PDA
View Full Version : A8 / S8 (D3 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 [39] 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
  1. 2009 A8 4.2L Intake manifold adaptor change
  2. New questions!! Cd changer/Parking light
  3. Not for the W12 faint of heart, from a sister board...
  4. Rear brake pads
  5. CALLING Mishar & MP4.2+6.0 & Brozee
  6. ECU Tuning software
  7. retro ski bag
  8. Help! Locked out of trunk
  9. Installed new compressor still need help
  10. Bluetooth Puck
  11. Just got VCDS, what to check?
  12. Air Suspension
  13. Larger tire size possible
  14. AUDI A8 (D3) 19" to 20" Wheels (RIDE QUALITY)
  15. what do i do and how bad is it
  16. broke the glovebox door dampners today...
  17. Blue tooth phone PUCK
  18. rear starter bolt 2004 A8l 4.2
  19. 2004 Timing Belt Replacement Interval
  20. NEED HELP! Suspension settings/menu
  21. just wondering i have the german plate holder,on the front of my car
  22. 07 D3 Audi Dension Unit
  23. VCDS scan Salt Lake City Utah
  24. Sold the S8! parting out $$$
  25. Feeling lazy. How many parts from a 2006 won't work on a '04?
  26. i want a parking break handle not a button so i can drift
  27. rear wheel treadlife
  28. driver information display has big "X"
  29. any way to pump the air bags on suspention with it not running a8ld3
  30. 05 A8L Purchase
  31. my w12 needs a cooling fan
  32. starter removal
  33. Re-colored my leather seats/armrest
  34. 2007 vs 2008
  35. Front seatback removal / change headrest
  36. coolant bleed valve locations?
  37. A8 2008 3.0TDi Emissions Control Warning Light
  38. Telephone box / ecu location? Need help quickly...
  39. What is this part called?
  40. 4.2 petrol mods
  41. D4 Headlights on a D3?
  42. mmi 3g?
  43. HELP! Pump sound from above front left tire
  44. Bad thermostat?
  45. A8s in snow
  46. First pics of my new toy :)
  47. Heating not working properly
  48. Brozee, are you selling your car?
  49. tomorrow I will put 150,000-th mile on my 2007 S8
  50. Audi A8 1 PSI Super Charger System....Real? Would it Really Work?
  51. brake upgrade question...anyone here consider the
  52. Heater/AC Blower motor
  53. If you have upgraded your D3 tail light, please read
  54. Seriously....it just doesn't stop. I need a quick answer please
  55. Winter Special: 15% off for the next 24 hours at Detailer's Domain
  56. 2004 A8 hood stays open... latch broken?
  57. Another trunk lid question...
  58. Parking Brake Motor failed
  59. getting smoke smell out of a car
  60. Replacing rear vanity mirrors with LCD or ???
  61. 5000+ RPM and the throttle cuts to 50%
  62. how to test lambda sensor using vagcom
  63. AMI cable - connection not working?? So I bought the ip
  64. VCDS Ride Height Adjustment
  65. Vag-Com Suspension?
  66. Calling K9COP
  67. broken part, dont know what it is.... :(
  68. navigation missing
  69. Removing rear seat headrests - A8 D3
  70. SHOCKS 2007 A-8
  71. 02510 - Steering Column Adjustment
  72. Leak: Green Liquid under A8?
  73. Unknown part. Any Ideas?
  74. Bluetooth causes Radio to Cut Out Sound HELP (2005 A8)
  75. auto trunk/bootlid close dont work
  76. Want an S8
  77. VAG?
  78. MMI Update issue and VAG Com results help
  79. New 2006 a8 owner
  80. Volvopentaman quick question
  81. AC questions
  82. New A8-L owner
  83. Burning oil question
  84. RVC install/retrofit
  85. "Crunch" or squeak from front suspension
  86. Vag-Com Help on 2008 S8
  87. Dash under steering wheel .. Seems no one knows ???
  88. 2004 Audi A8L Mimi
  89. MMI Control module saga
  90. diagnostic cable
  91. headlight bulb change
  92. Air Supension Continued....
  93. any experience with AMZOIL EURO ?
  94. removing TV in motion
  95. Rusty nail side wall low pros what would u do?
  96. Upgraded tail lamps to 08+ (pics + wire install)
  97. OT: What is your tool set-up for working on your D3?
  98. On the road & need help! MMI problems
  99. Is it a engine cover or belly pan?
  100. Audi MMI vs Blueooth - Streaming Pandora
  101. b1 s2 o2 sensor
  102. Nav cd for sale anyone .. Looking for north America nav cd
  103. Rolls Royce drifting // figuare someone would like this
  104. Anyone wanna share there custom leather interiour pictures
  105. Soft close anyone know about adding it to a8l d3 2004
  106. Lane change and departure assistant retrofit
  107. What essential tools do I need for a D3.??
  108. New to D3 (had 2 d2's before this)
  109. D3 won't start
  110. door window removal for tint
  111. New MMI Module: New Problems
  112. audi motorola phone
  113. New Phone = Bad Bluetooth connection?
  114. Trunk Open Button on D3 Drivers door
  115. Yet Another MMI Malfunction Thread
  116. Steering Rack
  117. code key using VCDS vagcom
  118. Suspension continued...
  119. Starter no longer engages in cold weather (20 degrees)
  120. MMI Some buttons stopped working
  121. Problems with my D3 gearbox transmission - oil chnage
  122. '07 A8 rear head restraints - change options???
  123. Need help with Air Suspension
  124. Car finally came in late last night. I am smelling a "burned rubber" smell and
  125. Battery Question for 2007 A8L....
  126. Calling Mishar "RVC Retrofit"
  127. 2004 A8 startup gauge needle sweep
  128. Buying w12 without putting my eyes on it...
  129. Front door suction help S.O.S
  130. sharing some pics that i took of my ride.
