PDA
View Full Version : Audi 5000 / 200 / V8 Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 [100] 101 102 103 104 105 106 107
  1. cross drilled rotors?
  2. One more thing, the P/N for the resistor pack so my fan doesn't always run at high speed
  3. Also, my temp guage is out, sometimes it comes on, what is the P/N for the sender unit?
  4. How do I fix a sticky caliper?
  5. Cranked up the Boost! This car flies!!
  6. does the 86 5ktq have single or dual piston calipers?
  7. front brake pad warning light is on, RR wheel scrapes when braking, front brakes slip
  8. Selling the 86 5000 CST
  9. Audi 4000 Quattro Aux Gauges for sale...
  10. Hellllllllllllllpppppppppppppp....
  11. Annoying brake light and beep
  12. Cly head project is finally finished
  13. What's the worst thing you've put your car through?
  14. Hey Gary/Steve (in GA)
  15. Fuel Injectors
  16. Audi 5000 Aux gauges for sale.
  17. Audi V8 in 1:18 SCALE
  18. I think my tranny is gone....
  19. Lookin for somethin New...???
  20. New 200 TQ Avant
  21. Sanity check! Help!
  22. Ive said it once and I'll say it again, I really want this 200 !
  23. Diverter (Blow-Off, Bypass, etc) valve questions.
  24. Well the engine is finally out. Yay! :P
  25. E Bay item Item # 1843798336
  26. Has anyone ever put a belt driven supercharger on their NA 5 cylinder engine ?
  27. how many of you have the dreaded cracked dash or wavey window seals?
  28. Fusable link installed...
  29. How much is a AAN exhaust manifold worth?
  30. Should I resurface the flywheel while changing the clutch
  31. HELP!!!Please.......1st and 2nd gear gone.........
  32. how would these A4 wheels look on a 5000S ? or any Type 44
  33. starter removal
  34. Well, the "Side Servo" gets repaired....
  35. Project "Odometer"
  36. gentle thump from the front end while driving above 30mph
  37. Found this info on rad fan bearing replacement...
  38. Hey New Problem
  39. HELP!!! Tie rod end
  40. Any one seen this 83 TQT on Ebay? Sweet!!!
  41. that Audi 200 on Ebay is over $3000 !!
