- Cis-e power limit
- Another Potential Parts victim
- does anyone have an active carfax account?
- winters here...
- Wiper blades/wiper arms
- A few Questions?
- Metal distributor gear for 20v - possible source
- What are all you Megasquirters going to do with all the found engine room? Pic of Header Collector..
- hydraulic sys. flush
- Success
- I need a combo switch!...........Please.
- finally started taking digital photos
- Update on my lighting problem.....
- look what i got!!!!!!!
- differential
- EFI conversions and boost
- I/A STAGE 2 COMPUTER AND 1.8 BAR SPRING FOR SALE
- and one more thing, audi for sale...
- some info on Mega squirt...
- Low idle when my 84 5000 first started in a.m.
- '87 5kq non-turbo.....
- VIR December Driver School
- hey guys....just preparing to do some struts on an '86 5000 turbo/quattro.for the strut cap removal
- hey adam
- An old Audi has been found, towed to a pick-a-part yard
- It's the little things that piss me off......
- tranny mount again, HELP
- Got the new clutch master installed.....
- question about shocks
- My first run-in with the RS6! some pics! X-POST!
- Armored TT :)
- i need standart shocks for my 200tq 89
- fuel cutoff thoughts/ramblings
- tresser comparision to stock center section
- tresser center lights installed
- I just had what an alcoholic would call "a moment of clarity"
- Dot 3 Or Dot 4?
- Can't find TDC mark on vibration damper
- Autronic?
- Brake Booster
- So how does my new "NF" engine feel?? x-post
- Tranny mount Removal for differential fluid check
- Adam you asked about headgasket and someone asked about fuel.
- tox--
- Anyone ever change tran's seals on a 89 200 ?
- Allignment
- Moving into a new place and found some headlight cover's i'd forgotten about, anybody interested?
- My car is a complete bitch........
- Help me find 4x108 16" Borbet type T's!
- Value of my 5000 model
- Is there a 5kq short shifter kit avail?? Where do I get it?
- does anybody have a picture of...
- Unstable idle
- Intermittent Check Engine Light
- BPV: Set me straight on which one to go for! Too much information!!
- k whats up with people?
- THE S4 CRASH VIDEO WILL BE UP SOMETIME SOON>
- tox....
- Rear Speaker Wiring???
- Tox
- differential fluid?
- Is there a way to test if the knock sensor is working?
- here are the pics : (
- This is just a guess but if my 88 5kqt is pissing anitfreeze out ...
- Audi V8 Oil Pressure
- WOW:) I can bark the tires!
- Need some good ideas.
- audi meet
- Help - Torque spec for..
- Where can i get some differential fluid for auto tranny?
- Help with steering rack and leaking hoses on '90 V8Q
- I need a starter lockout relay for an 88 5000s
- power steering fluid,mobil 1 syn.atf
- Ignition Coil
- How are the solar storms affecting your audis?
- Sold This One To The First Caller $2000
- More engine swap pics!!!
- reminder. dubsnorth vw/audi meet
- Heated Seat Switch-Light
- Tranny fluid leaking?
- Bumper chrome trim ...
- Triangular Exhaust Clamp ...
- I think I can finally call my project done
- Hard starting 1990 Audi 200 TQA revisited....
- Getting no signal from knock sensor two....Got some questions..
- which way is lean on CIS CO adjustment ?
- Could someone tell me the correct way to convert psi to hp?
- I know a few of you are changing CIS to EFI , so...
- Finally the forum works !!!!
- My new turbo...
- easy fix for sunroof?
- MTM Audi 200 at 24-Hours race
- I'm glad were back online:) My car is puffing smoke.........
- X-post, I think you guys will like this!!!
- rear shelf recovering project
- final drive??
- Audi is barely broken in...
- Auto Tranny
- okay fellas, I really need some help on this noise I've got
- A-Pillar Trim Removal ...
- Does anybody have a good working ISV?
- Could'nt find any intercooler straps?.........
- higher temperatures with new radiator............
- drove a 91 200 TQ wagon today...
- cat. converter : universal vs. direct ?
- Oh yea....Adam M. How is the short shifter? Let a brotha know when you get it figured out.
- Im too lazy to look at the book....Whats the quickest way to identify a NF or NG motor with them....
- Anyone have an extra turbo oil return line?
- time for new shocks??
- 1990 Audi V8 Automatic Trans (Hard 3-4 Shift)
- My sedan's coming out of retirement for one more race.
- Video of the Audi Factory/Museum in Ingolstadt!
- So what do you guys think of this?
- dilemma- opinions please -
- factory stereo headunit removal? anyone?
- The 5000's can shift so fast, but I'm wondering how many of you have modified your front motor mount
- Pros & cons on purchasing a Audi 90 V8
- 90 V8 Quattro Radio Locked Out.
- auto tranny question
- audi 200 locking diff
- audi vw New England gtg this weekend!
- hey tox what's the story on the white coupe in your picture poster?
- Whats the famous BIG VALVE HEAD code? ? with the larger exhaust valves KH?
- rear calipers
- what's up with the search function not working on our forum?
- Anybody here from Canada?
