PDA
View Full Version : A8 / S8 (D3 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
  1. A few questions on various issues
  2. HELP MMI and Speedometer Intermittent issues
  3. Europlating Yer D3 A8/S8
  4. 04 audi fan
  5. 2007 A8 D3 Parking Brake Issues
  6. I need help finding an S8 or W12 right rear caliper...
  7. Major coolant in oil
  8. Need definite fuse diagrams for my 04 a8l 4.2l BMF petrol
  9. SAI hose to combi values need help reattaching
  10. Climate Control in Protection Mode
  11. 04 A8L Won't Start
  12. Front floor mats with brown lining
  13. Oil change- Now more leaks
  14. New 04 A8 4.2 Quattro questions
  15. Another A/C blower issue, but is this different
  16. Air recirculation Flap Positioning Motor (V113
  17. Transmission making noise
  18. LED light in door handles
  19. Parking Brake Motor - Just spinning (parking lot wrenching at lunch)
  20. CAR MODE DEAD ON MMI
  21. Bad bulb or wiring/connector problem?
  22. Audi A8 D3 2004 Rear indicator (outer)
  23. stock vs. drill & slotted disks ?
  24. Rear Badges
  25. Used S8 or W12
  26. Sunroof drain leak - not clogged
  27. S5 Wheels on A8L?
  28. 2009 A8L W12 P0172/P0175 Codes w/VCDS Log
  29. Painting Replacement Parking Sensor
  30. Fix Audi A8 D3 Sunroof drainage problem
  31. What is this part?
  32. Smoke testing a Secondary Air Injection System code
  33. HELP! Changed out drivers side coils and plugs...MISFIRES EVERYWHERE!
  34. Audi A8 2004 4.2 D3 V8 Turbo ?
  35. 07 Audi A8l is stuck in trailer tow mode.
  36. 05161 : Brake Vacuum Pump code "Open Circuit"
  37. Interesting Air Suspension Video... Measuring Blocks
  38. 2008 S8 HID/LED fog lamp replacement
  39. Sunroof rattle misery! - any advice?
  40. a/c only cold through rear right vent?
  41. Nice aftermarket car mats
  42. LED headlight bulbs installed
  43. 2007 S8 Owner's manual set: $300?!?!?!
  44. Soft Break pedal.
  45. Vehicle Extremely Un-Level and Has became a Low-Rider on the right
  46. 2004 a8l 4.2 bfm wont crank!
  47. Taillight upgrade
  48. Seat heat
  49. New to me 2004 A8L
  50. Hvac issue ac not working also blowers not right
  51. Rear Left Light and Engine Hum
  52. 04 A8L won’t start after a long drive
  53. Front Suspension Control Arms
  54. Adaptive Cruise Control recalibration
  55. Searching for exhaust for V10
  56. Ross tech
  57. 2008 s8,13500$
  58. Rear view mirror
  59. Rattle at decel- Exhaust valves?
  60. knocking noise at 40mph
  61. A8 L 4.2 FSI misfire problems
  62. Sway bar stabilizer link problem
  63. Lubricating Rear Shade
  64. 2007 S8 whining noise coming from steering column
  65. starter life
  66. Need to replace the Fuel/Boot switch in door
  67. Ventilated seats and gas range
  68. Rough Idle & Misfire / Help with VAG-COM Scan
  69. Do I have a light sensor?
  70. Hi beam issue
  71. Are both front air struts bad?
  72. O2 Sensor Part #s
  73. O2 Sensors - worth replacing?
  74. 2005 A8L Cruise Control Inop
  75. audi s8 engine noise when hitting gas
  76. DRL bulb part number
  77. Rear Brake pads replacement
  78. Limp mode
  79. Was ready to give up...
  80. MMI Keyboard Part Numbers
  81. Audi A8L D3 2008 Paddles / Manual Mode
  82. Low oil warning
  83. Aircon Troubles
  84. Does the 04 a8l even have an AMI?
  85. Rear brake error codes, need help getting this car fixed!!!
  86. I think my wife’s car is loosing it!!!
  87. Brake Pedal Pressure Problem but fluid level seems fine?
  88. Mmi 2G update problem
  89. Retrofitting AMI unit
  90. 17” wheels?
  91. Cd changer
  92. D3 S8 vs D2 S8: seek advice from someone with hands-on experience with both
  93. My A8 is shinier than your A8 (MMI, Pbrake etc update)
  94. Hello and Goodbye (for now)
  95. 2006 Audi A8 Wiring Diagram Needed
  96. Navigation and parking sensors
  97. Tiny hose connection location?
  98. My Audi A8 L Tail lights
  99. Audi S8 D3 MMI Display Pinout for aftermarket display
  100. BVJ HPFP or injectors leaking, How to test?
  101. Rear caliper
  102. Audi S8 front left rattling sound!!
  103. Audi A8 D3 bank 1 & bank 2 running lean.
  104. Maintenance, Non-mechanical
  105. Bluetooth adapter for sale $50
  106. Anyone do Tail light repair?
  107. A8 4.2 Rev bounce when coasting
  108. Need Help Locating Vacuum Reservoir Hose Location
  109. Air conditioning trouble
  110. Dreaded Combi Valve
  111. Rebuilding rear calipers
  112. MEW MEMBER NEED HELP 04 A8 OBDELEVEN MMI CODING
  113. Fuel pressure sensor location ? help!
  114. D3 alternator heats up, Help
  115. HVAC not cold enough
  116. Intermittent battery discharging
  117. Where does this hose go?
  118. Vcds engine module tests step by step guide
  119. Valve Cover Gasket BFM
  120. HELP WITH MY D3
  121. Elect park brake error
  122. From an 03 S8 to an 06 W12?
  123. Couple issues
  124. Screen won't open, MMI dead. fuses OK!
  125. 04 audi a8 wont start
  126. 08’ A8 AMI - Tune2Air Doesn’t Work?
