PDA
View Full Version : Audi 5000 / 200 / V8 Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. my car finally passed smog! ended up being the distributor cap/rotor and wires that were giving me
  2. 200 20v ignition miss? Long story....
  3. boost questions 87' 5ktq
  4. 92 V8 for sale ibn Baltimore MD
  5. the job begins ... T Belt 93V8 .
  6. Treser Audi
  7. the morning opener (Ghost in the machine)
  8. stalling
  9. Hooking up XM Satilite to a car with a Bose radio & factory CD changer in trunk ?
  10. what kind of suspension do I want for my V8? (look inside) (long)
  11. Cd=0.30. One reason that I liked the 5000 from day one.
  12. rough idle and other things
  13. Aluminum stiffener for door moulding???
  14. Maybe it's time to start fix my audi.
  15. New Audi V8 enthusiast here. Looking for performance / lowering springs
  16. rowdy audi on ebay
  17. Fender and bumper +
  18. How nimble? gas mileage?
  19. V8 guys: Are we at the mercy of the dealer for strut mounts?
  20. Pictures and results of Classsic Audi meeting in luxembourg
  21. Shocks/springs purchase
  22. valve cover gasket
  23. Last Chance! Type 44 ('90 100) Headed to Recycler
  24. Intermittent Warm Start Problem
  25. cam pulley
  26. Antera Rims
  27. No Headlights - 90V8Q
  28. Anyone have the PN for the Ignition Noise Supressor on the 110 Amp Alternator?
  29. Has anyone put dual exhaust on thier car? Pics?
  30. Brake light is Blinking!!!
  31. More Alterenator/Charging System Questions (long)
  32. What else is the splashguard
  33. Getting Sulphur Smell after hooking up lambda(o2 Sensor)pre-heater.State sniffer just passed car A+
  34. This may be old news, but Autohaus AZ sold me a Boge clutch MC that doesn't require the short wrench
  35. is there supposed to be a vac line that attaches to the nipple on top of the wastegate? 91 20vt
  36. WTB: V8 tail lights for my 5000CSTQ
  37. 5000 QT Cooling Fan
  38. '90 Model 100 Heading for Boneyard. Part Out?
  39. 87 5000cs
  40. Since I'm replacing bulbs,diff switch is red,engage light is green should the graphic be lit?
  41. 89 audi 100 auto trans.problem
  42. Oh geez that's a lot of busted stuff
  43. Alternator Removal Questions
  44. trying to get this car to pass smog, runs clean at speed but reads high emissions at idle 91 20020vt
  45. doing control arms on the V8 this afternoon. they're pretty straight forward,anything i should know?
  46. how complex is replacing the injector seals?
  47. Laundry list of problems...
  48. Window Regualtor Question...
  49. fuse location
  50. How common are Audi radar detectors?
  51. Looking for heater control box
  52. cold start valve??
  53. X-Post - //S-Fest West Registration
  54. battery drain follow up...
  55. Engine Clean up
  56. What is this remote for?
  57. OK Guys... You get first dibs...
  58. Anyone getting "fed up" with the AudiFans Marketplace lately?? [Rant]
  59. no spark on my 5000s HELP!!!!!
  60. Good evening Gents, Just picked up a type 44 200TQ which will become a track car. Has anyone here
  61. 1990 100 Alternator Belt Problems
  62. battery drain...
  63. tick tick tick ( V8 )
  64. Who was looking for a type 43 turbo diesel?
  65. 91 100 Quattro cutting out...
  66. Is there a market for 5KTQ parts?
  67. What's the sensor under the intake manifold w/6th fuel line running into it?
  68. I originally bought my 200 as a donor car for a 90 swap but this car is so clean and fun to drive...
  69. could this be an ignition connection issue?
  70. NEED HELP ...with 90 200 QT transmission PROBLEM
  71. K24 turbo differences?
  72. *Free car* Giving away my baby... :(
  73. a little off topic....
  74. Overheating
  75. Was cruising local craigslist and saw what might be a decent deal
  76. After Run Relay - Rebuildable?
  77. Why did the V8 lack cup holders?!! I'm sick of wearing coffee!!!
  78. dot 4 brake fluid is correct for 90 v8?
