- Audi A8L Gearbox Harsh change.
- WWYD? ( What Would You Do?)
- 2003 Audi A8 4.2 cold start rattle
- W12 Emblem on rear door
- car level and headlight range lights warning on
- front bumper swap
- AMI Questions
- Passenger door not opening from outside
- Rear Licence Plate light housing
- Power steering rack replacement
- mObridge M2 Pro MOST on a 2005 A8 ?????
- Coolant tank replacement
- Camshaft position sensor:
- Need new tail lights. Best and cheapest place to get them?
- MMI phone mute issues
- Buying an S8 - general tips, Torsen binding and CEL?
- Driver camshaft tensioner
- Is it time to trade in my 2007 A8L and get what?
- trunk issues
- A8 Navigation control module
- A rare sight these days
- New Battery bem code
- Hood latch/hook
- Front licenses plate bracket trade?
- Is There Truly No Way to Adapt MP3 Player to the Blutooth/Cell Phone Dock?
- OEM Valve Stems:
- replacing "level sensor"
- 250,000 miles? - S8 v. A8 V. E500
- Running lights
- Gruven Parts
- should i replace my timing belt? PLEASE HELP
- going up in sidewall height?
- My route and observation on our trunk issues.
- rain sensor - how to disassemble - 2006 D3
- 2008 audi a8 4.2L quattro coolant issues
- Is It Time To Sell?
- Issue with blower on my Audi A8
- Ami music port - not working? What am I doing wrong?
- Parking Brake Light Error
- !NEW AUDIWORLD EXCLUSIVE PROMO!
- A8L D3 Rain Sensor Error
- Another Noise Mystery
- Adjusting Headlight Aim
- Found A Nice Car Cover... Inexpensive and functional
- d3 s8-alternator belt change?
- A8 P0441
- Many many thanks
- 4.2 died on me. Seems like no fuel
- Need Help MMI not working
- A8 RF air suspension leak
- Don't give me any lip
- All set to share ingenious tip but...
- Can't start abs pump bleed procedure
- Voice control of AMI - MMI 2g
- Abs control module coding
- Steering wheel heat malfunction
- audi a8 2006 valvotrain
- Timing via Vag-Com
- Best place to sell a low mileage clean a8?
- 2004 Auxiliary Ventilation?
- all SW controls and all stalk controls non-op
- Picked up my 2008 Audi S8 in Metallic Gray w/ kevlar interior and black seats
- MMI Help Please!!
- Hood cable came off at the latch passanger side!!! What to do now?
- s8 oil consumption
- Headlight
- Waht does a bad PCv value sound like?
- Serpentine belt
- Fidelity warranty - anyone have a hook up on these?
- 2001 S8 AC not blowing hard
- MMI Not Working
- Hood Cable Snapped- 07 A8L D3
- S8 exhaust on A8L Success! Need Flap Actuator Vacuum Advice.
- Exterior door handle button
- General suspension Q
- ACC wire location in the trunk
- Initial Maintenance on a used A8L W12 2005
- FM Station programming
- New to us 08 D3 S8 in Ice Silver
- interior door handles
- Correct pinch bolt?
- Recourse For Shop Breaking Parts
- Trunk issue
- New key and programming
- Gas Pedal Slack
- Correct tire setup for W12 20inch wheel?
- kutafec video in adapter for tv tuner
- Risk Factor of upgrading from 4140 to 4160?
- Does Manually Operating the Power Trunk Damage its Motor?
- SiruisXm
- Intermittent "Parking Brake!" warning
- Radiator Fan Relay
- Loose lower grill
- Side Maker Light Stuck On - 2006 A8
- 2008 Audi A8 Information
- RMT Air suspension leaks again.....
- For Sale
- Correct battery
- fuel door and trunk motor stopped working
- Crankcase vent valve
- Anyone know of any inexpensive vacuum solenoid?
- Electronic Brake Question
- Leather seat wear/repair
- Real time help, stuck at work.
- Need some information and assistance about headlamps
- P0012 code after valve cover gasket replacement
- Rear footwell heaters
- It's time to say goodbye
- Opinions needed
- She's Gone!
- Persistent Air Suspension Codes
- Trunk Release Issues / Motorization
- oil filter cartridge cap
- Picked up a new D3!
- Parking Brake Lever Snapped Off
- Is this a good deal? What should I expect?
- W12 issues
- Winter Tires
- Apprehension buying at 150K miles??
- Motor flap for drivers side body vent:
- Front camber issue
- 2007 S8 Oil leak (camshaft solenoid)
- Browsing Audiworld
- Windscreen Washer Bottle Replacement?
- Euro Front Plate: Bracket or No
- What the fark size exhaust clamps on the rear section?
- I need a magnetic transmission gate for the shifter
- Stream Music / 2006
- Would like to add FBAS (Paging those who have)
- UTAH Audi Help
- I'd like to find a Drivers Side Aspheric (Wide Angle) Mirror...
