PDA
View Full Version : Audi 5000 / 200 / V8 Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 [65] 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. Where is the AC evaporator drain tube ...
  2. getting Codes with out VAG-COM?
  3. Sticky doorlock - anyone BTDT?
  4. Quick question re: lower control arm ball joint bolt...
  5. Will Ng- are your wheels rediculous close in the front to the steering arm?
  6. Boom!
  7. 1990 Audi V8 parts worth money?
  8. two problems today, stripped tranny bolt and can't get the fuel injectors out
  9. ATT: boxerfan. The MTFS wiring you wanted....
  10. heh heh
  11. Will Ng... You're being a huge help...
  12. timing
  13. Anyone? How to get around the ECU cutting FuelPump on hi-boost
  14. Big power ?
  15. 5ktq vs 200
  16. What's your oil of choice for your I-5 turbo?
  17. Looking for CIS injector comparison link
  18. how do u know what spring is a front right? (Passenger)- set of springs just sitting out of car...
  19. results of my 2113 code no start situation..
  20. Reminder - BBQ Sat Sept 4 for any & all Audi owners
  21. boost controller question...
  22. Ok Guys, some help would really be great...
  23. a little entertainment
  24. Brake Resevior
  25. Not a good day for Audi's in my family.
  26. ATTEN: Rockinv8q
  27. Could I impose on a couple of you for...
  28. Anyone have a spare Auxillary water pump?
  29. Starter screech
  30. Just bought 97 Subaru SVX ... no flames please
  31. Looks like the rear speaker in my 1990 100 FWD are about 5", can anyone comment?
  32. Damn power steering pump decided to piss all over
  33. Almost amusing Dealer story.. Checkered Flag Audi in VA Beach.
  34. UrQ clutch/trans help needed ( massive x-post )
  35. Risking detonation... but it is fun!!!!
  36. post of the night: trouble getting the car in gear
  37. Audio setup for my 1990 Audi 100 all but ordered- thoughts? MB Quart and Polk
  38. HELP IGNITION
  39. Attention: 3B owners with Mihnea tuned ECU's...
  40. 91 100 for sale
  41. V8 Boot Spoiler !!
  42. Automatic transmisssion - Is it dead???
  43. 5000s (nonturbo) have the same distributor as our 5000cs turbos?
  44. V8 speedo drive electric or mechanical?
  45. economical source of european spec lights?
  46. How much tranny fluid should I need?
  47. "shorty" Audi power antenna problems..........
  48. Inspection woes...need left headlamp...
  49. silicone alternative to MM hose
  50. Damn rear brakes!
  51. Ditching Q on V8 #2.
  52. return line, power steering,high pressure hose
  53. Failed Smog test due to check engine light
  54. Which motors which??
  55. Copied as much QLCC info as I could find for those who are interested. (LONG)
  56. Electric fan on V8Q
  57. No start related to...
  58. Rear-deck brake light housing removal . . .
  59. I'm gonna do timing belt, water pump, etc on my '90 200 TQ this weekend. Any advice would be great.
  60. Brake pad warning light ...wont die !!!!
  61. what are some good sites for audi parts classifieds
  62. V8 vs. 200qt
  63. leaky injectors?
  64. Turbo cutout at 1.5 bar?
  65. looking for 5ktq
  66. Can Anyone Scan: Knock Sensor Diags for '89 200 from the Bently
  67. Any way to convert the 4 bolt pattern of the '90 100 FWD to a 4x112 or 5x100?
  68. 100 no start problem
  69. My 5ktq's new toy....
  70. QLCC anyone?.... Here it is...
  71. one thing over , back to another- that,s audi
  72. Type 44's, first introduced as a 1984 model, what year did production cease????????
  73. Just curious...
  74. any way to stiffen up the chassis of a 200
  75. i got boge turbo gas shocks, do they work good with stiffer spring
  76. Adjustable voltage regulator
  77. FWD 200 turbo trans fitment
  78. what changed in 1991?
  79. Suede Headliner X-post
  80. 9/25/04 Audi Dyno Day Spots are now Open - Wethersfield, CT ....
