- Installed today new Intake Manifold on my S8 and getting CEL.
- Torque mount replacement on S8?
- [REQUEST] Navigation Wiring Diagram
- Coolant leak Between engine and transmission
- touch sesnor
- no boost
- audi a6
- 2006 Audi A6 C6 2.7tdi intake manifold flap valve faulty
- Looking at a 2009/2010 A8L, do they have an SD slot?
- Finding security access code?
- Lemforder Control Arm Part Number
- Audi A8 3.7 Quattro Oil Leak
- PARKING BREAK ISSUES
- Trying to figure out what options are out there.
- Exhaust system
- A few issues with Audi A8 D3 4.2L V8 (2003)
- Maintenance and other stuff
- VCDS Scan- Los Angeles / South Bay
- 07 audi A8 4.2 008213, 008224 at same time
- Wheels question
- Is VCDS still available?
- Rear seat Entertainment
- Considering this 2007 A8L
- 2007 A8 D3 Lift mode greyed out
- Audi lift mode
- Vaico ATF 8HP
- ESP and ABS light following battery failure/replace
- How do you make the Audi display songs?
- Parts for Sale
- Rear light LED's stopped working
- Seat covers
- how to get suspension compressor output reading ?
- Q about Head Light Range Control warning light....
- 06 d3 trans
- I probably shouldn't buy a 2007 A8 right?
- Bang & Olufsen - How to lower tweeter lenses?
- Audfi A8 2005 4.2 L Quattro Parking Brake Sensor light is on and Beeping sound
- How do I do basic setting/adaptation on control head (module 7)
- - 9 degrees here this morning and front air suspension
- suspension drop - question (codes below)
- Alittle misalignment...
- Strutmasters Air Suspension fix
- Near Swampscott, MA to check out a 2008 S8 at a dealer (will make it worth your time)
- ADAPTIVE AIR SUSPENSION
- Audi A8 3.0 TDI Quattro 2005 -Hardware number on phone-
- Have a small oil leak coming from the Oil Filter housing
- D3 S8 Brake options
- 05 Audi A8L sluggish, takes a while to shift into gear and leaks fluid - Help Pls
- A8 roof rack system - what options are there?
- Possible Purchase 2007 A8L
- Broken intake manifold flaps end up on top of my valves.
- Sideways movement over bumps
- dead battery or parasitic draw?
- Here's THE worst car care product I have ever tried!
- Q about fix for "self leveling" failure...
- 2006 a8l smog pump relay location?
- Front passenger seat oddness
- DVD Navi wire
- 2008 S8 carbon buildup
- Bulbs for hi-beams and fogs
- air compressor thermal sensor g-290
- audi a8 /a8l
- Battery drain issue (have already upgraded MMI and replaced battery)
- Backup camera does not activate in reverse
- Wrecked W12
- Keyed car
- Facelift Fog Light Question
- How my air suspension is behaving...
- 08 A8L 0668 supply voltage
- A6 3.0t or a8 l 4.2?
- 08 S8 Pricing help for 130k miles at pay here lot. Big gap!
- How much coolant is needed to top off?
- solar roof charging rate?
- Need help with an odd part request...
- Coolant found in engine oil!
- Rear Window Shade
- What does a Air Suspension Emission Vacuum Reservoir do? Please Help
- Please identify this part
- No Suspension Control in frigid weather
- Headlight issue - Need advice please
- 2008 S8 INTAKE MANIFOLD REPACEMENT
- '07 S8 Wheel size swap 19 or 20"
- S8 V10 5.2 FSI Common checks
- Driver Side Heated Seat Problem
- Grinding feeling when I brake.
- No Sound from speakers in 12 degree weather
- Battery replacement....
- S8 D3 crank sensor location?
- Accumulator Test in VCDS
- Diesel Injectors possible issue
- Warming up
- Audi A8/S8 Upper Control Arm Bushing Rebuild
- Misfire - Cylinder 8: Fixed
- Trunk Auto Locking not Working
- 2007 A6 2.4 starter wont release sometimes
- Coding 11/Login VCDS
- G70 code which side do I replace?
- 2008 Audi A8 radio comes on in about 10 second after car is locked
- wind noise problem, so I'm taking a survey...
- Audi logo courtesy light
- Will be doing carbon cleaning on my S8.
- Soft close Problem
- Orange Coolant (just an FYI)
- 2004 AUDI A8L | Display current speed on the instrument cluster
- HVAC Rear Heat
- my A8L doesn't like cold weather?
- S8 D3 tie rod ends size discrepancy.
- Econ off/on Normal operation?
- Steering Angle Sensor
- Pirelli's with noise canceling
- Installing Rear Comfort Headrests
- Spark plug fouling
- 2015 Audi A8L 4T eliminating speed goveror setting. And stage 2 program instal
- It's Christmas, be Merry and have a great one...
- 2004 A8 rear left sun screen blind
- Time for a new camshaft chain tensioner?
- Glovebox woes
- Burn mark on Headlight
- Brake pad thickness reset issues
- Yellow car warning light
- orientation lines
- Chrismtas Comes Early - Pinch Bolt
- Lower control arms ball joints
- Thump when going on and off the acclerator
- tail light LEDs
- Shorted Radio Control Module
- Back up camera doesnt work
- Heads Up - Control Head Reset! ...
