- Coolant Overflow Hose
- Different tires front and rear ?
- 2007 A8L CD Player DEAD, want to integrate ipod
- engine surge
- Painted (plasti dip) my grille
- Possibly Joining the A8 Group
- HELP ASAP PLEASE
- 1st oil change in a 2006
- "Good bye" - but not gone...
- just had all engine seals and piston ring replaced. why blue smoke???
- audi safety... astonished..
- Identify sound..
- This looks like a good one
- A8 D3 Adding additional key
- ANYONE INTERESTED IN ALUMINUM BELLY PANS
- Low speed "wobble"
- Is this what the vacuum pods on a 4.2 are meant to look like?
- So my 2006 owners manual says....
- VAG will not clear out codes
- Oil Leak. Front of FSI motor
- 2007 S8 Exhaust Leak
- Need VAGCOM read Nashville, TN
- LIQUI MOLY
- 2008 -> 2015 Seat Upgrade?
- :: ECS Tuning :: D3 A8 ECS Exact-Fit Brake Lines
- Proud owner of 2005 A8 coupld questions
- Your Reccomdenations Please
- Extended Leather Option?
- My studded snow tires after a season of no snow
- Any help with some defects appreciated!
- Intake Changeover Valve
- 4.2 BFM Start problem
- Coding VCDS
- soft close door not working,any thoughts?
- D3 chrome exhaust tip cover
- mmi updating issues....
- Parking Brake DTC
- Part number for audi rings that are in the engine compartment
- Carista: VAG-specific diagnostics and coding through a smartphone app
- Binghamton /Oneonta NY Area Help?
- Right tail light is acting strange (not bulb) 00985 & 02200
- Arnott Introduces New Front Air Struts for '02-'09 A8 (D3) with Sport Suspension
- Audi of America Honors 91 Dealers with 2014 Magna Society Awards
- Help with Level Control Module
- Sunroof maintenance
- Low oil presure light on, help needed
- AW technical issue/change that has sidelined me, maybe for good.
- Rear climate control removal pics
- Does this sound like fueling or MAF?
- NZ Japanese import mmi newby question ?
- A Check List For A8 D3 Buyer Before Taking Delivery
- NEED HELPP MY D3 won't start!
- Trunk won't open, fuel lid won't open
- *Spied* Stretched A4 to A8 Sized Retrofit spotted
- How to replace front door window
- Russian Traffic Hell
- 4.2 246kw Problem
- polishing an old gem
- Guess who drives a D3 w/ "UNIVRSE" plate...
- garage sale?
- Right hand S8 bumper grille?
- 07 A8L
- trunk pass thru
- ESP/ABS & Parking brake malfunction
- Idle pulley whining noise?
- Do you know what this wire is?
- Removing seat switches
- Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - March, Monday 25th - Sunday 29th
- Starter about to die? or just more technogremlins?
- :: ECS Tuning :: D3 A8 Alzor Style 020 Wheels
- Transmission issue
- 2006 A8L lower grill
- Telephone microphone not working A8L
- Failed exterior door lock - driver door
- Mirrors stuck on 'Dim'.
- Upper/lower radiator hose Oring Pt #
- Audi S8 d3 2007 Need help with error messages
- Tips on Audi S8 2007 Fault codes.
- They tried to steal my A8...
- S8 bumper conversion
- 05 A8L Air Conditioner Stopped Working Help!!
- Got a CEL related to low pressure fuel system, now what?
- Xenon(mono) to Bi-Xenon retrofit
- Probably a dumb question, but rear view mirror...
- Tire Size Question
- Brake Pads light came on...what brand to replace pads with?
- 07 A8L Water Leak Under the Dashboard
- Bought myself a USB stick for the AMI....
- Error for secondary air system
- My 2008 S8 with MTM Exhaust
- looking a possible purchase 2005 A8L
- how many seconds does it take your car...
- NEEDLE SWEEP-old topic new visual confirmation on D3 S8
- What a year! (breaking things)
- Coolant needs a top off
- Cylinder 1 misfire - stupid question
- No pickup under full accelertion / other codes
- ABS control module defective?
- Clogged sunroof drains totaled my car!
- Suspension compressor (loud screeching)
- Front Brake Pads
- All Weather Floor Mat Recommendation
- 05 A8 Headlight Bulb Replacement
- 2004 Audi A8L MMI Control panel is unresponsive and lights never come on
- Best sparkplugs for the 4.2FSI engine
- Car shipping Question
- Nav unit pinout?
- How do I open an Alarm Siren
- Air Strut - Arnott now offers NEW item for Sport
- Low life (in a VW) electronically breaks into an Audi
- Craiglist Engine and trans
- Pesky Low Coolant indicator
- now a fuel pump problem...
- Tires
- My car must like cooler weather.
- A8 wont start everything is dead
- Strange Beeping Noise
- Swap Front Bumpers
- Sound of an idling engine.
- Sunday drive pic...
- My new Key fob cheap !
- Wanted: Front Bumper assembly
- Anyone in the Chicago area with a VAG-COM?
- Anyone replace the O2 sensor with a universal from Bosch?
- Can you code out the "Passanger airbag off" warning light?
- BATTERY REPLACEMENT (HELP)
- Starting issue / Level Control Issues
- Battery drain problem
- GoPro snow patrol 2008 Audi A8l
- Audi 3.0TDI intake manifold replacement
- My 2004 A8L 4.2 died after a normal journey
- Converting Japanese MMI + Radio + Nav to ROW?
