PDA
View Full Version : A8 / S8 (D3 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
  1. Need Help on Suspension - Thoughts?
  2. ABS module changing does it need programming
  3. question about soft close
  4. This is the beast I just got
  5. Air pumping and hissing noise on '07 S8
  6. Foreign Leaders, Corruption, and the Audi A8
  7. chrome window trim-where to buy
  8. HELP! Rear passenger side leak
  9. know part #s needed for softclose retro-fit ?
  10. Did it! Bought the 2007 S8 and the wife did not kill me!
  11. Taillights
  12. Radio Code
  13. 2007 S8 Production Numbers
  14. Anyone have thoughts on a D3 Buyers Checklist?
  15. CD PLAYER REMOVAL
  16. Key battery low
  17. Musty A/C Smell Fix
  18. Autoweek article on 2016 A6/S6 midlife update; I think it gives some D5 clues
  19. MMI FAULT
  20. 2005 Audi A8 base
  21. 2006 AUDI A8L ... PO221.... EPC / CEL / .. HELP PLS
  22. Do I just have a wide foot or...
  23. Can’t get a D3 S8 out of my mind…
  24. The carbon problem - just a question
  25. The 2003-2004 A8
  26. Cable in the rear armrest
  27. Can the clock be reset using VAG? My car button broke.
  28. A8 and S8 Upper Control Arm Bushings--Part #'s/Differences
  29. New S8 Owner, Need Diagnostic Help
  30. Need a local Audi-er
  31. Heating (HVAC)
  32. Installing USB charging ports in a D3
  33. Close to buying my first 2008 A8 L
  34. recent gearbox oil change concerns
  35. Interesting "Cars of the Future" article
  36. Lighting / Grounding / Brake Alarm Issue
  37. Timing belt - after 10 years 75k miles
  38. 2005 Audi A8 Base
  39. 2008 Wooden Steering wheel and gear knob
  40. Running costs on 2006/2007 A8?
  41. Why the reluctance to do software updates?
  42. You know, my compressor sounds pretty strong so I'm wondering
  43. Steering Wheel / shifter compatability
  44. Found a 2007 S8 and thinking of buying it
  45. Tire troubles: Will going with a bigger tires cause problems?
  46. going to start with suspension air compressor repair kit
  47. Loose Cam Shaft Chain
  48. Interior dome light stay dimly lit
  49. Need some advice
  50. Grille R&R ?
  51. Removing back seat on an S8?
  52. 2004 A*L Relay location for air compressor ???
  53. leak in suspension : PArt 2
  54. "Leak in System Detected": Suspension
  55. My A8L Build
  56. Radiator fans running at high speed
  57. Rear License Plate Brackets
  58. NEW 06 A8L OWNER
  59. RWD.
  60. Direct to 4610, AMI, Onstar-Bluetooth swap-Parrot aftermarket Bluetooth, or?
  61. A8 D3 2004 in UK Found a non Audi Gizmo
  62. Disc Brake Rotor Clean Up – How To
  63. Trunk Cargo Net
  64. Xenon light on one side is no longer working
  65. Parking brake malfunction lights, parking brake light, and (p) brake blinking
  66. Metal noise from front end when turning at slow speeds
  67. Difference between 2006-2007 A8?
  68. Reason # ___ why D4 is looking doubtful. Control arm bushings...
  69. New A8 owner
  70. Interior Trim Restoration
  71. 2006 Audi A8 3.2L V6 Petrol FWD
  72. Side marker delete - with pics
  73. My Baby.......
  74. Alarm is working but the sound is missing?
  75. Rear Light Control (Interior)
  76. Upgrade/ Enhancement :cool:
  77. need abs wiring help for 05 A8L
  78. Audi A8 D3 Trunk / boot motor fix - sanding disc
  79. 2007 S8 brake caliper customization (powdercoat, pads, seals, etc....)
  80. any experience with high carbon or cryo rotors ?
