- I think I taught my ECU naughty things... how can I unteach it?
- visit to die autostadt... img heavy
- Hmmm, wonder what these would look like on a 5ktq...
- Recharged Bomb?
- Strange bulb check problem...
- No charging??
- anyone interested?
- Hey Jim Bush or Steve A.
- Grinding?
- overpressurized cooling system
- I don't understand parting out these cars...
- Coolant temp warning light question
- 1986 5000 Rear Brake Caliper leaking
- Waterpump question: who is running a plastic impeller?
- MOMO/V8
- where might i get a used 1991 audi 200 20v tq intercooler for cheap?
- Dash light problems
- 1991 V8 Q- Won't Start
- CT/NY Audi Group Gathering & Dyno Day - We're still on for tomorrow (Sat) - E. Hartford, CT
- where is urs4.com?
- I never thought the brand of gas would make a difference but...
- found my no start problem
- I've got a hypothetical that probably hasn't been thought of much on this forum... what to replace??
- Commemorative Design photos
- Audi connection has changed their name
- diagnosing boost issue....still
- ahhh, the BMW 325ix. what a wannabe
- Audi 100 euro lamps?
- Anyone raised a 5ktqa before? (or even a sedan)?
- Thoughts on torsen vs man. diffs handling comparo
- Clutch problem...
- On one really hot day last summer...
- Are there any direct replacements for the K26?
- For those of you running lowered 5kcstq's...
- here is a stupid question for you
- This should end the CS controversy. Maybe not!
- Heated seats process of elimination....
- 91 200TQ -- My confusion.. Updated
- Power door lock servo - the search begins
- Any 5k parts cars out there w/ alcantara interior?
- Air filter?
- AC programmer from 100 in an '87 5k?
- This may seem like a dumb question to some but....
- Want to see what can be done with a 2.2 liter engine?
- Anyone have a tuned 87 5000cs turbo Q? I miss mine so much.. sigh
- ECU Mod Recommendations
- 1991 V8Q Battery Suggestions Anyone?
- window goes down, but doesn't come back up
- does anyone know what type of plastic
- 5KTQ Downpipe question...
- Car won't start in the lot...
- first oil change for newbie ( me)
- turbocity said K26 and K24 have same internals. True? 1993 K24
- OK... prototype A/F Meter ready...
- Just a friendly note...
- Word of warning......stay faithful
- Check Engine Light coming on after 5min of driving.
- Praise for...Shokan!?!
- boost controller only?
- Turbo Question
- Trying to get a value on a 1991 200 TQ 20v
- Any need a fuel pump check valve?
- ACNA 2-day track event @ Buttonwillow Raceway coming up on March 27 & 28th (Mon/Tue)
- Reminder: This Sat, 2/11/06 - CT/NY Audi Group Gathering & Dyno Day - XXTuning - E. Hartford, CT
- 200 ignition switch
- Whats the difference between 5000 Q, 5000 QT, and 5000 Turbo for an 87' 5000 CS Quattro
- Please educate me on the termo-time switch.
- anyone going to the dyno g2g in CT on sat.?
- '86 5KTQ: Intercooler piping
- ok, so no thanks to you upstanding gentlemen i now know where to get a transmission kit for my 5k
- Looking into Audi 5k CsTurboQuattro performance
- voltage
- 90' 100 hard start when hot and....
- Any 200 20v owners in/around phoenix?
- More questions for you guys (cold running)
- Thanks to AudiHERE1730 meetup.
- turbo after run pump leaking...
- Audi's new Lamanns car
- Break Fluid Rez Bone Dry
- Enjoying a great Waitangi Day long weekend,
- OK...I'm looking at 2 (1990 V8 and 1993 V8) both in Pearl White and a couple of ?s
- reference pin location mc1 vs mc2
- tranmsission rebuild kits?
- Can front leather comfort seat cushion be r&r'd with seat in car?
