PDA
View Full Version : A8 / S8 (D3 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 [37] 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
  1. Head Gasket Failure
  2. Remote oil filter kit
  3. A/C Recharge?
  4. 07 S8 aftermarket drl wiring location?
  5. D2 S8 Grill fit a preface lift D3?
  6. New Old 2008 A8L 33k miles small issues
  7. Well...Finally...I took the buffer/polisher plunge
  8. Microphone and voice assist not working in car I just bought
  9. AC Problem
  10. I need help from some one in Houston...
  11. Rear door speaker grate/cover
  12. Vacuum valve connector
  13. Armrest- how to open up?
  14. where to get universal catalytic converter and exhaust to fit 05 a8L
  15. Bleeding brake system/peddle almost at the floor
  16. Driver seat stuck
  17. MMI Dead
  18. 2000 A6 2.7T Wheels fit on a D3 A8?
  19. 2009 A8L Audi Exclusive - leather care
  20. new member: need help with exhaust and catalytic converter 05 a8
  21. lowered S8
  22. Found a Perfect A2DP Bluetooth Music Solution, NO AMI required!
  23. VCDS scan results...what do they mean
  24. Part number for bumper screws
  25. d3 s8 logo floor mats
  26. Water On My Feet
  27. oil drain plug
  28. V 10 FSI for the newer S8
  29. Bicycle carrier
  30. Detailer's Domain - July 4th Special
  31. If this is legit - it's a steal - A8L lookers!!!
  32. Which VDCS??
  33. Parking brake malfunction light came on last night
  34. Dash board lights
  35. 2009 s8 brake/rotor/caliper service
  36. Rear Headrests
  37. will 2001 19" A6 alloys fit my a8 d3
  38. Changed my Trunk Motor Today
  39. Good Reason To Be Nice To Newcomers...
  40. 04 a8l front upper control arm replace
  41. Rear PDC Harness
  42. MMI Navigation Upgrade
  43. wireing help from engine bay to interior
  44. OK.... what's the trick here.... upper control arm bushings
  45. Daytime Running Light
  46. VCDS Camshaft Positioner error
  47. First Audi A8L 2007, 68k mi!
  48. OnStar Switches
  49. any member live in Houston ?
  50. Need to replace CD Changer needing help...
  51. Anyone with VCDS / VAGCOM in DC/Northern Virginia?
  52. Latest newest MMI software update part number?
  53. Removing Front Grill
  54. Wiper Blades - Squeaky Noise
  55. Some VCDS foults
  56. Light smoking from rear of the engine
  57. 2004 A8 LED Tail Light
  58. HVAC Performance
  59. Part Number for Interior Light Bulb Socket?
  60. How I Did My Front Brakes On A8L Sport
  61. Le Mans
  62. Aux power
  63. Check engine light (car pulsates)
  64. Headlight Assembly Question
  65. Anyone want to buy a used S8?
  66. 5.2 ignition puller
  67. digi tv
  68. Air Suspension Compressor Autopsy (WARNING GRAPHIC CONTENT)
  69. VCDS FAULT, 3 engine faults + motor mount
  70. Where else can we tap to the driver turn signal
  71. I fixed those vanity mirrors. YES!
  72. fuel lid removal
  73. The rotor stuck doesn't want to come out???
  74. New brakes S8
  75. Hardwired the V1 into my S8 today
  76. Rear side airbag faults and solution
  77. MMI Screen Repair Instructions
  78. Battery Draining
  79. 2004 a8l over heating
  80. Park with RVC Only
  81. Suspension or battey issue?
  82. O2 sensor
  83. Still have the lift mode and loving it...
  84. COOLING SYSTEM CAP PROBLEM???
  85. W12 Production Numbers
  86. Moving to another forum....
  87. Electrical Problems!!
  88. suspension heights
  89. Fog Lens Cover???
  90. Oil Filter Cap
  91. Both rear vanity mirrors broken
  92. Controls on the roof melting?
  93. GB: Metal Skid Plate Audi A8
  94. Air Compressor filter
  95. will 9 " wide wheels with a 41 offset ...
  96. Looks like I'm done with Blau Parts
  97. Bridgestone Potenza RE970AS Pole Position
  98. Fault Code for Level Control System
  99. full car wrap opinions :)
  100. steering wheel compatibility question...
  101. MMI Screen Gears for 2006 Audi A8
  102. Sunroof randomly wont close fully
  103. D3 A8L ...Time for new brakes
  104. Certified Pre Owned question
  105. Another air suspension question
  106. air suspension lowers overnight.
  107. Where to put the jack pad? Lift points? Jacking?
  108. Hitch installation - power latch motor (Part 3)
  109. VENTSSSSSSSS
  110. Which d3 ?
  111. Brake lamp switch: "switch may only be installed once" Argh!
  112. 2006 vs 2007
  113. Suspension Leak, compressor relay, compressor fuses
  114. TPMS Sensor Replacements
  115. Timing Belt Loose after cranking engine w/ Cam sensors unplugged
  116. Black Headliner?
  117. Dynamic Air Suspension
  118. A8 Options- NEED OPINIONS- A8
  119. The Beast in Action
  120. Audio Fault Codes
  121. Audi Prepurchase inspection ? Or VagCom ? Or Both ?
  122. Hitch installation – VCD coding questions (Part 2)
  123. Hitch installation – my experience (Part 1)
  124. Curb got my bumper :(
  125. Antenna and AUX question
  126. Biggest rim I can fit ? 04d3 a8
  127. Chance to buy an 04 D3 w/ 124 k miles. Need advice...
  128. will 9J x 19 ET 41 wheels fit a D3 ?
