PDA
View Full Version : A8 / S8 (D3 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 [38] 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
  1. what to look for in the battery chargers
  2. Best tire size for 18" wheels
  3. DOH! Door ding...!
  4. Steering wheel squeak
  5. Back up camera turning off!
  6. Air compressor works often
  7. AMI Question
  8. Tow Ability
  9. Anyone seen or had experience using one of these?
  10. Amber Side Marker Lamp
  11. Rear end shimmy going over bumps
  12. Drive belt tensioner
  13. MMI not working when car is cold
  14. What tires are you running?
  15. Beeping sounds from Dash - Speed > 130km/h
  16. lower door moulding refit
  17. Can't wait to see if the camera is working!!!
  18. SELFLEVELLING
  19. Considering a 2004 A8L
  20. another mmi question
  21. Considering a 2004 A8L
  22. Source for hood liner clips?
  23. Headlight range control and adaptive suspension warning lights
  24. AMI Cables Black/Blue/Red??
  25. 00456 - Control Module for Access and Start Control (J518)
  26. Adaptive suspension will not save calabration
  27. Car off but strange clunking sound and jumping around
  28. Grinding noise from front end
  29. Headlight Lense cover
  30. help needed d3 door mirrors
  31. Nav & DVD
  32. My rear brake pads replacement experience
  33. Custom steering wheel is on!
  34. '06 A8 Oil Filter Question
  35. Looking for Vavona wood, Amaretto Leather in RHD SWB A8
  36. does the 2005 A8l 4.2 (d3) have a OBD2 Plug?? general Ed on the A8 plz
  37. COMFORT CONTROL MODULE
  38. New to the Audi club
  39. Would I be correct in stating this info ?
  40. Anyone that can help with sway bar link replace
  41. So long to my A8L - listed in classifieds
  42. I'm part of the Audi 8 series group now!
  43. Hengst Filter, Wix box
  44. Starting Bootloader
  45. Electric motor mount fault
  46. V71 and J520 errors
  47. question about OEM battery date stamp...
  48. Front bumper turn signal delete / euro bumper guard source found
  49. Wheel spacers
  50. H.I.D issue
  51. Fuel System Cleaner Recommendations??
  52. o2 sensor locations 5.2 S8
  53. Vibration
  54. Timing Belt Kits
  55. Is there a fuse for the Lambda sensors on a D3 S8?
  56. VAGCOM Rear Parking brake
  57. Voice Control
  58. :: ECS Tuning :: NEW Alzor Style 349 Wheel Sets!!
  59. 22' rims for sale
  60. A8L W12 rear passengers door won't open
  61. Clunk when pressing brake
  62. i'm not liking my EBC brakes
  63. i'm not liking my EBC brakes
  64. Leaving the Audi world
  65. hood / bonnet lever broken
  66. Sanity check (Power steering fluid)
  67. Rain and Light Sensor Retrofit
  68. Boise Audi S8
  69. rear tail light warning
  70. No Supermarkets In POI?
  71. Rattle in the back passenger door.....
  72. Bose Amp - Can I use a Q7 / A1 in my A8 ?
  73. Seatbelt chime and Comfort System settings
  74. Audi AMI vs. iSimple device
  75. Rear door will not open
  76. A/C service on my 2004 D3
  77. MMI fault - Sound System Fuse - CAN - Optical Errors
  78. Update MMI 3360 To 4610 Successfully With 4F0998961 CD2
  79. How do you get the Speed warning 2 back after the 4610 update?
  80. Canadian fog lights to stay on with high beams?
  81. D3 2007 A8L Grill Mod
  82. 4.2 V8 Petrol Thermostat Swap - Big Job?
  83. Face lift bumper
  84. newbie Vagcom Help
  85. Maintenance time Bearings and differential fluid
  86. The Vag Com has arrived!!
  87. Spring Beautification
  88. just did headrest upgrade
  89. Search Function
  90. 2007 A8 Sun Roof issue
  91. Not sure what I have
  92. current software version
  93. MMI Parking Sensor Screen
  94. Sunroof buzz
  95. What a great forum! Wanted to introduce myself
  96. RSE + MMI
  97. MMI Screen Change
  98. Slow kickdown?
  99. Steering wheel voice command
  100. DOES anyone know a shop in the connecticut area
  101. Bought a Audi S8 2007 have questions about options
  102. New Battery
  103. Cracked wooden steering wheel in 09 A8
  104. MMI version
  105. Trunk Lift Motor
  106. 06 A8 camera retrofit pursuit...
  107. About time I said Hi.....
  108. Update MMI 1190 to 3360 Successfully With 4F0906961AB CD
  109. Headlamp washer unit
  110. Any S8 Chivers?
  111. DVM power module
  112. MMI 1190 to 3360 update question... Again
  113. First Thing - Homelink Garage Programming
  114. vagcom in Utah?
  115. looking for a 20" chrome wheel middle cap
  116. I'm selling my 2009 A8L...check out the classified
  117. Picked Up The A8L Yesterday... OMG!!!
  118. Drivers door wont open once unlocked
  119. Tire pressure monitoring system 2006 A8
  120. 2006 Audi A8 Wheels
  121. S8 out on the town
  122. 079 115 433D HELP!! Need Oil Filter Cap
  123. Help with some VCDS fault codes
  124. serpentine belt replacement - when?