- knuckle removal a8 d3
- 2004 A8L Leveling Crunching sound, wont stay on lift
- 2006 A8 key stuck in ignition...arggg
- A call for help/data
- Steering Wheel Off After Whacking Wheel Off Kerb
- D3 steering wheel upgrade
- Intake manifold removal
- Upper arms pinch bolts issues
- S8 started running like crap.
- Headrest swap
- 2008 Audi A8Suspension Issues
- V113 Recirc and why I have no heat :(
- When you have a lemon make a lemonade :-)
- 2005 A8 D3 4.2L Engine Whine
- Video clips of my A8
- Vacuum hose puzzle
- Gearbox Behaviour Cold Weather
- occasional no start
- Steering wheel button not working
- Spark Plug Replacement Interval for 4.2 engine?
- A-1 CARDONE is DONE.....again
- Help Identifying This Part of Cooling Hose Assembly
- Good times removing a seized Tie Rod.
- 2008 A8 114k miles, engine shot, best options?
- Newbie Hi
- Control arms advise sought.
- ignition Amplifier Module on AUDI A3 2006 MODEL
- HOOD LATCH STUCK
- Misfire/P0303/ oil on spark plugs issues.
- first oil change coming up, question
- V107 Flap Motor and Oil Cooler O-Rings
- New to vcds
- USB Memory Stick Recommendations & Question Re MP3s
- Overheating issues
- I broke a skinny hose and need to replace
- Newbie A8 questions
- A8L - A8L W12 strut question
- Engine overheating
- MAF FAULT WHEN FUEL TANK NEARLY EMPTY
- Audi A8 4E 4.2 supercharger
- tire selection
- AMI - went to sleep - hung
- Shifting issue 4,2 BFM/GQF
- 2008 a8L 125,000 miles
- A8 D3 repair / service manual pdf?
- ATF Fluid
- Right side front oil leak?
- Tool to remove fuel pump?????
- Tire Pressure Warning Light
- Looking For PDF User Manuals
- 2015 Q5 - my radio list for FM stations disappeared as did my AM stations.
- VARIABLE ACTUATORS, NEED SOME HELP
- Boot Wont close completely
- ANNOYING power steering noise issue
- Is There A Cheap Diagnostic Cable For D3
- USA 2009 W12 just purchased need help
- Massage seats mods on D3
- Air suspension not levelling and no faults
- No key identified
- Farewell for now and THANKS
- UK shipping company/customs broker to ship to US?
- Fault P000A - Camshaft Slow Response
- Strut Replacement
- Carista?
- 2006 Audi A8 Air Suspension Modes
- Door Proximity Switch / Battery Issues
- 04 Audi a8l (Help)Front end vibration of another kind
- Over heating
- D3 steering wheel replacement (with D4 model)
- diff between 05
- alarm goes of when using a cabin heater
- just did my first oil change on the 2004 a8....the horror
- was left/right standing light function deleted in 06 ?
- Adding AMI, but driver won't update
- Key fob buttons don’t work. How to resync?
- engine light, ran vag-com and these codes came up...
- Traded in the S8 for a VW Sportwagen
- Found a 2008 for sale, need CARFAX
- Air Suspension Outer Diameter Line Size
- TRANSMISSION GLITCH
- Aftermarket or OEM?
- New Tires Came Yesterday - A few questions regarding Alignment
- Strange whining/high pitched humming
- W12 for sale - just a heads up if anyone is interested.
- miles since last oil change (sri reset)
- vss
- A8 Power Steering Problem
- 2007 AUDI A8 AMI INSTALLATION ISSUES
- ABS
- 4.2 TDI - Is This Start Up Noise Normal - Potential Purchase
- DRIVER'S SEAT THINGY
- Oil in coolant overflow tank 2008 A8 4.2
- Looking for coolant reservoir alternatives
- ABS, ESP, loss of steering
- CAN'T FIGURE THIS OUT!!
- Adaptive Light Defective warning
- Waiting/Continuing to hold out on a D3? (Hypothesis)
- 2006 A8L Instrument Cluster
- Customized Audi A8/S8 video compilation!
- 07 audi s8 stalling question fuel pump?
- Loss of Power Steering, Suspension Forced to Dynamic. No Speedometer | Please Help
- Vag com needed in West Michigan
- Brake Light Switch : Audi A8 D3 2004 3.0TDI
- Think I need to replace ignition switch- Help
- MD changer for Audi mmi 2g
- UK: Looking To Buy TDI, Opinions Please
- Audi A8 D3 light coding for leds
- Changed battery, recoded, will not start
- Code P0087?
- Question on the Light sensor
- Question for steering column experts or not...
- Glow plugs question
- Intermittent Right Rear Fog Lamp
- MMi Head Unit Replacement
- 2006 A8L buying advice
- Winter Tires
- AUDI A8 WASHING FLUID LAMP
- Weird suspension problem on my s8!!!
- Seats mounting measurements
- Fan Blowing but no circulation of AC or Heat
- DRL on "AUTO" position ???
