- '90V8 Oil Cooler Hose Removal
- It's been a long time but I'm back
- Advice on unreplaceable hoses
- WTB: passenger side chrome trim
- looked at a 1991 Audi 200 10 valve turbo
- Audi 100 CS?
- Source for original capacitors for Bose speakers Audi 200 20V
- 1989 200 Cranks but wont start
- cold start issue: flooded or ignition?
- Spare LF Window Regulator ?
- Intermittent Dash Indicators
- What is this part? (door locks issue)
- 2004 A8 Quattro, Loud Engine Knocking and oil sludge
- Sluggish / delayed automatic transmission shifting on '86 Audi 5000 S
- 1987 Audi 5000CS headlight
- 96 A6 Dash / Instrument Cluster in 90 V8
- What's wrong with my poor 88 5000s?
- 86 5000s - gutless pig
- troubleshooting ac on 86 5000S
- intermittent smoking
- 200 20v Throttle Potentiometer
- changing 91 200tq seal from back of transmission
- Best brakes for 100 typ44 Tq
- looking for interior parts - 86 5000S
- I bought the 86 5000S
- 91 100
- V8 Cruise control..works when i heat up the cabin.
- 86 5000 will not crank
- newbie looking at 86 Audi 5000
- *V8 Quattro, Help?*
- 91 200 fresh air flap operation
- help! car cranks won't start
- 89 audi 100 crank sensor?
- Fuel pump replacement 200q20v issues
- Original BBS wheel from '91 200 20V
- 1986 Audi 5000 CS window electronics
- UFO coversion
- ECU upgrades
- 91 200 Motronic control unit location? and other various electrical issues
- Quattro Euro E code lights anyone?
- New 5000 CS turbo quattro owner
- 1991 200 20V rear caliper rebuild kit
- Will be parting out an 89 audi 100 automatic
- Quick question about V8 brakes, not a how, but a how much money.
- 91 200 20v turbo quattro suspension upgrade
- 200 20V upper radiator hose
- Steel fuel line replacement, 200q20v
- Anyone else having problems posting to audifans?
- 1987 5000 CS Turbo Quattro Wagon Light or Heavy Duty brakes?
- Coil Overs
- introduction, just bought a '91 200 quattro avant, first questions
- 91 200 Misfire
- ATSCO Reman Hydraulic Pump--BTDTs?
- Audi 200 good used parts available
- Audi v8 Quattro 5HP24A swap?
- V8 Quattro seat belts, need info asap
- Looking for 1 center cap 1991 100
- Is there a way of testing the cruise vacuum pump without removing it?
- Serious current draw - 1991 V8 3.6 auto
- Audi V8 3.6 Motronic control unit - where is it?
- fuel injector regulator
- Wipers, Turn Signals, Cruise Control
- A "new" source of used 034133471K (3B, AAN and ABY) MAFs.
- Has any of you installed molded mud flaps in your 200s?
- my audi 200qt
- Odd boost issue on 91 200 20v
- 1990 v8 missing @1800 rpm and up ? ?
- Is it really worth this much?
- 20v Driver's side door latch release
- What front seats fit in a '90 V8?
- Ventilation display/fan speed question from a 90 brother..
- Found weird Audi 14" alloys in junkyard - identify?
- Break Bomb part number: audi 200 20V
- Rebuilding Bose Sound Rebuiding. Some questions
- Timing belt replacement, 91 200q20v
- leak in fuel supply line-5000cstq
- 2-2 above rear bumper corrosion & fix AUDI V8
- 1-2 above rear bumper corrosion & fix AUDI V8
- 78-83 Audi 5000 fans ??
- Carslie 2013 / prep work / 93 V8 4.2 see PICTURE
- 200 20VT 3B Boost Leak Test Options (a work in progress) (comments welcomed)
- best place for vacuum hoses?
- Low oil pressure at 4000rpm
- Pretty cool on the way home tonight!!
- V8 Quattro Service Manual Suggestions
- K24 vs t04b for 91 20V
- Potential purchase--Thoughts?
- 1990 200 Turbo Quattro Starter
- Fan relay cliking like crazy
- 89 100 high rpm problem
- Start issue at altitude: flooding?
- Looking for real help 91 V8 4.2 or 96 A8 4.2?
- 1991 200 steering leaking! Replacement thoughts?
- Fuse locations for Auto Check and Trip Computer 200 20V?
- Alternator belt keeps breaking 87 5ktq
- 1990 V8 trans is toast; Options??
- Need crank lock tool 2084
- Fuel pump relay issues
- 200 20V turbo
- 1991 200TQ Interest
- Fuel pump adapter?
- couple of V8 parts for sale
- Audi 200 TQ No spark
- 1992 Audi V8 parting out
- Ice Racing Highlights
- Can an autobox from an Audi 100 be installed in a 200?
- 3 speed gearbox difficult to engage reverse and vaccum diagram
- Audi V8Q intake modifications
- 1991 200 quattro 20v Avant wheels
- Head Gasket timeframe
- 3 pin versus older 4 pin temperature sensor
- Grill trim clips..where can I find them?
- EDO-dome lights and radio went out
- 1990 200TQ Trans code
- Stalling after high RPMS
- Heater Core hoses
- 1989 Audi 100 stalling and hard starting
- Whats interchangeable beween 100q and 200 20vtq
- Bought a 1989 Audi 100, help please
- V8 Quattro Fuel Filter Location? Help!