  42. timing belt question
  43. Is your fusebox cover tough to get off?
  44. Well I'm back from vacation and starting to pull the engine
  45. turbo lag
  46. This shows that Bosch is some high quality stuff.
  47. I was perusing Ebay for 5k parts cars and ended up with this
  48. Starting issue
  49. Turbo woes... kinda long sorry
  50. Audi History please?
  51. A rough idle success story
  52. Hey Jim Bush here's a pic
  53. Maintanence woes
  54. Audi 5000CD Turbo Quattro Olympic Edition
  55. It's Alive.
  56. Cam gear bolt and seals
  57. Audi 100 Question
  58. So many Trips !
  59. Please Help! Hot start problem. Replace injectors?
  60. What is your favorite gear?
  61. crazy thoughts on radiator fan
  62. Audi 200 Questions.
  63. Help! I need ECU # 0 280 800 134 for 86 5Ks
  64. Timing belt and seals - 5000 QT
  65. Lets talk about radiator fans, fusable links, etc...
  66. Looked at a possible parts car candidate this past weekend...
  67. Cyl head swap?
  68. The wheels may be worth the price
  69. starting problems
  70. Found this in the performance and tuning forum.
  71. Jim Bush -- Re: Idler Pulley -- 5000 QT
  72. Does your Pentosin resevoir look this bad?
  73. V8 quatro 5 speed shift knob interchange
  74. Audi 200 2.2T Quattro 10valves chip needed.
  75. rattle at 3.5k-4k rpms must be the clutch
  76. 5000s with rear spoiler opinions wanted
  77. I know this has been asked a million times but.....
  78. 5000s intake backfiring problem
  79. Junk yard tour!
  80. surfinsilly need any parts ?87 5kcstq 5spd
  81. Sun Roof Woes...
  82. Is there a difference in engines from a '90 200 Auto..
  83. What is the purpose of the 6 inch hose feeding from the front bumper into the alternator?
  84. Prestone antifreeze?
  85. Mysterious rattle from the front of the engine compartment at and above 4k rpms
  86. 1988 5000s
  87. reverse engineering - wheels
  88. Pentosin CHF 7.1 power steering fluid ??
  89. Nice 5000!
  90. looking for 2 wheel caps 85 5ks
  91. Question: What solution do you use to clean the ISV? How?
  92. 2002 NORTHEAST AUDI AFTERMARKET EVENT INFO & REGISTRATION
  93. 5KTQ 5sp in distress, send help
  94. Anybody (Tom) know where I could find a cheap...
  95. Calling Steve in GA:
  96. New Rear Shocks are in...what now Crotext???
  97. Mystery solved??????
  98. 21 Point Inspectoin
  99. Sunroof Headliner
  100. Well Just got the Audi 100 back from the delearship
  101. getting main pulley off 5000
  102. Mid Muffler
  103. Ordered the center bearing from Blau today...
  104. A/C wiring diagram
  105. 1989 200 quattro for sale
  106. engine misses
  107. Opportunity knocks: Road trip to pick up a 5000 TQ...?
  108. Need some help with parts, and what you think of these prices...
  109. anyones car surge at highway spds only when a/c on?
  110. audi v8 rpm sensor
  111. O/T But the "Junkyard" people on the list will like it
  112. Reminder: Audi Lunch GTG in Reston, VA (Thursday July 11th)
  113. Re-finishing Wheels
  114. Buying a radar detector
  115. Fact: There are NO old Audi Quattros in southern Alabama.
  116. Front brake ticking/rattling when hot....
  117. Audi mysteries...
  118. You guys ever take anything apart and forget...
  119. Wow, the 5ktq was car and driver's number one of 10 best cars for 1986.
  120. Anybody replaced a fuel pump recently? got suggestions?
  121. To RTV or not to RTV, that is the question...
  122. who wants to donate a 5000cstq to a good home? heh
  123. Gonna buy some new tires! What do you guys recommend
  124. VW Parts
  125. O/T computer help needed - pop up ads shutting me down
  126. DanA100...
  127. Warning light on dash
  128. Well I think I am going to go ahead and change the clutch
  129. Driving without the bomb
  130. Anybody else spend the 4th working on thier Audi?
  131. Stereo Modifications and Questions
  132. red light flashing in dash board please help
  133. Too much time on my hands - a helpful hint
  134. swappin out the slushbox
  135. v8 quattro battery problem
  136. Starting Problems
  137. Having problems removing the main pully nut.
  138. Engine question: Whats a wristpin?
  139. a/c question
  140. Different chips for 20v turbo 91 ???
  141. Drag coefficient (Cd)...
  142. D1/44 Application Chart - Feedback Wanted!
  143. My can of Pentosin leaked. What irony!!
  144. clear corners for 91 200TQ
  145. 1987 Audi 5000 S
  146. Hey Everyone
  147. door sensors??
  148. Auto to 5-speed conversion on V8
  149. For Steve and the other "Junkyard Hawks" a real score
  150. V8Q body conversion for 200 20V
  151. Would gutting the cat create less backpressure or would it be better to go to a straight pipe?
  152. Where to post car for sale?
  153. Anyone change a fuel pump before?
  154. Could loosening the main pully with a impact air wrench damage the crank?
  155. When replacing the clutch do you have to remove the engine/trans and then separate them?
  156. I'm hot! 1987 5000 CSTQ A/C compressor questions
  157. New shocks...
  158. 86 5KTQ project/parts car must go.
