- update to previous post. car chuggs sometimes after hot start, always starts
- 1990 200 quattro 5spd $1000
- '92 V8Q for sale in Idaho $3850
- Oil change adventures...
- Front suspension strut
- 5000CS TQ gauge cluster issues - Speedometer not working
- Fault Code 2312
- Should I buy it? 1989 200 t.q.
- 3b/7a Metal Distributor Gears
- Anybody need a brand new drivers door lock mech for a quattro v8? 25 bucks
- Just installed stereo system into my 200TQ, with custom door pods, check this out :)
- Without Dif lock If you drop the clutch at 5grand will all tires spin?
- opinion on 1991 Quattro Coupe
- F/S - 14' Pirelli tires on 4-lug audi rims.
- Anyone have a pic that shows the location of the oil drain plug on a '90 V8?
- Bought a 200 10v wagon this weekend and had a question
- 90 V8Q vibration since tranny replacement
- Pulled the engine out this weekend. Should have her back on the road and even beefier soon.
- F/S '86 5KCSTQ, western PA
- Looking in Chicago
- Anybody Know likely hard start suspect for a 96 vw golf?
- World's only I-10, 30V Turbo 200 TQA?
- Beautiful 20 Valve Wagon for sale...
- anyone running an aftermarket wg on a 200?
- no gauges
- V8Q Changing Spark Plugs
- 20valve won't idle sometimes
- 5K turbo head
- 1990 V8 Exhaust Swap?
- Does anyone have details on this V8 Quattro biturbo set up?
- V8 TBelt Done, 2 notes
- CV axle inner bolt size?
- Audi V8 (And probably others) Free Diagrams :D
- door rest screw
- rad fan low speed not working sometimes
- Rear Spoiler on 200?
- tires size
- PS pump question
- long grey 1 inch wide wire strap from dash to boot ?
- Performance parts
- so long 200, hello a4!
- In dash brake light..how to turn off?
- 1990 qv8 antenna question
- 1991 V8q 5-spd Clutch kit/flywheel
- A 5k could make a mean off road vehicle with a lift kit and some tires
- V8 hood: will it work with 200 ('91 20v) fenders?
- How do I remove the front strut assembly?
- Audi V8: Cost of repairs, just wanna make sure I'm not getting ripped off..
- I have a V8 here that is always in drive
- Anybody else see some Volvo influince on the handles of there 5k...
- 1988 5000CS TQ vacuum routing diagram
- What's a '88 5KTQM worth?
- Audi 5KTQ Transmission Problems
- Popping sound
- The black metal box in the trunk. Is this an Amp for the speakers or...?
- Where were you guys ? I had the only type 44 at Sebring ?
- 91 Audi 100 - Dash lights out
- NAC-Motor Trend Police Car Comparison- :-)
- rear strut problems 1990Qv8
- Anybody Got a pic of coolant lines after heater core loss...
- Just installed: INMotion ECU chip in my 90 V8Q
- Temp Guage / Coolant Warning Light / Air Cond Troubles
- Do you guy's mind clicking on this link and looking at the
- anyone in the lebanon,pa area?
- Good source for audi wastegate diaphrams?..
- 91 Audi 100
- Does anyone have the part number for the distributor hall sensor (G40) for a '91 200 20v?
- Reputable Auto Shop in Vancouver, BC that does Audi's?
- Couple of Q's about the Euro Sport Steering wheel...
- Possible Fuel Injector air leak
- 5000CS Quattro Problem
- Sweet...someone backed into me last night, no number
- 1993 with a 3.6L in Europe, is this real?
- Splicing Generic Bosch O2 Sensor (Bosch 13913)
- I found a parking spot for my 200t : )
- Charging System final question
- 5ktq pulley question
- Audi V8 Quattro Distributor Caps and Rotors - Part numbers and suppliers
- 'CAT Light Shining' FIXED! THANKS!
- V8 coolant pipe o-ring repair
- 1989 200TQ... $450,000 ... Make offer.
- 1990 Audi V8: Accessing Backside of Doorlock
- is replacing injectors as simple as just pulling them out...
