- Looking at buying a V8 Quattro
- Compression Dropping Head Gasket?
- Need UFO Rotors for 1990 V8
- Fan meltdown and now weird ticking noise
- Drive shaft remove
- steering rack R&R
- 1983 Audi 5000 Turbo power window switches needed!!!
- Rear trailing arm outer bushing
- Looking for speed sensor "87 5000 cs tq
- Timing Help
- brake issue '87 5KQ
- Oversized Roof Rack
- 1990 Audi 100 Turbo Quattro too high boost (code 2224)
- Need a crank pulley/balancer for a '90 200q!
- FS: 1988 5000S Quattro
- 1990 audi 100 quattro running poorly
- Looking for Mech/tuner for V8 in Los Angeles
- Need help/advice on removing the rear caliper piston
- 1988 audi 5k cs tq CIS modding
- 93 Audi V8 gauges
- Do we have a write up for RACK
- Audi 100 1990 2.3 NA Automatic trans reliable??
- Welding V8 frame rails on 200...
- 1988 Auti 5000s Quattro Not Starting
- Need help with 1989 audi 200 tail lights
- New one for you. Boiling Power Steering fluid
- '87 5KQ non turbo 380K miles non start
- N75 Valve - Compatible for MC engines?
- need 10v mc1 cyd head
- bad ground? 91 200 avant
- Looking for an stage 1 boost upgrade on 200 turbo 10V because of my WG
- 1990 V8 has to go...
- FS: Audi 5000cs turbo quattro
- New to audi v8 quattro
- Audi 200 disconnect the turbo?
- Are the windshield wipers and turn signals linked?
- '89 200tq $1000 obo
- Suggestions for getting antifreeze out of carpet
- which heater control valve is correct for a 5000csqt?
- Help with a Bentley shop manual!
- Rear Brakes
- How do you remove the plastic engine cover on a 5000?
- Fuel exhaust
- Two Audis for sale
- Power Window Issue 86 5000CS TQ
- '87 5000 cs VDO tach not working
- what does the 1-2 switch do?
- Mysterious fluid residue on '87 5000CSQT
- Smoked Tail Lights
- sonofa... got hit today...any have parts for a 91?
- audi is toast...who needs parts
- 1988 Audi 5000 Cold Start Idle Issue
- Strut Mount Replacement
- 1987 5000 CS TQ Idle Problem
- 1987 5000S Q 380K non starting
- 1990 100Q fuel issue
- 1988 Audi 5000 Manual Boost Controller
- Timing Belt 1986 Audi 5000S
- 2.8l V-6 = 0 compression
- crank shaft, oil pressure, altinators, breaks lines, fuel line
- 200 20V Front CV Axle
- Ignition lock and shifter mechanism
- 1990 100Q 332K miles
- what can i do to my audi 5000
- 90 V8 rear drivetrain vibration
- WTB 016 prefix 3U transaxle
- Bosch Alternator For Sale
- Massive Oil Loss
- Rear brake job. Can someone point me in the right direction
- driving program switch where do ya get this ?
- help, she's dead
- 86 audi 5000 CS TQ - need yellow Window Relay / "+" seals for PS Pump
- Power Steering Fluid
- 91 200 20v 6 spd swap
- My 5000TQ saved my life
- Just bought a 88 5k turbo with issues
- 1989 200 q rear differential grommet leak
- headlight help
- Small electrical issue
- 6th Cranckshaft bearing and 4th and 5th conn. rod bearings worn/marked. Loooong...
- 89 200 Avant/Wagon I-5 Turbo
- 1989 100 Quattro
- Question on 5000cstq T35 Wire Distributor
- Question on T35 Wire Distributor
- Bad day park brake problems
- No spark, no fuel after used cylinder head install
- 200 20v ... Need some things!
- clutch pedal problems
- I need a (slightly) longer alternator belt
- Electric schemes Audi 100 TD
- continuing fuel supply issue in 1990 100Q
- Audi 5000 --> 200 door swap. V8 door handles?
- 89 200 Strange Fuel Gage !!!!
- 1990 Audi 200 stereo in safe mode?
- 1989 Audi 200 quattro hesitation/turbo lag, hanging up
- Cruise control repair questions. Is it possible to plug the vaccum lines to test?
- Gamma CC instead of Gamma/Bose with Bose Speakers. Is it possible?
- Alternator DIY
- off road audi?
- Bad gas,water in tank or bad fuel pressure regulator?
- Hall sensor 2113 questions
- figured you guys might like a shot of my newest addition to the Avant
- New ignition switch = no crank
- low coolant and oil temps. autoshift indications
- 7.5mpg....
- 89 to 91 audi 200
- Investing in classic cars (Audi 100 coupe)
- Auto to Standard.
- Diff Lock Problem
- Problems with 1990 QV8
- Intake hose
- Bose Radio works but all speakers distort. One or several amps?
- Need advise of how to fix dash trim
- audi 200 turbo problem help
- Variable boost controaler
- Euro Headlight
- 1988 Audi 5000 CS TQ Misfire
- stripping a car...what should i get
- Audi 5000 s Turbo Cylinder Head
- Some Fuel upgrade questions/bouncinig ideas...
