PDA
View Full Version : A8 / S8 (D3 Platform) Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82
  1. I did my first timing belt on my 04 Ausi A8l
  2. Paddle shifter steering wheel selection assistance
  3. Disable Soft Close Doors
  4. Airbag settling
  5. Hissing sound from driver side of the engine, Engine misfire
  6. are CD players component protected ?
  7. Brake Pad/Rotor Replacement
  8. Trunk lock removal
  9. Parking Light Error 01494 and 01498
  10. D3 S8 used in "How to drive in America from a German point of view" Youtube video
  11. Door handle button broke
  12. New A8L Owner - A few issues, ABS Sensor help needed first
  13. Radio/Nav "Open Circuit" Faults
  14. Rear parking buzzer
  15. Rear HVAC motors location
  16. ACC AND BREAKING GUARD; NOT AVAILABLE
  17. Cig Plug and VCDS
  18. Sofl close door issue or driver's side
  19. 2004 A8L Exhaust blow out
  20. Samsung and MMI
  21. "Is it supposed to look/sound like that...!?"
  22. Advice on valve cover gasket, serp belt, and plug replacements
  23. This should be good.....I have choices.....need advice!
  24. rear driver side indicator cluster failed
  25. My recent VCDS fault codes-- input guys?
  26. Automatic on of auto-folding mirrors when parked?
  27. Bluechem Carbon X combustion kit
  28. charhger
  29. Vinyl button repair kits (and "sticky" buttons!?)
  30. Changing the trink handle/licence plate light holder/grip moulding
  31. 2005 A8 D3 improvements
  32. Rivets for Doors
  33. Air Suspension Issues - Out of Ideas..
  34. Water sloshing in rocker panel??
  35. Any suggestion on rod bearing replacement?
  36. brake caliper spring clip
  37. Audi D3 W12 2004 camshaft sensor - engine runs rough
  38. Cost Efficient WABCO Air Compressor
  39. Trying to do the Rain/light sensor retrofit!!!
  40. Why do people park like this? What protection is available?
  41. 2004 A8 MMI screen squiggles intermittently
  42. Replacing the flip-up screen enclosure/motor
  43. Audi A8L Brake Issues
  44. Glovebox audio\video connections
  45. Winter Tires
  46. Wipers not working, Please HELP :'(
  47. Audi 2006 A8 quattro
  48. Part number / name for transmission knob 'boot' / 'cover'?
  49. It's my turn... Please Check Navigation DVD
  50. Oil change and suspension check
  51. S8 V10 Oil filter horror & PCV whining sound & oil separator heater bypass kit
  52. Already have factory backup camera..What do you do when you want to add analog tv ?
  53. Transmission problems after battery replacement
  54. Mishar
  55. Am I able to
  56. Air suspension relay not engaging.
  57. 04 Audi A8 NO Lights ON Dash
  58. Getting a Hard Drive to work
  59. Changing Intake Manifold Adapter from coolant box
  60. Voice command
  61. Relentless Pursuit for Apple CarPlay on MMI 2G
  62. Air pump repair
  63. 2009 Audi A8 W12 Suspension Problems.
  64. Fix broken glove box frame
  65. TPMS error
  66. Think I fixed my Secondary Air Injection Issue
  67. D3 S8 Purchase Opinions
  68. Hood Parts A8
  69. MMI 3G AV questions.
  70. Rear passenger window won't go all the way up
  71. Inner tire wear, front passenger side
  72. my golf 5GTI doesnt want to move
  73. "Old Reliable" MMI System Reset Behavior
  74. Water pump brands
  75. Starting issue
  76. 433 hz or 315 hz for TPMS ?
  77. Heater Control Valve, 2006 Audi A4 2.0T
  78. 2006 A8 battery dead, trunk won't open!!!
