- Does anybody need a set of indiglo gauge`s fo a 5000 CS turbo? If so I have a set!!!!
- want to bore out block want to know were to pet pistons
- Computer Problem
- Mileage issue
- quick ? - how do you open the doors on a shaved quattro?
- Distaster strikes the "Evo Killer" 200q20v
- WooHoo! Finally, some decent snow....
- AMM, Fuel Distributor 89-200QT
- Progress on the car...
- Sighting, Columbus, OH
- Euro-spec Treser...
- looking to get a new clutch sometime this week....
- Ti retainers....Yea or nay?
- Audi 87 5000s starts ok but engine stalls in just a few seconds when cold
- What is the good cylinder compression for an MC-1 10vturbo engine from an 87 5ktq?
- shifter boot
- Hey Audi200tq - Is your car for sale?
- Does anyone know where to get a MFTS for less?
- search continues... guess how much CDN $ he wants...
- X Post for 200 20V owners looking for more hp.
- Door lock actuator doesn't work
- Hey Mowafy....
- 89 200 tq. Dwell will not adjust.
- turbo upgrades (feeler)
- My friend has about 6 to spend, i was thinking a 5000s with a 5kCS engine in it
- Was anybody watching TLC?
- QLCC ECU fired up fine...
- Here's the damage
- CT/NY Audi Group Get Together & Dyno Day Update - Dyno Scorecard & Car Wash
- need a torque converter off a 087 tranny! any takers?
- so I'm running lean and want to enrich the CIS...
- Lookig for a bypass valve for 86 5000 turbo q
- Newb looking to buy old V8 Quattro
- Adding another to the stable. My first type44......
- What kind of pistons does the 3.6 v8 use and are inexpensive low-compression replacements available?
- Question
- Electrical chaos in my 5000
- What to do with the 91 200q?
- searching for an Audi 5000S engine
- Coolant leak
- Would guages from a 88' 5000 work on a 95' 90......
- i need a blower motor
- CIS tool...
- what is some good mods for k24 turbo
- does anyone have pic of oe 5ktq wheels?
- calling NY, CT NJ... and whoever in the NE
- Heater Blower Operation (Tried searching)
- High NO reading on emission test
- Sort of Scientific Survey - How much is this 89 200tq worth....
- 85 5ks door handles
- Thinking about a 200
- 5ktq suspension interchangeability
- Alrighty, here is the post that will define if I will be buying a 5Kqt next week
- Finally, I have something to post about...
- '89 Audi 100 Questions
- chronicles of the blown speaker
- HOW TO CALIBRATE SPEEDO FOR 86 5KTQ AVANT
- nice work....
- V8 quattro upgrades
- Anyone have a 5ktq pressure plate they want to part with?
- '90 V8 with warning lights
- CT/NY Audi Group Get Together & Dyno Day Update#5 - This Saturday 1/24...
- Stupid lights....
- Written off.... ouch.
- separate wastegate exhaust?
- what kind of bump in boost can I expect if I do that " put bolt on W/G spring" mod?
- What's the audi part number for an RS2 turbo ?
- 86 5ks p/s rack
- 2 cherry 200 20 v for sale on ebay...
- Red triangle BRAKE light flashing.
- Need help installing remote starter switch
- where can find glow gauge`s for my audi 5000S
- This forum is so dead. Looks like a case of Mondays :-)
- Toxcheap how much do I have to spend to run 13's with '86 5ktq?
- How much would you pay for an '88 5ktq in OK shape, with 95K miles?
- Thicker Sway bars? Coil overs?
- How or where do I get a new transmission for my GFs 1990 100?
- instrament cluster
- Attack of the foaming oil - Part III
- Tacho repair info...
- What is the engine code of the 1986 N/A 5000s engine
- 89 200 tq fs
- V8 Fuel mileage
- hey rockinv8vq
- does anyone know what....
- 1991 Audi AVUS Quattro
- ebay strikes again
- 200q20v vs Evo VIII
- A show for all 5K owners to watch......
- WANTED: flywheel from 3.7 or 4.2 manual tranny car.
- Focus rims on this 5K?
- K26 options
- Help with ECU Fault Codes Please (audiqV8, rockinV8q)!!!!
- Update on my possible V8. Need advice (long)
- More pics by popular demand! (Multiple Pic Post Inside ... and i really mean multiple)
- HELP! I need to replace the Heater Core on my Audi 100!
- Things that make you go ... Mmmmmm!
- You Sexy BEAST!
- what rims are these off of?!
- pictures of my boost gauge (and a couple others of my car)
- Thanks Stephen, got the key and it works great!
- 200q20v now with limo tint and V8 tails
- MC1 Rebuild
- Hmmm...Audi-VW brakes
- Has anyone ordered anything from Direct Parts Online?
- southern parts cars
- Dumb starting problem !!
- fs. 5000 avant in canada
- Better/stronger Valves, interest?
- now heater only blows out defrost vents again - must be alien possession or it it just being an audi
- Can I put 17x8.5" et38mm wheels on my 91 200 without rubbing ?
- Intake backfires...
- XPost...some nice pictures
- My boost gauge
- my weekend project.....
- heat miracle
- Question for you guys...
- leftover 200q parts
- Questions about head rebuild...
- Comps for 1990 200 TQ?
- SPEC Clutches Possible group buy for cheaper clutches
- Hey Stephen, how's the key modding going?
- 88 5KT, some parts gone, BUT
- by the way...
- What are everyone's feelings on Total Audi Performance?
- Rims for Audi 200. 5x112 w/ a 35mm offset?!!
