- 2004 a8
- Camber Wear ??
- Diagnosing possible wheel bearing problem
- W12 check engine light whoo hooo
- ATTN D3 A8 Owners:OEM AMI Bluetooth Adapters Located!
- First Experience with Audi Dealer Service Dept.
- New/First 2004 Audi A8L owner
- Any experience with 1A Auto parts.
- how many mm in dia are '04 rear rotors ?
- New/First Audi Owner
- An ounce of Pinch Bolt prevention
- Smaller wheels on S8
- How to remove 1156 DRL bulbs A8 D3 ?
- NGK 3911 review
- question for those with the fridge option...
- chain tensioners change on a 4.2
- New member with a few questions
- Halloween comes early
- New Owner Air Suspension Questions
- Bluetooth Streaming Adapter
- No Start, Need Codes Diagnosis
- Change of chain tensioners on a 4.2 BFM
- New Member and Fan/Trunk Question
- VCDS DIAGNOSTICS
- New D3 - 1st VCDS Scan - Engine Code
- Thanks for advice from forum members
- VNS AMI 2G: How to create playlist on USB?
- MMI Car button Doesn't work 2004 audi a8l
- Frustrated 2004 Audi A8L 4.2L
- Modify AMI cable to stream music and sound through bluetooth dongle
- 2004 A8L 4.2 Gas Flap Sticker
- Rear back window sun shade
- Thanks for helping! (New D3 owner) LONG
- Camshaft Position Sensor Location (3.2 FSi)?
- vinyl wrap fun
- Why I hate NJ's numbnuts rules...
- how do you R & R third brake light ?
- 08-09 4.2 TDI
- Picked up my 2007 A8 today.... so nice.
- P2190 and P2188 and P1083 and P1087
- help source stupid little part
- 2004 with abs problem
- STABILIZER LINK .......which one to buy
- REAR SEAT ENTERTAINMENT NO POWER
- Avant Garde wheels | Monoblock collection |Saudi Arabia / GCC
- retrofit DAB
- Ethanol gas vs. Mileage
- Module incorrectly coded
- Any way to disable adaptive light warning?
- Suspension, I know it's been done many times here but
- oil leakage
- S8 or W12?
- Dealership errors what can I do?
- Front left is down when the car sits for at least 8 hrs or more
- Strange noise
- :: ECS Tuning :: D3 A8 ECS Assembled Ignition Service Kits
- Camshaft Position Sensor & Timing Chain
- A3 4.0 TDI water pump drive
- Has anyone done a Instrument Cluster Upgrade
- Question for those with AMI
- Dimmed side mirrors -how to disable? A8 D3
- A8 D3 4.2 petrol 2004
- Fault Codes after timing belt replacement
- Any suggestions for AMI cable extension?
- Knocking Noise Upon Start Up
- Suspension compressor parts
- Question about Radio
- :: GruvenParts.com Billet Intake Manifold Linkages, Oil Cooler Tubes, and More for A8
- S8 MMI Issues
- Rear defrost and fridge not working
- How To Replace Headlight Range Control Module? 2004 Audi A8
- Changed battery and now CD Changer blank in MMI!
- Finally Driving a D3 W12 again.
- Lock confirmation 'beep' redeux...
- Need Seat Control Module ..anyone ?
- 05 a8 base model usa e-brake problem
- Rear door sunshade won't retract
- check out this win !
- Oil change time / blauparts discount
- Strange Plastic Object
- trying to identify source of smoke from engine
- climate controls work but no air blows out
- Electrical issues
- Strange navigation problem
- Misfire #4
- Where does this sensor go?
- Alignment in Comfort/ Auto/ Dynamic
- Special promotion for Audiworld members
- Poor A8
- Oil Filter Housing O-Ring
- engine oil type
- How can one determine if their 2006 A8L 4.2 has sport suspension or standard?
- Brand new owner! 2004 D3 A8L
- Apparent Audi keyless security flaw
- 2005 Price?
- MMI Menus Missing
- Considering selling my '04 A8 L 175K miles
- New 2006 Audi A8 D3 Owner
- Contrarian question: has anyone done the belt job withOUT a front clip pull?
- D.I.Y. Timing Belt Replacement
- I'm coming back, FINALLY. I have a grill question..
- seat adjustment. is this normal?
- Water Leak
- 2009 Audi A8L Quattro - Questions
- Bulethooht or not
- White smoke on hard acceleration, then lingers
- Air Strut Diagnosis Help Needed
- Sleep mode question
- HELP!!!!!! crank lock cap.
- Warranty
- Cat replacement $$$$ 2004 A8L
- 2008 S8 high beam problem
- New D3 Owner!
- 2004 A8 battery drain
- weekend project.
- :: ECS Tuning :: D3 A8 Roof Rack Necessities|Yakima|Rockymounts
- Audi S8 Plus - 605hp
- Feel like a dumbass asking this
- NAVTAQ NAV disks 2015
- Can you identify these OEM wheels?
