- S8 Throttle body wiring repair kit
- Torque specs
- stripped air box screws
- Cooling Fan Assembly availability and parts in general
- JHM D3 S8 TCU/ ECU Tune - Review
- Good Independent shop in Denver Colorado area?
- Have you guys watched, "Better Get Saul" on Netflix?
- Air strut Failure front right
- Thinking of getting a D3 A8L 4.2
- parasitic drain search using FLIR
- 06 A8L key stuck, SAFE came up, battery died
- Back-up camera comes on goes off
- A8 D3 Cam Tensioners
- Mando the full moon with flowers and empanadas
- Cannot calibrate air suspension - raises when checking low level
- Air suspension dead
- Free OEM D3 roof racks
- Alternator differences
- EPC light/HP Fuel pressure question?
- Trunk motor issues
- Hood cable snapped
- A8 runs very rough, ESP fault, EPC fault, no power brakes, undriveable
- 8,600 mile ‘08 on BaT
- SAI issue w12
- Bluetooth installation help (input very much appreciated)
- A8 Coilover installation Coding question
- MMI button woes and part numbers
- MMI fiber optic problems
- Issues w/ Gear Selector & EPB - Car Won't Start
- Free oil cooler pipe..
- Anyone now of a good Audi tech in Miami/surrounding areas or Sarasota/surrounding are
- No power just headlights
- MMI turns on by itself - Oh boy another problem!
- Rear Power Shade
- Looking for a write-up on how to remove front end.
- Vacuum line on air filter housing - 2006 Audi A8 4.2
- I miss the full size spare tire
- CD Changer - USB - MP3 (for a 2004 MY)
- Driver's Headlight
- anyone had the ABS unit re-built ?
- Another one bites the dust
- S8 AC Compressor failure
- A8 W12 (2012) How do I access and replace my PCV Valve
- Audi s8 5.2 v10 accelerates on its own
- Rear Parking Aid fault, stuck at 0 cm
- Radio presets show up as wrong station
- Audi S8 - Coolant hoses constantly cracking
- Year (over) with 06a8l d3 as daily
- Meyle HD vs OEM Audi
- Front ash tray disassembly
- ABS ESP pump Long wheel base
- On your wheels, what do you prefer...
- Audi S8 constant vibrations problem
- So brakes were installed today...
- where is the brake pressure sensor ?
- Free MAF sensor in San Diego
- How about Solar Roof trickle charger mod ?
- Source for front right shock?
- Roof electronics control unit - replacing
- AC Compressor $$$$
- Are ABS sensors all the same?
- Blew off serpentine belt
- Yaw rate sensor s8 v10 2008
- Sorry, long post..A8 starts then immediately dies after replacing immobilizer system
- Not charging , new alt new battery , swap Bem , coded
- Solar sunroof taking off
- Troubleshooting the MMI system
- Flashing lights on remote lock
- Cutting off the headlight washers completely - HELP!
- Enabling needle sweep
- Lean codes and SAI is...missing?
- D3 S8 MAF Peak Values
- D3 direct injection valve cover gaskets?
- CTEK Charger not working
- AT: Nachrüsten Alpine Rse
- ReplCed battery and alternator 11.7 volts at battery
- Audi A8 d3 defect side assist module
- A8 4.0 tdi ignition disappeared
- Easy & Free Lifter Rattle Fix!
- W12 DIY Oil Change
- S8 Throttle Body Error
- 2007 D3 S8 directional lights...
- Easy way to change the D2S bulbs!
- 265 35 21 vs 265 40 21 Tire Sizes
- Thermostat replacement
- My car...an introduction...
- Vibration under the seat at 2600 to 300 RPM
- ticking
- Front Bumper Shocks FYI
- I performed a JHM ECU TCU calibration............
- RO: 2008 A8 , New owner and some questions
- Laminated or Not Glass in Door
- S8 Updated Intake Manifold Design?
- Suspension solenoid valve block and VCDS measurements
- O'Reilly Batteries
- 2007 S8 D3 Instrument Cluster Dead
- Quick question - putting A5 wheels on my A8 D3
- coolant temperature - need help!
- How to service the transmission (writeup)
- Vcds 01200 code D3 A8
- Able to get turbo?
- Highest Mile Factory Timing Belt??
- New D3 Owner Here
- Camshaft and Crankshaft Location A8 W12
- J197 Air Suspension Control Module - can this go bad with no faults?
- Lic plate lights questions..
- Lowering the car with VCDS
- AC refill!!!! A8 W12
- Terminal 15 006 - Short to Plus
- 2004 4.2BFM A8L airbag light
- Parking sensors problems with wiring?
- S8 Clicking/clunking when turning at low speeds. Tie rods?
- Lean Condition Intake Manifold & Fuel Injector
- Advice on Good Independent in LA Southbay?
- ZF 6HP26 Sealing Sleeves
- Front Wheel Bearing DIY and Caliper Torque
- Retrofit OEM headlight w/LED DRL
- A few questions
- Headlight frustration. 2006 A8L 4.2l
- To much power?
