- Got these codes from Vagcom scan toaday. Replace all the parts?
- What is this hose inside the front passenger side wheel cowl.
- Peeling Valve Covers
- Take a look at this!!!
- Time to say goodbye... :(
- 2006 Audi A8 trunk lock fix!
- ??? What is the "Test" Forum???
- STILL no heat....and winter is on its way !!
- Audi Dealer says I might have to replace the ENTIRE front Suspension System?
- Latest navigation CD
- Copper Paste
- Careful on where you get your oil changed folks. This could be you
- Brake Carrier Bolts
- Only use OEM air filters
- Kid in a Candy Store!! A8L vs A8L??
- MMI update from 660 to jug 317, 2750, or 1090
- 06 D3 A8 ~ MMI just died ~ any advice ~?I am not spending 3k for repair ~
- moved from my 2004 t0 a 2011
- Finished Replacing Air Struts! Compressor Questions....
- Opening up the W12 for a Coolant Sensor Need some Ideas
- 19" Sport package wheel width and snows
- Timing belt time
- Few questions on rear sub and instrument cluster
- Do I have Bluetooth? my iPhone doesn't get signal
- 2006 A8L 4.2 - Won't Start
- Umbrella holder in trunk?
- What are your thoughts on this S8?
- Intake "Damper Pan"
- Lug bolt broke off in rotor....
- Audi S8 Reliability
- fast discharging battery
- No Key Identified
- I know it's not an A8 but, this is what I have been up to !!
- Transitioning from 19" to 17" Wheels
- Replacing Front Air Struts
- P0171
- Bad ground somewhere
- Shifter cover plate
- Door handle replacement?
- Multiple Air Suspension Questions
- :LOST: Where Is There To Go After Driving An Audi A8 for years...
- Suspension Squeek
- Audiworld is the Best!
- Disable Air Suspension To Prevent Yellow/Green Error Lights
- Front speakers cuts/dies when turning up
- Concerning Engine Codes
- '04 A8 Valve Cover job... then CEL (P1340-001)
- :: ECS Tuning :: 50% OFF CYBER MONDAY ONLY! Audi Ziza Master LED Kits
- Dual pane glass
- PLEASE HELP A8 electrical issue
- 2010 D3 A8L Wheels
- Food For Thought
- AudiUSAParts - Free Shipping
- Happy Thanksgiving!
- Someone talk me Doc out of buying a 911 (we're famous)
- Which TPMS for 17" rims?
- Black Friday/ Cyber Monday deals from Car Parts Discount
- need an AMI unit?
- :: ECS Tuning :: 11th Annual Customer Appreciation Sale|Save up to 25%!!!!!!!
- Why so much issues with this???
- Has anyone replaced sunroof drain hose ?
- still no heat...would this idea work for test ?
- updated MMI and lost bluetooth?!?!
- Differences between an 08' and 09' S8?
- Window buttons problem
- Excessive inside front tire wear
- Found Possible Cause of Lean Code
- Green Suspension Light Question
- Where is the Water Coolant Sensor?
- Wipers Coding
- Original Battery replaced at 187k miles with walmart battery
- MMI Battery level indicator
- battery and VCDS?
- Flauta's objections with my choice of an S8
- A7 vs A8 (someone talk me out of it :)
- Climatronic
- Electrical Problems, Windows/Mirrors/Signals/Tail lights, Headlight
- Help with MMI Issues
- Sun roof maintenance
- Car Stuttering After Routine Maintenance
- New Owner
- Flat Battery, no sleep mode
- online coding and component protection
- A8 D3 04. MMI and NAV update...
- advice needed on air suspension failure
- Differences in D3 emissions from state to state?
- 2006 A8 or 2008 A8
- start access
- All Season Tires
- Old "Beater" A8's - what is the actual TCO (cost of ownership)
- Where to put axle stands at the front
- Suspension strut or level control
- Help with Boost Sensor Code P0236
- Age of Battery?
- Higher revs and slight power loss
- Are All Audi AMI Compatible?
- What is this clip?
- Telephone issue - Reading SIM card
- Coolant leak - unidentified
- Upgrade 06 A8 instrument cluster lcd to 07 & up larger screen
- Search narrowed: D3 S8 it is!
- Front End Rattle - 2007 A8L
- Google maps navigation program
- Google Maps, Pandora, Torque OBD, & more without taping the smartphone to the screen!
- Anyone in CT or NE area with VAG-COM??
- 2005 A8 cooling fan will not shut off
- Radio forgetting memory presets
- Just sold my D3 S8 ... goodies for scavengers
- Parking Lights and Lowbeams
- Did I win??? VIN codes decoder needed
- Going to pick up my 2011 A8L 4.2 I have a few questions!!!
- Washing your car
- Parking light bulb blue tint
- inner tail light fix (water damaged)
- left inner tail lights
- Option code sticker
- Brake Supplier
- keyless start
- New to Audi
- Any one updated their sound system???