  81. Heads Up Display
  82. Changing horns
  83. BI Xenon Bulbs/ Repair Shops/ Stealership
  84. D3 S8 Uneven wear on front right tire
  85. Yes! It's official. New W12 in the family...
  86. 2008 S8 Rear main seal leak?
  87. Dealer wants $910 to replace
  88. Axle Bolt hex bit size and triple square size??
  89. Gear Selector
  90. TPMS effected by Rain?
  91. W12 engine option cost...
  92. Need advice on brake pads...
  93. All door handle locks stopped working - help requested
  94. Rear Hvac dosent blow warm air
  95. Air suspension troubleshooting and misc
  96. 2007 Audi A8 driver side power seat malfunction
  97. 05 A8 Transmission
  98. 2006 Audi A8 4.2 TDI - S8 front retrofit/conversion - PLEASE HELP
  99. 10 A8L side mirrors and 05 A8L
  100. Has this ever happened to you?
  101. Maybe I'm back to the D5 wait, or D4 change in motor choice, or...Tesla :/
  102. Audi emblem fell off engine shroud
  103. air compressor or strut ?
  104. Potentially my Fourth Audi, but the first A8
  105. Turn Signal Stalk Replacement Tutorial (pics included)
  106. Locking and Compressor Life
  107. New owner of a 2004 Audi A8L
  108. My car's honking, and it aint the horn.
  109. Recording S8 exhaust notes + custom windsock fabrication
  110. What steering wheel is this?
  111. For those who wish to upgrade thier puddle/trunk/glove box lights
  112. Alignment issues
  113. fog light trim piece loose
  114. New Member Winter Wheels for 2004 Audi A8L
  115. Euro trailer hit installation on an S8... trunk holes are filled in??
  116. Minor annoyances with my '07 A8
  117. So I replaced the parking brake motor
  118. '05 A8L, 115K miles, $2K bodywork worth it? Pics included
  119. Steering Wheel Column Removal
  120. Interesting reading
  121. Trunk malfunction
  122. Selling 4 Used 18x8 RS6 Replicas with Dunlop Winter Sport M3 tires mounted.
  123. 2006 Audi A8
  124. electronics board under council
  125. Vag-com in Michigan
  126. 2007 & 2008 S8 air box difference
  127. air compressor smh
  128. Replacing right rear parking brake motor only
  129. I have the hoot! But wait, it's not the hoot...
  130. Rear brake light issue
  131. something odd with function of parking brake
  132. VAG COM scanner help in lower NY?
  133. Upsizing brakes
  134. Cold transmission issues
  135. vacuum house whistle?
  136. check engine light
  137. Converted to coil springs
  138. "The Quattro Groan" Grinding, Binding, Rubbing from S8 front end
  139. lower radiator hose
  140. No heat!
  141. Starting Hot - 4.0TDi - Update
  142. Coolant and Cam Sensors 4.0TDi
  143. Door Lock (Alarm) Beep is AWOL
  144. "New" '08 A8...
  145. Changing wheels and tires on my A8L
  146. soft close door trouble shooting...
  147. Paddle Shifters
  148. Brake fluid level warning light - intermittent
  149. 2007 A8 right side vents blow scolding hot
  150. Leather covered oh $hit handles
  151. Audi A8 4.2 TDI - S8 front retrofit
  152. Anyone here got a Bluetooth OBD adapter?
  153. window tint
  154. after 10 years...new wheels !
  155. Gauges not working
  156. I think I heard a "Woot" today from accelerating
  157. WTB A8 6.0 W12 Need Some Help Please
  158. Lower rear control arms (front wheels)
  159. 05 A8
  160. Air Suspension Compressor Rebuild Kit Available
  161. European plate bracket?
  162. Can D4 wheels accommodate D3 TPMS sensors?
  163. Soft-touch close dying
  164. Exhaust options for A8??????????
  165. can i fix this under part of the audi s8?
