- Fuel Filter Location???????? need answer soon..
- clutch slave & master cylinder
- QLCC code
- Need advice on 2113 code
- Treser Club founded in Germany
- My Oil alarm (pic of oil can) activates every so often under speed, no pressure problem on guage
- Fried my stage 2 IA chip....
- name that noise
- Between '86 - '88, what changes were there on the 5ktq's? Just HVAC for '86.5+?
- Different motor?
- spark plug change interval?
- Anyone have any experience with TAP sport injectors for a 10V Turbo?
- i amlooking at getting a 86 5k turbo for a engine swap anything to look out for on these cars?
- Chasing engine/heater temp problem; please help!!
- Original Audi Dealer Brochures 5k, 4k, 200 & Coupe GT
- Smoking wiper switch...
- Lets talk fuel mileage
- wheel bearings
- Anybody up for a photoshop request?
- FREE PARTS ANYONE ?
- a new strut tower brace
- Happy Holidays everyone!!! What did Santa bring you for Xmas?
- CEL Blink, no codes?
- ISV controller is complete!
- Pulling Codes
- 89 200 auto fwd
- Looking for couple of small parts...
- CIS line VAPOR LOCK!
- all i want for christmas is a smooth running audi
- anyone play with type 43 diesels?
- Passat cupholder part #?
- Progress
- Passenger window quit but works from my drivers control.
- yeaahh! my car runs 10x better! ;-)
- Merry Christmas to all and to all a smooth running Audi....
- is it worth it
- Comparison of AAN engine and MC?
- Another V8 Q. There is a rattling/banging against the floor
- MAC11 reverse engineering
- steering fluid vs. hydrolic fluid
- 1991 100 Power Steering
- The V8 is on the road... heated seats but no blower.... help...
- the 200 20v may go ...
- 20v bypass valve
- yakima rack
- Oh yea... How do the ashtrays come out? PO of the V8 was a chimney and left it full... yech!
- FYI: The Crank ref pin on FrankenVagen took a vacation...
- Differences in 5000 ECUs.
- V8 tranny fluid level and type? When checking level, should the engine be on/off....also
- ABS switch problem
- The V8 is certified and ready for an e-test.
- Perplexing boost problem, anyone?
- Climate control question
- Merry Christmas to all 44 owners !
- Speedometer is reading 5-7 MPH faster than actual with summer and winter OE rims. What needs adjust
- Need some advice on uneven boost at lowest RPM's (Not smooth but choppy at first or jerky then fine)
- Stuck Power Antenna
- boost problem.....
- Wheel / tire advice...
- High Mileage Mods
- Paging TreeHunter... Where you at?
- What was your last car B4 you purchased your first Audi? (88' Saab 900 Turbo Coupe) And do U wish
- '89 Audi 200 turbo
- Looking for pointers on thermostat replacement...
- WTF IS LEAKING
- Alignment questions
- Question for 3b owners?
- OK all... I need some suggestions...
- Question on chips for 3B motor
- Quick question, is there a difference between a Mc2 and 3b flywheel timing dowels placements?
- Attn: Stephen Ankney
- I'll take two!!! 2004 Audi S4 340hp V8
- Diaphram arrieved!!! Where did the power go?!?!?
- Question about 86' 5000cs engine.. Pics...
- Interesting bodywork :)
- 1990 100 Rear Disc
- Remember that thread about me needing some stock avant springs?
- Should I leave you guys and go Porsche?
- New 1990 Quattro V8 Owner.
- Rear shocks difference: FWD & Quattro...
- Found on S cars forum: Hans Stuck at the Nurnburgring
- Inchangable parts
- Miss that Audifans marketplace....
- 1989 Audi 100 Q
- Miscellaneous - Audi 200 turbo '89
- where can i get a bypass valve and about how much do they cost?
- V8 drivers/mechanics.. burning oil, any suggestions?
- X-Post: Possible GTG opportunity, input appreciated (For Those between WA and MI)
- dash lights
- Catalytic converter... I've questioned this before, but just got around to checking the test pipe...
- Gas Milage (horrible)
- might this be a solution to replacing rear brakes every 2 yrs?
- So... pressure test... dipstick leaking??? huh?
- Starter or Ignition Switch
- I finally got laid
- this guy definatly dont want to sell this car..
- Tire/rim interchange, other Audis/VWs
- Properly Diagnosed Fuel Problem?
- Saving a 1990 100
- anybody near charlotte,nc?
- '89 & '90 differences?
- V8 Quattro - Simple Question
- This is pretty cool, no affiliation
- 85 5000s turbo 5-speed LOOKING FOR A GOOD HOME
- 5000 Body Parts
- Crappy Audi day today.
- anyone know where can i get a new fuel pump for less than $160?
- Someone explain the proportioning valve on the type44 car to me.
- old Pentosin vs new pentosin
- Oh no. That didn't just happen...
- this car amazes me!
- im entertaining offers on my whip.
- For those of you located in Southern California...
- blowing fuse, where should I look first to find the short??
- where are the heated seat relays at on a 5k? thanks!
- 1/14/06 - CT/NY Audi Group Winter Gathering - EPL, Stratford, CT
- nasty storm
- 87 5KCSTQ--how much to ask for seats?
- Neverending hard starting story...
- Chipmunks in Door Speaker - Where to start?
- Finished brake work in time for ice age
- 20v no start uncovered: any one have a dist gear 4 sale?
- Hmm can't figure this one out ... can you ?
- Strapping intercooler, what did you use?
- Installed a new MM hose....
- Where to start. What should I check on my new 5000TQ?
- Anyone looking for a 20V Avant?
- Why do I have to have a coolant leak right now??? Where is it coming from? ideas?
- My super duper pressure tester that needs no air compressor...