- Swapping to a salvage yard motor
- Volume not working on MMI Control Panel
- Someone Talk me out of buying a 07 A8L
- What is wrong w/Canadians? A8 Photoshoot:
- Alternator Coolant Line Leak
- Silver "soft" dashboard trim piece
- Engine cranks, barely starts then immediately dies.
- FYI: I'm selling a euro tow hitch with the wiring kit
- Maybe some cheap deals on D4 TDi's coming up
- Plasti Dip wheels
- Wiper blade contacts A-Pillar
- Salt, magnesium chloride corrosion....
- One year with my 2007 D3
- First A8L purchase advice
- RevV Coilovers to replace stock air-Suspension
- HID Bulb and Ignitor melted
- Scratch removal and type of paint....
- Very cheap parts site
- Service indicator question...
- Bent Bang and Olufsen speaker cover
- Special promotion for Audi World Forum members
- My new toy
- Air suspension failure
- Bang & Olufsen radios
- Ceramic or Semi-Metallic Pads
- Adaptive Cruise Control & VCDS Fault Codes?
- 2005 A8 No Start
- 2004 a8 4.2 coolant leak
- Left rear caliper blown
- Fuel pressure woes
- Radio Reception after mmi update
- Oil Change..........I'm not happy
- Mirror Mystery
- Could this be why Audi uses plastic oil filter caps?
- 2007 S8 - Unable to "program" in fingerprints
- J519
- Forum group buy with Car Parts Discount
- problem programming car for new battery...
- Brake Pad
- Remove Shift Knob Internals
- Cover
- Drivers side rear tail light
- driver front door speaker sounds miserable
- The battery is dead; long live the battery !
- 2008 A8L 3.2 FSI Limp mode after new ECU change
- 0w-40 causing leak?
- New Owner. Thrilled. Question/problem re Adaptive Air Suspension
- 04 Audi beeping from engine compartment
- New Owner "A8 (L) Essentials MY 2004"
- Check Engine Light at high acceleration
- My first car
- Driver's Mirror - I need 3D glasses on??
- Radio volume decreases in gear
- Audi Parts Dealer and Bolt Size
- Faulty AC controller ("button").
- how to R&R side trim on front seat ?
- W12 front airspring ..sport or comfort ?
- w12 Rear Differential Service 100k
- Air struts limited warranty replacement
- paddle shifters-how?
- Floating cell phone mount (PIC Heavy)
- Kessy clone and swap
- how to R&R shift knob on an '04-07 A8 ?
- Trailer wiring harness. I'm lost!
- New Owner (2008 S8)
- Where exactly are the lift points ?
- 2007 D3 altinator
- ATF blue or Gold
- AC problem - works from time to time
- Oil residue on Left front lower cowling
- My S8 2008
- What else while intakes out?
- Shakedown Lap
- 2nd AMI with changer
- S8 Power steering Noise- FIXED
- Farewell Audi awesomeness (sorta), hello new German auto(likely)
- hood sensor location
- Help me decide : "comeback" to the A8?
- Knocking sound from back of the engine
- vacuum problem?
- New tires on the D3
- Fixed overflow tank inlet nipple
- is there a control module for the locking system
- Parking sensors issue
- Air suspension
- Massive Coolant Leak
- Rain/light sensor
- Double pane "security" glass retrofit?
- Best method to sell this beast?
- Rear Window Sunshade control module
- Enabling comfort open/close from key on 2007 A8L
- Non Resonated Stock Mufflers- No standing revs.
- Have to Remove Engine to replace PS hose?
- Need help. Who has VAG COM around central New Jersey. Will pay
- Air hose from pump to filter housing
- Popping/ Thumping Noise from Airbox
- Replaced my upper arms this weekend
- Very Interesting Exhaust Note
- Removal of Start Button housing help?
- 2008 A8 Camshaft sensor
- 2008 A8 MMI don't work
- Sluggish Performance Solved - Replaced Intake Manifold Links
- WTB: Rotors, Pads and lines 2008 W12
- Trunk Lid Spoiler
- Updating MMI issues
- OEM wheels to....>>
- Where is the ICM/POS on 2008 A8L 4.2?
- annoying message - the pin number has been entered
- S8 D3 Power steering whirring noise- Advice please
- 2009 A8L 4.2 Code P0011
- Arnott Intros New Front Air Struts for A8 (D3 Chassis)
- Audi A8 3.0TDI Quattro EGR/Smoking
- D3 A8 MMI "Car" Button Not Working
- I'm in!
- 2005 Audi A8L 4.2 V8 Quattro
- HELP!!! MMI Stuck in Bootloader Mode
- UPGRADED TAIL LIGHTS
- Suspension Compressor Wiring Question
- 2nd round of Mods
- Audi A8 MMi 2G to 3G Retrofit
- Slight coolant leak - need some advice
- 2004 Audi A8 Bluetooth Help...
- 2004 A8 brake pressure sensor wiring
- Help with a 2004 Audi A8 4.2L Issue
- Speakers sound blown out after battery re-connect
- A8
- Brand new A8 drives "darty."
- Brake Light warning
- A/C not working properly
- audi key set replacement questions. please help!!