- CAN any body parts from first gen, A6 fit on V8Q?
- Aftermarket Window Regulator
- no more C.E.L. now what
- handling options for the 200tq?
- RS2 tuning for the 3B motor...
- When you start your car after its sat for a couple of hrs >
- Intake air temp sensor V8
- what does LOL MEAN
- $600 5kcsq someone buy it...
- Excellent article on reducing cabin noise
- 1989 Audi 100 Automatic
- I need a drivers side white marker for turbo euro lights... any one got one?
- PLEASE HELP! TIMING QUESTION
- Lighting supply source: Bulbs, lenses, housings etc. Excerpt from Steve Jensen's post dated 11/19/01
- 2/11/06 - CT/NY Audi Group Gathering & Dyno Day - XX Tuning - E. Hartford, CT - 3 spots remain
- Looking for black t44 sport seats or entire black or black/gray sport interior. TIA.
- 1990 V8 Quatro Question and Finding Parts
- Specs for 1.8 or 1.9 bar wastegate spring?
- Looking for a good v8 Hood
- Fuel injector question
- ATTN Jerome@PARiS: I will be in Spokane this weekend...
- can any 200 parts fit on the v8q?
- Update on my clutch problems
- Head swap
- What turbo came on the 91 20V turbo Quattro?
- 87 5kcst / 8x' 5k td transmission compatability questions
- Still getting the 2142 code...Ideas?
- Frustrated... and somewhat confused... headlight relay questions with euros...
- Anyone knows - nitro on CIS sytem?
- Just purchased 86 5000csTQ
- p/s rack&pinion pics(fits 100, V8Q, S4Q, S6Q & A6 w/8mm bolt)
- Advancing timing on normally aspirated engine...............it helps.......
- driveshaft carrier bearing R&R?
- Power window question. - Drivers window not working when door closed.
- Anyone have an 83-87 Euro "200" badge they'd trade or sell...
- Ideal Tire/Wheel size/bolt pattern/offset for 16's on a '91 200 tqa?
- Off topic--> Sister want a g60 synchro
- Climate control system musings
- hard to start, now ok, probably will come back
- Clutch pedal again...
- Anyone need a set of Koni rears? I have....
- VIN plate scratched
- CD Manuals ... are they okay ?
- 93 V8Q still runs hot...more ques.
- Interesting 20V manual... no connection with seller...yadday yadda yadda...
- Need used clutch disk
- Heater noise
- Northern MN sunrise on the way in to work this morning.
- Looking at a Avant.
- Another day and time to act...
- Some debate about the 20vt conversion... Parting out? Selling?
- Nology spark plug wires....
- Brakes
- Pulled the Codes...2142, Knock Sensor
- Ideas on draining 5ktq fuel tank???
- Wanted Distributor for Turbo Car
- euro headlights for audi 200 q
- 5K Engine splash shields?
- The 'NEW' dBu ECU...
- Leaky intercooler... not at end caps... fixable or toast?
- indicator relay behind dash
- Alternator Question :
- i got a 2144
- Brakes stuck 1/4 way down
- Gray Leather Interior
- 5000S won't start...
- What tools (& sizes) do I need to swap a driveshaft?
- Head Gasket Question, Non Audi, Please reply.
- Audi 200, How easy is the sunroof headliner piece removed/installed?
- Yippie turned to Damn it!
- Will UrS4 springs fit on V8's??
- Will 17x8 ET35 BBS RGRs fit a '91 200 turbo?
- floor mats for audi 100
- Can anyone tell me what engine a Euro 85 200 turbo had?
- 1983 5000 parts
- Lock system problems... help running out of light!
- Ignitionn, starting problem, need help.
- debate: should i fix up the 5ktq or modify the 90q?
