PDA
View Full Version : A8 / S8 (D3 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
  1. moved from my 2004 t0 a 2011
  2. Finished Replacing Air Struts! Compressor Questions....
  3. Opening up the W12 for a Coolant Sensor Need some Ideas
  4. 19" Sport package wheel width and snows
  5. Timing belt time
  6. Few questions on rear sub and instrument cluster
  7. Do I have Bluetooth? my iPhone doesn't get signal
  8. 2006 A8L 4.2 - Won't Start
  9. Umbrella holder in trunk?
  10. What are your thoughts on this S8?
  11. Intake "Damper Pan"
  12. Lug bolt broke off in rotor....
  13. Audi S8 Reliability
  14. fast discharging battery
  15. No Key Identified
  16. I know it's not an A8 but, this is what I have been up to !!
  17. Transitioning from 19" to 17" Wheels
  18. Replacing Front Air Struts
  19. P0171
  20. Bad ground somewhere
  21. Shifter cover plate
  22. Door handle replacement?
  23. Multiple Air Suspension Questions
  24. :LOST: Where Is There To Go After Driving An Audi A8 for years...
  25. Suspension Squeek
  26. Audiworld is the Best!
  27. Disable Air Suspension To Prevent Yellow/Green Error Lights
  28. Front speakers cuts/dies when turning up
  29. Concerning Engine Codes
  30. '04 A8 Valve Cover job... then CEL (P1340-001)
  31. :: ECS Tuning :: 50% OFF CYBER MONDAY ONLY! Audi Ziza Master LED Kits
  32. Dual pane glass
  33. PLEASE HELP A8 electrical issue
  34. 2010 D3 A8L Wheels
  35. Food For Thought
  36. AudiUSAParts - Free Shipping
  37. Happy Thanksgiving!
  38. Someone talk me Doc out of buying a 911 (we're famous)
  39. Which TPMS for 17" rims?
  40. Black Friday/ Cyber Monday deals from Car Parts Discount
  41. need an AMI unit?
  42. :: ECS Tuning :: 11th Annual Customer Appreciation Sale|Save up to 25%!!!!!!!
  43. Why so much issues with this???
  44. Has anyone replaced sunroof drain hose ?
  45. still no heat...would this idea work for test ?
  46. updated MMI and lost bluetooth?!?!
  47. Differences between an 08' and 09' S8?
  48. Window buttons problem
  49. Excessive inside front tire wear
  50. Found Possible Cause of Lean Code
  51. Green Suspension Light Question
  52. Where is the Water Coolant Sensor?
  53. Wipers Coding
  54. Original Battery replaced at 187k miles with walmart battery
  55. MMI Battery level indicator
  56. battery and VCDS?
  57. Flauta's objections with my choice of an S8
  58. A7 vs A8 (someone talk me out of it :)
  59. Climatronic
  60. Electrical Problems, Windows/Mirrors/Signals/Tail lights, Headlight
  61. Help with MMI Issues
  62. Sun roof maintenance
  63. Car Stuttering After Routine Maintenance
  64. New Owner
  65. Flat Battery, no sleep mode
  66. online coding and component protection
  67. A8 D3 04. MMI and NAV update...
  68. advice needed on air suspension failure
  69. Differences in D3 emissions from state to state?
  70. 2006 A8 or 2008 A8
  71. start access
  72. All Season Tires
  73. Old "Beater" A8's - what is the actual TCO (cost of ownership)
  74. Where to put axle stands at the front
  75. Suspension strut or level control
  76. Help with Boost Sensor Code P0236
  77. Age of Battery?
  78. Higher revs and slight power loss
  79. Are All Audi AMI Compatible?
  80. What is this clip?
  81. Telephone issue - Reading SIM card
  82. Coolant leak - unidentified
  83. Upgrade 06 A8 instrument cluster lcd to 07 & up larger screen
  84. Search narrowed: D3 S8 it is!
  85. Front End Rattle - 2007 A8L
  86. Google maps navigation program
  87. Google Maps, Pandora, Torque OBD, & more without taping the smartphone to the screen!
  88. Anyone in CT or NE area with VAG-COM??
  89. 2005 A8 cooling fan will not shut off
  90. Radio forgetting memory presets
  91. Just sold my D3 S8 ... goodies for scavengers
  92. Parking Lights and Lowbeams
  93. Did I win??? VIN codes decoder needed
  94. Going to pick up my 2011 A8L 4.2 I have a few questions!!!
  95. Washing your car
  96. Parking light bulb blue tint
  97. inner tail light fix (water damaged)
  98. left inner tail lights
  99. Option code sticker
  100. Brake Supplier
  101. keyless start
  102. New to Audi
  103. Any one updated their sound system???
  104. Swapping to a salvage yard motor
  105. Volume not working on MMI Control Panel
  106. Someone Talk me out of buying a 07 A8L
  107. What is wrong w/Canadians? A8 Photoshoot:
  108. Alternator Coolant Line Leak
  109. Silver "soft" dashboard trim piece
  110. Engine cranks, barely starts then immediately dies.
  111. FYI: I'm selling a euro tow hitch with the wiring kit
  112. Maybe some cheap deals on D4 TDi's coming up
  113. Plasti Dip wheels
  114. Wiper blade contacts A-Pillar
  115. Salt, magnesium chloride corrosion....
  116. One year with my 2007 D3
  117. First A8L purchase advice
  118. RevV Coilovers to replace stock air-Suspension
  119. HID Bulb and Ignitor melted
  120. Scratch removal and type of paint....
  121. Very cheap parts site
  122. Service indicator question...
  123. Bent Bang and Olufsen speaker cover
  124. Special promotion for Audi World Forum members
  125. My new toy
  126. Air suspension failure
  127. Bang & Olufsen radios
  128. Ceramic or Semi-Metallic Pads
  129. Adaptive Cruise Control & VCDS Fault Codes?
  130. 2005 A8 No Start
  131. 2004 a8 4.2 coolant leak
  132. Left rear caliper blown
  133. Fuel pressure woes
  134. Radio Reception after mmi update
  135. Oil Change..........I'm not happy
  136. Mirror Mystery
  137. Could this be why Audi uses plastic oil filter caps?
  138. 2007 S8 - Unable to "program" in fingerprints
  139. J519
  140. Forum group buy with Car Parts Discount
  141. problem programming car for new battery...