  81. So I was watching Speed Channel.....
  82. Anyone ever replace their tie rod assemblies?
  83. Decisions, decisions....
  84. Audi Posters
  85. so my water pump is failing, timing belt making some squealing.. is it possible that
  86. can anyone explain step by step how to remove my distributor TIA!
  87. help me out... what wires should i be checking if.. kinda long post..
  88. Does the 91 200 20V use the same Michelin Man hose as the 10V?
  89. Got some vids up of this weekend's import war. Including this 8 sec car that hit the wall!
  90. ACNA GingerMan event still has openings
  91. Pics of the carnage....
  92. Hello all, it has been a while, but the car of the month club is issuing me audis again.
  93. noob temp questions
  94. I can't find this in any manual, but it seems usefull.
  95. not cranking..how do I hot wire the solenoid ?
  96. No Start
  97. Bouncing speedo !!! Help !!!
  98. Still have these 5000T or Q wheels cheap...great condition
  99. ??treser car up for auction, but non turbo, auto, cloth.. :(
  100. anyone looked at this? random auction
  101. Mr. Ng's Mystery hose...
  102. Doing a 10vt motor swap into my 4k have some ?????
  103. Man, I hate bologna
  104. Infrared Keys? Any one know where to get them?
  105. is there a samco hose kit for our 5000's? i know there is for the 200 20v. anything better than oem?
  106. 87 5ks front axels
  107. Did I blow a heater core hose?
  108. WillNg- got my a4 wheels (same as urs)
  109. 1991 4spd AT
  110. 1991 100 Delta radio.
  111. Mystery hose...can anyone identify?
  112. 100 - 200 rear bumber covers?
  113. Transmission Cable
  114. I need some help.....
  115. front boge turbo gas shocks needed! i have rears, all the links i've gone to are for just rears..
  116. CIS question
  117. Still wondering about those MFTS wires..
  118. k.. i just won these off ebay, rears only though. still need fronts...
  119. my car tonite
  120. opting for a hybrid turbo. so I'll be selling my k24
  121. oil pressure light coming on when it shouldnt........
  122. MFTS Question... HELP... please...
  123. Power steering question
  124. V8 Transmission
  125. general wear and tear
  126. Hardly leaked on disassy...
  127. HELP!!!!!!
  128. rear brake set up?
  129. Wow, this is confusing...?
  130. how is BOGE as in boge shocks pronounced? BO-GEE Right?
  131. where do i get a set of front boge shocks for my 87 5kcstq shox.com doesnt have them
  132. Shift linkage adjustment
  133. 91 200 20V sedan power versus the UR S4/S6 engine? Any difference in power? More below
  134. Oh maaaaannnnnnnnn..... The MFTS connector crumbled! HUGE PITA!!!
  135. I hate the Type44 accessory belt tensioning system...That is all.
  136. Speaking of front grills, check out what I just did.
  137. WOT not all of it after all...
  138. HELP! pic requested!
  139. ISV / Driveability Problems, but not what you think . . .
  140. '85 5000 Turbo Parting Out
  141. custom grille tryout... just playing with some stuff i had around. what you all think?
  142. Air Conditioning
  143. How rare?
  144. i will miss that interior!!!!
  145. Crazy Crazy Night!!
  146. custom hood scoop/vent?
  147. Heh, "Ahhhh, rest!!" :D
  148. Automatic Launching...
  149. i see rear boge shocks all over the place for the 5000 where do i order front turbo gas boges from?
  150. Went to the track...
  151. will be selling
  152. Brake Warning Light (idiot light not Autocheck warning light) Audi 200q
  153. ahh not again.. car wont start... help me out!
  154. is there a way to hand crank close a window ?
