PDA
View Full Version : A8 / S8 (D3 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 [33] 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
  1. I need name of good indie shop in Nashville
  2. so my d3 caught fire yesterday.
  3. Memorial Day Special @ Detailer's Domain - Stock up on your detailing gear!
  4. Don Nguyen | Norcal / Bay Area Vinyl Wrapping Tour - June 16th - 20th 2014
  5. Close Trunk With Remote Experiment
  6. Let's see pics of different wheels
  7. Audi A8L Accuair suspension build
  8. had a warranty from Mercury Co. ?
  9. New owner needs two things.....
  10. Air Suspension question
  11. another possible new owner thread
  12. VagCom help in Louisville, KY
  13. AUDI A8 D3 4.2 V8 BFM. CAR SWITCHED OFF WHILE DRIVING .
  14. S8 Anti- Sway Bars for 2005 A8
  15. I need a driver's side outer tail light...
  16. 2006 A8 cigarette lighters, cup holder lights and vent lights not working
  17. Is there no fuel pressure sensor?
  18. Auto open trunk doesn't always work, intermittent problem.
  19. Multifunction Steering Wheel not working
  20. New D3 owner
  21. AC Blows Cold in Center, Warm on outer
  22. Taking a look at an 07 A8L....anything I should look for?
  23. Kick to open trunk lid - Summer Project
  24. 4.2L multiple error codes
  25. What We Need is for VCDS to Display On MMI Screen!
  26. Battery Issue
  27. Steering Wheel Illumination
  28. Audio 'crackle'
  29. Valve noise x post
  30. Screen Between Tach and Speedo Inop
  31. How I Replaced Rear EPB Brake Pads On My 06 A8L
  32. ami retro fit...how to split fiber optic cable ?
  33. 17536 & 17538 (P1130 P1128) too lean (multi) persist
  34. 2006 a8 oil cooler
  35. So how many of you are thinking about D4?
  36. The rear pads are almost to the metal and the warning
  37. How the HELL do you get the intake hose off the throttle body?
  38. Diesel Particulate filter sensor
  39. Soft-Close Trunk; Literally a Ten- Minute Fix! (Thanks Mishar)
  40. question, Temperature SENDER and SENSOR
  41. Rear Courtesy Lights Stuck On
  42. MIL Light On
  43. 2 fixes I did, and saved $2000 for $7 fix !
  44. suspension pump question...
  45. Drive A Super Car On A Racetrack In The Dallas/Fort. Worth Area May 31st & June 1st!
  46. Cupholder and ashtray dampers
  47. Engine died after starting
  48. About to buy another D3....Need a little advice.
  49. Low note Horn
  50. Cleaners???
  51. Only showing two codes
  52. BLAQUE DIAMOND WHEELS || Audi A7 with BD-5
  53. Audi Repair in Northern Virginia
  54. OTHER things I found with W12 plug change/103K miles
  55. W12 cam positioning sensors; identical Bosch OES part
  56. Getting the right O2 sensors in Bosch for a lot fewer $; plus W12 #'s
  57. Cup holder tidbit.
  58. Why are we here? A8 D3 Forum
  59. MMI Not Functioning - Sunroof Leaked!
  60. Burned out Xenon bulb
  61. p2015 & p2020
  62. Front Sway Bar Bushings???
  63. Right fog light not working
  64. Headlight retrofit
  65. BLAQUE DIAMOND WHEELS || 2013 A5 on BD-4's
  66. Brake light problem
  67. Campaign 28FZ (2010); and coil pack recall sticker?
  68. Changing out Solar Sunroof to Non Solar Sunroof
  69. 2007 S8 passenger door soft close feature dead
  70. Leaky Sunroof + Blocked Drains = Sunroof and MMI Controls taking a shower
  71. 19" Sport Package Wheel Center Cap 4E0601165-A
  72. Five DTCs; could it be a bad connector?
  73. Found some good H7 LEDS and here they are
  74. Oil Leak on 2007 fsi
  75. How to get to clock spring?
  76. looking to move out of my 2002 S8
  77. How cool is this..
  78. Sport Suspension
  79. 05 A8 Oil in Coolant tank HELP!