- Brand New 875ktq Injectors Must go, Gimme 50 and their yours...
- O2 Sensor Location in 1990 V8?
- 84 audi 5000 brake question
- steering rack on ebay
- another part interchange question
- Note to self: When thinking of removing snow tires, wait until no more snow.
- Intake hose for Sea Foam "cleanout procedure"
- "NEEDED" ignition coil with 3 pin module 1991 100
- IAT - where T stands for Trouble
- e-test blues update...
- Question about parts interchagablity
- 'CAT Light Shining' Update Post...
- 2312 coolant sensor code holy war
- What is the outside diameter of a 5KTQ (5 lug) hub?
- WTT: Driveshaft
- 89 Audi 200, non-bose system, aftermarket speaker pods for doors?
- Hey all .....
- Anyone interested in a group buy of manual boost controllers?
- Rim repair? Who have you used? Cost? (I'm asking for someone else)
- Tach sensor
- '90 V8 ECU removal help
- Engine rebuild #2 But this time performance is in mind.....also a few other plans
- CAT Light Shining
- 87 Audi 5000 Cs quattro for parts or for sale....
- Any experience with Bilstein HDs, Sports, or Koni Reds
- FOR SALE: 1991 Audi 200 20v quattro
- Recharged Bomb
- Pump Or Rack
- Thanks for everything: Questions concerning wheels and suspension..
- Anybody run a straight pipe thru their 200 20v kitty? If so, would you please share dimensions?
- Does anyone have a front subframe for a 90 200 tq they would sell.
- Anyone know what happened to InMotion?
- 87 5000 CS Quattro Avant 155,000 Miles
- Most common battery drain issue on 1991 100? Courtesy light switch?
- Anyone have an MC-2 flywheel for sale?
- 1979 Audi 5000s For sale
- 1990 V8Q . . . Still blowing black smoke!
- What's the widest tire you can fit on a 200 20V?
- rear and center diff fluid amounts and recommendations?
- window stuck down, infrequent operation
- Possible Fire Risk? Help please.
- I need help guys 87 Quattro, hunting idle....
- drive shaft therapy questions
- anyone have this sympton , 1990 200 TQ 10v
- Can someone please confirm that the stock voltage regulator on a '90 200 QT 10V is: 1 197 311 027?
- Alignment after R&P + LCAs
- Any one know if 1990 80 Springs will fix my 86 5000cs tq?
- Has anyone found an aftermarket solution to the Avant "crumpling side/cargo...
- average turbo life?
- Weird vibrations and "humming" drone???
- the 200 lives on!
- 200q20v parts car or sale
- Picking up another Audi next week....
- PAGING STEPHEN ANKNEY
- My minor front suspension odyssey
- Free 3.6L V8 motor in the GTA...
- Had to take off the snows too. Aw, might as well give her a bath too...
- Need some Help with Suspension
- anyone know this 200 avant 4 sale canton/ann arbor area?
- Looking for Good Machine Shop in Cols OH.
- How "made out of unobtainium" are well functioning Type 43 turbo cars?
- Car Starving for Gas when Hot, code 4433, suggestions??
- Crankcase Vacuum Hose
- Cheap set of "Swing Wheels" on eBay, I think they look pretty good on type 44's.
- 91' audi 100 Nf trying to pull codes "led light just stays on"
- Any BTDT's on R & R of the valve cover gasket (200 20v)?
- Intake Manifold Removal - Exhaust Manifold Gasket Replacement
- shiftboot question
- can of marbles rattling
- Duhhh!! Speedbleeder!
- 90 qv8 stereo question
- Feeling adventurous, our fearless hero pulls the snows off the car....
- NG Cam on MC-1 engine?
- coolant leak
- Jim Bush, YGM
- Hi All, I just got a 91 200 10vT,, any ideas on more HP???
- Setting the Dash clock?
- Last call -- 91 200 20V has to go
- SHAZ-BAT!
- Co-worker just bought a 90 V8 - pearl white - need recs on wheels under $200/ea...
- Bleeding Slave
- WTD: Need a 5000 quattro driveshaft
- E-test blues...
