- How often do you need to replace the spark plugs?
- 2004 D3 License Plate filler plate
- Color combination question. '04 & '05
- Sunroof shade "stuck" to glass
- Groan from Right Front at low speed - Common?
- Mangled coil pack boots, should I be surprised
- EBC Redstuff front ceramic brakes
- How do I get lightbulb warning beep to stop?
- what model is this?
- winter wheels
- Deal of the day Save 70% off Uber All Purpose Towels at Detailer's Domain
- Answer to deck lid bumper puzzler....
- $1800 water pump!
- wanting to purchase a 2003 Audi A8L, looking for advise
- Component Protection issue
- Broken Center Armrest Latches
- ET32 OEM Y Spoke Rims on an A8L ?
- How do I tell which pump failed?
- Reversing Rear HVAC Sync...
- Sticking accelerator in 08 S8
- For those looking... At first glance this appears to be a nice deal
- Changing oil on the 08 for the first time this weekend..any
- Newbie to Forum-Need Advice
- 04 A8L Help Code 17981 & 17985
- MMI Stuck In Bootloader
- Voice activation security is locked?
- Flip out screen door sticking
- Please help me not buy a 2004 A8L
- Nav Control Unit Interchangeability
- Car sitting
- tpms sensors need new batteries, can i do this myself?
- Anyone in the Seattle area with a Vagcom?
- rear differential bearing replacement
- Code P2422
- 3g mmi parts arrived.
- my a8
- BruceM
- Any beige interior owners have black floormats?
- Detailer's Domain: 15% off Orbital Polisher Bundles and Car Care Kits
- Can I Turn It Off?
- Help!!! light sensor or automatic light
- Radiator Leak
- North Dallas Mechanic Recommendation?
- audi a8 w12 long 2005. Reliable?
- Air Suspension: Jack Mode Light on all the time
- S8 V10 or A8 W12?
- Sale on rear rotors
- MIL came on, any ideas where to start
- Tire pressure/sensor warning -05 W12
- Speed Warning settings missing after 1070 > 4610 MMI upgrade...
- Changing Spark Plugs on 2005 A8
- Aux for mmi on eBay??
- Hartmann wheels, any good?
- Sorta OT, Why I try to do most repairs myself..
- 2007 A8 replacement upper control arm bushings
- Replace right front Air Strut
- Empty space to the left of the spare in the trunk...
- whining noise from rear of car and rough idle
- Anyone running 17's as their winter setup? Tire Rack
- Best Time To Buy?
- :: ECS Tuning :: LED Lisense Plate Bulbs FREE Shipping!!!
- Retrofit seat warmers 06 A8 4.2tdi
- Will 255/55R18 tires fit, bluetooth puck questions and FloorMats
- Keyless Entry Problem
- Anyone ordered from Naviservice before?
- Antenna open circuit error
- seen this?
- Newbie questions/confusion
- 06/07 versus newer FSI A8's
- How to gain access to overhead unit?
- Considering a 2005 W12 6.0
- MMI won't pair w my new phone.
- Replace center bumper cover
- what is the purpose of these....
- 6HP26A : fault - 17119
- had to replace trunk latch today...
- Anyone have the Tech Service Bulletin for transmission "hoot"
- High Mileage
- FREE leather shift boots and more for Your Audi!
- 80,000 Miles and still going strong (2006 A8L)
- door rattle when closing with window open.
- 2004 A8L Horn Problems
- have a multi-meter ? please tell me what...
- Help with finding suitable rims/wheels for W12...
- Is it possible to modify the ambient lighting with VAG-COM
- 2007 S8 tranmission not shifting in Drive or Sport mode
- Creaking noise coming from front brakes
- back passenger side sagging when parked
- 07 S8 Adaptive cruise inop - ACC doesn't work after Radar replace - vag com
- Taking back my 04 A8...
- Suspension Air Leak Troubleshooting
- Cost of new brakes and rotors
- scan tool
- full tank of gas to do the mmi update?
- Rear Vanity Mirror Latch Clips For Sale.....
- Possible to disable parking brake warning
- Can't remove oil filter cap
- audi pure protection to buy or not to buy
- The H&R Catalog, by AWE Tuning.
- Nav DVD 2g
- Purchase Opinions
- Passenger side marker signal light not working
- 04 FIller plate - black
- rear door trim/card removal
- Audi a8 3G mmi retrofit
- New owner of 2005 A8L
- Need help...Found some 18" S5 Rims with
- Trim replacement on the front grill
- Audi S8 Side Mirror Indicator Bulbs Change
- Stuck Blend door?
- 2 Questions - Bluetooth Phone and Whats this box?
- Fuel filter change procedure for 4.2 tdi
- thinking about getting a 2006-2008 Audi A8 4.2L
- Door Pocket and Center arm storage replace?
- FYI...D4 S8 Just Revealed---520hp 4.0L Twin-Turbo V8
- S8 D3 'Flapper mod'
- headlight wiring schematic
- MMI update where to get the cd's
- A8 D2 vs A8 D3?
- RennTech Lowering Module
- New 2008 S8 owner-PICS!!!
- Input on tire size and spacers setup
- MMI software and Navi DVD question
- Parking brake engaged when parked?