  155. Update: Turbo is off!
  156. Checked out a 200 20V sedan today/ some questions on maint issues I noticed.
  157. parting out 5000 quattro
  158. 1989 200 tq Happiness(sp)
  159. 1989 200tq radio
  160. PA/NJ/DE/MD folks --> Reading PA Fun Fest/GTG this Sat! 48 hours left to RSVP!
  161. Limit to 1.2 boost?
  162. New to the 200tq family
  163. V8Q headlight surround?
  164. Check this out!
  165. seat adjustment turns without effect
  166. Stereo work on a '90 100 FWD... need some help/ideas
  167. Infrared V8 Key
  168. Mud/Snow Flap looking for.
  169. Emblem Removal
  170. New owner ... and special thanks
  171. HELP! '93 V8 Power steering prob.-right turn only...
  172. BOV for MC / CIS setup
  173. What my 5K S needs....
  174. Want to install shocks on rear of '87 FWD......what do I need to know to do this?
  175. Playing with new camera's manual settings...
  176. FS: 1990 V8Q parts car
  177. Suggestions: Dash Spkr replacement 1990 typ-44 Bose junk
  178. Listening to the motor in the 90 this weekend brought back memories of how much I enjoyed the 5K on
  179. 1985 5000s.... turning the key doesn't start the car 99% of the time anymore.
  180. would removing the rear muffler and leaving resonator
  181. Tips for getting the alternator belt tight
  182. hauptkontrollgerät
  183. Audi TT wheels on 5k???
  184. Removing turbocharger..... Anyone know how to get these bolts off?
  185. Front shock cartridge tool?
  186. Who controls cold start valve?
  187. got around to replacing my speedo in the V8
  188. 91 200 20V sedan / Are these rare like the wagons? Is this the only year of the 200 20V? Reliability
  189. what kind of BOV should i get for a 20v 200
  190. Passanger Front window regulator gremlin...........
  191. Ready to 'throttle' Audi designers!!!!!
  192. Hard start and crap "cold" idle.... 1990 200q 5spd
  193. New Engine 1989 100 Q
  194. Could somebody send me a QLCC chip program please?
  195. electric window problem(s)
  196. Help my car won't start...
  197. will 18" wheels with 225 or 235 tires clear on lowered 91 200tq20v
  198. Went for a 4000+km trip...
  199. GOT LAG?
  200. 91 200q front suspension swap
  201. V8 in Limp Mode Please HELP
  202. That was a good race
  203. Wiper problem.....
  204. Brain teaser for Audi gurus
  205. Parting out 1990 V8
  206. Upgrades: the seal has been broken!
  207. External Spring Compressors.
  208. 1990 Audi 200 Turbo VAS/VAG communications Port location
  209. NF engine Intake vaccum hose. Which one?
  210. I can't find the directions for the resistor & zener mods. Can anyone help me out?
  211. Question re: MAC-14 knock sensor authority [long]
  212. hard hot start / cold hesitation - fixed
  213. Need your guy's opinion (long, but interesting)
  214. toxcheap: launching a quattro
  215. Internal Door Release
  216. new turbo cam in n/turbo car,sight
  217. rear brake pads?
  218. Climate Control Conversion?
  219. Radiator Repair Kit
  220. Installing new stereo
  221. ECU for 1987 5000 & 1988-89 90
  222. Help ! Engine ticking driving me crazy
  223. anybody know where i can get one of these...
  224. 5k /200 compatibility please. long
  225. Audi GT Coupe "recent models"
  226. Ceramic brakes
  227. Black out Kit?
  228. V8 Torsen rear diff for sale; fit urS4-S6 , 100Q,200TQ,...
  229. Terrible Vibration in a 90 V8q
  230. lowering a 200
  231. V8Q for Sale
  232. Stupid Audi Stereo
  233. Washer fluid pump
  234. Looking for a recirculation valve installation
  235. Manual boost controller installation
  236. losing expensive hydraulic fluid/clutch sticks to floor
  237. Bizzare Incident
  238. Help! Do people know where I can get a new rear torsen diff for a 90-94 V8?
  239. long hot start / stumble when cold - NF motor
  240. Does anybody have a picture of Avant with red tail lights from Paul (Luxemburg)?
  241. Will Ng- Do your wheels fit without any modifications (Spacers in front/flares in rear)??
  242. Replacing wheel bearing. A few questions (90 V8q)
  243. Exhaust Manifold removal
  244. anybody seen new a4 wheels on a 1991 200
  245. 5000s Transmission
  246. audi quattro 5000cs
  247. Ronal, 17-18", R41-R38, Wheel/tire sale, 2 wks.
  248. Anyone know what the MSRP was on a 1990 200 TQ 5 speed when new?
  249. Ignition key cylinder removal.
  250. Clutch noise (X-Post from Audifans)