  79. air suspension
  80. Swapping Bose Amp
  81. Elsawin Error
  82. 2004 audi a8 4.2 Wipers Not working
  83. 2006 D3 bluetooth music options
  84. D3 S8/A8 items for sale in Classifieds
  85. Changing front rt parking light bulb
  86. took off cover underneath my 06 D3 A8.
  87. My Audi D3 Archive
  88. Window winder dysfunction, window stuck half-down
  89. Bluetooth & Android phone calls etc.
  90. Another Window Glass Thread...
  91. Has anyone else experienced supercharge/catalysts going out on their Audi A7?
  92. Serp belt install problem...any suggestions?
  93. MMI Firmware Update Disk
  94. getAudiparts.com | Genuine Audi Collection Key Rings!
  95. New ride and a couple questions
  96. What car to unload ?? (and I'm a cyclist!)
  97. Brake (!) Red MIL warning instrument cluster - blinking
  98. A8l d3 strut question
  99. Air Strut has finally been fixed!!!
  100. Problem with Audi front lights part number
  101. How much torque of engine subframe bolts?
  102. Trunk Lid
  103. 2008 S8 Cigarette lighter door broken
  104. Front door removal
  105. Bumper Question
  106. Low Pressure Fuel Rail - HPFP defective?
  107. audi a4 1.8t epc and management lights are on
  108. 2004 audi a8 no power to anything
  109. loss power steering and a few codes appear
  110. 2008 A8L air suspension compressor
  111. Transmission
  112. Audi A8L D3 3.0 Rear Light Fault & Vehicle Cutting out
  113. Air vein repair?
  114. obd codes
  115. 06 D3 overheating
  116. Adaptive headlights
  117. Rear Pillars removal
  118. Headroom and seating position (mini study)
  119. D3 S8 steering rack failure.
  120. 2006 Q7 Bluetooth connection
  121. Rear right wheel Toe can't go further
  122. Please help interior lights and dash lights randomly turning on and off
  123. Lean codes bank 1 and 2
  124. Coolant leak under intake manifold on audi a8 2006
  125. Another suspension issue
  126. Hey look, another suspension thread!
  127. Borescope check on V10?
  128. BBS LM's - S8 carbon-ceramic brake clearance?
  129. Bank 2 Sensor 1
  130. Messy Module Swap?
  131. Air Suspension - Slight leak? Airbag or O-Ring?
  132. suspension problem
  133. Air Strut repair or replacment TIP!
  134. Front Bumper 2008 Audi S8
  135. Evaluating D3 cars
  136. Is Audi Parts Supply legit for Genuine Parts?
  137. Do I need to re code the battery after I disconnected it
  138. Axle - rebuild or replace?
  139. Swapped in a USED Battery Module
  140. Front Suspension
  141. Intermittent misfire and ECM codes
  142. 2010 A8L key not identified
  143. Muffler bisection complete
  144. 2008 A8L Ride Height Issue
  145. Parking brake malfunction
  146. Disable or otherwise "fool" annoying running-light MIL?
  147. Can Vag-Com/VCDS check oil levels?
  148. Maserati Quattroporte - eg 2006-08
  149. 2006 4.2L STARTER A BOSCH OR VALEO ????
  150. Removing Top Speed Limiter on D3 S8 - Lemmiwinks or Unisettings?
  151. Bootloader A8D3 4,2 quatro 03/2003
  152. Front and Rear door won't open from outside
  153. Air Suspension Fault Somewhere
  154. Trunk Lids ??
  155. D§ 4.2 charging issue
  156. Misfire on 2006 4.2
  157. Door Shade replacement with B&O
  158. Headlight high beams not working
  159. 06 Audi A8L.
  160. Installing Mufflers | How many oxygen sensors on exhaust assembly?
  161. Activating LOJACK on a used car
  162. How many Michigan members here?
  163. Daylight Driving light bulb change
  164. Looking for BT audio solution
  165. How do you guys store your car for winter?
  166. Camshaft Jump during timing job
  167. AMI retrofit problem
  168. S8 Climate Sync - what am I missing
  169. 17 in wheels
  170. Suspension settings grey out in Dynamic
  171. NEED INSIGHT | ABS, ESP, CEL| Lateral Acceleration Sensor, Camshaft Position Sensor
  172. 2007 (D3) Audi S8 - Engine Diagram or starter location?