- 86 AUDI 5000 Quattro cut out under full throttle
- WTB "Butt Pad" for heated seat
- 200 w/20v For Sale in NH $2500
- Hot back seat (200 Tq)
- oem euro springs
- squeaky radiator mounts?
- Power, leather, heated seats upgrade
- Interior modificationis?
- ◦'91 100q vs '90-'94 V8 Trunk Liner - How do they differ?
- Writeup on oil pan gasket R&R on 5KCSTQ
- 86 audi 5000 CS TQ - idle not controlled
- 1991 Audi 200 20v 5 Cylinder Turbo Quattro
- Looking for upper and lower steering wheel stalks trim parts. Any guess?
- the diesel...shes stuck in the snow
- 90 a100 egr valve location
- Audi 200 1989 or 1991
- 91 20v avant gas mileage
- Powdercoating pictures
- Pictures of new oil cooler lines
- E brake cables
- My 1990 Audi 200 Turbo is whistling…
- warly 90s 200/s4/s6 trans question
- audi v8 uk breakers
- timing belt replacement alignment help!!!
- My Audicakes
- 1993 v8 blower not blowing
- overboost problem.87 5ktq
- 1990 a100 Bose amp locations?
- need a bbs wheel
- 1990 a100 oxygen sensor location?
- special tool
- special tool
- Can anyone explain how that long metal rod thing between the a/c comp & alt works?
- 1991 Audi 200 Quattro 20V Instrument Cluster Gauges Not Working
- Relay & Ecu Assortment
- 1990 a100 door locks not working
- 91 200 20V mis-fire
- Alas, sadly the time has come...
- 89 Audi 100 Door Locks
- 1989 Audi 100 sun roof
- 200 20VT Fuel Cut questions
- Just picked up my 200
- Heated seats on 86 5000CS TQ
- V8 Quattro Idiot Display
- 1989 Audi 100 Fuel Pump Removal
- Cruise control/ injectors
- V8 trunk struts for the 100/200: Does anyone have any feedback?
- Black Friday at 034Motorsport!
- Question about drive belt sizes
- New oil line vs old line
- Wiper arms
- power steering fluid for my 86 audi 5000
- 2 Broken wires on MAC 11 ECU
- Audi 200 Stebro Stainless Steel Exhaust System
- FS: (2) 1990 3.6L 32V V8s Engine
- 100 hood adjustment
- A/C on hiccups on power
- Best source for buying a new Warm-up regulator
- Oil cooler lines
- V8 Motor Mounts
- Swaybar bushing washers...
- 90 Audi 100 Coolant
- Starter & oil pan update #3 cont'd (with photos)
- Starter & oil pan update #3 (and a few photos)
- Audi 200 Parts for sale
- Sensor and or Wiring issue - 86 5000TQ
- 1991 Audi 200 Turbo Quattro 20v
- Instrument cluster
- v8 won't start.
- Quick Alternator Help
- ABS problem in 1990 100Q
- 91 200 with BOSE system and aftermarket stereo unit
- About v8 Camshafts.
- V8 3.6 to 4.2 conversion
- just wanted to share an xpost of what's been goin on with my 200 avant...
- Can someone verify a part #
- Audi wiring for dummies (starter and oil pan r&r update # 2)
- MC1 block for sale
- Audi v8 electrical?
- 7A cams
- Losing Patience, melting fuse on fuel pump
- Need to know this. Is the center trans shaft from a 200 20v the same as on an S4.
- smelling gas
- V8 valve covers
- biz zar 2
- where should I install my newest present?
- 1990 V8 4.2
- V8 steering pump again.
- stuff for sale
- Looking for a 200 Avant...
- found it!! now for questions...
- ring end gap spec
- Update on starter and oil pan R&R
- Deflector for injector cooling 034133905b
- Completely bizarre starting problem?
- question about electrical connections
- ABS problem on 1990 100Q
- Bad vibration after installing center transmission shaft support
- More peculiar behavior from my starter
- chk eng light under load
- turn signal lenses
- replacing the oil pan 87 5KCSTQ
- 034 throttle cam
- Cargo Cover, Other Parts Wanted
- A/C compressor gone --> no heating?
- 1993 Quattro V8.. Hard to find parts I've GOT
- Super high idle/unplugged ISV
- New to the game
- tell tail signs of a bad starter?
- beware to v8 guys
- 3.6 V8?????
- Lock and Key for 5000?
- 10v camshaft
- Finally fixed two annoying problems on 86 5000CS TQ!
- Parting out '89 Audi 200 TQ
- Blaupunkt Bose Delta
- How much power can be made from a 10V?
- RPMs up and down
- Dave Audi Garage
- 200 20V hot shifter/e-brake area
- radio Woes
- Coolest Audi 200
- Projector Lamps for my C4
- V8 1991 Air Conditioning.
- 1991 200 avant relay setup
- 1990 v8 serp belt help ... photo anyone ? ?
- 5000 snow thrower