- question
- If anyone's looking for a low mileage V8 automatic quattro
- wiring euro spec headlights
- 5000 Turbo and TQ owners, please look at bottom rear of front bumper cover
- WGFV and output tests
- Boost problem difficulty level 8.6
- 2/11/06 - CT/NY Audi Group GTG & Dyno Day - XX Tuning - E. Hartford, CT - 4 dyno spots left!
- Check Engine light on '89 200 TQ
- Well, since I'm still waitting for the A8 rotors...
- Disapponited with Silverstars, going to 100w driving lights
- Coolant mixture
- 1989-AUDI 100 Automatic
- V8 Fuel Pressure Regulator
- 93 V8Q runs hot when stopped or...
- Happy Australia Day to PushButtonAuto (iirc)
- OK boys and girls... Looks like there are lots of us in need of parts...
- Would an outer CV from a 4kq or CGT fit a front 5ktq shaft?
- Need help! Rear Shock part # for 88 5kcs tq wagon.
- Oil on the sparkplug surround.
- Still have shifting troubles and clutch problems
- Double-kill: Another 5kcstq for me...
- Rough start and lean top end
- Pretty much determined that the 5000's clutch/pressure plate is dead. What's the car worth as is?
- Need additional gauges... 5KTQ
- Is it possible for the sunroof/power window relay to just work for the power windows?
- anyone selling
- My dissertation (if you will) on my heating system
- 1990 V8 quatro running rich
- ECU code 2341
- Fouled out spark plugs
- Anyone have good used injectors for a 1990 Audi 100 to sell?
- Need a headlamb bulb... HID or No?
- If anyone needs 5000 Koni strut inserts...
- 200 20v Guys: Those running cone intakes, did you notice a difference at all?
- 88 5ktq wagon master cylinders?
- heating for the back
- Need to get rid of my canadian instrument cluster.
- Audi Expo 2006 - June 24th
- Need BTDT on pass side front driveshaft/halfshaft/CV replacement
- Please bear with me everyone, I have two more questions about the heating system
- towing
- 1990 100 transmission
- Looking for Passenger Side V8 Dash Trim (Burled Wood)...
- Mr. Ben
- Check Out This Concept Car
- does an 87 audi 5000cstq have a diagnostic port?
- 10 Valve Turbo Stage I.5 - ECU+WGS ON EBAY!!!!!!
- IAT Sensor needed.. Possible to find?? (3B)
- VW Content-parts suppliers question?
- Car idle low, stalls when braking. Pulling the 2322 code
- Bucking when hot, solved!
- Anyone parting/know of a 200 with black interior?
- Can't just turn the key when car is cold.
- "LORD OWNZ YOUR SYSTEM... FOR IRAQ" hahaha... www.blauparts.com
- WTF!! More heating ideas needed please.
- Repairing leather seats in my '89 200 TQ?
- 87 5000CS TQ - testing alternator?
- auto trader?
- 87 5kcstq headlights?
- Old Center Bearing Carriers?
- adam
- What's the correct procedure to change manual trans fluid...
- Alignment Woes
- Oil cooler replacement process??
- To advance distributor timin, should cap be rotated clock wise.........
- Did I see one of you guys in a 200 Avant running with anotehr Audi on 87 South today?
- know the code?
- Buy My Car its in Groton CT
- Quetion about RS2ing the 3B motor....
- glass
- Looking to sell: '90 200 auto
- Put the old 5k on the dyno today. 153 WHP
- changed the sig to a more simplified one
- Vent Problem
- Finally got my girlfriend in an Audi
- glad to be lurking and posting more now, almost forgot my knowledge!
- Am I buying the correct center support bearing?
- couple pictures, eye candy for TonyOldSchool who seems to miss the pix!!
- My timing is waaaayyy off - damaged?
- Coolant sensors
- UFO's felows:
- My '89 200 TQ failed emissions...
- Feeler: Mac14 chips
- A/C Belt Trick
- Living with it too long...ISV does not get power or signal to it...
- got me new...
- wierd overboost problem
- Shifting is way off
