- High Beam: Bi-Xenon Only to Bi-Xenon with Halogen High Beam
- World's first W_2
- Great video for the enthusiast..
- Whose Sig is it that says "Call Me for All Your Shipping Needs"
- CD Identification...
- ISO Drivers side headlight
- Headlight and dashboard light
- Valve Cover gasket replacement on my D3 S8
- Brake pads light came on-any suggestion on pads
- Air suspension question - changing regular to sport
- Kinda confused about this whole updating thing
- 2008 A8L extended warranty
- Hose To Nowhere in Intake (intake hose noise suppressor / silencer) 077123951A
- A8 D3 4.2 MPI - vacum hose
- Seat Control Module Part # Issue
- Navigation upgrade
- Clutch Positioner Vacuum Valve
- air suspension not lifting no fault code
- 2008 S8 V10 Torque Mount
- AMI not showing up
- Rear door trim
- Updating my MMI in 2005 A8
- The New Audi A8 Doesn't Need to Sell
- Wheel Bearings
- Need advice on summer tires
- MMI not working
- Cross post: A D4 CPO 2015 S8 now in the stable
- module 38 roof electronics fault code 02160
- First time occurence-leveling of rear wheel, driver's side
- Roof Electronics: J519 Module
- HELP! Can't get rear bumper cover off.
- MAF sensor torx size?
- Relationship between ABS module and electronic parking brake?
- Help! 2006 A8 lowered from the front
- Intro/Thanks/STFA/Suspension droop
- Timing Belts - Lifetime Costs
- Air Suspension Problem - Stuck in Dynamic Mode, Lights Flashing, VCDS Over temp code.
- Thinking of buying
- plenum drain
- where the positive pole
- Transmission Failure
- Barometric Pressure Sensor
- 2004 Coolant Leak (cannot locate!)
- Looking to buy S8 grill !
- Navigation unit disassemble
- Raspberry Pi 2 and MMI 2G
- Radio will not turn off....
- MMI Screen auto open/close disable
- New to me '06 List of items repaired/to repair
- Carbon build up
- Forgot How Good Bose Can Sound
- 2 trunk latches in 3 months?
- If anyone is looking, avoid these two.
- Unlocking Nav with VAG-COM
- Sorry to say goodbye but the time has come
- Add another to the new S8 crowd
- Sunroof motor
- New to the group
- Sounds like a diesel! 2007 A8L 4.2 FSI, 199k kms
- Gauge Sweep for D3...
- Fingerprint Start retrofit...
- MMI 0600 to 4160
- Touchless remote unlock...
- MMI Screen won't open
- car failed to start -battery question
- Cleaned the MAF
- Bluetooth no longer Connecting (MMI Update?)
- Snapped some shots of/on the A8
- Navigation memory issue
- MMI Controller
- Welcome screen change
- Ride Valve Block Replacement
- Spring is coming!
- Air Suspension Leaks
- 2005 audi a8 d3 scan results
- Thanks for comments. Battery, trunk latch, headlight update
- "cheapest" 19" tire option for my A8?
- Strange occurrences after dead battery...
- Will D3 A8 Run Without Alarm Horn / Module?
- -30 C (-22 F) Dead battery. Questions.
- 2005 audi a8 d3 upper control arm bushings
- 2005 A8L Turn Signal Problem - HELP
- New S8 Owner here...
- Re Suspension Adaptation and Car's Contents Weight
- 2005 audi a8 d3 steering column
- 2003 A8 running rich
- Off to a new home
- Couple issues on 06 A8l
- Air Suspension Issue
- Coolant Leak juggernaut--I know, I know----HELP_BAD
- 2005 audi a8 d3 parking light to led parking light bulb recomendations.!
- Selling the A8 question.
- Video on the MMI
- 2005 audi a8 d3 brakes
- A8 2004 Electrical fault , runs without cluster?
- Great D3 Find! : pontiac2006 Audi A8 4dr Quatroacura - $2010
- Calling Jake Musser to the courtesy phone please?
- Do '07-'10 years have the 'crack pipe' problem ?
- Where can I get a black honeycomb grille for my 2007 D3 S8?
- Trailer Assist
- can't see in the MMI the graph
- 2004 BOSE Amp Replacemnt
- Newbie With Dumb Question About Dash
- Audi Hold Assist - Is it possible in D3?
- Battery Manager
- Oil Leak on my 2008 S8 V10
- Replace MMI interface?
- Heater fan speed changes on its own...
- How To Fix Dash Board LED indicator panel lights out - 1A Fuse Blown
- How much you lower your A8 only with VCDS?
- D3, nothing works at back seat
- Installing lowering links?
- EPC, ESP FAULT HELP PLEASE !!!
- Upgrading the parking assist module
- "Parking brakel" fault
- Just a Thought
- Intake Flap Issues (Coming Apart) '07, S8
- Tinting My Windows Soon.....
- Considering installing AMI USB cable ~Can some some advice on my software version?
- Did my rear break pads replacement. ~ Feels good !!!
- L\R foot well heater R&R
- Any VAG COM users in Chicago?
- 2007 S8 valve cover gaskets replacing
- Question regarding parking and battery draw
- lifter noise after oil change. Help?