- 1990 Audi V8 Quattro Chip?
- timing belt broken
- Do fuel pressure accumulators leak?
- connector under bonnet
- Cat Delete
- '90 V8 Hit Deer - Looking for Spare Blinker Lens & Headlamp Part
- cleaning hydraulic reservoir--what solvent?
- Mac-11 chip tuning question
- hit a deer
- Ben Swann ->
- transmission swap
- Steering Wheel Removal
- 300,000 mile 5000S
- 200 Cold Start "issue"
- Need AC wiring harness for 200 20V. any ideas?
- Audi 200 Door Lock Cylinder Operating Arm
- Audi 200 HVAC system failure.
- Editing For Sale Ad
- replaced ignition switch...now what?
- i was "audi 5000" thing took off on me
- Replacement radiator recommendations?
- have brand new 034 tranny/diff mounts.
- Eurolights anyone?
- 1992 V8 4.2 transmission fluid level??
- 1991 Audi 200 quattro turbo NEED DISTRIBUTOR!
- What is this hose?
- vehicle speed sensor fun, V8Q
- Thinking of Buying a 1990 V8
- 1990 Audi 200 Turbo - Which octane do you use...???
- car, Transmission and other parts for sale
- "stalling" problem
- Gas gauge and instrument cluster not working
- ECM for 1991 200TQ
- It Lives! 1990 V8 Quattro & Spark Plug Gap
- 1990 200TQ
- Newly acquired 20V, have a few questions
- '79 Audi 5000s cunundrum
- Radiator Cooling Fan not working
- Newbie looking to get into a 20V this weekend, what should I know?
- radiator for 200 20v
- Auto check and trip computer not working after jump battery start
- Blauparts.com says they have the Bosch WR7DTC
- Missoula, MT '91 Audi for sale
- 3/1986 Audi 5000CS Quattro Turbo Parting out.
- 1990 V8 Coil Test - How?
- TWO WEEKS until S-FEST West! Register now to ensure your spot & door prize!
- Need help! Replacing turbo and bypass valve for 200 20v
- possible new owner with questions
- V8 REAR DIFF
- 1990 Audi V8 parting out !
- k26 Question
- What happened to this forum?
- 1989 Audi 200 Turbo brake prob lems
- 91 200 20v
- '91 100 speedometer
- 1989 Audi 200 Valve Head Conversion
- Idle Vacuum on 2.2 turbo?
- Sport Seats Compatibility
- No AC Compressor - '86 5000CS TQ
- Need a good '91 Q-V8 DIY repair manual
- '91 V8 Quattro Dies at consistent temp
- Free.....OEM Color Code Touch-up Paint Pen
- GOOD Online source for V8 quattro parts?
- aan motor
- 90 V8 fr half shaft replacement
- Fuel Line replacement questions?
- 1990 V8 Quattro Speedo Problem
- BlauSport Struts/Shocks
- FS: 1987 5000cs QT
- Audi 5000 Turbo Mechanic Special
- FS: '86 5000 CS (turbo quattro) in Brooklyn, NY
- clear turn signal covers
- doors, doors, doors
- New to Audi, picked up a 1991 200TQ
- Fan relay cliking like crazy. Car bucks
- Back in the game.... got another 5000, its got issues
- AC fan on 20v200 Avant
- 1990 Audi V8 Quattro Alternator
- Need a front passenger half shaft for '90 V8
- 7A cams for 3b build
- Partially working lights and climate control
- Hp22 ZF Transmission Temperature Sensor Location (Audi V8 Quattro 1990)
- ha ha!! and so it begins
- Any cure for old Audi addiction?
- Ignition switch removal on a '93 V8 Quattro
- 034 Shift Kit
- 89 Audi 100 not starting.
- 5ktq partout
- 1990 No Start - 1990 V8
- I need some parts help...
- 1990 3.2 HELP!!!
- WTB; Door lock
- Brake Warning light
- Lifter tick?
- WTB: Front and rear struts
- door locks inop from drivers door.
- '91 100 rough engine shut off
- Serious AWD Tire Question - 1990 V8 Quattro
- 91 200 20V
- brake warning light?
- 1986 audi 5000cs overheating
- 1990 100Q air bag light
- MTM Stage 2 Chipset
- Help finding timing mark of flywheel
- how much can stock 2.2 10vt 5000 handle?
- 5th gear boost surge 12psi-15psi
- V8 Wiper parking
- Who's 4.2 V8, Ohio plate FMZ 3694
- Coilovers or strut and spring?
- Check engine while in boost. '90 200 quattro
- Help with 5000 Shifter
- 89 100 Fuel pump number?
- 500TQ/200 20V springs/struts
- Clicking in steering colomn when audi 100 is completely off
- Brake Accumulator Questions
- Window regulator rubber mounts
- Replacing TPS
- Rotors....
- Strange things while bleeding clutch
- Floormats
- CV Boot book time
- Crank Case vaccum line
- Audi 5000S
- 1990 100 part numbers
- Turbo Removal?
- 100 Quattro shifter socket
- heater/idle ? and diff locks mod
- Looking for a good 1990 V8 RF CV Joint & Trans
