- Turbo Rebuild??
- ISV Wiring
- v8 pic
- silicon hose vs stock
- Quart. Mile question.
- how important is the plastic air intake hose on the alternator?
- is it true replacing UFO's with G60's will shave ~150lbs off the front end?
- Loose shift linkage
- Power steering belt
- My Passport 8500 saved me from laser on I-5 S. in Tacoma, yesterday.
- skiddmark ....
- Ponder me this ... Ponder me that!! .. more inside (stalling problem)
- Yay, I finally figured out why my fan doesn't work, but..
- Anyone here have much experience autox'ing Type44 TQ's that they can relate?
- Is 17 PSI safe?
- wallpapers...
- Serious V8 Problems
- is a squealing belt too loose?
- Does anybody have a pic of what a 200 20v oughta look like with Eibachs?
- Something very interesting at the junk yard today
- ah my 1st muffler broke ... so this means cut it out and put straight pipe in? :)
- WTB: 5k CS seat bottom leather
- 5K sway bars
- QUestion on missing hose?
- Window fixed
- Clutch Master Cylinder, worth $800 repair bill
- new parts coming....
- Custom tail lights for audi??????
- Noticed at the Kennedy Engineered Products site
- I fixed the brake pad auto check
- Power antenna
- Is there any way to make rear doors speakers work with aftermaket radio?
- What kind of struts do I have...
- were there factory accessories for the 5K wagon roof racks?
- Recharging the air conditioning
- is there a V8 5 speed? or jsut auto?
- 875kTQ, does it have a knock sensor? if so where's it located?
- Kind of in a 'car borrowing' dilemma
- nice feature eberspächer heating
- No air out of dash vents
- head stud question...
- Dash lights not always on
- Cooling the cooling fan?
- Indy Audi loose in Columbus, IN!!!
- This AUDI is still running...
- Got tuck?
- Boost gauge...
- Rumbling noise from V8 auto transmission
- anybody want to buy my audi?
- Electrical problem
- off topic: Nigeria + Scam
- Hard Steering Wheel
- Further on my window problem
- Door Panel removal - 100
- Possible source of cheap EFI
- Rad. Fan not working, any ideas?
- '87 5kcstq - clutch problems
- My two teenagers...
- Stock height vs lowered...
- leaky crank seal - any rush to fix?
- Window motor question - '90 100
- very origonal idea.....any one know who's car this is
- tie rods/tie rod ends on the 5K
- what models had a k24?
- high speed fan on constant/ w key off, runs battery down
- Whose gonna come out for western Canada's largest show & shine?
- Changing CV axles
- What's wrong with my lights?
- Does the 200 20vt have a fuel cutoff at ~ 6200 rpm?
- so then....
- Found out what my stalling problem is...
- $10000 Audi 200 Turbo Quattro
- For anyone who is interested in relaying thier headlights
- So I got a ride in one of these this weekend...
- Our parts car...
- questions
- 100 Auto rebuild
- learning about the bentley manual..........
- serious turbo question since my compression ratio is 8:1
- What 15'' all-season tires would you suggest for 5KCSTQW?
- When you sell or know of a car for sale, please.....
- Looking at Buying a 200TQ, what problems should I look for?
- Best price for a M.M. hose please
- Cooling system
- Anyone looking for a 200?
- Clutch on my 5000 goes straight to floor, no resistance for the clutch pedal to come back up.
- What anti-freeze to use?
- pic of my car , just installed driving lights !
- Got scammed by Ebayer
- I have just sent wire transfer instruction to this man, John Victorisi.
- Rev Limiter??
- Time for a new blower motor
- 1991 200 quattro turbo 20v wagon problems
- More Seat heater info
- why?
- where's everybody from?
- idle and boost problem
- 200 intercoolers
- Holy fu*%##@. New heater core leaks!!!!
- help with steering rack please
- codes
- Questions on turbo quattros (200s)
- Cruising Ebay in Germany
- connector for turbo oil hose?
- How to bleed the clutch system
- This is pretty cool (I think)
- Seat Heaters
- Anyone know of any solid Type44 Q's for sale in the tri-state area (the REAL one: NY, NJ, CT!)?
- Had a blown airbag when i got my car! I switched it out but my light is still on! Is there a reset?
- 89 200 auto tranny problem?
- Does anyone know the part number of the Autocheck box?
- Does anyone know when the Type44 first began to receive adequate rust-protection?
- By any chance, can someone run WAUGC5448KN052950 for me?
- Audi 200 help needed. Continued for the millionth time (cuatrocoop help me!)
- Wastegate question... long
- lost all my oil today :(
- 3 Fuchs wheels in Mass.
- what's the diff between single and dual pass IC's?
- Exhaust clamp help needed
- Question about 200tq tire size...
- Bulb question for the V8
- Think'n about sellin my few month old Passport 8500.....