  129. will an update turn off my vim
  130. 2007 A8 running light bulb
  131. LED DRL which picture looks best - or NONE - input please
  132. Abs Esp & Parking Brake Light
  133. Remove or Replace Trunk Lid Motor
  134. 2004 A8 audio patch cable
  135. best method to change power steering fluid?
  136. '04 A8 Sunroof question
  137. 2007 S8 Horn Problem
  138. Bubbling on the valve covers?
  139. Would Any of You Buy This?
  140. Schematic of Air Ride Setup?
  141. 2004 Audi A8 Owner Manual
  142. UK MMI Update Disc Anyone?
  143. Wheel locks / locking lug nuts
  144. Oil Filler and Expansion Tank Caps
  145. Extended warranty
  146. Yay got my username fixed thanks to Kris H
  147. Extended Warranty CarChex Mepco
  148. Tire Changes for the D3 A8 - 4 tires at a time absolutely necessary?
  149. Question for W12 owners
  150. vag com
  151. Battery Issues
  152. Summer, the lake..the boat...and the D3
  153. chrome trim removal
  154. Can't wait to install brake pads on my A8L
  155. Turbo repair kits
  156. 60 K service items to check/replace -nonaudi service
  157. S8 5.2 Spark plug removal
  158. APR Trial Tune
  159. 2006 key fob replacement question
  160. d3 4.2 v8 coil packs
  161. Power steering fluid service on D3 A8 W12 and S8--basics and deeper maintenance
  162. Air filter service on D3 A8 W12 and S8; basics, special tips & pictures
  163. audi extended warranty
  164. 2005 A8 wheels, identifying them
  165. 2006 A8 bluetooth / MMI question
  166. dtv
  167. not your usual AC problem
  168. driver's window wont' go up...
  169. Coincidence? Or Is Mishar THE MOST INTERESTING GUY IN THE WORLD?
  170. Rear brakes...any Vagcom workaround?
  171. Voice Command Issue
  172. Warning light bulb light
  173. Insane Audi A8 driver trashes his own car
  174. D3 Pic from Southern Worthersee 2013
  175. 2007 S8 AMI with micro SD (Android)
  176. Adding AMI to 06 A8
  177. Buying an out of state D3
  178. In search of: post facelift D3 center grill
  179. new to forum
  180. Memorial Day Special at Detailer's Domain Starts Now - Stock up!
  181. LEDs Retrofit on 06 A8L
  182. Loss Of Power and Blinking Yellow Light
  183. car not locking on one side
  184. Cam Shaft Sensor Replacement
  185. Planning on purchasing a 2005 A8L need some advice.
  186. Cylinder misfire
  187. RADIO PROBLEMS!!
  188. 2006 A8 D3 Sport For Sale
  189. Trunk unlocks, opens an inch, then closes and relocks
  190. Rain Sensor Gel Pack replacement DIY w/ pics
  191. What's up with TPMS? I'm totally blind - hopeless!!!
  192. AUDI A8L 2006 OIL LEAKAGE
  193. CNG conversions
  194. Wheres Waldo: Finding Rear Wheel Housing Trim
  195. Valve Cover gasket replacement
  196. 17" wheels barely fit the A8L Sport Front
  197. rear passenger window shades
  198. S8 brake upgrade?
  199. New 2007 S8 owner signing in
  200. 2004 with unusual bumper photos
  201. New Wheels :)
  202. First hand wash - Just Towels, Warm Water and Soft Brushes-
  203. Leaking moonroof
  204. Timing belt & Serpentine Belt
  205. Suspension Adaptation- Big Issues
  206. A/C Blows cold and warm
  207. Arnotts or Rebuild Master Tech Suspension Recon?
  208. Another TPMS issue...how to enable?
  209. TPMS Malfunction Puzzle
  210. Custom Exhaust: Help Please
  211. MMI Menus 2004 A8L W12
  212. Close call?
  213. Thoughts on Tesla Model S
  214. New Tires
  215. Edmunds or Kelly Blue book ? Whats Black Book ?
  216. Extended Warranty
  217. V10 Power Steering Pump question...
  218. 2007 MMI Question
  219. What I've done with my 06 A8L since I didn't get the 07+
  220. My car is a bird's toilet
  221. TrueDelta.com needs 1 more 2007 D3 Owner!
  222. My 2005 A8L HVAC Blower replacement
  223. Stock up on detailing gear before Memorial Day @ DetailersDomain.com
  224. Thinking of buying a 2004 A8
  225. Audi A8L 4.2FSI Normal Noise?
  226. 130,000 mile service
  227. Looking at getting D3 A8
  228. Leaking washer fluid in A8 4.2
  229. VARTA 4E0 915 105 A
  230. Rear door window shades
  231. W12 UK Production Numbers
  232. I know it's not a A8
  233. Coolant bottle overflow line issue (2006 W12); anyone else seen this?
  234. which transmission?
  235. Need to be walked through a wheel/tire purchase
  236. What is This?
  237. Service Independent in Philadelphia Area
  238. D3 A8 Fuel Filter Service Notes (2006 W12)
  239. D3 A8 Rear Differential Fluid Service Notes (2006 W12)
  240. Headlight washer bleeding out, where do I start?
  241. A8 4.2 Cranking but no starting
  242. Got VCDS - Lowering Issues.
  243. Tire Change
  244. NJ-NY Audi A8/S8 Meet.
  245. iphone 4 not connecting
  246. Parking Aid Sensors
  247. Anyone done upper control arms?
  248. What service manual is this?
  249. what to look for in the battery chargers
  250. Best tire size for 18" wheels
