- Now only if we can get the type44 to handle like this...
- Does anyone have a suggestion on how to clean the crankcase vent trap
- Who else gets to replace their brake MC once every 9 months??
- how hard is it to take the spring and struts out of a 5000 cd?
- Anybody know if US spec A8 rotors fit UR-S4 strut housings??
- Wideband O2 kit got here
- Lots of parts in this package.....
- Radiator is gone...
- does anyone know where to geta 60mm bolt on high flo cat for my 89 200
- What color blue is this?
- Location of ISV Control Unit
- Where is the time delay relay located? A5kTQ 88
- type 85 vs type 44
- new pic of my 200q20v
- Wow. What metal are those turbo fasteners made of?
- Is $5900 a fair price for a 8/10 condition 91 20V Avant? 225K mileage!!!
- Motronic control unit testing ?
- UPDATE: Oil pressure...
- O/T Carpenters? Woodworkers?
- It just never ends...
- Bentley for 84 to 88 5000 FS
- Help! my poor Audi is making noises
- V8 PCV Hose?
- well my car is a write off now :(
- slow cranking below 20 degrees F in AM
- Missing Clutch Fluid
- rims and offsets...
- what is better 4kq cs or a 5k q turbo?
- Boerge, check this, regarding the #4 fuse
- o2 sensor for 91 200 20v
- Hey, Alex@Europrice
- Drove my friend's 5ktq last night...
- Do V-8 Quattros really gulp gas?
- Steve Ankney... A couple questions if you dont mind... (A bit long)
- Brake upgrades for G60 equipped V8...
- Anyone have a pass. side mirror glass for a 1990 200 or know where I can get one...
- same video of my car launching, a little longer to see the actual "launch" though
- back up lights?
- "91 100 Delta Radio
- Gas mileage, what are you getting??
- Towing with V8 quattro....
- Need a '91 200TQ BBS Wheel
- Best chip out there?
- Car won't start.. Need help please!
- 89 100 Q front outer boot replace
- Anyone ever have a metal tank radiator repaired?
- Changing the fuel pump from an '89 200 Quatro- I'm stuck!
- Holy cats, the V8 quattro is an awesome car!
- Battery still goes flat..Fuse no. 4 has to be pulled every night
- Spacer to fit fuchs over UFO's?
- Intercooler questions
- Need ideas on clutch problem.
- Finding Auto door lock air hoses
- Cold start, hard starting, low boost, uneven running, sluggish
- Audi 100 TQ site
- Because I miss my car, you get a short video clip of her..
- Solutions to a cracked 10V exhaust manifold
- Clutch pedal ?
- Euro headlights for 20020v... let me see the light! / bulbs?
- My "I told you so" post about my 5k needing an ecu backfired. My current situation: =( *LONG*
- Anyone ever sort out their dash ligh gremlins?
- Winter is here and theres to much snow to get out!!!
- idle and rpm......
- Some of you probably qualify to wear these.
- Same TTS Tuning Audi 200 20v that beat the viper... beating up on some other nice cars
- Anyone had a front diff or gearbox failure, 200q20v?
- Jason4kq20v's 5ktq in the snow
- Hey MiB, any updates on the oil pressure situation?
- 18 X 8.5 Wheels 90V8
- Quicky windshield wiper question...
- anyone know where to get filters and o rings to rebuild fuel dis.
- WOW, they're pretty proud of this car, with an automatic?
- aluminum flywheel GB
- 89 100 Q Hub Removal
- My POS car update******
- how much brake pedal travel should I have?
- temp gauge intermittent
- Brake master cylinder?
- Fuel Pump Fun
- Plug wire question...
- Tornado red door handles & smooth rear pillar trim FS
- Oil pressure readings
- Looking for a 200 10v TQ Exhaust Manifold
- My Audi V8 and a Brake Question
- 10 bux
- Bombs away!
- CRAP! Help!!
- BTW, Boxerfan >>
- I have some cheap parts... just to make room, Is this price fair?
- First real snow... QUATTRO is at home!
- Audi INjectors
- Won't start 200QT
- Let's share wheel cleaning tips & alloy question
- photo of the black 200 vs. dodge viper posted by duffWL (Major BWW)
- Need a source for decent cross-drilled front rotors
- People really ask quite a bit for their 44's
- Sunny December afternoon complete with sunroof that won't close!!! Need help please.
- I'm hoping these pics will help explain why I cant get the trans out of my parts car.....
- Waste gate spring question: Mine has a blue stripe on side and 55mm / 2.25" high..
- climate control problems
- Airbag warning light
- I never get tired of looking at this Type 44 IMSA Trans Am race car...
- Audi 200 vs Dodge Viper
- trip computer has not "seen the light"
- 12 hour rule argh!
- Overheating problem fixed.
- Dead Speedo
- Is 5K Turbo 1988 FWD anything at all? vs Quattro
- Does anyone have a writeup on removing the upper dashboard
- Anyone have the part # for the thermo time switch for the '87 5k CS Quattro
- Heater Control Valve?
- Warm start problem ...
- Will 92 S4 Cluster fit plug n play in a 91 200 20V?
- 17" A4 rims on the 5ktq
- I know we discussed this a couple years ago but I have to bring it up again
- looking for a write up for installing pads and rotors on my 5ktq.
- help
- Lockplate on tie rods front of car... Cant straiten out to gain access to inner tie rod bolt
- 1990 200 TQ
- Oil pressure relief valve - how to locate?
- Door Latch Help
- '89 200 TQ problem, it sounds like a tractor
- Stalling out
- I need some help w/ ABS problem on a 1990 200TQ....
- Anyone know the difference between the Bomb for the V8 and S4/S6??