- Horrible sound, but the car is off...
- Audi A8 2009 Problem with Suspension
- Emergency brake question
- ESP & ABS lights, no speedo
- Reset service light on A8 2004?
- New Front Suspension
- Finally ~ adaptive headlight warning(Horizontal) ~
- I think my air suspension compressor has kicked the bucket
- CobraCommander, what kind of wheels on your...
- Audi A8 D3 Fog Lights and HighBeam HID Upgrade
- Supercharger Install
- Audi A8 d3 need help with head gasket!!
- Bluetooth help
- How do you change the rear bulb on a 2007 S8?
- Rear climate control
- Bluetooth Module Location?
- Enable keyless entry while car running
- How Do You Remove The Trunk Lock/Release?
- heater blower fan not working.
- Replaced upper control arms this weekend
- I'd like to replace a few bulbs with LED's
- Off-Roading - Doable or pass?
- Went for a drive to blow out the cobwebs
- Purge valve location, help?
- Sudden Power Steering Loss
- Tiptronic (MANUALY) shift modus in J587 selector lever sensor con is partly defective
- Backup camera
- Find the cleanest, best cheap Audi - Competition.
- Rear Vents Not Functioning
- Still no heat...I need a video of a heater valve unit
- 2 Suspension Fault codes VCDS Any suggestions on the remedy for these
- Front end control arm kits, 2004 A8L
- help with changing transfer case fluid
- Hydraulic Adjusters
- Automatic mirrors close
- Custom TV tuner noise in audio and video
- Remote start questions
- tires question
- Air-conditioning problem
- My doors were frozen shut this morning
- 2005 audi a8 centre console fix
- Please check navigation DVD/Insert navigation DVD
- Power Steering Leak BIG WOES
- Help!! In my endeavor to program "windows up and down)
- License plate light flashes on and off
- Bike Pump Coolant Tester ala Youtube
- Bumper Clips
- Does anyone know what these are?
- MMI screen opens then closes
- Left Tail light Fault
- Low mile D3
- Strange suspension issue, maybe not a leak
- Starter jammed
- compression pump
- I need a used vacuum servo for manifold ...
- Windshield Replacement
- do W12s also have the 'crack pipe' problem ?
- Lord of the Rings - matched set.
- Crashed the Bentley er... A8
- $136 for a set of four...is not bad at all.
- Know of a W12 for sale ?
- FS: Euro bumper molding
- Advice on buying an D3 S8
- 2005 audi a8 d3 fog lights upgrade
- TPMS light shut off
- My mother took my S8 for a spin
- A video of my 05 A8L W12 .
- Bye Audi, hello Toyota!
- VCDS Scan/ Camshaft Position Sensor
- New to Forum
- Carbon Cleaning?
- Tires for 20x10.5" wheels?
- 2006 A8 4.2 - engine compartment positive connection
- Is it wise to replace control arm or just the bushings?
- Anybody want my OEM front winter mats for shippng cost?
- heater and blower not working.
- Loud Air Compressor
- Tired Horses - Quiz
- Happy new year all
- Oil filter housing drain plug? 4.2.
- 2008 S8 OIL LEAK
- headlights are foggy and dirty
- Finally cold outside... weird hot/cold simultaneous from vents.
- Switch engine off and check coolant level... sounds simple, right?!
- Thermostat Replacement on 4.2 w/Timing Chain
- 2007 A8L Suspension Issue
- -6.5 degree ~anyone driving in cold weather right now?
- Old A8L owner !!!!
- TPMS Not Reading with No Errors
- DVD for RSE - region code
- Bang & Olafsen Tweeter wont rise.
- Hood not sitting Flush with fender ~!Passenger side only~~
- Removing Cell Phone Adapter
- Yes, I stupidly pressed bootloader and now I'm in panic mode.
- Wiper Mod - The Kit Fits!
- A little stumped...water pump or thermostat...other?
- can someone please help.
- Thought you were gonna be in an SUV?
- Timing Belt Service
- Air suspension leaking
- 2007 Audi A8L Radio Problem
- Merry Christmas to me!!
- Audi s8 5.2 v10 misfire please help
- Pumping up the air suspension manually???
- Checked Engine Timing
- 06 A8L Headlight brightness not as bright as new cars ~why? !Its not the bulb,
- Anyone know the best route to restore ACC Sensor and the system?
- The Psychology of Dealer Bashing
- Going to have my A8L fully detailed next month! Can't wait ~!
- S8 air suspension clearances?
- Got these codes from Vagcom scan toaday. Replace all the parts?
- What is this hose inside the front passenger side wheel cowl.
- Peeling Valve Covers
- Take a look at this!!!
- Time to say goodbye... :(
- 2006 Audi A8 trunk lock fix!
- ??? What is the "Test" Forum???
- STILL no heat....and winter is on its way !!
- Audi Dealer says I might have to replace the ENTIRE front Suspension System?
- Latest navigation CD
- Copper Paste
- Careful on where you get your oil changed folks. This could be you
- Brake Carrier Bolts
- Only use OEM air filters
- Kid in a Candy Store!! A8L vs A8L??