- Could someone test the BLU Vivo 5 Phone on the Bluetooth for me?
- VAGCOM Scan Results / Secondary Air Pump
- Air suspension
- 2005 A8 D3 - it all started with a timing belt replacement
- New Air Filter. Reset ECU?
- Video clip of my Magnaflow Mufflers
- Damn floor mats
- Rear door window screen - where to buy replacement?
- How Do I Replace a Battery Management Module
- Sunroof
- Want to Install S8 Exhaust on A8L. S8 exhaust info needed
- Bluetooth
- TIRE PRESSURE MONITORING FAULT
- Throttle Body G188 Sensor
- Fuel pressure
- Warning - RainX Washer Fluid
- Backup sensor "brain" and MMI gear replacement questions.
- 4.2 liter 8 cylinder gushing oil out of drivers side of engine.
- Fuel supply problems - D3 4.2 FSi V8
- My minimum Oil light came on on my 2004 AUdi A8 4.2l
- How many miles on your 8?
- Throttle body problem? Hunting/surging
- transmission failure
- Mixing struts?
- need vag help from my fellow a8 lovers
- 2008 A8L Battery replacement:
- Soft close - slamming door
- RSE retrofit: need a +12V signal in sync with the MOST ring
- I hear water in my face vent!
- 3 spoke multifunction steering wheel with shift paddles
- 2006 A8 water in vents
- Intermittent AC Issue
- Anyone looking to sell their D3 S8?
- OAT sensor
- Rapid clicking from steering column upon entry to s8
- Ok the on going saga with my fuel issue ......
- Help Wanted: Issues after VCDS scan
- Maybe a dumb question
- Noise Coming From Back of Air Intake
- Vanity Plate Opinions Pls
- Interior LED Kit + Exterior LEDs-Error Free-Lifetime Warranty-Free shipping
- "audio pilot" works backwards (2004 D3)
- Keyles entry and shut off?
- NOT DEAD YET
- Air struts and control arms
- S8 Inlet manifold flaps inspection
- Valve Train/ Head noise
- BIRTHDAY SALE!
- Air box question
- The case against NEW Arnott struts?
- strange sat nav issue, any help appreciated
- Are these buttons supposed to light up?
- 09 A8 changes gears wierdly
- Stripped belt tensioner
- Got Another D3; Sage Green - Am I Insane?
- Who DD's their S8, highest miles? Share your experience
- Miessler Air Compressors
- Help with Leveling Suspension
- Question about Address 07:Control Head coding
- Cant Code Battery after Flat Battery
- Good sunglass holder
- GOING, GOING,GON
- S8 Project Update, only a few faults now, air compressor still will not turn on
- A8 Quattro 4.2 V8 (2005) Transmission Oil
- 05 D3 4.2 secondary air Monitor not set. Need SMOG
- 2004 A8L Pricing Advice (looking at the car tomorrow!!!)
- Door Handle alarm that alerts you to someone attempting to open your Audi
- Auxiliary Fuse block install (w/ Blue Sea Systems Fuse block)
- Suspension noise
- paging The_Duke: H-E-L-P !!
- Battery Flat - how long before electrics come back to life
- S8 Trunk Cargo Net as a gift
- Audi A8 D3 2008 - Lights
- MP3 CD Changer Capabilities
- 2005 A8L VCDS Scan with Error Codes
- Going from 2005 A8L to 2007 A8L
- 2005 A8L MMI Issue - non-responding/flashing
- need VIN history report
- Please Please Help I am frustrated
- Secondary Air Injection Pump
- New Ball Joint Boots Splitting
- Sunroof glass recall FYI
- Upper control arms with letter E and F?
- Took the car to dealer for service and they updated the MMI?
- SAI question
- Bovee Bluetooth for iPhone on S8
- A/C Heat Exchange unit leaking water
- Noice when coming to a stop...
- D3 or D4?
- Temp digits are polarized
- Analog TV tuner replaced with Hybrid TV tuner - probems with the MOST ring after that
- Dashboard Lights behaving strangely
- Where to buy the upper control arms
- Advise on buying an A8L 4.2 V8
- D3 S8 Steering Pump Replacement
- Removing Window regulator : front Driver side
- A/C Blower not Working
- My audi is gone :'(
- Where do I place Axle Stands
- DVD changer
- Fuse for Sunroof
- audi s8 2007 doesnt start sometimes
- HPFP update
- Driver seat controls
- P0300 and P0301
- Headlight upgrades
- Amplifier radio tuner carrier plate removal
- ABS, ESP and Parking Brake lights on dash.
- Dash showing only KM and not switching to miles
- Fuel/Trunk buttons
- Wheel bolts
- Injector Supply Voltage
- Timing belt replacement tomorrow...
- Help to connect battery charger
- Any way to bypass Key recognition?
- MMI screen, how to..
- Car Shakes during accelerations, stops and idling
- Squeal during harder acceleration (transmission?)
- Console by gear shifter light wont turn off! Help!
