- Passenger Power Seat Won't Move
- My Curve Light Story
- aTOMic news: Rosemeyer, Broken Driveshaft, Divorce, and Misery on me...
- DIRECTIONAL HEADLIGHTS - they move quite a bit
- The #offroadaudi A8 D3 project...
- Is it possible to open sunroof manually?
- Audi A6 Quattro 2003
- D3 W12
- Used parts - Do you?
- upgraded sway bar to S8 version
- audi a8 d3
- Highlights of Hydraulic Adjust Change
- Dealer unable to remove CP...?
- Few Problems with Audi S8 -2008
- Changing oil filter in between oil change
- Wont start replaced fuel pumps and filter
- Pinch Bolt Problems
- B&O amp fail
- Good Indy Audi shop near Lithia/Brandon/Tampa FL?
- MMI dead, Nav fuse keeps blowing
- Windshield Replacement - Soundproof vs Not
- Front suspecion groaning sound
- Just purchased an 04 with a TON of problems HELP
- A8L MMI/Radio Not Working
- Multiple network errors
- Can anyone help to find a post with pic of hole on back of engine leaking oil?
- Do US 05+ under-armrest phone cradle preparations include aerial antenna connection?
- AC recharge quote from Audi and VW dealers. Is VW service equivalent?
- Original fuel filter
- So outside of fuel is running a D3 S8 that much different than a A8?
- Looking for a recomendation for an axle replacement
- Vacuum Line replacement
- Wheels, please give model
- Wheres the subwoofer located in the trunk
- S8 D3 engine rough when brake depressed
- Weird AC issue
- 06 Audi A8 Cigarette Lighter Wires
- KESSY module 2004 AUDI A8 L Please Help me
- AC BLOWING WARM AFTER REFILL
- W12 check engine P2195/P2197 CODES
- W12 friends + part identification help
- Rear Cam Plug change
- MMI Update
- Bank 1, Bank 2, and Firing Order
- Serpentine Belt Failed, Replaced - Now running rough
- 06 audi a8l
- How to remove inner door panel?
- Need to replace DVD Navigation Reader in Truck
- Fused sway bar bushings?
- 2006 Audi A8 NAVIGATION DVD READER
- side rearview mirrors are folded in.
- A8 D3 4.2 tdi quattro
- ***Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - Aug 28th - Sept 4th, 2017***
- Oh no, it's too early for a timing belt service
- Car is throwing codes P1129 P1127 HELP!
- Q7 thermostat & water pump after only 56k, is this normal?
- gearbox light
- ...and another suspension problem
- 2004 Audi a8l fog lights not working
- What are you guys using to replace your TPMS?
- coolant leak has dealer stumped
- headlight relay location
- D3 with night vision system exsist?
- Tried some chrome window trim restoration
- Seat Upholstery
- MMI SCREEN REPAIR?
- One corner sitting lower
- VCDS Scan Fault: "Please Check DTC Memory of ECU Number 2"
- I want to install an aux cord
- Rearview Camera Retrofit for A8 D3
- CV Axle replacement
- Expensive Lesson Learned..Mr. Bally Was Right!!
- Noobie A8L D3 owner - Some electrical niggles... 🙈
- Audi A8L D3 W12 - Not getting up to temperature
- PSA about Timing Belt Engine Oil Leaks
- Audi A8 D3 steering column
- Ideal D3 wheel lug bolt size and specs for use with spacers
- Parking Brake Module replacement?
- Audi MMI Computer turns on and off
- do wheels affect suspension
- A8L 3.0 no start issue
- Emergency brake malfunction...serious issues.
- Audi A8 D3 ventilated seat
- Suspension causing steering wiggle?
- suspension
- Time For New Brakes - What's the correct process?
- Metallizied windshield?
- I know this is an Audi forum, but I have a chance to purchase 2004 VW Phaeton
- Air suspension thread #6543873125
- Fender bent
- thanks to this forum it just saved my 2008 a8!
- HVAC not showing on MMI after 4610 upgrade
- Need help with Bluestream 3gen bluetooth
- How to bild DRL LIGHT D3 using D4 LED
- Dash cluster lights
- measurement fuel pump
- 2007 S8 D3 Front Suspension Kits
- BSM engine vacuum hose routing diagram
- About to buy some wheels, need help please
- thin brittle hose on the back of the engine
- Help needed regarding EPC
- Pimped out A8 :/
- Component Protection Active MMI Sound is DEAD
- how to remove mmi screen open/close button
- Brake System Dash Lights
- Wow, where do I even start??
- Relay overview
- 2019: Important Info On Current Arnott Rebuilds
- CV Half Shaft replacement
- Does anybody know how many D3 S8s were built?
- Replacing return ps hose advice
- Battery choice: VARTA H3 or G14
- fuel pump replacement 2006 audi a8L 4.2
- another air strut story ....long
- Recommendations for PPI for 08 W12 near Thousand Oaks/Burbank
- Data Request
- How to obtain old MMI updates?
- 2002 Audi a8 4.2
- Air Leak in the Cabin??
- LED turn signal bulb , Fast Flash
- about traiangle
- Audi A8L 2004
- anybody know how to change the serpentine belt on a 2007 Audi S8?
- 2007 D3 S8 serpentine belt replacement
- D3 w/ ECU Malfunction. Help Deciphering the Scan results.