- OK...I am having a Homer moment...need help
- where is the check ball on the CIS ?
- Pix of Audi Museum in Ingostaldt, made by our secret agent fjones
- Part needed...........somebody? anybody?
- Help to replace speedometer cable
- mr. mowafy
- good weekend...
- Where can i get replacement lenses for my euro's?!
- need help! to much camber....
- Overboost problem PART2(was wastegate spring too stiff-86 5kcstq)
- 90 V8
- ABS Motion Sensor Tips
- 5000 dies when it gets warm consistantly
- reliability MC engines
- Head replacement tips, please
- probably off topic, but the forums quiet today,soo to wake all you up!
- Where can I get the QLCC code ?
- I need headlight covers for an 85 audi 5000
- 20V alert - Massachusetts
- in reply to 750Nighthawks Tick..... tick.....
- Motor? Anyone
- woohooo... going to get the new engine right now.
- 83 5000 turbo diesel..........
- hey Moving Violation, I have the *exact* same brake problem you mentioned... you figured it out yet?
- Anyone know if I can put a p.s. pump from a different Type44 into my '91 20v?
- Paging TOX. and friends. Let me get that turbo research.:) .........
- need cam lift and timming spec's. please
- front camber question,i need some imput on this
- Audi Back Alive. ISV how to removed pls?
- Long gone 5000 TQ!
- I know we're not supposed to use BOV's but............
- Check engine light gone for now, and Road Atlanta tomorrow!
- installation of digital odometer completed
- Um, crap. '91 200q 20v's p.s. pump appears to be leaking... what's the most practical avenue here?!
- Self leveling suspention
- Power Steering Jerks!
- Vibration through clutch pedal?
- I got some parts car that is sitting in my driveway if anyone is interested!
- horrible noise durring acceleration solved..sort of
- Window motor?
- Sumbling is gone:)
- Gear Shifter Lights Question!
- what is the best way to remove the door panel?
- Anyone know?
- why hasnt PMC been working?
- New wastegate spring too stiff (86 5kcstq)
- Brake Fluid Resevoir
- '85 and '86 5k power mirrors
- Speedometer Problems
- Tick....tick..................
- imfo. on instaling turbo cam into no turbo car
- put in new headliner today........
- going through some old pictures..
- Doh!! yet another problem, think my clutch is going...
- Baby got back! Red Tail (ale?) and a dissasembly question
- Engine light comes on today, 2141 code...
- cant figure out these 2 annoying problems, probably fuel related...(longish)
- RATTLE HUNT ...
- The saga continues.........
- Low idle when car first started
- would this turbo bolt up directly to a 5ktq(link to pic)...urgent
- 1990 V8Q - Emissions
- I just installed QLCC in car...............WOW
- OPSSSSSS
- Split flange for exhaust to cat
- gas tank sending unit...
- 1988 5000S non turbo
- YAA-HOOO Parts are finally coming in from germany.
- Surging/stumbling?
- free brake upgrade for 100/5000 non-turbo
- will an s-4 or a-4 rear swaybar fit an non torbo 89 100 body?
- 200TQ Idle Question
- turn signal flasher location?
- Hissing sound
- Sig/Subj lines
- My neighbors think I'm cazy:)
- Oil seperator
- Paging tox again-
- Slight starting problem when engine is cold. '87 5k Q
- V8 front blinker help
- Just curious ...
- this vid gets me SO Pumped up !
- Screeching sound from front drivers side while
- Throttle switch and idle switch
- Diff locks, problems with
- VT, NE Audi/VW GTG Details...
- Power steering leaks at the rings on the pump
- Left turn signal on= buzzing noise?
- Timing off by 15 degrees
- So, who is going to be the Hero and design a rear swaybar:)?
- A Fuel Pump story .... warning
- Low miles and its a 20V! Look what i found on ebay!
- WTB V8 Engine,
- andrewrasletter Re:only one type 44 pic from last years waterfest ):
- Check Engine Light - ECU
- fuel pump replaced -- engine not starting
- headliner and swatbar questions ,and camshafdt for 1989 100 non turbo.
- adam mowafy-
- My new ISV is already bad!!!
- Vacuum Leak
- Replaced the rad fan resistor pack today
- Quattro reconquers Mt. Washington....well sort of.
- Climate Control Codes
- Clunking noise from drivers side?
- I had an (200) ECU get wet, how do I pull the codes to find out if its gone or not?
- Fuel pump numbers
- By the way. You guy's Rock!!!!!!
- My isv leaks air.......
- Case File 986344: the case of the missing 5th gear, SOLVED....
- Incident (FIRE!) after test driving an '88 5000... long...
- awful noise during hard acceleration in 1st &2nd...
- brakes? Help! Ahhh....89 200T10vMC
- Exhaust flange to cat
- I would love to make a TQ into this...
- Worn Springs?
- Extra parts are in from ebay - MrEd - Sergei?
- Ever had one of THESE break?
- @#$%%%!!!! wont start:(
- Sorry To Say I'll Be Leaving Type 44 Forum Soon
- New 034EFI Forum!
- Help ! Climate Control Woes
- Bad idle problem
- C-Pillar Trim Removal ...
