- Audi A8L 2005 D3 - Turn Signal / Flasher Problem
- camshaft pos sensor wireing
- loose TB after tb job
- anyone have an MMI control panel with issues ?
- To D3 or D4
- New W12 Owner !
- Tach only works sometimes
- Threshold panel clips
- Lifted the rear suspension D3 A8 too High. Now I can get the rear shocks to come down
- Thinking about picking up an A8
- Finally in an A8
- front rotors
- Belly Pan / under Engine Cover
- S8 Engine sometimes starts sometimes don't
- 2006 wood shifter knob
- Close to 75,000 figured I'd change filters...
- Cup Holder...
- About engine mounts
- HELP WITH AUDI A8 D3 2004 POWER STEERING ADJUSTMENT
- 2005 A8 & 2010 A8 Side mirrors
- Help needed pricing car
- aircon Pressure valve location
- my warped head, continued
- Please welcome M'Autolite; new vendor on AW and receive 20% discount on all items!
- Is what the dealer offering fair?
- Battery Energy Control Module.. any way to test?
- 07 A8 L-Missing electronic device under center armrests(?)
- Newbie with some issues
- Upgrading to W12 seats
- Shaking
- My Audi A8L
- Air suspension rebuild kit
- New to the A8, do I have a FUEL ISSUE OR MAF problem?
- D5 elements starting to come into focus
- Chronic wheel bearing issues?
- 2005 Audi A8L Bluetooth
- Audi Drive Select (ADS)
- Audi D3 2007 Front Parking Light bulb type?
- Oil filter top stuck
- Black Book vs Blue Book for S8?
- searching for vacuum leaks with carb cleaner
- Missing bolt
- Lane change turn signal duration
- Speed warning adjustment
- Power steering hose
- Fuel issue
- A vote of confidence for Arnott Air Suspension
- Rims
- 2g AMI directory structure
- Wish.com VCDS
- Blower motor/ blower resistor issue
- Need Some Opinions Pt.2
- What did I mess up now?
- On Board Owner's Manual
- gas mileage on D3?
- Long coding on VCDS?
- Transmission or engine surge?
- Manuals galore (pdf)
- Turning the key = nothing happens
- Can anyone tell me what this wire does
- S8 CHECK ENGINE OIL DIFFICULT DIPSTICK
- Power Steering Rack issue confirmation
- $2,000 for fuel pumps?
- Battery Warning Light
- Anyone with problems with windows roll down / mirror position?
- Updated MMI Software and lost use of speakers!
- Lost my only key, what are my options?
- Some Pictures of the 05 A8L
- Strange happenings in the world of Keyless-go
- Modules Installed 2004 Audi A8L 4.2L
- New rear door bought Do I have to replace the Handles
- How rare is the A8 D3 sports SWB W12?
- A8 D3 PCV part number???
- No lift mode, no power steering, no speedometer, Uhhhhhh what?
- spray water into air intake beyond MAF experiment
- Air suspension compressor didn't stop.
- no coolant drain plug on 04 A8L. another
- What do you guys think ? A8
- Stuck midway through job, can't get steering column off
- Replace my Hood Shocks
- Clutch Slipping?
- Shady Dealers
- Fun things to do with Vag-Com!
- AMI bridge cables
- Can't seem to justify $60k more to upgrade to a TDI
- Soft close - Driver's door
- AllData or Bently?
- MMI/RADIO NOT WORKING PLZ HELP
- Amazing S8....Crazy Price:(
- D3 Still Turns Heads?
- 2007 D2 S8 with 83K. To Buy or not to Buy?
- 2006 A8L ENGINE WONT SHUT OFF !!! HELP
- Does anyone know if the spoiler on the D4 S8 will fit our D3 S8?
- air conditioner cutting on and off
- Roof Console Removal?
- Letting the engine roar...
- Full throttle to "clean" or "stretch legs"
- Washer fluid leak...
- 2009 A8 Window Motor Issue
- New car Christmas!
- At least 4 S8s of all vintages in Amtrak garage today
- Need Help Verifying Issues
- 2005 Air Bag Module Location
- Looking for D3 Taillights
- 2006 A8 - Adaptive Headlights
- Just noticed my Air Con settings in MMI are reversed!
- Cluster A8 D3 dead
- 2010 A8L info on a part number
- First commute in the A8L, a couple of observations
- 04 A8L taillight problems
- VCDS PURCHASE
- Steering Wheel Replacement?
- New D3 A8L Owner
- MMI Screen Problem
- How usefull is Carista
- Carista
- Help from a Bentley owner
- ACC Light Defective?
- Audi oil cooler deal between cooler housing and block...
- 2003 A8L electrical problems
- Ready to change my upper control arms
- 2005 Northern Blue/Amaretto suspension
- S8 TRANSMISSION SERVICE ( ATF + FILTER ) DONE IT!!!!
- Seat Control Module Coding
- 2005 A8 brake pads
- 2005 A8 low oil light.