- Mmmm, Bose suspension...
- hello steve j in ga
- Arrrrrgggggggg......
- disassembling 200 door handles?
- 91 100 pentosin question
- Always some problem..Now clutch pedal stays in..
- Plusses and minusses of synthetic vs. regular oil
- thermostat on ebay - dropped price to 99¢
- Idle speed steady when electrial connector is disconnected
- 1991 Audi V8 Quattro
- Christmas and Oil
- ECM malfunction?
- Need Front Left Inner tie rod end ASAP
- Strange idle updates..........
- Oil filter question
- looking for a fellow 5ktq owner to help me with installing pads and rotors on my audi.(Seattle area)
- What hose is this?
- Is it a Canadian thing or....
- Snow much fun... arr arr arr...
- Day #1 of christmas break
- Car dilemma (or: should I buy another 5ktq?)
- Notice there are ALOT of problems with EM studs? Why not use...
- switched to royal purple oil...
- Stocking stuffer for motorheads...
- 016 aluminum flywheel group buy
- PITA problem: not so hot start problems
- Can i switch to synthethic after head job
- Rear crank breather hose....
- Locking Diff question..
- Master cylinder grommets
- Best method of head removal from 5KTQ?
- avant trim
- Looking at an '98 200q 5spd. Thoughts
- i've got gas and some questions (steve or jim)
- do Optima Red or Yellow Top batteries fit in our car?
- how do I fix a broken exhaust manifold stud (connecting to pipe) ?
- Transmission Noise
- Stupid skid plate!!!
- Look at the price this older 5k turbo diesel is fetching...
- 91 200TQ 4 sale
- 90 audi 200 4 cyl?
- OT: A little bit of needed relief from all our Audi gremlins.
- 200 20v michelin man hose the same on the 87 5kcstq?
- does the wiring for the interior guage/dash lights go through the door jamb?
- Ghost problem
- Water temp gauge on my 1990 200TQ doesn't work. Should I replace the sensor?
- looking for a quick answer....on Golf II
- here is my "I TOLD YOU SO" post on my no start situation. Final results...
- Wiring alarm to running lights
- changed crank sensor and speed sensor.Yet no start.
- time it takes to swap an ecu? short right?
- An Article on ignition
- Guys, don't ever use Europeanlates.com
- ok check this out
- D'oh! My 5KTQ has at least one broken exhaust manifold stud.
- fuel meter ????
- weird power steering problem
- How Long will a Turbo last?
- Fuel cut???
- How does the V8 Torsen work?
- Transmission vent
- Flasher Relay Location?
- Climate Contol Brain Replacement
- Hey, Jim Bush >> How's that Dialynx em working out?
- Weird transmission happenings today...
- Anyone near Saratoga NY? Looking for....
- need a quick answer pleaze:)
- Dual exhaust or single?
- Car is burning oil...sigh
- OK, so say that a front WB is definately on the way out
- Overwatt bulbs for the Euro's?? What do ya'll like..
- does everyone who lowers a 200q20v need camber plates like 2B sells?
- Audi 100 parts
- Bit of experience now on changing gas tanks
- Type 44 avants for sale
- Anyone have an ABS relay # 443.927.826 for a 1990 200TQ? There is also a big "76" stamped on the top
- Bad stutter
- Hey dans5ktq... If you can't turn that grease fitting around, try experimenting...
- Anybody need CIS parts?
- Headlights, Driving lights, a bunch of hair brained ideas... anyone got a busted up headlight?
- Sold my 100... put some items on ebay
- fuel pump not turning on EVEN with fuse in fuse pump relay
- anyone know where i can find a guid to reduild fuel metering valve
- Doh. spun out in my quattro
- Will this EM fit on a 10V Mc1 engine?
- Just bought a new `87 5ktq-have some questions
- new Intercooler installed (mostly)
- OK, Phoenix
- Hooray for me!! I was going to wait till it came in, but I'm too psyched to wait...
- Discovery Channel - top 5 rally cars (Ur-q #1)
- In all my years of driving I've rarely if ever
- T44 parts
- Euro Headlights for x-mas... where to find them? Any ideas?
- Diagnostic Tools
- i changed injectors
- testing fuel pump relay signal @ ecu
- Ghost problem
- He finally called! He sold the 1990 80Q for the asking price of 650!
- just changed my engine oil and added 1 qt. of Hyper Lube Oil
- V8 sport grill
- almost giving up.....may sell audi's both for h jobs....=)
- Starting
- !!!!%%$#@#$ Warning Lights
- Does anybody need front axles or shifter knob & boot for a 5kq?
- ALL you wanted to know about HEATED SEATS and were afraid to assk ?
- Thinking about buying a MC II motor or bottom end:
- Windshield washers won't spray!
- Now how nice would an aluminum shell be!? wow.. came across this searching...
- mm... came across this while browsing the net...
- Sunroof, brake AND power steering Q's
- HVAC
- Cig lighter relay
- How can I get at the 02 sensor?
- New to the world of Audi
- still looking for an mac11 ecu for my 87 audi 5kcstq....
- I know this is not a question fr this Forum but maybe you can help on a future addition of a 80Q
- WTB: 5000/200TQ Avant in Denver area
- Holy Buhgeezus do our door handles suck in the winter:( That is all.
- I take back everything bad I ever said about this bitch
- No Spark 89 Audi 100
- Paging Adam Mowafy & Black-Wolf....
- What grease fitting is on the 5000 quattro's driveshaft U-joint?
- I think that I discovered the part on some water pumps that "warbles"
- audi for sale on ebay. remarkably honest seller!
- how do you take off the fuel dis
