PDA
View Full Version : Audi 5000 / 200 / V8 Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. S4 (C4) suspension in a 200 Wagon?
  2. Rear caliper removal (200 10V to V8 rear brake conversion)
  3. 1991 audi 100 needs a home
  4. i saw a red 200q in orange va fri you post here ?
  5. WANTED: Audi 200 parts car.
  6. Flywheel Removal - Rear Crank Seal
  7. '86 5KTQ: Fuel tank replacement suggestions?
  8. redrocket5000....was reading a forum from a few weeks ago...question
  9. Head question once again!!
  10. Anyone taken apart a CIS fuel distributor or have an extra to check?
  11. suggestions for a replacement battery? 90' V8
  12. FREE PARTS CAR
  13. coolant fluid
  14. a spring Qustion
  15. Anyone on here with a white 200 in
  16. Wierd brake symptoms...
  17. macgivers ignition switch repair
  18. bad BOMB.....?
  19. Help with starting issue on an 89 Audi 100.
  20. Help with cold start issue
  21. hey all quick question ........
  22. V8 Cell Phones
  23. 5000 turbo issue (Don't know much about turbos)
  24. temp flap vaccuum servo
  25. 1990 200 QT repair hell
  26. Anyone else have an Olympic with faded doors/hood/trunk/sunroof, but the rest is fine?
  27. Time to replace the O2 sensor..any brand preference?
  28. I like to keep an eye on the audis on craigslist.org, man have the prices gone up in winter!
  29. Wow, TWO 200 Avants near me FS
  30. 20V 200TQ Oil Viscosity
  31. I recruited a 'new' Audi owner
  32. I suspect my brake bomb is going out, does anyone have a good one lying around?
  33. Almost buying a 5000TQ! need advice!
  34. Starter problem... or wrath of wife
  35. These things could eat small children!
  36. Kneale Brownson user...little confused on high/low beam spring issue
  37. anybody here driving a V8 on I 384 in Manchester Ct. doin about 110 mph last nite?
  38. Turbo Bypass Valve on 20VT engines question..
  39. Warm Start Problem
  40. Hey pretty trick ride ...does this belong to someone here??
  41. Need a reputable tuner shop to look at car
  42. "Dimmer" for an 89 100
  43. Wiring questions/issues... '89 200 TQ
  44. transmission troubles
  45. Another 5000CS radio question
  46. Update: 1991 200q20vt. I bought it a month or so ago. New boost hoses, bypass valve, MFTS, WGFV,
  47. 1991 200q20vt Avant part number(s) request: rear plastic piece that the license plate bolt to, plus
  48. For those that remember my issues last winter (heater core)
  49. Fog Light Install/Electrical Q?
  50. are the repective sensors the problem?
  51. off board for a bit
  52. suspension compatibility question
  53. '89 MODEL 200T Air con.
  54. Want to buy a v8 quattro auto
  55. 5000 stereo system....advice/anwers
  56. nearly trashed my engine and trany today in freeky accident....
  57. 65-70 cms of snow in less than 24 hrs : - )
  58. She made it!
  59. dont know how to remove ignition switch
  60. Leaking oil cooling hoses
  61. 20v200Q no heat,erratic temp gauge-multi function temp switch?
  62. 5000...high beam/low beam problem....
  63. greddy profec b spec boost controller f/s
  64. Here's something you don't see often - 5K turbo engine with 2 oil filters
  65. Hey JRSATX, is this the car that I think it is?
  66. Help!: OEM Car alarm going off when not engaged.
  67. Are summer tires drivable in winter?? Kumho Ecsta?
  68. overdrive
  69. '91 200 20v running well, and is a beast!
  70. Need new rear wheel liners for a 87 5000, where to buy?
  71. JRSATX are you out there?
  72. car wont start help..
  73. V8 - Replacing the O2 did the trick. Passed the e-test!
  74. 1992 100CS need to know how to set seat memory
  75. Question regarding the side review mirror ------------>
  76. looking for a lago drivers side front fender- 1990 200 tq- good sites?
  77. Mystified
  78. chmnyboy
  79. Okay, who scarfed up this one on FleaBay?
  80. 87' 5000cs turbo...alternator belt keeps loosening....
  81. 86 CS 5000 Turbo Wagon, Seats...
