PDA
View Full Version : A8 / S8 (D3 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 [46] 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
  1. Mirror auto dimming not working? Want auto dimming with interior lights? Read this:
  2. Battery drain question
  3. help in Salt Lake
  4. Rear seat massage show in 2008 A8L owner's manual?!?
  5. UV insulated glass standard in W12's?
  6. Mr Bally
  7. Moonroof not closing all the way...
  8. Help choose my next car
  9. Anyone using an oil extractor device
  10. 2 Part Qestion!
  11. options for the 05 and 06
  12. Compare These Years
  13. Random oddiities...
  14. Massager failing
  15. Cost of 35K mile service
  16. rotors brake help
  17. Anyone has that part
  18. Totaled 05 A8L, Looking for 2009 A8L Options List
  19. Does AudioPilot just suck in general?
  20. A8 D3 Battery issue
  21. How smooth should winter tires be in comparison to all season on highways
  22. opinions about www.lltek.com
  23. RIMS AND TIRES
  24. When to replace brakes? Squeel sound or light on dash?
  25. mmi replacement
  26. 75k service
  27. New Wheels, Tire Recommendations?
  28. Sales #s - SWB vs LWB - 2009-10
  29. 2004 A8 wheel offset
  30. NEW THREAD A8 And S8's -- comparisons
  31. Didnt know we had motion sensors or some sort in the A8
  32. A8 or A8L hunt (long)
  33. Anyone drive an XJ8/ XJR?
  34. Will VIN show SWB vs LWB
  35. DVD read error in Nav
  36. In the market for a '08 S8
  37. "SAFE" displayed in place of trip mileage
  38. What is a good S8 replacement?
  39. TGIF Poll..How much is my car worth? I have found
  40. 2005 A8 D3 front Euro tag
  41. XM Radio module part number
  42. S8 Horns, Mounts, Pads this month
  43. Air bag light reset procedure (anyone try this?)
  44. Leak diagnosis (power steering pump, I think)...
  45. Sliming Your A8
  46. Bluetooth
  47. White noise inside cabin
  48. Intermittent fresh air blower 04 A8L
  49. Should I go for it?
  50. Wiring changes : 08 LED tailight in 07 car
  51. Brake Pad Warning Light Reset
  52. Navigation update issue.
  53. facelift
  54. tried substituting H9 bulbs in foglights ?
  55. Reupholstering - has anyone done it?
  56. How do you remove the ignition coils?
  57. anyone with SW version 4610 ?
  58. A8 with electical problem. need help!!
  59. DRL Lights Stay On When Car Off
  60. NO sound through speakers
  61. Windshield washer tank question
  62. Changed OEM HID D2S bulb to 6000k Now I get Flickering
  63. A8 D3 2003 4.2 coldstart with blue smoke
  64. Best looking rims for a 2003-05 A8??
  65. How accurate is edmunds TMV?
  66. link to write up for TPMS battery replacement
  67. 2004 Bose stereo noise
  68. Led Mirror retrofit
  69. Anyone changed there steering wheel ? D3 08
  70. 75K service covered ?!
  71. Does anyone have the specs for these wheels?
  72. Bad AMI?
  73. battery positive wire corrosion
  74. Vag com question
  75. Suspension Replacement
  76. Air Filter Q?
  77. LED DRL's from A6 on A8
  78. Mister Bally and Brozee. How is your timing belts holding up?
  79. 2008 A8L Suspension
  80. Need license plate filler for 05
  81. Spacers
  82. Bose Stereo amp source?
  83. Engine removal procedure??
  84. Audi A8 Auto Lease Programs - February 2011
  85. D3 to D4...
  86. 2005 A8 air suspension warning light
  87. How many miles are you getting from your tires?
  88. ok, its tire time.
  89. FS: facelift A8 license plate filler
  90. Audi A8 air suspension problem
  91. MMI diplay gears....
  92. "Easy Care" vs CPO
  93. Great Forum
  94. Question about high beams..
  95. TPMS sensor part numbers/where to buy?
  96. Audi A8
  97. a8l s-line is amazing
  98. Splash guards install
  99. New 2006 Audi A8 Owner :) Pics
  100. Different Center Display
  101. Just purchased 05 A8L, what do I need?
  102. Blue Fluid Leaking
  103. Parking brake motor
  104. OT: I bought a 2002!
  105. O2 Sensor in 2009 S8
  106. Bose in A6 vs A8
  107. 2009 vs 2010 A8
  108. AUDI & NOKIA Phonebook integration, Resolved!
  109. Oil Leak
  110. Bought the AMI bluetooth kit, a question
  111. Question about rear climate control
  112. Auto Locking
  113. And so it begins ... (time for maintenance)
  114. Winter wheel/tire/TPMS set for sale
  115. Changing Transmission Oil?
  116. 2004 A8L 75,000 mile service
  117. Remote Starter and LED DRL - '08 A8 Newbie
  118. Rear view visibility tip for D3's with 4 seat/power rear seat config.
  119. key stuck in the ignition switch
  120. A8 SWB 2009
  121. Need help
  122. Auto Check Display: New one for me.
  123. 05 AUDI A8L LEAKING OIL BETWEEN ENGINE AND TRANSMISSION..HELP!!
  124. TPMS Troubles
  125. Rear Passenger Digital Thermostat Control Upgrade
  126. Fix or trade
  127. Fuel Pump?
  128. 9 degrees outside. Stereo won't work.