- Front Bumper Cover needed for 2005
- Gut check before I replace my trunk hinges
- removal of door pocket
- New Owner bluetooth install question
- what do u think about this A8, good deal or not?
- Found an A8
- Best looking rims on a D3 A8??
- The audi rings snapped off my engine cover of my 4.2.
- A8 W12 air-ride and VAG-com/VCDS problems
- SOFT DOOR CLOSE PROBLEM FULLY EXPLAINED AND REPAIRED.
- Thanks forum members for the help with psuedo-75k service.
- Trunk Issue
- Can't seem to reset service indicator with Vag-Com
- Seat Fuse 04 A8
- Anyone do an MMI update??
- BT Telephone Module location
- A8 and Canoe
- VAG in SF BAY area
- Water leak after rain
- CHECK ENGINE HELP.
- AUX input!?!?
- Blower motor replacement
- Squeaking sound from suspension
- should I do spacers and if so..
- Are the front and rear sway bars on a sport
- How to change fog light bulbs (2008)?
- Navigation DVD
- AUDI FAULT CODE P0741 17125 100% FIX.TORQUE CONVERTER CKT PERFORMANCE OR STUCK OFF/NO
- Vibration issue
- 06 Factory S8 Rims for trade
- Steering wheel change
- Do Canbus Error-free bulbs work on an A8?
- Standard vs. sport adaptive air suspension in the various modes.
- a8 s line?
- Bluetooth/Phone issue (2006 & 2012)
- 285/40x18 9.5x18 ET45
- Miss Piggy in Yellowstone
- Shots 20" 2007+ OEM wheels with 12mm fr./20mm rear spacers
- FS: or Trade 20mm spacers
- Timing Belt Tension
- Knee Airbag
- Added spacers today to the wheels. Turned out well.
- Engine Mount On/Off?
- TPMS battery life measuring block
- 2008 Audi A8 Exterior Light Sizes for LED & HID Upgrade
- AMI Bluetooth Dongle Sounds Terrible
- A8 steering column fault
- $100 to the person who can...
- My 2005 A8 Dealer Sticker
- K&N air filter
- code 16840 and code 01217 anyone know where to start?
- Strange noise from rear wheel well
- What does this button do?
- Like I said before...it's the little things...is there
- Audi S8 Oil Change, Castrol 10w-60
- Fan running with out the AC being on & Temperature gauge moving up!
- Removal of mirror housing
- Anyone ever remove rear packing lid area behind rear seats?
- 2005 A8L vag-com
- Phantom Warning "recharge battery now"
- navigation version 11 update
- 2004 A8 D3 Replacement of Headlight Lens ONLY - not the whole assembly???
- Loud sunroof wind deflector motor...Fixed
- maybe this will solve your trunk closing issue
- Batting 0 for 3 today...
- A8 centre door pillar air vent removal
- 2007 audi A8L passenger low beam headlight out
- Audi interior lights to LED
- Map light bulb removal?
- Cradle & BMW puck
- Thinking about upgrading my exhaust, need some advise
- D3 A8L W12 Coolant errors/issues...
- Dealers, dealers, dealers.....
- Rear suspension flat
- New spy shots of D4 S8...
- Front Indicator Bulb Replacement.
- Instructions for rear deck removal / blind installation
- Slime A8 suspension
- Air Con & Wheel Caps query ??
- Homelink
- A8 front valence
- Transmission oil change procedure
- questions about issues...
- Mo' better....a little cosmetic mod.
- Audi Pure Platinum Protection not so Pure
- got 'sand blasted' 04-05 headlight lenses ?
- 2007 S8 vs 2010 535ix
- Single Frame grill conversion...will this work?
- Who is your extended warranty with?
- Ambient Lighting Door Strips - One's out!
- Charging Alternator Issue..Need Master Advice
- AC blowing not so cold air
- BYUM for sale or trade for VAG-COM coding
- High Engine Temp, No A/C
- Rear bumper removal
- Power Trunk sticking: Solved
- Airbag Light Problem Solved
- How Does it Stack Up Powerwise?
- Vag Com for seatbelt chime 08 S8
- Show Pride In Your Ride and WIN $100 !!!
- W12 Owners that had a V8 before
- Tire Wear
- Help ASAP with rear brake replacement
- Tire pressure help
- BruceM?
- Need HELP!!
- VAG COM
- pinging noise from engine
- 2008 A8 Trunk lock out
- Observations of an Audi owner
- 2008 A8/S8 brochure
- S4master1:
- Audi windshield washer solvent
- Not that exciting a find...but I just noticed that
- Wheel balancers in Palm Beach Co, FL?
- AMI for 05 A6 the same as for A8 ?
- Waterfest 17 Special at Detailer's Domain - 20% off!
- New Tires and TPMS info
- Transfer Case Leak
- Just ordered a bunch of LEDs for 2008 A8L
- Thinking of selling my 2007 A8 sport.
- New....and really thinking about a A8
- New, and nervous 2006 A8 owner
- Airbag Light On - 3rd time in the Shop
- Inspection prior to warranty expiring
- MMI 46.10 and BT telephone issues