  142. Brake Pad
  143. Remove Shift Knob Internals
  144. Cover
  145. Drivers side rear tail light
  146. driver front door speaker sounds miserable
  147. The battery is dead; long live the battery !
  148. 2008 A8L 3.2 FSI Limp mode after new ECU change
  149. 0w-40 causing leak?
  150. New Owner. Thrilled. Question/problem re Adaptive Air Suspension
  151. 04 Audi beeping from engine compartment
  152. New Owner "A8 (L) Essentials MY 2004"
  153. Check Engine Light at high acceleration
  154. My first car
  155. Driver's Mirror - I need 3D glasses on??
  156. Radio volume decreases in gear
  157. Audi Parts Dealer and Bolt Size
  158. Faulty AC controller ("button").
  159. how to R&R side trim on front seat ?
  160. W12 front airspring ..sport or comfort ?
  161. w12 Rear Differential Service 100k
  162. Air struts limited warranty replacement
  163. paddle shifters-how?
  164. Floating cell phone mount (PIC Heavy)
  165. Kessy clone and swap
  166. how to R&R shift knob on an '04-07 A8 ?
  167. Trailer wiring harness. I'm lost!
  168. New Owner (2008 S8)
  169. Where exactly are the lift points ?
  170. 2007 D3 altinator
  171. ATF blue or Gold
  172. AC problem - works from time to time
  173. Oil residue on Left front lower cowling
  174. My S8 2008
  175. What else while intakes out?
  176. Shakedown Lap
  177. 2nd AMI with changer
  178. S8 Power steering Noise- FIXED
  179. Farewell Audi awesomeness (sorta), hello new German auto(likely)
  180. hood sensor location
  181. Help me decide : "comeback" to the A8?
  182. Knocking sound from back of the engine
  183. vacuum problem?
  184. New tires on the D3
  185. Fixed overflow tank inlet nipple
  186. is there a control module for the locking system
  187. Parking sensors issue
  188. Air suspension
  189. Massive Coolant Leak
  190. Rain/light sensor
  191. Double pane "security" glass retrofit?
  192. Best method to sell this beast?
  193. Rear Window Sunshade control module
  194. Enabling comfort open/close from key on 2007 A8L
  195. Non Resonated Stock Mufflers- No standing revs.
  196. Have to Remove Engine to replace PS hose?
  197. Need help. Who has VAG COM around central New Jersey. Will pay
  198. Air hose from pump to filter housing
  199. Popping/ Thumping Noise from Airbox
  200. Replaced my upper arms this weekend
  201. Very Interesting Exhaust Note
  202. Removal of Start Button housing help?
  203. 2008 A8 Camshaft sensor
  204. 2008 A8 MMI don't work
  205. Sluggish Performance Solved - Replaced Intake Manifold Links
  206. WTB: Rotors, Pads and lines 2008 W12
  207. Trunk Lid Spoiler
  208. Updating MMI issues
  209. OEM wheels to....>>
  210. Where is the ICM/POS on 2008 A8L 4.2?
  211. annoying message - the pin number has been entered
  212. S8 D3 Power steering whirring noise- Advice please
  213. 2009 A8L 4.2 Code P0011
  214. Arnott Intros New Front Air Struts for A8 (D3 Chassis)
  215. Audi A8 3.0TDI Quattro EGR/Smoking
  216. D3 A8 MMI "Car" Button Not Working
  217. I'm in!
  218. 2005 Audi A8L 4.2 V8 Quattro
  219. HELP!!! MMI Stuck in Bootloader Mode
  220. UPGRADED TAIL LIGHTS
  221. Suspension Compressor Wiring Question
  222. 2nd round of Mods
  223. Audi A8 MMi 2G to 3G Retrofit
  224. Slight coolant leak - need some advice
  225. 2004 Audi A8 Bluetooth Help...
  226. 2004 A8 brake pressure sensor wiring
  227. Help with a 2004 Audi A8 4.2L Issue
  228. Speakers sound blown out after battery re-connect
  229. A8
  230. Brand new A8 drives "darty."
  231. Brake Light warning
  232. A/C not working properly
  233. audi key set replacement questions. please help!!
  234. Took a little video today of the Milltek resonated exhaust - S8
  235. Florida Members October 8th-11th
  236. questions about improved ('08-up) trunk motor
  237. A question for fingerprint start.
  238. Time for a road trip
  239. microphone doesn't work
  240. Noise When Accelerating
  241. Exhaust System
  242. sweet smell in cabin
  243. Moody Turbo must be time of the month ;)
  244. Seat Module replaced - Coding ?
  245. Sunroof cover (inside) stuck way back and suggestions?
  246. Need help on buying my first Audi 2009 A8L
  247. Big Brother spying on my car? or yours?
  248. Ok Does anybody have these wheels on their D3 A8/S8?
  249. 2004 a8
  250. Camber Wear ??