  173. Shift knob removal - not budging
  174. Instrument cluster / headlight out of range
  175. A8L Won't Start After Replacing Wiper Motor
  176. STrange coolant leak location.
  177. Serpentine Belt Replacement | Looking for Diagram and Order
  178. New Product Launch Blue, red or clean bright white FOOTWELL LEDs for all AUDI Models!
  179. Ignition switch module replacement on 04 A8L Quattro
  180. AC
  181. Valve Cover Gasket Replacement
  182. Front and Rear Rotors DIY Service | How much torque to use?
  183. Dropped a valve, repaired and now its chattering like crazy
  184. help troubleshooting fault codes
  185. P2637 error code
  186. 2013 Audi A8L trunk lid inoperative
  187. Witch is my MMI?
  188. Hood won't unlatch on passenger side on my w12
  189. What type of wood is this?
  190. A8 vs 2018 BMWX3 vs X5 vs Q7 vs Q5 vs Tiguan vs KIA
  191. DVD changer will not eject cartridge
  192. Weak washer fluid
  193. A few VCDS questions and observations
  194. Throttle Valve Fluttering
  195. Proper Rotor Measurements | Options for ealy D3 A8
  196. Rear Brake Pads + Discs / Rotors Replacement
  197. A8 service reset
  198. 4.2L V8 | Engine Swap Possibilities
  199. Air Suspension strut removal pretty fast. Pic heavy
  200. BG GDI Fuel/Air Induction Service DYI D3 S8
  201. No Elec to air compressor
  202. Automatic transmission stucked in 3rd gear
  203. anybody had this tranny problem /what was fix ?
  204. 2004 A8L no response from key-no start or crank
  205. Found the clunk in my suspension
  206. Crazy Transmission Woes
  207. Changed cabin air filter in my -04...filter date stamped 2004!?
  208. Soft close door not working
  209. A8 2008 3.2 ECU Problem
  210. Red interior lights stay on
  211. Soft close door issue
  212. 2006 A8 3.0 TDI ABS module connector
  213. Electrical circus
  214. MMI Control Unit
  215. MMI update
  216. 09 A8
  217. Transmission Software Upgrade - Dealership only job or VCDS DIY possible
  218. RE: A/C BLOWER STOPPED WORKING
  219. Fuel pump relay in trunk/luggage compartment
  220. Battery cable getting extremely hot
  221. 2006 A8L
  222. Clunking and weird squeak
  223. Default F11 Top Coat Detail Product
  224. Fault code P0012 - sludge or VVT issue?
  225. Valentine v1 in d3-mirror
  226. NO: Car starts cold, not when warm (diesel)
  227. Wax or Clearcoat Failure?
  228. Doug DeMuro on the Euro-spec D5 (mini-review)
  229. drivers side door storage compartment is completely broken
  230. Reverse camera wiring
  231. Mmi control board
  232. Battery Drain
  233. Throttle Body Error
  234. Front Brakes Spongy after disc change
  235. Engine Error Codes Problem
  236. Rear Brakes Error Code Help Please
  237. Engine Cooling Fan Problem
  238. PSA from Detroit area: Buyer Beware of Audi A8 at Glassman Auto
  239. Engine waping
  240. Trunk lid tool set
  241. Suspension
  242. Lease takeover
  243. Audi A8L repair after colission
  244. Help with decifering Arnott struts
  245. Sport vs standart suspension
  246. Finding the HVAC heater valve on A6 V8 Quattro C6 2003
  247. diagnosing front seat problem
  248. Swirl Flaps
  249. Outside Door Moulding removal
  250. Der AUDI S8 V3 hat sich an mich noch mal gerächt!