  80. 2003 S8 Take the plunge or walk away
  81. What trends do you hope Audi will defy?
  82. How much has VAG-COM saved you?
  83. Why can't I recode my TPMS module?
  84. Please Check Navigation DVD...
  85. Car on the ground
  86. Wiper Failure
  87. BLAQUE DIAMOND WHEELS || New 2014 Collection
  88. Bulb access
  89. W12 (or other) owners doing plug changes--anyone found valve cover erosion?
  90. Upgrade from 2006 A8 to 2007 S8?
  91. **Don Nguyen | Gloss Black Vinyl Roof Installed - White Audi RS7 Sedan**
  92. Long crank, EPC and CEL, rough idle and surging
  93. TPMS Failure?
  94. Charger cable routing
  95. Autel VAG505
  96. Front brake job cost?
  97. **Don Nguyen | 3M Dinoc Matte Carbon Fiber - Wrapped Interior Trim**
  98. 06 A8 random electric issues
  99. MY2004 4.2 Suspension Fault
  100. D3 camshaft position sensor location
  101. A8 / S8 Rear glass / window
  102. Most Outrageous A8 part Cost I've seen! (Scary, but good for a laugh)
  103. Is it time for new TPMS sensors?
  104. True cost to own a 07-08 D3?
  105. Pricing Question
  106. Has anyone tried Unitronic ECU Tuning
  107. Farewell to the S8
  108. Lights don't turn off
  109. Parking Brake Failure?
  110. AC Not Working - But Compressor is On
  111. Can't post replies
  112. OK what just happened?.......
  113. Interior Access/Start Authorization Antenna 1 (R138)
  114. Inner Bulbs not working on 05 A8L
  115. Interested in joining the D3 club
  116. Timing Belt Replacement
  117. Coolant in wire harness
  118. Did your teacher ever call you "different"?
  119. Halfway done with the dash swap... phew!
  120. VAG lowering...want to put it back to OEM...
  121. Replacing Front Parktronic Speaker
  122. Back into another Audi
  123. Fault Code 00142 - Left Front Dampening Adjustment Valve (N336)
  124. 06 a8l rear end swerving
  125. 2006 A8 L P0221 code
  126. AMI TO IPOD???
  127. 2005 4.2L Radiator
  128. One more part: does anyone need a front left S8 shock core?
  129. Transmission in emergency mode / Tip-tronic issue.
  130. Leaving the fold - thanks for all the knowledge
  131. Leaky front strut or electric issue, VCDS codes suggest latter?
  132. Anyone looking for a set of S8 upper control arms?
  133. Switched power lead near glovebox?
  134. Advice needed on wax and polish...
  135. Rear brake pad replacement
  136. Suspension troubleshooting - another
  137. Spare Tire
  138. D4 (2010) 4.2 tdi turbos usable in 2006 D3 4.2 tdi?
  139. Looking for a plastic belly pan
  140. $10 pay pal reward for 1st correct diagnosis…….
  141. Sway Bars...
  142. A8 D3 valve cover removal: Help
  143. Question: '07 A8L Battery not getting recharged .........
  144. A8 d3 air suspension pump keeps running
  145. Is this safe?
  146. Matching spare tire
  147. 2007 Audi A8 4.2 TDI VS 2007 Audi S8!
  148. Softer than Comfort
  149. Air suspension relay location verification please.
  150. interior detailing - cleaning leather
  151. Right side Axle!!!!!
  152. MMI getting buggy 2007 A8L 85K miles
  153. Sirius radio and MMI question.
  154. 2007 Inner/Outer Tie Rod Replacement
  155. MMI 3G, Needle sweep question 09 A8L
  156. How do you turn the TPMS off!!!!
  157. TPMS and software update
  158. Silver Car Detail?
  159. Locking bolt removal and access issue/question
  160. FSI vs non-FSI 4.2L engines
  161. Audi W12 Exhaust tip & bumper
  162. Shudder Bounce in D
  163. CD Load times
  164. cd changer upgrage possible ?