- Need V8 exhaust! Aftermarket? Used? Where, who and how much? Opinions/suggestions welcome
- Power Potential
- V8 5 speed on EBOYYYYYY!!
- Update on the ISV controller
- WTB: K-24 turbo
- The 4ktq has been running well...
- Drive down from the Cold!!!
- Oh my goodness!
- Euros on Ebay
- Adjusting timing, fuel, vaccuum on 20v...? Jolt at higher RPM
- Cooling fan resistor pack test question
- its fixed !!!!!!!!!!!!!
- Neverending Saga 1990 V8 Quattro
- Auto show in Luxembourg Featuring---->>>Audi classics
- Need recommendation on Oil and Filter - 87 5000CSTQ
- Easy way to add the driving lights to the light switch?
- Turbo oil seal symptoms?
- s4 brakes on my 200tq 20- valve
- 85 5000 Knock sensor problem...
- a lil update
- Why do we love these cars? My two cents.
- Chapter 38 - The Never Ending Saga
- Where to find a brake tensioner bolt?
- I need someone to tell me that this was causing my problem. Stephen? Boxer?
- Carlisle Kit/Import registration is up and running....
- pcv valve?
- THANKS on the overheating issue. need you advice on fluids
- Anyone with Euro F/A-please help!
- Chris (cbpldc) - shoot me an email re avant
- idle stabilization circuit
- Hooking up check engine light
- What would be a good price for a set of used Ronal swing wheels?? Xcellrated...
- Fuel pump update...
- cool .. i'm finally using proper grammar with my name ;)
- urs4 intercooler into a 200 tq 20 valve
- scary brakes on a 200 tq 20 valve
- 89 200TQ shaky front end...(AGAIN, pretty long)
- Ugh, it took 8 hours to put in new front struts...
- Easy answer... need ASAP... I've got a fitting with a washer and an o-ring going into turbo coolant
- Xpost from A4 forum. Very good read on Torsen diffs / lockers. Well worth a look.
- Question about pulling the codes
- Any thoughts welcomed, this is my neck of the woods........
- Side Mirror Help
- huh? been getting about 10MPG lately
- You want fast? Turbocharged 1300cc Hayabusa > 220 mph video
- Need the part# for the universal O2 for mc-1...Getting conflicing reports.
- AHHH!!!!!! i wanna blow this car up and push it off a cliff
- Can anyone recommend an inexpensive fuel injection test kit?
- Strange and Irritating start up problems. Guru needed
- Steering wheel
- parting out 5ktq 87'
- Anyone need a Bentley for your 5K-CSQ?
- need advice
- coolant leak.
- Not a good week for me and the Audi! (long, please advise)
- F$&@ing Brake Warning Light!!?!
- Need winter tires, what fits and whats good? Studs?
- Ahhhh... a snowy day on the GTA.... QUATTRO rocks!
- Annother Possible Purchase Need some help
- Cold start (agian)
- Snub Mount...
- Anyone have a used set of 16" snow tires for sale in ohio?
- Possible Purchase Please Help
- I'm not in the market but if I was...
- HELP! Starting issues- need help ASAP!
- Attn Blizzak owners...
- 1990 V8 Skidplate BTW is $5000 too much for a 90 V8 with some problems, but only 60K
- floor mats for an '89 200TQ Sedan
- 200 20V MPG? My sedan get's 22 MPG on the HWY, some claim more like 25-26 MPG??
- Looking to buy a used 200 20V with the following problems: See text
- Anyone have a set of decent 15in tires with 100mi or so of 49001?
- ABS question - ABS kicks in just as I'm stopping...
- Red Euro Rear Light Lenses from Lux
- Above-door courtesy light . . .
- Can a backfire throw out the air sensor plate rest height?
- How cold is it where you are at? 16 below here. Zero car trouble, and fun in the 12" of snow!
- resolved (i think)
- OK... My ECUs are fine... the old recycled chips are the issue....
- deer problems
- Does anyone know which oxygen sensor is OEM for the 3B? Where's the cheapest source?
- Tick-tick noise from the intake "slug" thing
- Fuel pump problem I think...sigh.
- Towing a T44 with my Avant T44 - am I crazy?
- bad ABS sensor?
- Aircon compressor Audi200T
- how to check fuel acumulator?
- Repair Manual
- msd ignition
- So my car won't let me in...
- So, I thought the autocheck was crazy... turns out to be fuse 4!
- MEGASQUIRT/EFI questions.
- Welly welly welly.... something went horribly wrong with the IC burning...
- NAPA metal heater control valve...
- Decided to give nature a chance to redesign my 200t
- Anybody got a defroster switch for an '87 5ktq?
- Pop! no start
- Strange Noise when turning
- Put a half pint of "seafoam" in the crank case. Wow, lifter noise completely went away.
- Fuel Freezing... i think
- stumbling problem much worse when cold... (continuation on past rant)
- Parking brake
- Pulsating front brakes-help!
- why do we love these cars
- 20V crank no start= F*%k
- Another question for the night... continuing the beeping story...
- blaupunkt
- Are the corner lights turn signals?
- Sources for W/G Diaphram
- Bum low end power... compression dropping gasket? any BTDT on compression dropping head gaskets?
- Someone said "Florida Hicks"...shame
- 5000 Avant interior door panel removal
- p.s pump
- magic switch
- STEP1: fix the car, STEP2: gofast(er), STEP3: more go-fast!
- Dash lights no worky? Annoying!
- mc 2 coil black wolf.........
- No Fuel/Spark when Cold
- Har har..... burned me a chippy...
- attaching a yakima rack on my avant, how???
- ok, i broke my door lock
- Anyone have a pic of where the cold start valve is on a '90 200?
