- Fault codes
- Changing Alternator
- facelift W12 partout
- 2004 a8l mmi no sound playing
- A8 BFM 4.2 Valve Cover Gasket Help
- 06 W12 serpentine belt-what else to replace
- sunroof headliner slide rails
- A "Top Gear" Classic, Recently Re-Uploaded!
- Rearranging My Trunk Emblems to Fool Cops...
- Moving on to a D5
- VCDS log - keyless and circulation pump problems
- Air suspension problem
- Keyless entry application
- Time to call it?
- Wire loom help rear seat.
- 40v 4.2 intake manifold removal manual
- Bouncy car + green/yellow arrows on
- MMI console is not working
- Gas leak
- D3 parts...
- D4 W12 w/22k Miles on BaT!
- Coolant leak no idea where it's coming from or where it's going to now
- PL: Problem with electrics
- Audi A8 D3 Fan radiator
- Swapping key assembly from one 05 a8 to another
- Need help
- I need a pre-purchase insp in Oceanside,CA
- Drivers front Airbag Crash sensor
- Oil leak in spark plug holes
- Steering fluid instead of brake fluid
- When i shift out of Park, the Dash still says my car is in park
- Individual electric rear seats ++
- Battery is almost dead
- A8 D3 oil retention valves theory
- Front differential fluid change D3 A8
- Where is the ICRM?
- Rear seat 2004
- removing headlight lens
- Basic Diag wont connect
- 2006 D3 Audi A8L 4.2 litre petrol/gas V8
- W12 for Sale Near Orlando
- Anyone looking for a champagne cooler?
- headlight wiring crumbeling
- Audi A8 D3 L or not
- Rear parking brake
- KESSY
- Disabling the steering lock?
- A8 2006 4.2 MPI Expansion Tank Replacement
- air suspension O ring
- Fuel pump / bad contact/ code P3089 / 12425
- A8 no crank
- S8 Low Fuel Pressure
- Merry Christmas / Happy Holidays to my D3 Friends!
- Is this the end?
- MMI select
- BG: Noise in motor !
- 04 audi d3 4.2L slow crank no start.
- Damaged engine noise, what could it be? 4.2 TDI
- Shout out to the long time posters
- Audi a8 d3 3.0 Yellow light of airsusspension
- Steering Rack
- Dreaded chain rattle - oil check valves? 3.7L V8
- Looking at a 2007 A8 missing keys, coolant leak, maybe mice
- MUTE ICONE appear and music stop 2 seconds
- Dynamic headlight control
- panel under engine
- CZ: Webasto - i dont understand
- 2006 Audi A8 4.2 Mpi transmission limp at start
- Parking Assist question...
- Buying a fossil 2005 A8 W12 and PROJECTING IT
- Quick Front Strut Question
- Banjo connections
- Starter Relay Location
- Coolant Leak - back of engine area
- Go figure. Here's another clue for you all...
- Audi a8 quattro codes. NEED HELP!
- VIN # says "VIN: NOT SUPPORTED" when I do a OBD2 diagnostic test.
- Are the valve cover gaskets on 2006 A8 4.2 MPI Symmetrical?
- 2010 A8L Headrest Monitor Repair/Replacements
- 2006 A8 4.2 Motor/Trans (110K) for Sale
- Replaced rear bearing now a problem
- Audio Bose EQ Tuner Questions
- Changed plugs & check engine lights come on
- Anyone with a good grasp of Kessy system layout ?
- Installed repaired ABS module, new issues
- A8 gremlins! Car menu button/ headlight issues.
- Valve Cover Bolt Access
- 2010 A8 crank, no start
- Water from trunk Hatch
- What's next after your A8?
- Wireless Carplay & Mr 12 Volt
- Facelift tail light set
- S8 Continuously raising and lowering
- The screw that won't come out ... ABS Module
- 2006 Audi A8 Light sensor on the dash is bad help!
- 2009 W12 partout
- 2006 A8 4.2 BVN twin turbo starter motor removal
- Air suspension problem update...
- Battery Charging
- Kessy problem/question...
- 2007 AUDI A8 4.2 FSI Help With Intense VAG readout
- Air suspension/VAGCOM question
- 4.2 BFM fuel pump trouble
- QuickJack
- Relay Assignment
- Anybody got extra V10 Intake Manifold Parts?
- My 2006 Audi A8 Rear Left taillight issue
- 4.0TDi, Hole in head between exhaust port 2 and 3.
- 2004 Audi A8L radiator fans not coming on
- My collection is up for sale
- Constant battery drain
- Mom screen & centre console inoperative
- Transmission mounts thoughts pics
- Oil Temperature Sensor
- B&O Speaker Grill
- brake rotors for sale
- Best Weatherproof Outdoor Car Cover
- Best way to find full interior trim set
- Banding tool Preference
- 2009 D3 ACC Replacement issues
- CZ: Sunroof seal, please help!
- Local A8 owners in West Michigan?
- 06 A8L AFS Headlight Power Plug
- KE: Audi A8L stuck in rainy water not starting
- Audi A8L stuck in rainy water not starting
- driver's door wont open from inside or out...fixed !
