PDA
View Full Version : A8 / S8 (D3 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 [40] 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
  1. Emergency management at limit and charging
  2. Can Gateway J533 4 sale
  3. Can't get my front struts to air up!!!!!!
  4. Driver's seat heater and ventilation turns off on it's own
  5. How to disassemble the rear bumper on D3?
  6. 2.8 A8 1998 Heating issue
  7. FS: 4 19 inch hartman 5 spoke winter set with Bridgestone LM-60 tires
  8. FS: Wheels/Rotors/Lowering Links
  9. Front wheel drive V8/V10/W12 A8/S8?
  10. MMI
  11. Steering angle sensor implausible signal????
  12. Airbag Question
  13. S8 control arms on A8
  14. brakes recommendations --Ebay
  15. electrical system not working properly
  16. 19 " OZ wheels for sale
  17. Some repairs that could save you lots of $$
  18. best place to look up parts???
  19. 2004 A8 - Adding Bluetooth & Satellite questions
  20. 2007 A8 L Telephone package
  21. RS6 owner considering switch to S8 - insights
  22. 2004 A8 - do i need to update MMI? and how?
  23. RADIO COMES ON BY ITSELF
  24. WHEEL WELL NOISE
  25. VAG-COM Fault codes... Cause for concern?
  26. Rear wheel bearing and other problem noticed.
  27. need a Tan leather back seat... need help
  28. MMI Upgrade Problem
  29. Fuel Filter Write-Up
  30. F/S 2005 Audi A8 4.2 - Gray/Black - 88K Miles - Fully Loaded!
  31. G12 flush process questions
  32. strut / pump question
  33. 2008 A8 DRL light front light replacement
  34. Set of stock 19" Sport wheels for sale
  35. Will this interface work?
  36. Has anyone seen these wheels on a D3?
  37. Fingerprint input and one-touch memory setting problem - 2003 A8 (D3)
  38. 2004 A8 D3 Powerflex Bushings
  39. MMI shut off and reset twice the other day
  40. Release parking brake manually?
  41. A8 MMI stuck in update
  42. A8 Top Speed
  43. LED Lighting, the OEM+ way.
  44. A8 3.2, 2006 gearbox control unit
  45. MMI screen - clicking when raising
  46. Bubbling engine paint
  47. heated steering wiring or clockspring help
  48. few issues with my a8
  49. 2004 A8L transmission flush - parts and oil?
  50. Replacing climate control buttons
  51. Dash Light Fuse 29 Keeps Blowing
  52. Lowering Links and VAGCOM Mistake
  53. 20" 2013 rims fit 2009?
  54. Question about led tail lights
  55. rougue headlight washer jet
  56. Anyone know part# for this???
  57. Anyone in a need of park sensor for Audi A2 A3 A4 S4 A6 S6 A8 S8 Allroad 2004-2010?
  58. is replacing a RH front strut a DIY project...
  59. 2004 A8 Help
  60. Nice looking Trunk Spoiler Suggestions?
  61. turn signal mod?
  62. Autozone Mobil 1 Sale
  63. VAG-COM help in Dallas (Park Cities area)
  64. 2004 A8L rear parking sensor removal
  65. Air Suspension "Activity"
  66. Timing chain vs. belt comparison
  67. Hard Drive
  68. Questions about my S8 - Please advise
  69. '07 A8 - Air intake making strange sound - please help
  70. Replacing ABS Control Module (+ ignition coil/spark plugs)
  71. Those with the Euro side marker delete in the front bumper please step inside
  72. Yellow and Green Adaptive Suspension Lights
  73. had a motor mount replaced ?
  74. Background lighting stopped working
  75. Air Suspension Fault
  76. Best Way to Sell Your Audi A8...
  77. Cd changer 2004 A8L
  78. Sirius Channels - need info
  79. Convert air suspension to coil springs
  80. Two Malfunction Reports from VCDS Scan
  81. Central locking horn
  82. Aux/parking heater
  83. 2005 A8 4.2 -- MMI update Question?
  84. Picked up a D3 S8!
  85. A8, Milage, years and thoughts from an owner in love
  86. Minus sizing for winter tires
  87. Drivers side door issue
  88. Need help with air fitting on air strut
  89. Replacing the Battery
  90. Decided on '06 as first Audi
  91. 2011 Grill on D3 2007 A8?
  92. Don't need plate holder on A8L
  93. Lone representative at the BMW hospitality
  94. Ride height sensor linkage length?
  95. MMI Bad ? 07-Control Head ERROR - ERROR
  96. What PSI does the air suspension maintain?
  97. 55k Dealer Service Pricing
  98. Has anyone had success with VLEDs
  99. Looking for 2 rear vanity mirror assemblies
  100. Independent shops in Delaware Valley?
  101. 04 Audi A8L 3.0 Car jerks when I press hard on the accelerator.