  82. Very Hard Start after overheat, very bad coolant leak. 5k turbo
  83. Electrical problem on my 90' 200. Radio & gauges black!
  84. Bolt pattern for 90' 200? 5x108 or 5x112? Winter tires?
  85. Turbo vacuum leak
  86. 1987 Audi 5000S won't go in reverse!!!! help
  87. Looking for Audi200 - Brake parts - Toronto Area
  88. Audi 200
  89. What would happen if you were to drive without the aux cooling pump?
  90. All gauges down on instrument cluster, gauge lights still on
  91. More on rich running V8...
  92. Removal of audi v8q automatic
  93. Wastegate question
  94. 1989 Audi 100 Question
  95. Does anyone have crankshaft holding tool and wrench I could borrow in the Seattle area?
  96. 1987 quattro 5000cs
  97. 90 200tq wont idle and no power above 2500 rpm
  98. TB Service
  99. Anyone have a Blower motor/fan? 1990 V8?
  100. Anyone ever use this stuff?
  101. some 91 200t questions.
  102. redline manual trans fluid
  103. some pictures of the new Audi named "Florida".. 1990 Pearl White V8 Quattro..
  104. need help locating source of these problems
  105. FUEL LINE ISSUES??
  106. virbration above 15mph - 89 100q
  107. Hydraulic Pump Again
  108. Didn't work on the Audi, but scored some nice tools this weekend...
  109. V8q questions
  110. News on the 91 20v - thanks to everyone on the FP install issue
  111. There goes my Audi . .
  112. Simple solution to a several day stumper.
  113. 91 200 20V AVant Struts? Is the Boge T the stock ones? My HD Bilsteens are great in town but on HWY
  114. REGISTER NOW: New England GTG on Wed, Nov 15 in Framingham, MA
  115. Weird V8 fueling problems...
  116. anyone have a right hand reflector for 200 euros?
  117. I'm Looking for some V8 body parts
  118. Temperature Regulating Flap Motor - 200TQ
  119. chmnyboy are you still looking for parts?
  120. where are all the V8's
  121. FS: 87 5000sq
  122. Well I'm now part of the V8 family! first question inside..
  123. Volcano-Effect in P/S Reservoir
  124. a/c heating & windows fogging question
  125. Distributors - '88 5KTQ vs '89 200Q
  126. ok guys.. Might have scored a 90 V8 for $600-$700 bucks need some help..
  127. computer not working
  128. Update on 4ktq no start (please read)
  129. Do they make rain guards for an 89 100 ?
  130. how do you check the drive shaft in the quattro for problems ?
  131. About the v8 PT and ABH engines, what the differences between?
  132. 86 5000 CS turbo wagon
  133. what are the single wire coolant sensors for?
  134. Yahoo, finally sold my '89 200!
  135. A little trick / engine
  136. Needed, Trip Computer LCD for 92' 100
  137. '91 200 20valve fuel pump part II - woes
  138. I figured out the blower motor...
  139. My clutch?
  140. Help!!!
  141. MP3 player jack w/ stock stereo
  142. Is UrS4/UrS6 a post '91 100?
  143. Ok, let's toss this theory around.
  144. Bad mileage after a new fuel filter?
  145. 89 100 running problem.........
  146. To Anyone parting a 200TQ, I need a Brake MC (master Cylinder)...
  147. Installing a throttle switch on an MC engine
  148. And here's me again thinking that a shop can do things reasonably...
  149. Can someone please check this part number?
  150. Audi super meltdown scenario... interactive.
  151. does anyone have a detailed pic of the rear driveshaft?
  152. Some Disconnected Wires and Hoses I Can't Find...
  153. Does the hood have to come off to change the front strut inserts?
  154. rebuild kit?
  155. Windshield wipers stop in the middle of the windshield.
  156. V8 not passing emissions...
  157. Euro headlights for T44
  158. continued from previous post,
  159. To anyone parting a 5000TQ
  160. I still need a window regulator . . .
  161. A6 4.2 vs 200q20v
  162. v8 are super hard to find.
  163. Carb cleaner or something else?
  164. Is there a "right" way to clean an MC engine?
  165. Does this hose look normal? Looks like it's been under severe vacuum to me...
  166. 1990 100 Didn't Like the Car Wash...a few lingering questions.
  167. 89 200TQ, "stuck" decel valve, unsticking?