- thick aluminum heat sheilds
- Loud knocking in engine
- Both of my directional lights stopped working
- Left Front Level Sensor Popped Off
- ES: Suspensión fault, HELP
- Grille options for A8 D3 post facelift
- Knocking clunking noise from front right
- Location of Fuses for Sunscreen
- Vacuum Incorrect Flow Diagnosis... Help Please!!!
- oil specs 0w-60
- Thermostat going bad?
- Transmission Opinion?
- Audi safety feature braking and accelerating
- What do you do with used electronic parts?
- calling all Euro AW members...I need your help
- Parasytic battery drain - Clicking noise in trunk?
- Small holes on side of engine manifold
- replaced HID bulbs and it took some time
- 2007 -4.2 BVJ - No spark -
- Upper Control Arm Ball Joints
- GE: Terrible ENGINE vibration at idling
- Buying a used A8?
- 2007 S8, is there an oil pan gasket?
- Strange Hole on the side of the engine
- orifice tube
- Suspension calibration using only VCDS
- Mounts
- Different transmission
- I hate Audi pinch bolts
- Glove box replacement 2004 audi a8
- Cleaning intake, 07 4.2 FSI; manual crank direction?
- Side mirror intermittent
- Newb Here - 2004 Foglight Grills
- air suspension
- SE: Engine light issue W12
- 2005 A8 rear abs implausible signal right side
- Chain rattle ?
- Camshaft VCDS Codes
- Need help with part number
- 05 Audi A8L hard time starting after warmup
- D3 A8/ S8 Bang & Olufsen Door Speaker Replacement
- D3 S8 - SAI & Upper Limit Exceeded
- Concerned about my spark plug appearance
- R-134 level at engine off?
- miessler automotive air suspension
- Is it just me or are the front rubber bushings on D3 S8s made of butter?
- Loose ring clamp on MAF connection?
- Intake actuator made of gold?
- Dropping out my 4.2 in my A8L '06?
- get RSE audio to play through BOSE speakers?
- PSA - Window regulator
- Front Plate Filler
- Rear Mufflers
- A8 D3 W12 webasto retrofit
- Another suspension problem!!!
- Key start issues
- Who makes a freer flowing muffler than the stock one for a D3 S8?
- ACC issue
- 2003 locate CAN-bus
- Electronic Parking Brake (EPB) Pointers Tips
- BG: Weird Sound from Engine Bay
- Rear Wheel Speed Sensor
- 2009 d3 s8 front grill paint remove
- UK: Audi A8 06 MMI not working
- ABS Wiring Harness Won't Reseat
- Engine turns over but won't start. Starts with 'Easystart' in the intake manifold
- Engine Issue
- Upgrade recommendations?
- PCV housing leaking?? or what’s the problem?? W12
- Complete parts list for 4.2 D3
- 2009 audi a8l 4.2 master rebuild kit
- Battery replacement dead batteries and no starts
- Need assistance
- transmission fluid
- Changed out torn, cracked old rear seat cushions/leather
- Passenger seat is stuck
- Rear light lenses
- Need help with BEM module programming
- SA: Level Control - Urgent OPINION
- difference between Engines BGK, BFM, BVJ
- Source / part # seat trim?
- RADIO ISSUE - No AM / FM option. ONLY SIRIUS XM
- Advice on suspension faults
- How do I find out the color/name of my wood trim?
- UK: Power streering gone heavy and MMI screen stuck
- AU: Weird Rear End Thump
- Audi Driver Side Door Soft Closing Issue
- Another A8 Suspension dialogue
- Oem bluetooth adapter 2008 s8 euro version
- Random ESP/EPC/ABS faults
- 2007 S8 what to do?
- Where/who are we buying our control arms from?
- Oxygen sensor compatibility question
- s8 v10 5.2 alternator removal - would be great to get instructions
- Dynamic and Lift off
- Air Strut brass fittings?
- Throttle body adaptation on a D3 S8.
- 2007 S8 dead battery and clicking in passenger side of trunk
- Audi A8 D3 4.2 Tdi short coding
- Audi S8 D3 (V10 5.2) massive oil leak
- Coolent leak
- I got a "Brake Light" warning light (driver's side US)
- Rear parking brake leaking/issue
- 275/40/20
- 275/40/20
- Surprise ,Surprise!! Just picked up a 05 W12 for $3,000
- O2 bank 1 Sensor 1 replacement. Question.
- Main seal and timing belt job tomorrow. Questions.
- New OEM A8 4.2L Trans filter and pan gasket
- Music and Radio cuts off and speaker starts clicking
- Another trunk post.....
- How to re-build soft close door latch ?
- Audi S8 Rear Silencers Re-install
- anyone had soft close door function repaired ?
- Mysterious leak, what is it?
- Plase
- 04 A8L air suspension issue
- Electronic Parking Brake rebuild EPB
- How to adjust Headlamps
- Cruise control not activating.
- 2006 -- coolant leak around oil cooler? help
- Engine belly pan, what does it do besides noise insulation?
- S8 whine…
- 07 S8, A/C blows hot on driver's side.
- What would be the best way to connect audio in my car
- Cluster change from small display 2004 w12 to S8 V10 wide disp. cluster.
- Need help to save me some time and money
- I think another S8 has bit the dust...
- Audi S8 5.2 V10 exhaust leak on cold start