  129. License plate light out
  130. TPMS wheel specific when re-finishing wheels???
  131. Fuel lid won't open, help
  132. Help with proper AMI connection and coding
  133. Newly Purchased D3!
  134. I'm seeing persistent faults...
  135. Beat the Winter Blues wtih Detailer's Domain - 20% off.
  136. Driver door soft close
  137. 75,000 tune up
  138. another sad day
  139. 2007 Audi A8L and Streaming BlueTooth
  140. Navigation Update?
  141. I thought I needed new CV joint boots -
  142. Mild Shudder During a Low Speed Turn
  143. Owning an A8: I'm not poor; I'm cheap.
  144. looking to buy pristene set of 'Pie Plates' :
  145. In need of a stock Bluetooth option?
  146. Have to remove power steering reservoir for headlight access.
  147. Vag-Com question
  148. Looking to buy 19" turbine wheels with or without tires.
  149. S8 x pipe options
  150. Vag-com/VCDS lowering failed. Any advice?
  151. My 2006 A8 L-South Florida-Low Miles
  152. anyone know whats needed for soft-close
  153. Window Tint....Brozee
  154. Looking for purchasing advise.
  155. In Need Of Forum's Help!
  156. next step in vagcom evolution
  157. Does 2007 S8 Have TPMS?
  158. Audi A8 Auto Lease Programs - January 2011
  159. Euro Plate for 06
  160. It's A Sad Day!
  161. unimpressive seat
  162. Bluetooth adapter for Audi Music Interface
  163. S8 and increasing gas prices
  164. Check Engine Light after car wash
  165. Convenience Entry Steering Wheel Question
  166. A8 vs. 750i - why go Audi?
  167. Splash guards
  168. Air Ride System Issue!
  169. First-rate Customer Service at Rector Audi
  170. from W12 to RS6...... report.
  171. 25 various faults-car runs great-looking for advice
  172. Windshields Wipers Stop Functioning?
  173. for members with a Euro spec A8...
  174. snowy squaw valley new year
  175. drl led"s need feedback
  176. Help - Rear Seat AirBag coding and MIL
  177. A8 reliability?
  178. B&O doesnt sound much better than Q7 Bose
  179. S8 front door sill insert removal?
  180. Bluetooth Solutions
  181. Need 08 S8 Wheels /Tires
  182. Calling D3 owners with MMI 4610 or MY 2007
  183. is the D3 model STILL WORTHY to Buy?! (exactly 2009 or 2010 model)
  184. S8 - How to check power steering fluid and replace air filters
  185. How To Upgrade MMI Software On Audi A8.
  186. Windshield wipers not working, and im not talking bout ice caking on the blades
  187. Navigation not working properly
  188. Do all D2S headlight bulbs have high and low beams?
  189. MMI Upgrade?
  190. 2004 A8L location of Bose amp?
  191. Just completed oil change, few questions..
  192. Need 04 A8L Tail Light Assembly
  193. DRL for 2004 A8L
  194. 2007 A8 Intake Manifold Flap Issue
  195. Can someone give me a prart number?
  196. Looking for OEM Subwoofer
  197. 1 of 4 main front vents not heating air.
  198. Front CV joint boots.
  199. Auto light error message
  200. Missing Fuses
  201. Need to code seat control module?
  202. Speedo Calibration
  203. Tire Pressure Monitor System in the extreme cold
  204. Blower Motor or Blower Motor resistor
  205. front brakes just replaced...I have a question
  206. Installed AMI but now says tv/dvd player not installed?
  207. Used Audi A8 Buyer's Advice - It Had To Be Said
  208. Replacement Cup Holder Insert
  209. major service 2007 a8L
  210. What oil to use?
  211. I bought a lemon...
  212. Issues with transmission...
  213. Vibration
  214. Sunroof wind deflector motor noise
  215. Got a new Ride!
  216. How easy is it to change the headlight?
  217. V10 Carbon Buildup - Dyno
  218. Michelin Pilot Alpin PA3 or Bridgestone Lm-60 Winter Tire
  219. Question regarding default navigation address
  220. Motorola Bluetooth Puck...
  221. EBC Redstuff rear pad thickness
  222. Adjustable headrests?
  223. Clips bent when trying to take out CD changer...
  224. MMI Help! Update has wiped the car!
  225. Vag-Com Interface Problem
  226. Purchased Caregard Auto Extended Warranty Complete Coverage.
  227. 2004 A8L Recommended Maintenance
  228. Audi A8 Auto Lease Programs - December 2010
  229. Purchased My 07 Audi A8L with 27000 miles for 35k
  230. I purchased an ipod AMI unit
  231. This weeks issue with S8
  232. 2006 a8 best snow chains
  233. High mileage A8L...
  234. HiD lamp type...
  235. A8 bumper ALWAYS catches Curb. Service Writer says file an Auto claim????
  236. Trunk not latching, WTF!!!!
  237. Seeking feedback
  238. 4.2 valvetrain noise on cold start
  239. 4-Wheel Alignment OK at Midas or Monroe??
  240. Bi-Xenon adaptive - poor light output....
  241. No battery level meter in MMI
  242. Question about brakes, sensors.
  243. Navigation Error
  244. Audi Music Interface Ipod Kit Wires
  245. Chrome on Steering Wheel Cracked
  246. New Wheels And Tires pics/issue
  247. ALLDATAdiy.com Introduces Sponsorship of AudiWorld with a Discount!
  248. Issue with climate control blower speed
  249. Audi A6 Hybrid
  250. Last day of having ....