  168. new 91 100 quattro purchase.......a few questions
  169. Very, very minor part request...
  170. Temp Guage Pegged Full Hot
  171. bizzarre electricks
  172. engine and transmissions mounts
  173. Finally got a chance to turn over my motor by hand. Should there be more and less difficult "phases"
  174. Removing starter - anything I'm missing after the two bolts and the wires?
  175. Replaced Hose from Wastegate to ISV -- Questions ???
  176. 4ktq no start, help!
  177. Plz post pic of 87 5000cs engine bay
  178. want to sell 95 audi 90 sport fwd 5 speed
  179. when i turn my headlights on both turn signal arrows and high beam light stays on now what ?
  180. Crunchy metal noise heard when starting? Car won't idle, dies quickly. Uh oh.
  181. Wanting to Sell, Audi 5000 CS Quattro Turbo
  182. not to happy with 1995 a6
  183. Gear shift lever
  184. 91 20V. How many bars should be on the stock boost guage? My car is jumping/jerking if full speed
  185. Hey V8ers... are the front brake pads really that easy to chage?
  186. wow 25 mpg in my 91 quattro 100 5 spd is this for real ?
  187. door wiring.... am I just lucky?
  188. Perhaps we should be glad we don't own RS6's with high miles
  189. wheel fitment: V8 Quattro 90 model
  190. back with more boost questions
  191. ive read much about air temp sensors bbut
  192. Wild temperature control in 200tq
  193. Codes for Dummies.......
  194. wrong coil wire?
  195. '86 5000 TQ Oil cooler lines
  196. Popping fuse for central locking system on the V8. Any ideas?
  197. Twin Turbo V8 Type 44 in Deutschland...
  198. [TUE Oct 17] This is it L.A., last GTG @ The Stand for this year... don't miss it!!!
  199. Needle Bearings in V8 P/S Timing Belt Cover
  200. 87' 5000 CS Turbo (Again)
  201. Audi lovers in Missoula,Mt
  202. Alright, I need some parts...
  203. 200 20vt Wastegate Question
  204. UFO Rotors for cheap
  205. Turn signal blinker question
  206. 2113 - Starts & runs fine... for about 10 seconds
  207. Anyone happen to have a pin-out for a euro-spec fog light switch for 85-88 200tq?
  208. Nevada Audi Fans???
  209. boostin' questions : Whats HG ?
  210. TopChip or anyone for that matter ..........
  211. Bad Boost gauge?
  212. Checking diff lock operation
  213. '90 Model 100 Right Axle (Type 44) & bearing Replacement
  214. 91 100cs in need of good home
  215. Tranny fluid change
  216. Local tire company advertises they sell new tires filled with nitrogen............
  217. Still wanted: 200 quattro parts car.
  218. Full throttle switch question
  219. Brakes and Steering really hard at low speeds, on a 87' 5k CS, power steering pump?
  220. 1990 V8 driveline appears to bind
  221. Hey Ron... itsav8 Odd Vag Error Code-90 V8 3.6
  222. 1990 V8 steaming up windows, but no sweet smell of anitfreeze
  223. Southern Electronics Inc anyone used this place for instrument cluster repair
  224. '90 Model 100 Right Axle (Type 44) & bearing Replacement
  225. Best quatrro system?
  226. 1987 Audi 5000 CS Turbo Ignition and Etc.
  227. passenger window wont go up, always
  228. Thanks Kneale for pointing me in the right direction.
  229. Forum etiquette
  230. Catch can install..
  231. 89 200TQ won't hold idle, I just replaced....
  232. A journey to parts car land (long)
  233. Question on SACHS clutch disc?
  234. Any Utah posters here? I need some contact information ASAP.
  235. Laundry list of problems?
  236. Widow regulator Remove and replace procedure
  237. 86 CS 5000 Turbo Wagon
  238. Dash lights going out
  239. Advice on 17" wheels that will work with UFO brakes/1991 200 20v
  240. power window help needed
  241. Finally got pics of my new ride.
  242. Looking for a quick sale - V8/200/100/500 Thule roof rack feet
  243. Looking for undamaged B-pillar trim pieces...
  244. I want an R8 <insert loud baby cry with tears> That is all. (sorry for useless post)
  245. 89 100 issue .........
  246. Finally got my door glass after oh, 3 months... Can anyone point me in the way of
  247. Audi 200 Prepurchase
  248. Anyone have special tool 3214 close to Tucson, AZ I could borrow?
  249. Long time - two new cars
  250. Hey V8ers... FPR question...