  165. A8L Rain Sensing Wipers Actually Work...
  166. MMI optical issue or electrical?
  167. B&O pop up tweeter speaker size ?
  168. Whaat? My Bentley Manual updates expire in 77 days?!
  169. Are there two versions of the upper control arms?
  170. So which remanufactured S8 shock provider to go with?
  171. how to fix you 2g MMI / easy fix
  172. 2004 A8L Sway/Stabilizer bar ?
  173. 2007 A8 Front End Collision
  174. Reset air suspension after sitting for a while?
  175. For a limited time Sonax Full Effect Wheel Cleaner 500 ml - $12.95!
  176. Solved my starting problem and you wont believe the answer!
  177. What is that noise in left front wheel well?
  178. lowering links ?
  179. concerns and question before purchasing 2006 a8 L
  180. Remote windows no longer work, but are programmed to.
  181. Overhead sunroof panel doesnt back light/auto headlights do not work.
  182. Good Mechanic in North NJ?
  183. Suspension noise
  184. Help me pick a wheel fellas?
  185. Power Trunk Lower Latch Issue
  186. Stash Your Valuables In The Ski Sack!
  187. A8 D3 - Urgent help required as garage is full of S**t
  188. Question on Osram XENARC COOL BLUE INTENSE bulb colors.
  189. Change Navigation default start screen
  190. A8 will crank but wont start after sitting for few hours
  191. Turn assist light bulb part number
  192. Subwoofer in the A8 opinions
  193. car no longer responds to key remote...
  194. The chrome trim is a thing of the past!!
  195. Status: Cannot be reached 1100 errors
  196. Air Suspension and Extended Warranty
  197. To X-Pipe or not
  198. keyes audi van nuys
  199. Need help replacing voice command module
  200. Peeling/bubbled buttons
  201. Tire Time
  202. Has anyone had clicking noises from front wheels parking/driving slowly? (NOT CV 's)
  203. New CD Changer installed, sound pulsating (cutting out)
  204. Headlight bulb or something else?
  205. What Would You Drive?
  206. 2013/2014 NAVI DISC UPGRADED
  207. No sound issues
  208. ugh air suspension problem...
  209. I'm having custom wheels cut, help me pick the perfect offset?
  210. Solve this A8L wont start mystery please.....
  211. Gear Box Leak
  212. Bicycle in trunk?
  213. Advance Key Issue
  214. Fog light grill, heated wheel & tires advice?
  215. VCSD lowered members question
  216. Upper control arm pinch bolt advice
  217. ac evaporator
  218. Weird issues with the drivetrain - D3 3.7 Quattro
  219. Spark Plug Change; anything else I should buy?
  220. Does anyone know how to remove the side moldings and bumper strips?
  221. Saw the strangest thing on MMI screen just for a second...
  222. air suspension problems !
  223. did read the post above
  224. P1136 & P1138 CEL ON - Vag Com Screenshots - Possible O2 sensors? Failed Block 107
  225. Question about trunk release button on Drivers door
  226. Hofele Performance Chip
  227. Drive Your Dream Super Car At NCCAR March 27-30th
  228. EBC Redstuff DP31535C - Wear sensor, yes or no??
  229. Auto Dimming Mirrors
  230. 2007-08 S8 Buying Advice
  231. Key stuck in Ignition
  232. Spring Therapy @ DetailersDomain.com - 15% off and shipping promos
  233. Vibration and noise when braking below 40 MPH
  234. Different Headlight Types
  235. Rain sensing wipers
  236. Drained battery = no backup cam
  237. My Oil Change On 2006 A8L @ 89k Miles
  238. Parking Aid Problem
  239. EBC Red Stuff etc. brake pads - discount
  240. Bi-Xenon Help PLEASE!!!
  241. Rear motor noise and fuses
  242. Can anyone help me out with dash removal instructions?
  243. Anyone know how to remove rear cupholder for cleaning?
  244. Sunvisor / sun visor is quite hard to move
  245. Strange Things I Have Found
  246. 2008 Audi A8L Daytime running light bulb 7506LL or 7560ST
  247. Has anyone done this chip upgrade here?
  248. VCDS says fuel trim too lean x2
  249. i get my car back, finally
  250. Fault code on Address 05