- Shifter Cover Plate
- 2005 A8 Washington State. Suspension is bi-polar
- 08 S8 CEL flashing
- Thanks to all of you!
- Finally drove a 4500lb v10 sedan with a manual steering rack
- Coding request
- Rear storage box won't stay closed
- ACC Calibration
- 2004 A8L not switching on
- Insert Sat Nav Disk
- Will these fit and work properly?
- Service Warranties
- Can anyone confirm a part number for me or steer me in the right direction?
- Clearing out Nav locations
- Help please with a misfire on my 2004 AUdi A8
- Need 1 Oem wheel 2007 S8
- Anyone have this happen ?
- Setting time and Date
- New Battery Needed. OEM or Other?
- Blown # 29 fuse in my 2008
- HVAC Issue Solved
- After a year I'm finally here
- A8 d3 crankshaft sensor location
- Dash cam = battery drain ?
- Offset/tire width question
- My 2009 A8 W12 has arrived.
- VAG COM / VCDS Expertise Seattle Area?
- '04 - A/C weak, NOT empty. No HVAC codes.
- Parking Brake Error - Hall Effect Sensor
- Steering wheel
- 2009 A8L
- Some Electrical Problems...
- Timing belt rubbing on cover
- Anyone Know A Good Audi Garage Near Huntington Beach ?
- Help with removal?
- Did t-belt job but...
- Anyone using spacers on stock wheels?
- Fuse box Terminals
- 2009 A8L-27k--possible purchase
- anyone have link to Audi Security Glass video...
- air inlet duct / air intake?
- D3 V8 compared to D4 V8?
- Very very bad noise
- Invest in a new car battery
- timing belt parts info
- Any D3 Experts in the Scottsdales / Phoenix Area?
- MMI Control Panel and Battery Issues
- D3 A/C pulley meltdown and diagnostics--all motors
- Audi D3 A8 W12 water pump and serp belt tips (and near nightmare...)
- Normal Engine Noise?
- Audi trailer hitch
- Suspension air Compressor blew up
- Ignition switch not locked in place
- ESP, ABS and Parking Brake Lights
- fixing a sagging headliner
- 04 a8l climate panel powers up for a secound then off
- 2006 AMI and SSDs
- expansion tank quick fix DIY
- Seat Schematics
- Did a VCDS & pulled up fault code:
- Just bought a 2005 Audi A8L
- Viscous Pulley for 2000 Audi A6 2.7T
- This week is WaterFest Whos going ?
- ESP ABS
- ATF change, dissassembly issues
- Finally "flushed" center differential.
- ECON won't turn off
- Timing belt change tools for rent?
- Sunroof carriage replacement
- loss of power steering
- oxygen sensor code diagnosis
- D3 Color Experts
- Urgent..bottom air box channel
- Found where my coolant is leaking from
- several remote/locking issues solved w/ one fix
- S8 Oil Leak
- AC Issue
- Misfire condition next steps
- Hoot noise and it's not the transmission
- A simple query re Accessory Position
- ACC (Adaptive Cruise Control) Calibration
- Audi D3 A8 W12 coolant leak in front of motor; other noises
- D3 A8/S8 horn replace--fishmouth and no front end service position hassles
- The notorious Suspension rattling
- Just got my first audi, and its an 2006 a8L
- Driving Nashville to NJ tomorrow, any advice?
- Formal Introduction
- What does this button do?
- Average Life of a Car Battery
- First Spark Plug Chage
- confirmation 'beep' for locking has quit...
- torque converter
- How high is belt failure at 118k miles
- Specific AMI cable 2008 A8L to iPhone 4
- A8L 2004 tail light replacement
- Mac OS X users can use VCDS now...
- So I bought the Grey one
- Low fuel pressure engine light...
- Trunk lid motor issues 2004 Audi A8
- Tow ratings for the D3 S8
- Yet Another Suspension Thread
- Member intro and D3 MMI control board
- Driver seat "Medallion" replacement ?
- A few Rim opinions need for the stock S8 rims .
- :: ECS Tuning :: FREE SHIPPING on orders over $200!!!
- floor mats coming loose
- Another windsheild wiper problem
- Oil leak, front of 4.2 BFM engine
- D4 wheels fit on a D3 with no adapter ?
- The dual fan speed controls don't work independently...
- Door storage fix DIY
- Audi has come back since the 90's and now is ranking best in resale
- Cabin Lighting - LEDs
- Will an OEM A8 inner tail light from 2011 work on a 2004 model?
- W12 production numbers?
- G12++ with G12
- Adding video 08 A8 base
- S8 spare size
- no key identified - remote lock - unlock don't work... battery
- San Diego Check
- Shifter Mods
- Sunroof
- A8 D3 heater blower fuse/relay
- Labor hours for timing belt chnage
- Not driving the A8 for 10 days... charger?
- Anyone interested in trading their 20" wheels for my 21" HRE setup?
- Who has the best pricing on Spark plugs for our S8's these days?
- Problems with taillight not working.