  166. Lowering links mistake
  167. 2006 needing timing belt change
  168. Evap issue - any common fault areas?
  169. Suspension stuck in Dynamic Mode, HELP!
  170. A8 D3 keys locked in ignition and battery flat dead / ignition unlock wont work
  171. D3 2003 4.2 Introduction and some (retrofit) questions
  172. Moving Sale - Help us move out - Detailer's Domain
  173. BLAQUE DIAMOND WHEELS | BMW Gran Coupe fitted with 22" BD-1
  174. Low fuel warning
  175. Starting Hot - 4.0TDi
  176. Cursed "guide Link" (Rear LCA) / knuckle sleeves!
  177. Audi A8 power issue with coils
  178. Used D3s / Questions
  179. Audi S-Line pedals for my S8
  180. Jack Mode without MMI?
  181. battery wont hold charge when locked
  182. 2004 Audi A8 23k miles
  183. Nice D3 for cash-strapped enthusiast...
  184. 2007 A8 won't start
  185. WTB: Full size spare
  186. Auto Headlights Coding Help
  187. Thoughts on the 2014 D4 A8 with V6 turbo diesel
  188. hello to ewery one
  189. Upgrate tail lights problem ?? Can any one help ?
  190. Calling for Jakematic... Input please
  191. It took me more than 4 month to complete my carbon fiber trim !
  192. 05 Audi a8 mods
  193. Under-engine sound insulation retention pins
  194. Unlocking DVD Player
  195. AMI part # ?
  196. A8 Facebook page
  197. Anybody know how to turn off TPMS on 2007 A8?
  198. Headlight Help please
  199. Buyer Beware: OEM Plus parts
  200. Axle or something else?
  201. sound system upgrade?
  202. Got to drive a Murciélago!
  203. GPS date/time
  204. :: ECS Tuning :: NEW!! D3 Schwaben 6-Point Oil Filter Socket
  205. S8 V10 Engine badge
  206. Used 2008 S8
  207. Airbag swap?
  208. 2005 A8 - replaced battery - keys not recognized
  209. 2007 A8 130,000 mile service list
  210. Slow Squeeling noise
  211. Spare wheel
  212. 2004 audi a8 suspension conversion thread
  213. foggy headlights
  214. occasional noise after I shut my car off
  215. Vag-com version for 2007 S8 D3
  216. P0491 & P0492 on d3 a8l
  217. Wanted D3 S8 ACC Instrument Cluster.
  218. 04 A8 Good Buy?
  219. A few more questions...
  220. Can 2013 S6 front brake rotor&caliper fit on my 2005 A8 ?
  221. AMI Alternative .. The route I took
  222. Newbie Question. MMI version
  223. A8 D3 - Major retrofit
  224. New Owner '06 A8L possibly 1 out of 1 in US?
  225. 2006 A8L headlamps covers
  226. Voice Recognition & Special Destinations (2G MMI)
  227. Removing trim in ceiling, rear window.
  228. Am I an idiot? Sunroof/Moonroof glass
  229. Cup holder solution
  230. Fluid change in differentials
  231. iPhone issue
  232. Need help to ID seat trim part number
  233. 4 spoke heated MFSW w/shift paddles...
  234. Air Suspension nightmare
  235. Trunk Lid Tool Kit - Anyone improve it? Add To or upgrade the tools?
  236. Start-Up / Cranking
  237. Anybody with a D3 in the Phoenix area?
  238. Considering an A8
  239. rear Sunshade
  240. $10discount on Mobil 1 oil
  241. Aluminum pedal upgrade?
  242. Fuel Door Open Light
  243. APR - ECU software upgrade
  244. Problems after mmi update
  245. New owner 2006 4.2
  246. transmission troubles
  247. Replacing Suspension Control Module
  248. Does anyone know how to...
  249. 2009/2010 nav road map?
  250. MMI dead on Audi A8 2005