  79. strut noise during turns v8
  80. EZ 200 Dash Switch Illumination Repair With Lots O' Pics
  81. Ur S4/S6 steering wheel on V8Q?
  82. hydraulic fluid
  83. Kindly need some info from the '91 200 20V crowd..
  84. Any Ideas??? Experiencing problem w/ a '91 200
  85. So....Who needs V8 parts?
  86. been driving the car for a few days now......this Racing clutch along with the 4:11 gears is well...
  87. i think the starters on its way...
  88. '91 200 20v - bilstein's vs. koni's - which and why?
  89. Just brought home my new (old) 1991 200 20vtq! thanks fabryce @ gmg
  90. She turned 100 today...
  91. Green flood, expansion tank install questions
  92. installing 255/40r17 on the V8 today. pictures to follow.
  93. Got off lucky today, and PSA: listen to the BTDT's on clutch hydraulics here!! Questions still..
  94. shifter getting hard to shift
  95. Local oldskool show for you PA guys....
  96. just a rant!
  97. It only took 2 1/2 years....
  98. Gas tank off a 91 200 TQ
  99. Two questions about 200 10V compatibility with other TYP44
  100. Used 90 amp alt: under 50 miles 60 dollars takes it
  101. Looking for a used type 44 trailer hitch ('88 5ktq)... email if you can help
  102. Anyone in here live in Savannah, GA?
  103. Just bought a '91 200 20V to replace my 2005 S-4 Avant - have ?? please help out a noobie
  104. going price of cometically challengined '89 200A 144k miles
  105. K gents .. i need some input from the ones that are familiar with the 10 & 20 V turbo 5 cyl
  106. Sourced problem of short at fuse circuit # 4...........
  107. How is it possible to have gear oil leaking out of my CV boot?
  108. So I decided to swap out the cracked dash in the 86 5kcstq...
  109. starting question
  110. ignition locked
  111. Someone in Minneapolis - St Paul area
  112. 5000 turbo intake
  113. Factory Manual Updates
  114. Engine Code?
  115. Overheating ?
  116. Anyone have a guide for steering rack removal on an MC2 200q?
  117. where to start
  118. Back home from Carlisle
  119. Fuel Pressures -- Cold Start issues.
  120. Sunroof repair
  121. Steering wheel upgrade question
  122. SSSOOLLDD!!! thanks for all the help everyone !!
  123. Hello all... looking for a good buyer's guide or similar resource for a '91 200q.
  124. Does anyone knows what is the sensor on the back of the head on 200 20V?
  125. hot weather....now i have hard or no starts?
  126. Anyone have an open Carfax? Email me.
  127. parting out 200, lots of goodies, efi, 10vt, etc...
  128. wierd a/c comp belt noise..Qv8
  129. can air filter replacement really be this hard?
  130. Another question: cold start issues
  131. Bomb dead after only several months???
  132. 3.6L V8 Coolant Temp Sensor
  133. For some a sagging roof-liner isn't an issue....:)
  134. 89 Audi 100 - No Start, Battery OK, What next?
  135. highway hesitation
  136. upgrade to v8
  137. UFO Brake conversion, Searched forum but anyone have experience?.
  138. Blown Turbo fixed! Was-'The incredible shrinking wallet.........'
  139. Anyone want this?
  140. Yo Forumer's, just wana say mr. Brownson kicks a&%$ on the forum...
  141. Audi V8 Transmission Fluid Level
  142. power steering pumps=pain in the a#s
  143. Oil pressure warning symbol...'89 200tqa MC1
  144. Would this be the infamous re-circ flap spring?
  145. 200 20v no start-no signal to fuel pump, ignition etc. help!!
  146. 200q20v fuel line whazzit?
  147. a few newbie questions
  148. Identifying cams...
  149. Follou up to quest for T44. Any one enterprising want to make a buck?
  150. found out why my fan keeps coming on!(i think)
  151. Continuing quest for really nice type 44
  152. Frustrated!
  153. Noobs' Guide to Doing Things That Bentley's Doesn't Tell You How to Do - Removing the Back Seat
  154. back speaker not working - where do I start?
  155. 1987 5000 Quattro-non turbo intermittent high ilde: CIS E III...
  156. What is a normal running temp for a 3.6 v8?
  157. Are all Audi 5 lug rims the same bolt pattern?
  158. new brake issue....
  159. How do I know if the center diff is locked up?
  160. Where are you wagon guys hiding 10s?
  161. does the mfts have anything to do w/running the rad fan?