  102. Bridgestone Blizzak
  103. light malfunction
  104. Looking to buy 2004 A8L
  105. Tail lights faulty
  106. Transmission issue
  107. Time to put her back together
  108. MMI Failure
  109. Remote pre-heating the steering shell and seat?
  110. 2004 A8L not starting after service of oil cooler
  111. No DRL option in MMI !!!!
  112. Air lines...cheap replacement options?
  113. looking to buy 2003 s8
  114. AUX input - options?
  115. Quattro Experts. Is This True?
  116. Trouble deciphering the parts breakdown
  117. Dummy Guide
  118. Is an upgrade to B & O stereo possible ?
  119. Rear Lip Spoiler...DONE!
  120. Audi 2007 (D3?) Steering Column switch
  121. TPMS installation and sensor questions
  122. Hofele bumper quality?
  123. Disable TPMS System Success!
  124. A8 Compressor Relay 373 and fuse
  125. VAG-COM in Chicagoland anyone?
  126. Heater Control Valve?
  127. What goes next to the CD changer in the glove box?
  128. Engine Cover
  129. front brake pad warning light
  130. Different type of MMI upgrade question
  131. My New A8 W12!!!!
  132. Possible purchase of a 2003 4.2
  133. Get ready for winter - Vredestein Wintrac Snow Tires in 245 40 18 and 255 35 19
  134. Trunk lid Struts
  135. City light replacement - 07 A8
  136. It's solve the riddle time....What is missing in these pics?
  137. Here's another issue.....
  138. Rear view camera help
  139. 2007 S8 or 2010 S6?!
  140. 2008 D3 A Pillar Removal..
  141. S8 stolen in Granite Bay, Northern California on 10/8/2012
  142. Anyone know where I can find a solenoid valve block?
  143. Audi A8 max height
  144. Approved oil list
  145. Driver Side speaker fail
  146. Sprint Booster
  147. "17 and snows?
  148. A8L 4.2 vs SL550
  149. Weird radio glitch
  150. Fuse Panels?
  151. Another MMI upgrade question....
  152. Sunroof wind noise
  153. Armrest Problem, Help!
  154. D3 A8 or C6 A6?
  155. How does the key fob come apart ?
  156. need to know what options your car came with?
  157. Sweet Oyster Grey A8L in MPLS
  158. 2008 A8 Blue Tooth Pairing issues
  159. Getting Ready for Winter
  160. Wanted to introduce myself and my D3 S8
  161. MIL / Check Engine Light: 16826 - P0442 - 001
  162. External AV source 1 and 2 in MMI
  163. MMI Update issue
  164. Help me please, what is this part called?
  165. FS; 2007 A8L sport steering wheel and components
  166. 2005 A8L W12 no climate control display on MMI
  167. Repaired Fog light open circuit but now a new question
  168. MMI update
  169. Newbie - 06 A8 AMI? AirPlay?
  170. Pictures of my D3 A8l
  171. MICHELIN SUPER SPORT ANYONE?
  172. I need some honest opinions
  173. Stock rims for sale
  174. Need info - Looking to buy 07'-08' A8
  175. No audio
  176. Need part #'s...help please!
  177. Calling W12 owners
  178. MMI UNIT DEAD
  179. Possible W12 Purchase, thoughts?
  180. Xenon Bulb Clip Picture Needed
  181. front light - A8 D3
  182. Have a friend looking at an 06 A8L...
  183. AMI retrofit, with MOST-bus or CAN bus?
  184. outside mirror dimm when Ignition is on ?
  185. trunk latch issue
  186. Chevron Techron+Shell V-POWER=extra 2MPG
  187. Anyone ever use Pirelli Scorpion Verde ?
  188. Bose Surround Front door speakers question
  189. A8 Rear Power Sun Shade Clips Broken
  190. 01577 - Suspension Issues - Where is the relay? Bentley Publishers is not helpful...
  191. D3 buyer's guide?
  192. Has anybody owned BMW 750li ?
  193. Car back from local Audi dealer with new problems!
  194. Sub installed
  195. Thinking of selling my '06 A8L...thoughts
  196. Tiny Design Issues with the A8 that bug you
  197. Steering Column Button
  198. Telephony module bad?
  199. S8 battery level in MMI
  200. Auto trunk opener
  201. New to Audi - Introduction
  202. Does my 2004 A8L have rain sensing wipers?
  203. Indy Mechanic in Red Bank NJ Area
  204. New Guy with Suspension questions
  205. Radar detection systems: built-in
  206. 2009 A8L Audi Exclusive
  207. One pink headlight :-/
  208. A8L UK standard spec
  209. New all season tires needed ... suggestions ?
  210. Mmi PDF guide
  211. Tinted glass windows
  212. GOPROS, H&R SPACERS and LUG BOLTS
  213. Thoughts On Navigation Disk Updates?
  214. V8 Badge Y/N?
  215. Can soft close doors be disabled?
  216. fs; 2006 audi A8L
  217. Transmission or What?
  218. Break/Rotor Job DIY
  219. 2005 A8L W12 Throttle Body Service / MAF Service!
  220. Engine Check Light - VAG Codes
  221. Help on Aftermarket Warranty / 75K Service /Tires
  222. Anyone have some burnt out leds?
  223. The noises it makes
  224. MMI update with Nav Disk 4
  225. Nast battery for D3
  226. Bushings
  227. High Beams Won't Come On, HELP!
  228. New member '04 A8L
  229. Some general questions (rain rensor, DRL, memory seats)
  230. MMI got rained on!
  231. Labor Day Special at Detailer's Domain
  232. Driven Hard or Cruiser?
  233. Removal of Instrument Cluster/How do I?
  234. Aftermarket subwoofer question
  235. Confused Dash Lights?
  236. Location of 10D black pin connector
  237. New OEM carpeted floormats don't latch well.
  238. Head lamp high beam adjustment..
  239. Anyone towing with their a8L?
  240. Grille
  241. 07 A8 Sunroof problem
  242. Help me get my menus back in MMI(Also posted in Vag-Com)
  243. MMI Upgrade questions
  244. Bluetooth Phonebook Integration & Memory
  245. 2006 trans replacement
  246. Taking the first step
  247. MMI Screen Retraction Issue
  248. So This Is The Thanks I Get, I am truly disgusted
  249. Hopeful new owner
  250. Why so cheap?