  127. Best way to hold V10 engine from the bottom?
  128. Audi A8 MMI
  129. A/C pulley
  130. Highest Mileage S8?
  131. AMI and MMI 2 High
  132. W12 help
  133. I need the coolant reservoir
  134. Air suspension ?
  135. 2008 A8 Lower Control Arm Bushings Part Numbers
  136. Oil Pan Bolt Size and Thread Pitch
  137. 10' 4.2 V8 Rattle
  138. Air Suspension lights on. VCDS Scan results included
  139. Oil Pressure
  140. A8 mobile phone
  141. Inspection service, San Antonio area ?
  142. constant tone from Park Assist ?
  143. Audi A8 d3 radio issue
  144. MMI 4G System & Apple CarPlay Retrofitted in Audi A8 2013
  145. Hello, Not on in awhile
  146. MMI software update/upgrade
  147. Transmission problem
  148. Getting this code. Not much is coming up for it P0481
  149. Starter located
  150. Kessy module
  151. Lost my baby today
  152. EPC Light On After Intake/Injector Cleaning
  153. Key fob
  154. MM...I can't take it anymore! Aftermarket stereo install help
  155. will early D4 grille adapt to D3 A8 ?
  156. A8 corrosion issues ?
  157. Production Numbers
  158. Went and saw a 2005, also 2006 for sale... thinking about resets
  159. Anyone have the PN for the airbox snorkel?
  160. Coolant Fan Not working
  161. Recalcitrant Power Trunk
  162. That stupid pinch bolt
  163. Slow Air Suspension
  164. TIres
  165. Air compressor shananagins
  166. Audi S8 V10 - Timing Retardation
  167. Anyone able to provide some DIY instructions for PCV replacement on V10?
  168. 08’ 4.2 V8 FSI Engine Rattle on Startup
  169. Driver info shows trunk open
  170. Half Shaft Seal - 2008 A8L
  171. anyone added sound deadening material to doors ?
  172. After years of loving my D3, I think its time to sell
  173. MMI Keypanel - versions ???
  174. 2008 A8 4.2
  175. Bad Passenger side motor mount
  176. Moving on. Thanks For All The Help.
  177. Won't stay in dynamic mode
  178. Over heating
  179. Mmi music problems A8 d3 3.0tdi
  180. W12 secondary air pump fuse
  181. Front ist lowered. Air Suspension Settings in MMI grey. Compressor not starting up.
  182. Dead, real dead
  183. Front Sidemarker Light
  184. Paging Luis
  185. 01770 - Temperature Sensor for Level Control Pump/Compressor (G290)
  186. 2001 D2 S8 left side lights not working
  187. Seat won't move forward/back
  188. A/C Compressor O-rings?
  189. Keyless Entry Not Working; Seeking Advice
  190. Car does not have heat
  191. MMI does not open
  192. Is there anyway to get a second key for cheaper ?
  193. A/C not blowing cold air?
  194. VCDS Battery Advanced Measuring
  195. an economical source for injector 'O' rings ?
  196. Engine.... Heal thyself?
  197. Shifter track
  198. #2825 front parking light bulb
  199. How long for sleep mode to kick in?
  200. Siemens Control Module Fried
  201. Parasitic draw reading (pic)
  202. With two new struts the trunk still won't open
  203. Which MMI software do I have? (picture)
  204. Pressure Line Install
  205. AC blowing hot air
  206. Audi a8
  207. Ventilated seats retrofit
  208. Parking brake Help
  209. It’s time to say goodbye
  210. Heater core replacement 2005 A8
  211. Upper radiator hose help
  212. P0491 and P1411 codes
  213. A8 D3 4E 3.0 MUSIC STOPS when i driving
  214. 2005 A8L Won’t run with more than 4 gallons of gas
  215. Passenger mirror stuck down after car is in reverse
  216. Valve Cover Gaskets
  217. MMI DIAG
  218. Exhaust valve?
  219. 09 A8L start/stop without key or FOB
  220. Audi 2004 audi a8
  221. adaptive headlights
  222. engine start/stop without key
  223. 2009 A8L W12 P0172 & P0175
  224. FCP Euro life time warranty?
  225. Need help diagnosing engine shake. Please!
  226. Cloudy sky... Beautiful car
  227. brake rotor and pads recommendation?
  228. Continued air suspension misery....
  229. Fuel rail/system pressure too low
  230. Solar roof (sunroof) groan/mooing during last few closing inches
  231. Leaking water !
  232. Easiest way to remove air ride compressor for repair a8l 04?
  233. Keyless / proxmity unlock -- I don't get it
  234. Can you adjust muffler height?
  235. Car is down in front on both left and right side
  236. Audi s8 stops during driving
  237. Headlights / ballast / igniter
  238. PS Pressure Leak
  239. Air suspension urgent
  240. Drain Fuel from Audi S8 D3
  241. Honk.Honk.Honk... Nothing... Nothing
  242. Audi A8 light fuse
  243. Apple CarPlay No TV Tuner Required Plug and Play.
  244. ZF 6HP26 help, shift selector problem
  245. Turned the car off while air suspension was lowering
  246. Roller Rockers???
  247. Questions about installing factory under-the-floor Bluetooth module
  248. Audi a8
  249. A8 D3 AC Compressor Not Engaging, help pls!
  250. Just bought a second hand A8 D3 2009