- WTB: Idle Stabilizer Valve for 1988 5000TQ
- Sunroof Maintanence - 90 V8
- CSV testing
- trouble with fused wiring circuit........
- x-post
- Pins in Flywheel?
- attention audimafiaoso
- v8 frapper map
- Chmnyboy
- Looking for a ride share..
- Skid plate?
- For sale audi 200 turbo fwd auto. Good condition, lots of new parts.
- Boost drop, intermittent-Turbo issues??... 89 200TQ
- who owns a black V8 in akron area?
- For you guys running NF/NG heads on your MC1's...
- v8 coolant pipe o-ring
- Hours on clutch R&R?
- Need part # for the Alternator adjustment gear/star bolt for a 200 20v. TIA!
- Start saving your pennies
- Anyone in need of a running 86 5kcs for cheap?
- IIRC someone on here was selling a set of new crossover fuel lines? rail to rail?
- 1990 V8 Quattro-Blowing Black Soot out Tailpipe!
- Need to replace Air Compressor - Need pages
- Spotted a Couple of Turbos in the junkyard yesterday. Anybody need anything?
- 2 quick questions.
- Audi 5000 Turbo Quattro
- Anybody got any 5KTQ speedo-meter parts laying around?
- Who needs V8 parts?
- Gotta love idiot drivers that get mad at you for their poor driving (rant)
- Alternator belt install 1990 Audi 100
- IAT Sensor '93 V8 Quattro
- VR3 MP3 player/fm transmitter thumbs down
- I want my engine to look like this some day...
- changing front seal on rear differential
- problem with third gear. is this a synchro issue?
- So I thought it was just the release bearing....
- Spooky dashboard light apparations
- Popped out fuel pump and cleaned the strainer basket. Quite easy. Now I can replace it if needed...
- Mechanic says he can"change basic settings"on '91 4-sp Auto to help hard shifting & downshfts
- Just got flatbedded
- Nuts... CO duty cycle is running at 50%...
- O2 Sensor bypass: V8 Quattro
- V8 exaust survey
- What kind of spark plugs are best in V8?
- where is the other end of the small wire on the starter?
- Power steering
- another dumb question: differences between US and EU V8 bumpers?
- How to remove an O2 sensor
- Did all 1991 200 20v cars have Servotronic steering?
- More sick video clips from last week at Laguna Seca with 034 Motorsport hey Adam how do these make
- I cant even find the words to describe how this video makes me feel.
- Info from a Porsche forum. Good Turbo information for those interested...
- Engine running rich 90 3.6 V8 Quattro
- Oil Pressure Sending Unit
- A short clip of the Champion S4 & 2B GTR at Laguna Seca last week enjoy!!
- 1990 V8-does my oem deck have a line in con in the back?
- sorry DoctorD15 I've been getting killed with school
- Thermostat - Audi 100 1991
- Lug size?
- 1990 v8 brakes discs
- any US sources for Euro 100/200 bumpers?
- n/mind (found)
- 1987 5KTQ Speedo Help!
- Splice or no splice?
- blackthunder....high/low beam stalk
- Anyone got pics of the water jacket tapping for extra cooling mod?
- Paging Mr. S. Angry... Re Turbo....
- 200 20 v transmission compatibilty
- Door Locks and Window
- any reason a new timing belt would increase mpg?
- how many funny names for cars can you think of? heres mine
- rear strut clunk?
- Will 86 5000 wagon tail lights fit 90 200?
- ignition switch
- Visited 034 motorsport last week, headed over to Laguna Seca with them for the Audi Event (vids)
- anyone whos taken apart the combination switch for 5000....i need some help
- I pulled a 4matic mercedes out of some deep snow today. Type44 for the win:)
- Can someone give me an education on the early 44 hydra sys and the late?
- Possible group buy... testing the waters...
- Today I have been reminded why I keep buying typ44 cars!
- Going to be selling the Jetta Mk IV 1.8t if anyone might be interested...
- 1991 Audi 100 Quattro...
- GIAC Chip - Where to buy and HOW-TO Install?
- I'd forgotten about this video. "Da beast"