  131. :: ECS Tuning :: ISSE Textile Snow Chains - Save 10%!!
  132. BBS RS on A8L????
  133. Help with tires -2008 S8
  134. '07 A8 grill filler - no license plate
  135. 4.2 D3 Timing Belt vs Timing Chain
  136. Keyless timeout and Webasto
  137. MMI control head ecu - tv work or removal
  138. Escort 8500ci installation
  139. power steering issue
  140. D2 & New D3 Owner - Air Suspension Problems/Questions...TIA!!
  141. Seasons Greetings from the team at Eurocode Tuning
  142. Short Ram Intake?
  143. 2007 S8 back in shop 2nd time in 2 days
  144. Bluetooth phone module retrofit
  145. S8 5.2 Intake Manifold removal and cylinder cleaning
  146. MMI drawing power battery dead
  147. Broken button?
  148. Ticking when starting...D3 S8
  149. Importing tracks into jukebox, or not...
  150. RS6 Grill Fitment
  151. rear wheel bearing
  152. Instrument Cluster Gauges Dead
  153. MMI screen won't pop up...Help !!
  154. Last Minute Gift Ideas - Detailer's Domain
  155. HD Radio on 2007 S8
  156. AMI retrofit kit ebay 2004 a8
  157. Audi a8 d3 qustions...
  158. Codes
  159. Manually set time and date?
  160. pad w/ less dust than EBC RED STUFF ?
  161. Pressure control solenoid D electrical
  162. Wheel Width on S8?
  163. 06 A8 SOFT DOOR CLOSE PROBLEM
  164. Adaptive Air Suspension Light Won't Go Off and then...
  165. Transmission Flush at 100K miles
  166. MMI problems and dead battery
  167. Upgrades / Mods
  168. OEM Interior Chrome?
  169. New Custom Carbon Steering Wheel Is Finished!
  170. weak keyless entry- replaced batteries- what now?
  171. NEED HELP ON VAG-COM FAULT CODE
  172. Blue tooth streaming adapter
  173. Engine check light after replacing tires?
  174. New engine software update for S8, per dealer
  175. 2008 A8L underwater.
  176. Adam's Rotors Pics For Brozee...
  177. Use VAG - Ross Tech to turn OFF the city lights?
  178. I hate you MMI...
  179. how do i go about cleaning the engine and also
  180. just a quick post to forum users
  181. Almost done...(yeah right!)
  182. anyone have any problems with sunroof
  183. WILL WORK FOR VAG!!!!!
  184. Back from the D2 Forum
  185. epc light after re and re bumper
  186. Heater/AC Vent trim replacement
  187. Heater/AC Vent trim
  188. someone punch me in the face. .for using our audi jack that comes in the trunk
  189. Clipped a Deer last week- looking for Euro trim piece
  190. its gonna sound crazy but im new ..vag help
  191. lLOOKl u might know this answer..
  192. any mmi insight motors work gears work just off track
  193. adaptive suspention level sensor grey plastic arm
  194. battery going dead fast! !
  195. rear shade no power ??
  196. a8L 4.2 swap to w12. i know someone here knows if its poss
  197. "07 S8..Vag-com code." Any ideas?
  198. Popping sound when i open doors or trunk
  199. A8 OWNER'S ATTN: thanks
  200. repair manual a8l
  201. Ross Tech
  202. Rattling noise at start
  203. my A8L was on a flat bed today-long and sad
  204. Starter replacement
  205. Bluetooth Problem
  206. winter tire fitment too tight
  207. i am bying a s8 2007
  208. Stuck in MMI Update
  209. NEW MMI mechanism
  210. MMI 3G in D3
  211. O Geez...WTF did I do?
  212. Help me decide...Brake finish.
  213. got a few items for sale all at make a offer plus actual shipping cost
  214. Anybody selling an AMI unit ?
  215. Trunk Issue
  216. Please Help ID these Rims
  217. Trunk Latch Question
  218. I sell parts for retrofitting APS+ / optical PDC and Iphone Ipod Interface
  219. Hello! New guy looking at a high mileage 05 A8L... Should I run away?
  220. Underside of bumper damage
  221. Winter Tires
  222. A8 Questions (Newby of course)
  223. remote entry problem...
  224. AMI Cable
  225. Post Vagcom Mods Problems
  226. Heated steering wheel swap
  227. 3M-Fuel-System-Tune-Up-Kit
  228. 2005 A8L fuel filling problem
  229. post count
  230. Rear window trim replacement
  231. Vibration "Grrr" sound when coming to a stop
  232. Convenience Gremlins?
  233. PS Folding mirror won't fold—where should I start?
  234. VCDS - CENT. ELECTRIC & CODING
  235. Buy or run away?
  236. Analogue TV Red pin connector question
  237. fuse location parking lights
  238. Quetion to MP4.2+6.0
  239. HID headlight issue, '07 A8. Help!
  240. Questions about my new 04 Audi A8L - First Time Owner
  241. Is it worth it to replace my headlight bulbs? they are at least 8 years old
  242. Acoustic Glass ?
  243. Black Friday 2012 Special is here! - Detailer's Domain
  244. :: ECS Tuning :: The 8th Annual Customer Appreciation Holiday Sale!!!
  245. AAC retrofit and Instrument cluster swap
  246. Repair MMI for $3600?
  247. Sadly about to sell my 06
  248. 2005 Audi A8L Steering Wheel Controls Failure
  249. TIRE RECOMMENDATIONS
  250. Need Driver's Seat Relay