- Sandblasted the Valve Cover! How addicting. I wonder what else i can do now. btw left it gray/steel
- driveshaft center bearing symptoms?
- I guess we weren't cool enough to get a forum header image?
- WG spring, where is it and what does it look like?
- 89 Audi 100 tends to die and will not restart until it warms up when in cold weather.
- Questions about 20v
- heater woes.........
- which direction does the crank shaft spin?
- Anybody on here from Chicago? Need a favor.
- Horrible Noise 5000 TQ !!!!!!Help!!!!!
- GAS SMELL!!!!! Yikes...
- 3spd auto noise
- 86 5ks instrument light blues (reds, actually)
- 89 200 TQ or 87 5000 TQ prices and diffs beyond new interior
- A couple of Questions to V8 guys
- Ok...RI AWs where are you? North Prov. RI here
- Anyone Know of a headligth kit for 86 5000 qutrro
- Does anyone Know of an up grade for intake
- Is an Gasket Kit for 86 5000 turbo the same as a no turbo?
- If anyone needs Rear caliper or Bentley manual for 100/200
- Re: Hey Adam Mowafy.......I have a pair of 5K wiper arms.
- bosch and hella kits (reference to older post)
- EPROMs Programmed...
- 86 5ks owners manual
- How do you pop the hood open if it is jammed
- Attention 10vt owners...
- Fidanza flywheels for audi 5000.......
- Using 9007s....
- V8 Climate Control
- trouble pulling fault codes, early 89 200TQ
- looking for good,not loud fuel pump 200 T
- West Coast Driving Schools..at the track..>>
- Reminder: EPQC Events THIS weekend (skiing and karting)!!!
- 200q32v project official kickoff.
- New Year. New GTG. New Location - NE Ohio GTG 01/17/2004
- Audi V8 Seat Heaters
- Okay, lighting question after the Xenon thread I posted.... (long)
- 89-200 TQ hesitates and misses. Displays 5 mpg
- Anyone need a T3 or t3/t4 w/ k26 housing?
- Metric fuel efficiency?
- Euros on Ebay
- 5k "fuel injected"
- looking for a new oil pump for 3B engine
- Anyone have a cheap source for wiper arms?
- yeah its official, the 5KT is dead
- Found a TRANNY!! $200! Don't know exact miles but ... the guy said its low. I gotta pull myself!
- How to get the Door Open
- How many 91 200 20v Avants ?
- Hmmm, what is it with Audi's and woman accelerating
- Max 20v 200 wheel/ tire sizes ?
- Noise in right front
- warm start problem " trick "
- I hope this was a typo.......
- AUDI 100 PARTS INTERCHANGEABILITY
- late xmas gift from a friend!!!
- Opportunity to buy a V8
- my 200 hesitates when accelerating
- Quick question....
- Non Turbo Quattro 100, 1989, California .
- FOR SALE FOR SALE
- Heads up! Useful tool on clearance.
- Ignition Switch is bad ?
- Finally getting somewhere
- New to the forum, here's some pics of my ride
- How do you start an automatic 200 w/o the key ?
- engine 15 degrees advanced, can't pass smog
- Lord of the Rings
- Front cartridge shock absorber replacement.
- Found one... in England! - M12x50mmx1.25TP @ L1.04
- Whump, whump.
- can someone please explain this one to me?
- Thought i would share pictures of my baby taken at night
- Stole from V8phil..I just love the looks of this car
- sunroof hardware
- Still have Audi but now selling at the local Aston Martin/Jaguar and Land Rover dealer....
- A little dirty but she's still sexy as hell
- V8 Power Steering Pump Question
- Bodyroll? :-)
- Looking for a donor car in or around GA
- how do i get pics
- Okay... have any of you guys converted the HAA key (ie Switchblade key) found on '96+ A4's for your
- pics you dont want to see but should
- question for V8Norm
- clutch return
- Good car battery information site
- China Audi
- Cold weather - tranny problem
- Tools required for front brake pad replacement?
- Anyone have part numbers for 200 euro head lights...
- '91 Audi 100 9004 Headlights to Stage II Xenon Kit (Pictures inside)
- wipers ailing
- Ok, Role call again......who are u........where u live....what u drive?????????
- Good Audi Mechanics in Kalamazoo, MI?
- audi 100 problem, looses power
- Questions for used car...
- Finally I get the distribution correct! She starts!!! Its downhill from here (more)
- I need a pair of 5000 dome lights.
- 91 20V performance upgrades
- driving around yesterday and my drivers side window and half of the windsheild fogged up......
- Intermitent Blower Motor
- Getting an A8
- Question for you 200 folk coming from a 100 guy....
- wanted: info on tow bars
- headlights, 91' 200tq
- Oh boy oh boy oh boy...
- Used parts in central Ontario
- Strange RPM problems?!?!?
- Is there a way to post a few videos I have on my hardrive???
- idle lope
- Starter part numbers, transplanting, etc.
- M12x50x1.25TP bolt? Where can I get one?
- Looking to buy a cd magizine
- Booo Yah... Its here Baby
- door pockets
- Would a BPV help with stock ECU & Wastegate Spring???
- i may part my car
- Tire pressure question . . .
- It's been around 20deg F the last couple evenings (I know; that's nothing...); anyway my 10v is an
- 97 audi 5000s slow into 3rd gear when cold ,automatic
- opening trunk...
- Aftermarket alarm for 1991 V8Q
- what are stock turbos on 5000/200's.... i know k24 or k26 etc, but are they made by garrett? or who?
- Paging The birdman...Need part number and more.
- solution................maybe
