- Bi-xenon high beam shutter inop...no hi beam
- 2007 a8 D3 Rear Suspension Pressure Tank
- New Michelin PS4s, What A Difference!
- main starter relay location
- New Oxygen sensor doesn't fix P2231
- 2007 A8 D3 Backup Camera Module Compatibility & Coding
- Audi a8 front suspension
- UK: Need advice on high mileage A8..
- W12 Headlights?
- A8 Battery
- S8 Coolant back of the engine
- D3 a8 EPS EPC Rough Idle - Codes - Wiring?
- THE BLACK HAWK HAS LANDED!!
- anyone replaced compressor w/$200-300 variety?
- HR: My Car Takes a Deep Breath I Lock/Unlock It
- anyone have a W12 air ride compressor on the shelf ?
- 2005 Audi A8 4.2 Quattrro not turning over but have battery power
- Backup Camera Module Faulty 2007 A8
- How Do Visor Brackets Come Off? Interior Color Suffixes?
- Chrome mirrors wanted
- Can not code Bosch 5.7 ABS pump
- Emergency Suspension Inflation Tool
- 2004 A8L W12 rear left door control module
- Mmi issue
- center arm rest height adjustment
- How to remove VW/Audi electrical connectors
- 4.2 Top End Overhaul, Intake, Valve Cover Gaskets
- My 2007 Audi A8l 4.2 quattro keeps throwing random misfire codes.
- Bluetooth Issues
- Air Suspension Valve block
- LT: Best way to add aux/Bluetooth music streaming?
- Replacing cats and 02 sensors D3 S8 V10?
- Seeking TPMS Info
- 2006 A8 D3 4.2L Engine Temperature
- 07 A8 D3 Coolant Tank / Reservoir Spewing Coolant
- Anyone Have a D3 A8L SSP Index?
- 2008 S8 Key won't work in ignition
- Clicking noise while turning steering wheel [video inside]
- Need (Black Plastic) Trunk Handle W/License Lights (Long shot I know)
- Linuxx: Sunroof drain
- brake lights audi a8 2004
- design this electrical mod circuit ? I'll pay for R&D
- Help with Fender Removal !
- Center Air Vents Closing Strangely
- LT: Not synchronized working headlight washers
- New gasket doesn't fix oil in spark plug wells
- Serpentine Belt Size? 2535 or 2555? (BFM)
- Tier Pressure Monitor Quirks
- '07 S8 Drifting RPM
- Solar Sunroof tilting not working.
- A8 Cranks No Start
- anybody replaced deck lid struts in last few months
- Quick question: suspension
- Aux Water Pump... where???
- keyless entry door handle issue NO JOY!
- What Motorola model is this? New battery needed
- Suspension Air Bladder/Bag
- 00135 - Fuel Rail/System Pressure P0087
- Alternator not putting out power
- Audi A8L 2004 parking brake error
- Looking at 2007 D3 A8 to purchase
- S8 D3 Front Suspension elusive knocking
- ZF 6HP26 Leak
- grille parking sensors R&R involve bumper R&R ?
- Need help With TDC
- Hello All
- Hello All
- Help Wanted (Finding Trim Piece)
- Recently obtained a 2005 w12; have a mystery
- Component protection
- Andover, MA Cars Coffee Tomorrow
- Goodbye, maybe?
- Suspension Connector & Orings
- 2008 Floor Mats For Sale $20+ shipping
- 2003 A8L D3 ABS 00003 -014 control module defective
- Suspension Air Lines
- Mishimoto Thermostat?
- Seat Back Insert Repair - Any Suggestions?
- Audi a8 mmi control problém
- Valve cover gasket change anomaly
- Honest Audi mechanics in North/Central Jersey? Smoke frm back of passngr side engine
- The best way to deal with the Combi Valve?
- Rear Trunk Trim
- SE: D3 -03 VCDS coding headlights Scandinavia "auto" mode.
- 2007 Coolant leak --
- Finally got started!
- Secondary Air Injection
- 3.0 tdi white heavy smoke from time to time
- Catch Can install on S8 V10
- Paper, Cotton or Foam.
- 3.2fsi Timing Chain Tensioner Replacement
- Boston Meet Up
- Can I swap whole front end from 2006 to 2010 ?
- air ride strut replacement?? Can I have both rear wheels on ground ??
- Lean Condition and Misfire
- High Mileage A8/S8s?
- leater seat repair suggestions
- D3 S8 front/center differential fluid change
- Tuning my D3
- Sub buffer dead
- My new (to me) 2010 A8L & key fob question!
- 5.2L V10 oil pan leak and seal
- Ceika M1 Coilover Kit for D3 S8
- Sound from Driver Side Front End - ABS or Airbag?
- BACK ON THE ROAD!
- Thump sound in rear
- Can position sensor replacement
- PCV Or Vacuum Leak
- My fuel economy is horrible
- Replacing Engine Rubber Bushing
- HR: A8 2006
- would this upgrade be possible .....
- Vibrations at low speed
- A8 d3 2004 transmission Output speed sensor 3.0 petrol
- 2004 A8L Radiator coolant leak and repair question (pictures inside)
- Honk
- Struts
- New to Audi/Forum
- Fault codes after installation used abs module
- Invite to D3 A8/S8 Empire!
