PDA
View Full Version : A8 / S8 (D3 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
  1. Replacement key fob
  2. Climate controller replacement
  3. ECP when cold starting engine (A8 4.2 petrol)
  4. offer on 2009 A8
  5. Hot air left side vent
  6. Back on the road again
  7. 04 A8 MMI stopped working need help
  8. 2006 Audi A8 Ride Height
  9. 2 issues, no rear AC and coolant low warning
  10. My Audi A3 slide no lights on dash and no dials working any ideas plz
  11. air suspension problem update....
  12. 2008 S8 rattles
  13. Bonnet stuck shut on one side
  14. 2008 Audi A8l 4.2. Lack of Interior Heat
  15. Buy an Audi S8 for 17K or NOt?
  16. Struggling with intermittent parasitic draw..narrowed down
  17. mmi
  18. Nuebee audi repairs questions
  19. Flex Pipe Replacement/Fix
  20. o-ring specs for air strut ?
  21. 2004 A8L Engine Mount Replacement
  22. help need info
  23. Apple CarPlay and 360 camera interface
  24. Engine swap in my 2006 4.2 d3 A8L
  25. how to remove and refit an audi tt mark 1 drivers window
  26. Will 2015 s8 Wheels Fit a D3?
  27. timing the air suspension
  28. Rear brake pads fault codes. 02438
  29. Well Priced S8 in MN
  30. what does THIS air suspension scenario suggest ?
  31. Rad Hose 4D0121055.. DISCONTINUED
  32. Overhead panel problem
  33. Overhead panel problem
  34. Engine sound
  35. S8, failed catalytic converter. which one..
  36. Anyone parting or have access to a parts D3?
  37. Need vag com help
  38. Driver door lock issue
  39. My suspension woes don’t seem to be over
  40. A8 D3 - ABS - Handbrake malfunction - Brake wear warnings
  41. lower grill
  42. looking at 2009 A8L
  43. Power 12V with ignition on
  44. Rear door card removal challenge
  45. Had a nice chat with Audi Engineer for 2hrs on the plane...
  46. Looking at a 2007 A6 wiht the 4.2l. 90k miles.
  47. Air Suspension Help Needed
  48. retrofit
  49. Keyless: boot does not unlock
  50. w12 weird engine vibration
  51. Nitrile gloves where to buy in big size
  52. ESP failure
  53. Air suspension: how long to come up?
  54. Zenon Headlight
  55. D3 S8 front brake caliper replacement
  56. 3.5mm headphone cable
  57. 06 a8l air box plstic hose under it
  58. A long life with an A8?
  59. Unplugging Seats
  60. Slightly rough idle when starting
  61. 2005 A8 headlight/highbeam issue
  62. Any coolant flush howtos?
  63. cooling fans
  64. Best audio upgrade option
  65. A8L 2005 engine wiring harness
  66. Engine noise after 40kph then gone once below 10kph
  67. Can I add a 3.5mm headphone cable to my 2005 A8 (D3)?
  68. MAF VAG result
  69. Key stuck in ignition after removing fuse and closing trunk
  70. Bizarre Suspension compressor not running, I'm stumped
  71. 2004 A8L 1-0 2017 BMW M2
  72. Crazy Louie's E-Z MMI Interface (AKA What I Want for Christmas)
  73. Intermittent misfire
  74. A8 MMi screen 2008
  75. Transfer songs and playlists from iTunes to USB drive to play on the AMI
  76. Hero Giovanni Giovino 6.0+6.0TT (John)
  77. Will 2011 wheels fit a 2008?
  78. TPMS MODULE REPLACEMENT
  79. Arnott air Strut for Audi A8 D3
  80. Oil catch can 4.2 FSI
  81. Soft close doors....what am I missing
  82. AIR SUSPENSION NOT WORKING
  83. Fault code P0022 A8 D3 2004
  84. Location of ignition control module?
  85. how to get my a8l 2006 see my audio file in my s5 galaxy android
  86. ADS Suspension
  87. Selling My 2005 A8L with VCSD Reader
  88. S8 Minimum front rotor thickness
  89. Bushings/Control arm:
  90. AUDI A8 2003 LH
  91. What is it and where does it go?
  92. Question about Spare Tire
  93. MMI or some other device?
  94. d3 2006 and android music
  95. Tune2Air/Streaming Question
  96. "Dead" rear brake light
  97. Buddy, can you spare a dime?
  98. S8 Ceramic brake pads
  99. Next problem
  100. 4.2l Irritating Misfire problem!
  101. Pirelli PZero All Season Plus tires ?
  102. AC problems
  103. location of AC high pressure switch
  104. Can TPMS failure stop the ACC from working?
  105. Air pump function question...
  106. Honk Honk. inquiring minds want to know
  107. Hey All, I am the new owner of a 2007 Audi S8 V10 , any advice would be welcoming
  108. How do you get the transmission sump off an S8?
  109. Audi S8 V10 timing belt question
  110. AC Pressure Switch
  111. Front shaking....odd problem
  112. Moving front seat forward when switches not working
  113. P2179 ongoing issue
  114. G300 and G28 Incorrect correlation
  115. Selling my Factory Air Suspension
  116. Suspension issues with a twist
  117. Wet Feet !
  118. Audi A8 exteriour door handle lights
  119. Wow! - Audi Service Manual from factory-manuals.com
  120. Need some advice on O2 sensor B2S1
  121. ***WannabeRacer.com | Boston and New Jersey Vinyl Wrapping Tour***
  122. audi a8
  123. some rennovations to my 'new' W12...