  159. From a guy who's owned both a 200 10v and a 200 20v...
  160. Check out this baby! Gotta go wipe myself up before i turn my keyboard into a pool! drool***
  161. Ignition
  162. Audi tech in Tulsa OK.
  163. Audi 5000 H4 Euros for sale
  164. Those of you with QLCC, IA, or whatever chips (IC question)..
  165. Fixable?
  166. I know Gary and Steve are from atlanta! Anybody else! I wanna get a little get-together .. together
  167. 1991 200TQ aftermarket stereo problems...
  168. Well dangit, I broke a piece while trying to install the cam.
  169. Do you have to remove the the driver pull off the crank to change the timing belt?
  170. Help...with "hot" starting
  171. 91 TQ Avant purchase
  172. Anybody running anything other than a stock turbo?
  173. koop~ Chip Mod
  174. Does anyone know the part #'s for the turbo to downpipe and the em to turbo gaskets? (1990 200tq)
  175. Audi V8Q front on a 90 200 Avant.
  176. Off to Cleveland and Mid-Ohio for the weekend...
  177. speaker size
  178. 200TQ 10v...2 motor choices?
  179. At last!
  180. Need help with removing exhaust manifold
  181. Bilstien's on ebay
  182. Steve~ do you get your junkyard parts from pull-a-part?
  183. Good Info!
  184. More on my 200! ..... Taking longer then i hoped!
  185. Brake problem, help
  186. 2.2 L 5 Cyl. ignition question
  187. quattro and speed?
  188. Great Site for EFI Troubleshooting
  189. 5000 Power steering pump rebuild digram
  190. how much worth 87 CS QT
  191. looking for parts and pics
  192. HELP EMERGENCY!
  193. Weirdest thing!
  194. Where is the power window control relay?
  195. Paging: Tom Faust
  196. Need advice on the 'ol 5000
  197. Sport shocks and springs
  198. Does the oil line housing above the filter come off and fit on other cars?
  199. Junkyard Musings...longish
  200. "Ice guard" / Dynamat sound insolation update...
  201. Transmission/Final Drive leak
  202. Power steering pump noisey...
  203. Repair Manuals for 100/200
  204. Just installed new pads and rotors, what a difference
  205. Need downpipe for 5KCS Turbo
  206. Need source for reasonable rebuild Rack&Pinion
  207. A/C diagnostics question . 85 5KCSTQ
  208. Looking for coilovers/shock+spring combo for 200Tq
  209. Mysterious rattle on the 5000 QT
  210. BAD TIMES i need help
  211. Smaller Pulleys!!!!
  212. 200 vs 5000 (again)
  213. hey you east coasters!
  214. Quattro ?...hand brake works on rear tires right?
  215. I saw a 5000 on I-94W 2 days ago..
  216. Instrument Panel removal - can't get one wire out!
  217. Somebody just buy my '89 200TQ
  218. Rear Differential Fill plug 5000 QT
  219. 91 Audi 100 Autoom. Electric problem
  220. Bad week
  221. Timing Belt
  222. Anyone know the part # for the power window control relay? Thanks!
  223. Anybody want to buy my car's twin?
  224. Some new Projects for my Car...
  225. V8 for sale
  226. Waterfest 02'
  227. My car is equipped with a phone? Sweet!!!!`
  228. Anybody see this TQW on Ebay?
  229. water pump
  230. fuel pump, boost problems, what next?
  231. Cleaning engine compartment - What to use?
  232. More on my 200!
  233. Behold, the can that is a staple to my car's diet.
  234. Rack replaced and a leak
  235. Need a couple parts...
  236. Hi Everyone
  237. More Audi mysteries
  238. Update on my 90' 200_10v
  239. Audi 100, NF, 1990, Co adjustment
  240. Off to Cincinnati, Ohio...
  241. Almost got rear ended today by the local postman...
  242. Shocks...need advice :(
  243. Door lock broke -- @#$%*&
  244. AC question
  245. 10V High Po Turbo Head Work
  246. Coolant temp gauge...how high?
  247. A plea for sympathy
  248. She's Alive ...... well almost again!!!
  249. need an engine
  250. new problems...