- Coolant Dripping from inside crankcase 1 drop 11 minutes
- Tire size for 19X8.5 ET38 wheels on A8 D3 4.2TDi?
- trunk won't latch
- Looking for used front Fender Wheel liner.
- How to figure out rotor size? 2006 Audi A8 SWB
- BA: Reverse lights and fog lights inverted
- Fan temp sensor location
- How to remove rear overhead switch/lights panel ?
- Driver Seat Position
- Suspension Problems
- Trifecta lights solved
- Parking sensor issue
- Passenger seat mishap and stability system trouble also
- Coolant leak under the engine
- First Time Audi Owner
- Brake boost vacuum system
- 230k plus miles and still lovin the big A
- Exhaust manifold suitability?
- Engine Air Filter Housing
- 2004 to 2006 headlights
- D3 Audi A8L modules not communicating
- ideas to make this Euro feature work in US A8L ?
- Timing Check with VCDS procedure? Help needed
- Oil Pressure Warning
- Bought a 2008 s8 for under $4,800 updated* oil filter wth??
- A8 l 2004 3.0 petrol v6 gearbox fault vcds
- Exhust system form my Audi S8 V10
- Bad case of sunroof leak?
- S8 (D3) Advisory to what else to do while an engine out job?
- Fuel pump priming
- QA: 2009 Audi S8 EPC LIGHT?
- Changing rear lambda sensor 1K0998262B
- broken, ripped, cracked trashed
- Shorting centre controls when installing av1 source
- Not charging
- yellow and green lights
- Chain in back or belt in front?
- Replacing A8 cluster to S8
- When did you replace your starter ?
- my 546 000 km 2004 A8L is getting a S8 facelift. HEADLIGHT Questions
- Engine splash guard source
- Control Module Part Number: 4E0 910 280 A
- it wasn't the starter, but still not fixed
- Which Tire sensor is going bad?
- Key fob battery dies fast
- A8 D3 2007 Control Module Part Number: 4E0 910 280 A
- A8 D3 2007 Mysterious coolant leak
- Component location? Vacuum pump for power brakes
- Letting My 2006 A8L go.
- Audi A8 4.2 TDI Power Steering problem
- PPI on S8 (Minor oil leak?)
- a8 d3 phone install help please
- Wanting a source for B&O tweeter
- 2006 A8 ESP/ABS/Wheel Speed Issue
- Wanted Left Inner Tail Light
- above 7 km/h continuous warning beep
- Charging problem
- Using Ami Bluetooth sound to Watch YouTube etc.. possible?
- shift dust cover
- Air compressor knowledge needed
- AUDI S8 Intake Flaps removal TUNE
- Voltage out put from alternator
- WANTED: AUDI A8/A8L D3 - excellent original condition
- Motorized B&O tweeter not working
- D2? D3? WTH?
- flashing parking brake light
- horn replacement
- Rear reclining seats with massage and ventilation
- Secondary Air Injection Pump Relay and Fuse Location
- Please HELP!!! 2009 Audi A8L stuck on bootloader... :(
- Replaced HVAC controls but unit shuts off and won't turn on
- A8 D3 2007 Steering stiffening up intermittent
- TPMS help!!!
- Need help
- @#$@#$ license plate screws
- Need help
- 2007 Audi A8: Need help asap, please
- Totalled the D3
- Anyone Install this Supercharger kit?
- Bulb's power consumption?
- Front passenger side abs wheel speed sensor wiring
- A8 d3 post transmission replacement issue
- CEL - mechanic checked it- 31 hr job quote!
- Coolant leak behind engine, by the transmission.. help
- 2005 audi a8l
- 2008 A8l 4.2 front right strut
- Left head light going out intermittently than back on?
- LT: Audi a8 d3 3.0l Diesel havc problem
- Right rear strut 2009 D3/S8 leaking
- D3 A8 SWB W12 remove front bumper - how?
- Converter stall speed
- Replaced abs unit now it need coding
- I bought an Audi s8 d3 for $4,800
- Finally joined the D3 S8 Club
- HomeLink Help
- Abs module issue
- New to Audiworld, looking to buy 2015 S8
- My 2008 Audi S8 Strange noise
- Water Damage
- A8 D3 Cluster Mileage adjustment
- Contact Air Suspension Functional Issues
- S8 D3 is Comfort Mode adjustable?
- Replacement coolant bleed screw?
- Issue getting cam pulley sprockets on after pulling them for timing belt job
- Can anyone identify this wheel?
- Suspension recommendations
- Auto wipers issue
- Important timing belt install question...help!
- MMI chattering. cold weather?
- Brake size question
- Nav issue
- S8 vibration on idle
- Superbright leds website, do they work on A8s without throwing codes?
- Lower radiator hose oring size
- anyone w/ACC ever removed front bumper ?
- Having issues with my parking brake!!!
- Tyre fitment
- If in need of winter wheels & tires...
- 17942 - Camshaft position bank 2 adjustment short circuit to B +
- 2003 A8L purchase
- Aftermarket wheels....any good setups?!
- Mmi hidden menu
- Need engine subframe torque values, 4.2l A8 D3
- RIP- Audi Master Technician
- A8 DE 2007 Steering Issue
- Wiper Blade Spring Contacting Windshield
- 2005 A8 random no crank, starter issue?
- Driver door lock problem
- Bad Turn signal
- MMI dead after battery replacement