  125. Feeler: S8 Grill FS
  126. weight of gutted A8
  127. Spring....time for some new rims :)
  128. D3 A8 Is Unique and Special
  129. Wheel bearings?
  130. LLTEK RS8 Grill - Any experience here?
  131. Emergency brake malfuction/light blinking
  132. Option Package
  133. S8 interior option question
  134. Tensioner pulley needs to be changed
  135. Back up camera diagram?
  136. W12 A8 > audi S4 > friends S4 > V10 touareg TDI
  137. Anyone swap air suspension for springs?
  138. IPhone5 will not pair with my '07 A8L
  139. 04-05 bumper filler wo/plate holder needed
  140. problematic TPMS
  141. A8 Hood cable broke on demo car!!! What's up with these cables?
  142. Rear seat removal
  143. 12 volt key in power on?
  144. Dead battery?
  145. RS5 wheels
  146. Front end dropped to the floor when parked
  147. MMI flash blink flicker
  148. Air Suspension Stuck
  149. Buying A8 out of state / unseen
  150. 55,000 mile Maintenance .. O_O wow!
  151. Anyone have details on TSB 43-08-16
  152. Switching Off/Disabling Phone?
  153. A8 vs A8L again... Do I miss much if I get an A8 and not A8L
  154. Thinking about Buying this car
  155. Smell of Oil.
  156. Brake Pads Replacement question
  157. Please run a carfax for me, someone?
  158. How to check differential?
  159. sunroof problems?
  160. Need New Air Pump for Adaptive Suspension - Rides extremely low
  161. Steering Wheel Lock warning
  162. :: ECS Tuning :: Alzor Wheels Style 628 for Audi!!
  163. How to get nav dvd out?? :)
  164. Thinking about a move from a D2 to a D3
  165. New 2007 S8
  166. wheel size question...
  167. Instrument cluster -- illuminated dials
  168. Here's a new one.....
  169. Help - CD Player: Device Fault
  170. What do you think ? comments.
  171. VIN decoder
  172. RDS not displaying in the cluster
  173. Spotty chrome trim on doors
  174. Oil leak mystery
  175. Dashboard Lights not working
  176. Dealer recommended 55,000 mile service
  177. A8 not recognizing key fob when approaching
  178. Few problems with my S8
  179. New Bulbs
  180. Bumper Paint Headache
  181. Looking at A8s and Allroads
  182. reopening a case of severe top end power loss
  183. Mandrus Millenium wheels . . .
  184. Rear right door coding, VCDS
  185. Anyone else having this issue here?
  186. New Wheels
  187. I have bought myself a 520bhp W12
  188. My Rotor and Pad Install
  189. Pics of New Wheels - haters will hate!
  190. ECU power upgrade for S8 available?
  191. I found my A8 or NOT... HELP!!!!
  192. S8 Consideration!
  193. Does anyone know this car?
  194. Sunroof Drains plugged, help
  195. urgent help please Dead battery cannot access trunk
  196. After ignition off front drops 5-10mm
  197. Jacking the A8L with 2.5 ton jack to . . .
  198. Kufatec Comfort Hatch Module :D
  199. Displaying the speed on the on-board computer in an 04 W12 A8
  200. Painting Interior Wood Trim (in progress....)
  201. Lines in screen display A8L 2004
  202. Radio "radio not installed"
  203. Headlight housing condensation after . . .
  204. Yet more air suspension issues!
  205. Steering Differences: 07 Vs 08
  206. Upper Control Arm Bushings - Problem Solved
  207. How to check if a D3 has "Adaptive Cruise Control"? Thanks!!!!
  208. Need ECU assistance
  209. Bluetooth for In Car Phone
  210. Cleaning the sticky buttons on the consol
  211. Q7 rims on an A8?
  212. Navigation Unit
  213. head light range malfunction
  214. Navigation Discs 2006 A8L W12
  215. 06 or 07 A8 question again....
  216. S8 Transmissions
  217. Help :) - Cylinder misfire 4.2L V8
  218. Accidents and OEM parts not used
  219. Windshield Washer fluid leak Fix
  220. New EBC REDSTUFF pads are dirty !! ?
  221. Aftermarket Warranty
  222. Suspension 'play'
  223. tire size
  224. Front bumper license plate DELETE insert part #
  225. anyone else have an A8 that 'eats' batteries
  226. President's Day Sale at www.DetailersDomain.com
  227. Battery Problems
  228. My A8 and Questions
  229. Rotors that don't need replacing?
  230. Increasing overal wheel/tyre by 25mm any clearance issues?
  231. fuse schematic
  232. Pandora + AMI is possible! (New project on the way)
  233. Camber Adjustment?
  234. AirBag Fault - TSB Needed
  235. Crack on S8 wheel
  236. audi A8 w12 dyno results
  237. headlight flasher bulb type
  238. '03 A8 rear suspension not adjusting when stationary....this normal?
  239. Parts database
  240. Screen washer not working
  241. A8 cupholders
  242. Burning oil
  243. Inoperable Steering Wheel Controls
  244. Audi AMI Cable
  245. 2006 A8 soft close doors
  246. Height Sensor Link Abnormality
  247. audi a8l MMI issue, replacement information
  248. 2003 4.2 A8 has large screen display in console fitted??
  249. MMI Gear issue
  250. looking for 255/40/zr19 tires