  124. New wheel recommendations..
  125. cold start sputter problem
  126. sudden oil consumption & vented oil cap
  127. Alignment issue?
  128. Taking delivery of an 07 W12
  129. Questions, feedback following some suspension work.
  130. Second Owner Maintenance Plan Questions
  131. + changing gear pad broken
  132. unusual air suspension behavior...suggestions ?
  133. Aftermarket Suspension
  134. Audi A8 electric seat problem
  135. 01539 - Headlights Not Adjusted - MIL on
  136. 3.7 V8 engine noise
  137. EPB problem
  138. Bringing to the top. Why be a smart ass?
  139. Low/high beam not working
  140. Turn off warning sound - possible?
  141. Updates?
  142. D3 Stabilizer Bar Replacment Bushing Experiment
  143. How to Remove fuel rail
  144. HPFP blowing engine management fuse?
  145. Mmi
  146. Out on side of road with stream billowing from engine bay.
  147. Performance upgrades for 2014 s8 turbo
  148. Need code advice
  149. Pinch bolt replacement
  150. Splash Shield Cover
  151. Coding passenger door to prime the fuel pumps?
  152. Cant seem to find the leak on my 2008 audi a8L rear struts.
  153. A8l Sports Package 20" Winter Tire Recommendation
  154. 2005 Audi A8 ami plug location
  155. Sirius/XM replacement receiver - which one?
  156. Power up an instrument cluster
  157. Hello Everyone! I just bought a 2006 a8 with 109k, the car was hit in the left hand
  158. cant get rid of rear brake pad warning
  159. a8l interior led coding?
  160. Superpro upper control arm bushings
  161. A8 suspension chronicles!😡😡😡
  162. Strange Banging Noise
  163. Random misfire on all of bank 2 Help please!
  164. Mirror link box install 05 a8
  165. S-Line Steering wheel retrofit
  166. Q7 vs A8? Got my A8 back :)
  167. Airplane style rear seat directional reading lights
  168. Side assist sensor blocked
  169. Cambridge Green
  170. Bargain car
  171. Rims for 2009 S8 V10 5.2 - Can I replace with other brands OEM ?
  172. A8 fresh air blower
  173. 09 A8L Kessy Failure Help/advice
  174. Knee deep in a vibration issue.
  175. Broken Hood Release cable
  176. Modify AMI Cable To Stream Music with Both Bluetooth and USB Drive For MMI 2G and 3G
  177. Broken Hood Release cable
  178. Mini Road Trip Pics
  179. S8 chrome delete
  180. If one strut is leaking does the complete front end drop?
  181. How do you remove an S8 coolant tank?
  182. MMI comes up with random selection
  183. size of ATF inspection plug
  184. One thread...Multiple Questions
  185. Possible fuel pump - where's that relay?
  186. Intake manifold
  187. Spark plug & Engine oil recommendations
  188. Audi A4 2008 Quatro
  189. A8 6.0 W12 Engine
  190. New member intro - S8 D3
  191. i have 02103 issue audi a8 car works for 2 mints a
  192. Strut airbags Normal vs Suspension
  193. Aftermarket Parts advice.
  194. 07 A8L - suspension in front working in some modes and fail in others
  195. Fiber Loopback??
  196. a4 b6 alert what is
  197. RV Camera - almost there
  198. Suspension level sensor ball stud
  199. Partial MMI Failure Audi A8 2007
  200. Aftermarket Battery asking for trouble?
  201. Beware of Rebuild Master Tech-Thieves!
  202. Navigation disc year.
  203. Fuel smell & Engine hard starting
  204. i can't fix the any problem ( help me please )
  205. 12v to 15v
  206. Energy Suspension Sway Bar Bushings
  207. Just picked up my S8, noticed a few issues.
  208. NAV disk
  209. what fuel do you use and your thoughts on hydrogen?
  210. Driver window won't go up.
  211. 2007 D3 S8 Interior LED brightness adjustment
  212. PSA: Folding rear seat table
  213. Wing Mirror glass.
  214. source for Continental replacement strut bag ?
  215. audi a8 2008
  216. NAV DVD failure
  217. New to AW.
  218. Automatic Headlights/Automatic Wipers Defective - Any Advice?
  219. ever know of a strut bag exploding ?
  220. part number availability
  221. Parking Brake Malfunction light
  222. lemforder UCA bushings dead at 20k miles
  223. Dead Battery
  224. Hidden green menu
  225. My backup camera not work on 2016 Audi Q5--stopped working suddenly ?
  226. D3 4.2 tdi steering pump replacement
  227. finally got my 21"s
  228. S8 Arnott Suspension question
  229. Misfire code and causes?
  230. ABS module replacement
  231. Size and angle of TDI exhaust tips
  232. O2 Sensor fault AGAIN
  233. Audi a6 Allroad 2009
  234. What's it worth
  235. Wrecked my S8!!!
  236. vcds error (video) anyone know whats wrong?
  237. New (to me) A8L, New Member, Another suspension story
  238. 06 AUDI A8L,Q CANT FIND FRONT AIR LEAK
  239. 06 AUDI A8L Q
  240. Just purchased
  241. Cluster warning messages
  242. 2005 audi a3 bonnet
  243. Part number & DIY for Brake Pressure Sensor Replacement
  244. 2013 Audi S8 question regarding reliability and overall financial cost of ownership!
  245. MMI Sleeping (Not dead just taking a nap til I wake him)
  246. Onstar phone set
  247. near (freak) disaster with my 'new' W12......
  248. chasing w12 CEL
  249. Camshaft position sensor (G40)
  250. Big MMI problem