- W12 Advice Please
- Are the PSIs displayed by your TPMS accurate ?
- Easiest way to disable/deactivate OnStar
- 2004 A8L Rear Wheel Bearing Mismatch
- Time to jump ship, or at least move to another part of it
- A8 d3 power boot retro fit
- What is natural oil burn rate
- Huge Puddle of oil - Drivers side front of engine
- Decent site for used D3 parts
- Front end shimmey felt in steering wheel
- D3 Ceramic Brakes on eBay - $6500.00
- Address 61: Battery error codes
- Wheel identification question
- time for my heat problem thread...
- How to wash the Engine bay.
- Lost TPM, for a while
- Cabin Heating "fading"
- Broken A8 Air Suspension Compressor
- My '09 A8 L
- Air Suspension Issue
- Idea's for a power lock switch on a 2004 A8
- New problem with A8 - Power Steering
- Sad week, totaled my A8 and A6 avant
- Any experience replacing rear shocks - one man job? Amount of labour?
- 07 headlamps
- Local help? (Massachusetts) Tire
- Rebuilt *rear* suspension? And compressor rebuilt kit...
- :: ECS Tuning :: D3 A8 4.2L ECS Ultimate Plus Timing Belt Kit
- CEL P2195/P2197: Oxygen (Lambda) Sensor B1 S1 (& B2 S1): Signal too Low (Lean)
- How close are the D3's to Phaetons related?
- Another new S8 owner checking in
- Hi all :)
- Truck & Gas button not working
- Replaced thermostat - lessons learned
- Audi A8 D3 one is lower than the other suspension issues
- Coolant flush procedure?
- A8 -05 ABS-error codes 00287 and 00290
- My Amazing 06 A8L... Pass Smog at 101k miles
- WTB - Front plate filler
- Anyone have the part numbers for our hood supports?
- And for its next trick, the fuel is never full...
- D2 guy thinking about 2004 A8
- Want to retrofit W12 D3 rear camera and Headrest tvs
- Things I've Done With My Audis Over The Years... AudiWorld...
- Sirius Error - 16344 - RAM Error
- Thigh support not working
- Homelink woes
- Couple of questions regarding gauges
- Brake line quick disconnect - any experience?
- 2006 Audi A8L D3 Front Suspension Dropping WEIRD!!!
- 2007 D3 - A8L a reasonable high mileage car?
- Cell phone won't charge
- Two Passenger Rear Seating
- Please Suggest Easy & Safe Way to Crank Without Starting?
- The fun never ends... passenger floor is sopping wet
- 2005 A8 MMI water damage or nah?
- Oil on spark plugs
- D3 S8 versus W12.....what makes us prefer one over the other???
- Cannot see pics in many posts - help
- What hose is this?
- Something wrong with the D4 Forum?
- 2006 A8 W12 fotd for sale
- Winter mode, gave up on all seasons
- Transmission hoot - not the TSB issue
- 2005 4.2 noise in steering area (not control arms); ideas?
- 08 Audi S8 Upgrades / Discussion
- Help i.d. connectors in front of left fender just above belly pan fasteners
- HVAC noise during acceleration
- All season tire question
- Is Audi's D3 A8 4.2 Motor A Modern Day Best?
- Check engine light is on again
- No start after Blower Motor and Resistor Change
- Airbox intake hose
- Belly Pan
- Blacking out the chrome on a 2008 Daytona Gray S8
- Got a new toy
- Great Indy shop in the Chicago area?
- Warning flags on OEMPlus, KufatecUSA and Eurohitches.com
- NAV CD got eaten... WTF
- S8 brake caliper cover redo process
- S8 Die Cast/Resin scale model?
- :: ECS Tuning :: D3 A8 4.2L ECS Oil Service Kits
- 20x10" rims on 2010 A8L
- Front knuckle/spindle
- Air Suspension for my 2004 Audi A8
- audi w12 transmission
- New to Audi, and would appreciate your opinion
- Tires size for Audi A8l 2009
- W12 owners, tell me why I shouldn't upgrade to this one!
- TPMS brands (aftermarket) that transmit temp info
- My 07 S8 with the V10 removed (fixing oil leak)
- :: ECS Tuning :: D3 A8 4.2L Ziza LED Interior Lighting Kits
- MMI Problem
- 2007 Audi A8 Shaking!
- audi s8 d3 for sale
- Who's got the best prices for lower control arms for our S8's?
- Snowpalooza in New England
- MMI screen is cranking when it is going up and down
- Antenna; Passenger Side (R135)
- G291 Level Control Pressure Sensor Fault
- Serious run problems with the 4.2
- Why I can't eable the hidden menu on my MMI ?
- 06 A8 Gauge Cluster Questions
- D3 SWB correct rear legroom?
- Finally flushed the brakes
- SDS retrofit issues
- rubber floor mat sliding.
- Odd electrical gremlins - Backup camera, MMI, Bluetooth mic, more
- First trip in the snow with my S8
- 2004 Audi A8 EPC light comes on once in a while
- Re: '09 A8 L
- A8 Air strut leaking...or not?
- Newer Style Key Fob
- A8 2006 advanced key doesn't always work
- A8 air suspension issues
- car wont start, starter wont even crank!
- Power Steering leak (Coolant leak connection?)