- Embossed Aluminum Heat Sheild
- Audi S8 ride height uneven
- Access Manifolds WITHOUT Engine Out
- Annual W12 Owner’s Club Meetup
- Side mirrors snap closed
- MMI sound problem
- Lean Control Limit Exceeded Error
- ACC front sensor.
- D3 Audi S8 Heater Hose Rupture
- 2005 D3 turns over for 2 seconds and stops
- G28 / Crankshaft Position Sensor
- A8 d3 secondary air injection.
- S8/W12 headlights for sale
- broke down and stuck please help
- AUDI A8 2007 3.0 TDi D3 bootloader problem
- Electric steering wheel adjustment issue
- I got into a little accident the other day driving my 2007 A8L
- CZ: OIL DIPSTICK?
- Android Radio Upgrade 2006 A8
- Audi A8 2004 4.2BFL constant engine loud knocking
- Won't rev above 4000 when stopped?
- Want to upgrade your pre-facelift A8 ?
- CZ: Passenger seat wont move
- ABS controller defective
- Window motor
- Audi D3 4.2FSI wont start.
- ...and get ready cause this bills about to get heavy (w12 coolant woes)
- CZ: Middle brake light
- driver's door wont open...what now !!
- Here’s a weird one … adaptive headlight warning light issue
- D3 A8 blown head gasket
- not running .....right at all
- What’s Audi ruckus about? An s8 adventure
- Battery recoding after new battery installed, maybe the final untimate answer
- A8 d3 seats office chair conversion
- ABS module
- Android head unit for Audi A8/ S8 2002-2018
- Transmission /Gear selection
- Back in a D3 W12
- Audi a8 start issue- I need all the help I can get
- Anybody know how to pop the hood when the cable snaps?
- Continental Tire Noise
- Please help D3 A8 hood won't open
- Steering wheel shaking at 30 mph!
- module programmed by audi
- Does anybody know the name for this
- Our D3 is available - located in Connecticut
- Leaking water through the hood release latch and onto driver side floor
- Please help 06 a8l 4.2l rain drains clogged and have noidea where
- 4.2 TDI - ABS, ESP, G85 Errors
- Air suspension again
- Audi A8 D3 Front light left probelm
- Control climate sestup
- Should i tackle restoring a 2005 A8L?
- How much was the wood wheel & shifter on the ‘05 W12?
- Vacuum hose help
- Idle misfire
- Selling my VCDS cable - $150
- Control Module Incorrectly Coded
- ‘07 S8 - Fog Light Grille Replacement 4E0-807-682-AK-01C
- 08' A8 Headlight swap to 08' S8
- Car wont.start
- Intake manifold vacuum actuator
- Secondary Air injection system faults
- Drivers side parking brake error
- D3 A8L W12 - PCVs
- 07 A8 D3 V8 Thermostat URGENT HELP NEEDED
- Replacing headlight bulbs (07 S8 D3)
- Drivetrain out - Pallet jack?
- CZ: Flooded car
- Oil filter housing
- Oil leaks
- What is this I just noticed it's unplugged just bought this 06 a8l quattro 4.2
- Audi a8 d3 4.2 bvj pressure fuel pump
- A/C Only Blows Cold out of One Vent
- Tire pressure
- Battery change on 06 a8l quattro 4.2l v8
- 2006 Audi A8L Starting and Running Issue (Only runs fo a brief period)
- S8 D3 Brake Pad Wear Indicator Always On
- Help finding fog light grill for 07' S8
- Tell me I'm crazy...
- 06 audi a8l quattro d3 oil filter housing
- Air damper height failure
- 2013 A8L 4.0 Power Steering Pump Replacement
- Talk me out of a S8 D3… or into it
- This years AC compressor thread
- CV BOOT
- Brake fluid leak - Rear drivers side. Driveable?
- Need help with "Thumping Vibration" at above 40 mph
- Bose DSP freaking out
- Headlamp bulb replacement
- RO: Hello guys! 08 3.0 diesel shortwheel base gave me some trouble.
- Strut Type Compatability
- Audi A8 D3 shifter light problem
- 12.3"Blu-Ray TouchScreen Android 13 Car Radio
- how to exit the 'Green Menu' ?
- Audi D3 Body panels
- CV boot
- New s8 owner, help needed.
- S8 intake flap delete - What tunes are available?
- a8 4.2tdi 2008 want start engine
- Weird Noise?
- Air Bag Light
- What is this part -S8 5.2 V10
- 07 A8 D3 coolant leak 4.2
- Passenger side airbag
- Timing chain tensioner pad fragments
- Do all 4.2s have the same bell housing pattern?
- D3 S8 5.2l V10 Secondary Air Injection Pump
- Rough Idle and Low Fuel Pressure Issue
- A8 D2 TCU plug type/name?
- 2004 a8 rattle on startup
- P1534 - 001 - short to plus - MIL ON (N208)
- 07 A8 D3 Oil Control Valve Testing Ohms?
- 2009 S8
- Sound Cutting Out When Engine is Running
- High pressure fuel pump
- Adaptive Air Suspension
- Transmission service cost
- D3 headlight replacement -
- Audi A8 D3 ACC Retrofit
- Tapping deep within my dash