- In the late models 5k's in the front bumper, has ne1 put foglites instead of the front blinkers?
- Euro Spec V8 Lights?
- 200tq 20v sitting in my driveway now...
- 1990 200TQ Pearl White Black Sport Seats
- Seat Repair Question
- bentley
- Brake pad warning light
- Blower thing over engine
- 91' TDI gearbox with 87' engine
- Well I won a Audi singlepass intercooler off Ebay...
- anyone here added an aftermarket BPV?
- Mileage and FP sound '91 100Q
- OT - Does anyone row?
- cuatrokoop, quick question then
- Anyone interested in an '86 5000, needing work?
- speaking of IC's what is the term "Straping the IC"?
- ne1 here upgrade to larger IC? like a 20v'r IC?
- hey ck how about....
- Paging Tom Faust (or any other NE people)
- sure is slow tonight.
- Removing brake caliper, replacing rotor
- What is this hose?
- Timing
- how much boost?
- can the fuel distributor be rebuilt?
- Handbrake problem ?
- Anyone know this Alberta car?
- What's the story of '88 olympic ed. cars
- QLCC chips
- 200tq problems
- Going to do swap...tell me if this is a deal or not
- Injectors, Check valve, what to check before I replace.
- for those w/ indash computer on later model 5ktq's
- what fuel oct. do you all use in your turbo's???
- short block is together...
- new fuel filter in
- Final Drive Fluid....???
- Is this someone on here?
- Looking at buying a 1990 V8Q, what problems should I look for?
- rear axle seal, right side
- woohoo
- guys i need ur help
- wastegate diaphram
- need to fix my ignition switch
- transmission question ?
- 4 Wheel axis spins are fun >:-)
- the day has come .. :-)
- Best Summer Oil?
- A Couple WaterFest Questions...
- Where is the ISV?
- what motor/drivetrain would a 5000s have?
- Sunroof parts needed...
- How do you tell whether a an '89 200 has an MC1 or MC2? From the VIN?
- Ignition problem
- To Steve, door handle
- Can someone either sell me or.....
- Bad gas mileage, again
- failing tach ? not true rpm?
- How to spot shot turbo ?
- Starting in a smoky haze
- many threads...and sunroof
- 87 5kcstq - master brake cylinder problem?
- Looking for deep dish rims, anny Ideas?
- Strut Bearings
- poll - parts cars: a good idea, or lawn trash?
- One other thing...
- What is wrong with my full-throttle?
- help me out please
- Caution! Those of you putting clutches in 200's.
- fuel line repair...will this work
- Oil in the Michelin man hose--updated
- Flying into Salt Lake Saturday a.m. to pick up the 200tq...
- does the ABS relay/fuse affect any other systems - I want to turn off that ABS OFF light !!
- vac lines to heater box - I forgot the order of the color codes (DOH!) anyone know the order
- fresh oil, better running
- Eelpie...
- My car has finally start but will shut down after 5 minutes.
- white gauges at night
- brake warning light accompanied by a loud beep when brake pedal is pressed
- When did the type44 Quattro get ABS stateside?
- Hey andrew, how's life with a licence treating you?
- Does anyone have a heater core out of a car that they could measure for me? If not, which do you...
- fuel line trouble....need advise
- Odd climate control incident, started blowing while "OFF".
- HELP
- fan noise
- white front indicator glasses for the 100, are they in US allowed?
- 89 200tqa rear brakes question--Stephen or Koop or ?????
- Removing old pinstripes...
- Wipers = No Turn Signals
- Stock size exhaust on a 5ktq?
- Brake pad warning wire...
- Please help, car won`t start anymore.
- Well koop, I think the time and the deal are here...
- anyone have a lowered 200/5k?
- cont. Audi 200 work...
- Digital Instrument panel
- Benz' cool windshield wiper
- Cruise Control stopped working...
- Bought a 20v 200tq....
- check this out
- Type 44 track car pic's from this weekend...
- Electric windows - guesses please
- What's a source for 7 blade cooling fans?
- might be selling my turbo quattro
- audi probs =(
- Need 3b throttle body and front vaccum port, anyone?
- Help something weird happened and now can`t read fuel gauge
- what could possible be the cause....
- Audi 5000 + Rims & Question(s)....
- Update on huge flipping turbo!
- Source for new UFO rotrors?
- 1991 US spec Headlights on ebay
- Hot Starting
- New clutch equals driving bliss...
- steering rack... anybody in denver
- Here she is after her evening bath...
- Timing belt "opportunities"
- so I unplugged the isv during one of it's high idle episodes and
- Drive Axle Question
- I have a question about bypass valves
- I think I've decided that my fuel distributor
- Audi 5000 Head Interchange
- OMG!!!!This turbo is frickin' huge!!!!
- Muffler Question on V8
- Popped Speakers
- Ebay V8
- white gauges completed