- Air compressor removal
- newbie in need of help
- Did an ATF change...results not as expected.
- Modifying ride height, by shortening ride height potentiometer arms
- 3D Printed vacuum pod arms
- Timing belts - the truth
- Xenon HID (D2S)
- Pulling the trigger, Freaking OUT!
- A8 Factory Options
- My 105k Miles Service
- Must be the pump!
- Fixing the horribly-flat lumbar support in S8 seats
- Timing belt marks on cams and crank pulley
- NEW S8 OWNER!
- Audi A8 D3 - Transmission Fluid (ATF) - the truth
- AC not very cold
- AC leak problem
- ABS wheel sensor problem
- Simple hood (bonnet) maintenance
- Haven't seen this Exlusive interior before
- hood wont release
- WABCO Compressor: Electric Motor Servicing
- Upper control arm change S8
- 2004 A8 That sure nose dived in a hurry.....
- Scan results from today
- Question about 07 to 09 S8 shift knob/ handle
- In need of some opinions
- disconnect battery overnight--now variant rpm...
- Added softclose door on my Audi A8 2003
- 2003 Audi S8 Rebuilt Motor
- Oil Filter change today
- Which wheel is which in VCDS
- Heater/AC Blower - Intermittent Failure
- armrest latch source
- any one have a Northern Blue/Amaretto A8 ?
- SHOCK ABSORBERS DURABILITY ( A8 AND S8 )
- Cup holder in center console.
- Anyone know this part # from fuel pump?
- Water Pump / Timing Belt / Thermostat Replacement
- What steering wheel is this
- B&O tweeters stuck down, but...
- Exhaust stud removal to clear coolant pipe to remove oil cooler please help
- Tire Pressure Display on MMI
- Safe Mode
- Looking for an S8 could use some advice
- Iswear I'm researching plug gap... Audi Auto Espresso Machine?!
- :: ECS Tuning :: D3 A8 4.2L ECS Oil Service Kits
- Light
- Procedure for releasing fuel pressure?
- i thought the ATF was lifetime
- Update A8 timing belt....not
- Gearheads to Automakers - Knock it off!
- 09 4.2 large EVAP leak 0455
- 2004 A8 Trunk Hinge Replacement - DIY?
- my warped head
- Hopeful but nervous soon-to-be A8 owner
- which MY did A8s get the upgraded rear diff ?
- Headlight bulb - conflicting info. Help please
- S8 OWNERS, TRANSMISSION SERVICE ?
- Hello
- will cam chain 4.2 engines last to 200K+ miles ?
- Help troublshooting lean condition
- Timing belt fail after preventative work.
- Help Issues with 2006 D3/A8 Tail Lights
- DAB Slideshow
- useless card holder
- Question for D3 Group
- Secondary Air Injection Help Please
- Help with Engine Control Module(01) MBV for Group 058
- Changing TPMS sensors
- Passenger Side Parking Brake Motor Failure
- hearing the woosh again
- Tranny Oil Change
- Audi A8 06 Transmission oil change
- 2007 S8 new front struts amber light sometimes on
- 2007 Audi A8L Rear Caliper Piston Seal Repair
- Testing my MAF sensor on 2004 Audi A8 4.2L
- Extreme radio noise
- MMI will not start
- All dash lights on
- My new 2007 S8!
- Why Folks??!!
- Dreaded engine light...
- Time needed for sun roof swap ?
- ESP warning lights on, but already install new Brake Light Switch ?
- Spring is finally in New England
- Access/Start antena
- Play Music With iPhones and Android Phones Wirelessly
- I'm selling my S8 if anyone knows of anyone loooking?
- Phone Bluetooth????
- SiriusXM
- Relay switch for suspension
- ACC Problem
- Suspension at Proper Level?
- Tires
- Some Fresh detailed pictures of the A8
- Does anyone have a set of spacers/lugs they're looking to part with?
- why would one rear corner always ride in "lift" mode
- A/C compressor won't turn on----weather about to be hot
- Hello from Spain
- Arnott Warranty Issue - Anyone else?
- Rather than replace lenses, lightly tint tail lights?
- Parking brake error - 02439 - solution found (not new)
- Heated Windshield Control Module (J505)
- Yes! MP is Back!
- Crackhead stole my fog grills. Where to buy used?
- Opinions on summer tires
- Maintenance schedules by AW tech gurus polls
- A Great Deal.....or not..
- Engine light- P0087- AT WITS END- Help!
- Unbelievable Audi Service-blown away
- Quick Help Please. Compressor!!
- check engine light - my experience
- 2004 A8 power steering pump replacement
- Trunk Easy Open
- Audi SMEs...want to buy a used A8
- Looking to buy a 07 or 06. Need advice. .
- Silly question. Is it an A8 or A8L?
- Pair iPhone 6 to 2006 A8L D3
- 2008 vs 2009 prices?
- Rear Tail Light Wiring Diagrams
- Audi A8 D3 air suspension bags release air
- rear caliper - parking brake problem
- Help with front differential drain plug