  162. electrical gremlin
  163. sport exhaust for $144
  164. what's this light for?
  165. The new GTI W12 650........simply wow.
  166. Car stopped again!!!! Dammit!
  167. Anyone know the real story behind this ACNA notice?
  168. Anyone know the location of temp sender on 87 TQ?
  169. Rods are now shot-peened and micro-polished as is the crank....
  170. Hello forumer's, I need help with wheel sensor on a 89 200 atq
  171. Anyone know if 17" RS4's will fit on a 200 20v w/ UFO's?
  172. Spliting tranny guts from center diff
  173. potential scam
  174. The incredible shrinking wallet.........
  175. Nice looking 88 5k for sale locally...
  176. radio in 89 200qt
  177. Looking for VW parts in chicagoland
  178. finally got the engine in but...
  179. One weekend to fix it all...
  180. update on my semi-frequent no start....
  181. exhaust options...
  182. 90 audi v8 trans.shift problem
  183. Cylinder head pictures...
  184. i'm giving up car for sale cheap 90 200 tq
  185. Where to purchase wastegate diaphragm
  186. my 1990 200 turbo..
  187. Paging auditech1218
  188. oil cooler lines
  189. Anti lock switch pin out?
  190. bentley manual for sale
  191. No start 200 20v
  192. anybody need parts? just sold car still have fuel pump wires rotor cap
  193. Columbus, Ohio. I need a favor
  194. Is Flushing the radiator a bad Idea?
  195. '90 V8 E-Brake Cables Replacement
  196. Anybody replaced radiator fan lately? what's the best price?
  197. Audi 100 1991 - AC Compressor
  198. Since my headliner is completely missing over the sunroof, I needs some direction..
  199. 87' 5000TQ ignition system question....
  200. Caps and Sticks
  201. 200tq - clicking on passenger side and 2nd gear hesitation?
  202. 89 200TQ, oil light came on, only 1/4 qt low. Help!
  203. 20vt efi question... please help!
  204. Freebie: Audi Phone pamphlet (V8 Quattro)
  205. steering rack
  206. ignition lock cylinder housing
  207. need an A/C compressor, is this ebay unit worth the risk?
  208. 200tq doors and trunk fit on 5000cstq?
  209. while I wait for my B8 I thought I'd get a ...
  210. 91 200tq 20v - Visual Mods, Anti-Roll bars, Reliability?
  211. I find this auction description funny
  212. An RS4.....in MY driveway.
  213. Photos, rear window blind and moulded roofliner
  214. v8: rebuilding v8 block
  215. '90 V8Q engine shake at 1200, 2400 rpms
  216. Audi 100 Brake Caliper Questions - Lucas or Girling
  217. Fault Codes???
  218. Looking for a N.A. (non turbo) Quattro transmisson.. ADG code
  219. steering rack leak
  220. V8 power dropout. Question for 4x5x5
  221. PSA: Tire Rack has 5ktq/10v200 front brake rotors for $31/ea (link inside)
  222. Business Week article on Audi
  223. A long ride East...a long awaited bath...polish and primped She be...
  224. wire
  225. Fuel Pump Noise?
  226. Unintended Acceleration 5000....can't figure out.....
  227. altenator makes too much voltage
  228. PS pump question
  229. 5000 variable drivetrain Question
  230. 5000cstq seat interchangability?
  231. V8Q Gas Mileage
  232. With the cost of gas going through the roof. It is lucky for
  233. Running Still.....
  234. no start
  235. correct control arms?
  236. Update on my beast. Racing clutch, subframe bushings, control arms...
  237. Hottest Audi in America? --->
  238. Looking for a 89 200 TQ trans!
  239. all this trying to figure out the issue w/ my audi got me looking through old pix.. bww
  240. power steering
  241. Meet Saturday May 5th 2007 10:00am AMC Mercado20(Taxi's) Santa Clara, CA
  242. clattering noise from under the front cover
  243. Yet another 200 20V hesitation (or do you call it stumbling?)
  244. v8: possible to fix piston rings?
  245. Any BTDTs? 15x7 ET37 ronals with 205-60-15s on Audi 100
  246. Your daily dose of racing humor
  247. oil cooler and lines
  248. audiqtNewb.....you still have the audi...
  249. took some pictures of my car...thought I'd share
  250. Does the NA 5k/100q have four or five bolt hubs?