- Squeaky Noise especially when cold outside
- Warranty tire discontinued; store wants me to buy 3 new?
- Another MMI thread...with VCDS results...assistance desperately needed
- fuse panel
- Missing front headlight washer jet cap
- Parking aid chime
- RE: ESP thread ABS, etc my final solution and "HOW TO"
- audi a8 4.2 v8 engine issue
- Audi TT airbag light
- strange problem
- what a difference a key battery makes!
- how to remove front side marker ?
- Caliper Rebuild Tips?
- No start pls help :)
- Audi A8 Cat Bank 2 weird issue
- Push start button
- Audi a8 d3 wont start sometimes
- cd changer
- I need a new battery for my 1999 Audi S8
- Airbag Light code 00591 - Seat Belt Switch; Driver (E24)
- New Owner
- Transmission Range Sensor. Whats the proper connector?
- 2005 Audi A8L will not Crank
- anyone in Kansas City?
- my audi 2004 A8L sunroof leaks
- Motodyne Technologies Hainesport N.J.
- New member intro :)
- mmi system issue
- 110 in Vegas, hot air out of AC
- s8 post carbon clean, got a vac leak?
- location of valve for torque support mount
- MMI Control Advice
- Updated Navigation 2016 DVD 4E0 060 884 EG
- MMI 2g Update...
- About S-Line Wheels...
- Bubbles in Expansion Tank
- W12 Code
- how to identify adaptive headlights?
- Hard shift from 1st to 2nd ('07, S8, 60k)
- 2004 AUDI A8 42L Fuel Issues
- Who's car is this?
- 2008 audi a8l fully deflate suspension with 3 clicks on key fob
- Keyless Entry Questions
- Radio issues
- Radio issues
- Radio issues
- Audi A8 4.0 tdi starup issue
- How to remove front bumper trim ?
- 2007 S8 Possible Compressor Issue
- 2007 S8 - repairable - front end damage
- Never Ending Check Light - Secondary Air Injection
- Parking Brake Fault
- OIL FILTER STUCK TO COVER
- Bluetooth upgrade to an A8L
- 2009 Audi A8 front plate filler
- Battery, ECM and Strange Elec Issues
- Advice for technology advancements in my 2004 Audi A8L?
- Air brakes sound normal from valve block?
- Schematic for Blower controller regulator
- P2198 code Need help identifying location of O2 sensor?
- Horn Question On Pre Fish Mouth
- question about deleting front marker lights...
- Help. Car is jacked. Suspension over-inflated
- A8 D3 2003 BATTERY SAFE MODE
- Problems with suspension
- Intake manifold vacuum leak
- 2008 A8L CRUISE CONTROL PROBLEM.
- How many of you run ebay air spring replacement with grate results?
- Audi Wheels on closeout.
- 2007+ D3 Headrest Retrofit
- Pre-purchase inspection for 2006 AUDI A8 L QUATTRO AWD with 140K plus miles
- Important Info On RMT Rebuilt Struts
- Missing ECU
- Driver Side Ext Mirror Part Identification
- rear end whine?
- Updated analog tuner 20 pin connector pinout.
- Been Looking for a 2009 S8
- 2006 Audi A8 wont start
- No Key Identified
- Help With Rear Wheel Wear
- ROUGH IDLE AFTER A MINUTE OR SO OF RUNNING BUT VERY SMOOTH AT HIGH SPEEDS
- S8 right rear timing cover leak
- Looking for new rims for my Audi a8
- A4 Safe Mode removal procedure
- 1999 D2 A8 3.7
- Anybody Else an "Online Beta Tester" for Bentley Manual?
- Interested in purchasing an 2005 Audi A8 4.2
- Rear Window Sunshade Issue
- Fuel pump
- is my car fat shaming me?
- centre air vents
- Audi A8l '05 slammed after tried calibration
- Could use some advices - No key identified 2005 A8L W12
- mmi 3g navigation conversion from Japan to New Zealand
- Need help Recoding ABS Module?
- Because i have to remove it to access the TB........
- Washer Fluid Leak
- Parking Brake Malfunction - 16354 control module A/D Converter test failed
- I need 2010 A8 battery compartment photo
- A little interior work.
- Throttle Body Replacement how to?
- So new issue. Fuel gauge issue.
- Door Handle Touch Sensor (G415) issue
- Advice buying Hydraulic Adjusters
- 2017 NAV Maps disc?
- FS: Audi A8, A8L, S8 2004-2009 Bentley manual DVD-ROM
- Name That Part! Hood Joint Cover Edition
- Amber lights that come on with the HIDS?
- Catalytic converter replacement
- Aircon button
- A8 sat nav
- Front floor mats
- New rear floor mats - black - $49
- A8 2007 and up tiimng chain issue
- Advice on changing exhaust manfold gaskets 4.0 tdi
- Battery replacement with Duralast H-8 AGM
- Please S8 owners can you suggest Ceramic Brand Brake pads?
- Looking for front license plate holder
- RPM needle bounce
- HID headlight going yellow
- Anyone bought rotors from BrakePerformance??
- here's a first....a D3 stretch limousine !
- Arnott Intros Reman Rear Air Struts for '02-'09 A8 with Normal and Sport Suspension
