Bluetooth microphone stopped working - iphone 5s
- Audi Mechanic in Somerset KY?
- Rattle on Acceleration.
- Hate to beat a dead horse but....air suspension issue
- Instrument Cluster Temperature Gauge Wiring Diagram anyone ?
- Misfire cylinder 7
- Advice for changing brake pads on A8 4.0l Diesel D3
- Heater problem and its COLD here...
- Rare Option?
- no heat drivers floor
- Fixed my typical power trunk woes
- Changing Rear Air Struts?
- Driving and MMI & Dash Die.
- Where I find the Engine code 4.2L BFM 2004
- 1st to 2nd gear thump
- Fender well texture
- Buying D3 A8, need help
- Looking to upgrade
- Can't get xenon igniter to lock on?? Help!!
- actual fuel economy of 4.2FSI and W12 in europe?
- HELP!!! Power steering major leak
- Removing Mirrors and Door Handles
- Big mess after battery replacement
- buzzing and high pitched beeping from speakers
- 2004 A8 water in oil
- Anyone have lead on a used 5.2 v10 engine??
- Help With Loose Steering
- how to glue magnets back in suspension compressor
- Air strut height sensitivity to temp changes
- Trailer light wiring
- Time to Treat Yourself - 15% off and Free Shipping over $50 - Happy New Year!
- Anyone use a scissor lift or 2 post lift at home?
- Headlight warning chime - long delay before sounding
- Cabin air filter?
- HEADLIGHT BULB CHANGE
- 04 Air Suspension Issue ( VCDS Error Codes Galore)!
- Fuel Range Incorrect
- What do you think it's worth?
- Considering a 2007 s8... Any thoughts on this car?
- retrofit 2008y rectangular fog light
- OEM Bluetooth Module For Sale(Good For 04-05 Retrofit)-Make me an offer via PM
- HUGE air leak in suspension system...
- Picture request - A8 with splash guards
- any one tried Philips X-Treme Vision HID
- Thinking about a 75K miles D3 from Texas
- Autozone Front Break Kit
- MERRY CHRISTMAS EVERYONE !
- A8 2004 Airbag light on - repair kit installed, 5K0998582
- 2009 Right Front DRL Replacement Procedure
- Audi A8 2004 Adapter wiring harness for airbag
- 2003 A8 transmission slippnig, rough gearing, faulty TC?
- MMI problem on my 2004 A8
- Fuel rails squeeling??
- P/N for Upper Control arm pinch bolt
- Correct OEM spark plug for 2008 A8L BVJ engine ... NGK 6740?
- Taking a look at an 07 A8 L 82k
- Back seat armrest won't come down!
- Front bushings creaking
- 18x8 35 or 45 offset?
- oil change story
- no heated air from right side vent...
- Gas Octane
- Farewell...
- Big big problem!!!
- Bring wheels back to silver. Hyper silver or medium silver?
- service manual
- audi a8 headlight help
- Battery level meter caught in the act...
- Carbon buildup warranty extension
- NEED HELP! SUSPENSION ISSUE!!
- Cooling problem
- help plz
- Thanks Tag Motorsports
