PDA
View Full Version : Audi 5000 / 200 / V8 Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. 89 5ktq suspension on 92-94 V8, revisiting
  2. These cars.....and cold temps. Gah!
  3. '90 200T Non-Q. (MC-Dual KnockS.) MAC-14
  4. 1982 5000s TurboDiesel with coolant leak and oil in resevoir
  5. Mark Pan-O2 sensor question from previous post...
  6. anybody have a BPV Diy for those with limited tools?
  7. idle compensation and quick ones...
  8. Sputter, then xtra loud fuel pump. Replaced the filter, seems ok. The old one was mucky.
  9. Saw two R8's ripping down into Las Vegas yesterday!
  10. The power steering saga
  11. ICV's different Part #s will it work??
  12. Very Cold NO START '87 5000CD
  13. Bolt in V8 TT solution...
  14. Update on the 'ol 86 5kcstq...
  15. ItsaV8-you on line?
  16. any way to check the condition of the timing belt w/o taking it all apart?
  17. Cooling system, Step 2
  18. Questions or advice about 200 20v
  19. Anyone else in New England jonesin' for some snow??? Damm...
  20. Anyone know the metric size fittings that couple into the FPR for the V8?
  21. anyone heard of T. A. P.
  22. V8 chip. Discuss.
  23. Bypass the Fuel Pressure accumulator?
  24. Anyone know of an outfit in the Montreal (preferably) or Toronto
  25. Quick question
  26. What's under your backseat? (V8 Question)
  27. 5000 TQ exhaust fit a 90 200 TQ avant?
  28. Anybody experiance tps problem resulting in really high idle like 3200 rpm?
  29. So much for adapting the 10v tranny...
  30. 87 5kcs fuel mixture question
  31. Relays... I want some to run my euros on... Which ones to pull from donor cars? Euro light plugs?
  32. Hey guys, I'm looking to some MC-1 ignition coils
  33. 1987 5000S Q Welcome to my nightmare
  34. kaffercup....your post about lights a bit down....
  35. WTB: Arp studs (used ok) 10vt, and metal HG (ana? or copper)
  36. Spotted this ad on the local Craigslist
  37. R&Red the heater blower using the "modern" steak knife method...
  38. Fuel Pump Locked up Again !!??
  39. Interchangealbe interiors?
  40. are 200 20v and 5k middle mufflers the same?
  41. clear euro side marker for 200
  42. 1800hp anyone?
  43. Does Audi, on there 875kcs run the braking through the steering
  44. is it normal to have lots of pressure in the coolant line going to the top
  45. '91 200 quattro 20v intermittant bucking when accelerating
  46. anybody need injectors for an 87 5kcs, i dont need them but need
  47. Interior lights not coming on with door opening....
  48. Anyone Parting out a 5000Q?
  49. What would cause a New fuel pump to be noisy?
  50. 200 Avant-V8 bumpers
  51. Fried my motor last night
  52. Can somebody tell me that part numbers for the front turnsignals...
  53. boxerfan, what exactly is R-modding?
  54. will non turbo euro lights fit my 5ktq avant?
  55. Fog lights....87' 5000cs tq
  56. muahahaha.
  57. I *think* that my power steering problem has been solved
  58. Ignition Switch Question
  59. 89 200 10VTQA up and running - still some questions...
  60. Will a 200 climate control head work in a 5000?
  61. 1984 WU engine ECUs and ICU
  62. power steering fluids.....mixing questions...
  63. Looking to borrow timing belt tool 2084 in Chicago area - if you have it please email me. TIA
  64. Parting out 1990 V8q
  65. guys with 5000 Bentley... request.
  66. Jumper Terminal under hood 875kcs rusty and corodid...
  67. Settled on a Valvoline SynPower PSF and Pentosin mix.
  68. recent no start , no cranking get full electrical but no cranking , then 10 minutes
  69. A4 vs. 5000 snow vid
  70. Wait what... theres a jumper post under the hood on 875kcs?
  71. Any benefit from the turbo cam (MC1) in an NA engine?
  72. Cool Audi 200 database
  73. Starting to believe the Borat Movie..(strange news)....
  74. Any Canadian guys need parts? 3" exhaust, IA ECU, brake parts, etc available.
  75. Turbo Gurus, Help? Continued
  76. noisy/squeaky belts when wet or humid
  77. charging woes... 875kcs
  78. Mystified
  79. airflow potentiometer
  80. How useful is the 77-83 5000 Bentley for 84-88 5000?
  81. Chinese Audi Type 44 headlights update
  82. Gamma radio in T44
  83. And what are these plugs for?
  84. Strange, disconnected plugs under the hood. 1990 200 TQ - Part 2
  85. Strange, disconnected plugs under the hood. 1990 200 TQ
  86. Opinions? - 2.8 vs. 1.8t in say a '99 A4 quattro avant....
  87. Parts for 1989 200t
  88. Wow even the tires are a pain in my 5000
  89. Pilot Bearing Q
  90. ABS light...?
  91. part verification 443 407 625A
  92. 1990 200TQ Avant - Aux. Coolant pump not running
  93. This is the last thime im ucing G30
  94. replaced heater core and caused new problems
  95. if i pull an inj should it spray while cranking
  96. Red 1989 100q decent shape, $300. NY
  97. Dash lights out + Occasional no start = Ignition Switch?
  98. Figured out why my car has been throwing Alt Belts lately...
  99. Yakima Y clip attachments
  100. 5000 CS FOR SALE
  101. New owner of a 1990 200 TQ Avant - A few Q's for the board
  102. 1991 200 20v Avant, why no action?
  103. f/u on my previous post concerning fogging windows
  104. Question about engine head....
  105. so....dissed the cold start valve, it's about -17 here in Brampton ontario nightly...
  106. WTT 91 200 20v for a diesel
  107. V8 and bad emissions and a funny story
  108. Whats your opinion guys, I want my Radiator out Quick and painless..
  109. Open carfax anyone?
  110. V8 Quattro Transmission
  111. odometer rollback: is this a growing trend?
  112. Filling up my radiator on a 5000 (just changed), they shipped blue coolant instead of pink
  113. 87 5000... Radiator fan wiring question, which side does the three wire go on to the fan?
  114. A quick question about Lifter Clacking...
  115. Is a MC1 head different than a MC2 in any way other than the cam?
  116. non turbo 5k quat for $1993
  117. Umm, yay. Bought a 1991 100 automatic today. Is it a KX, NG, 20v???
  118. no heat. f@ck.
  119. No Power to Fuel pump or ignition???
  120. Tell me about the OXS frequency valve
  121. after run temp sensor, which wire goes on top the stripe or non stripe?
  122. Will the car run without the instrument cluster?
  123. intercooler hose
  124. OK... here's the scoop I have on gearing so far... Europeans/Tranny Specialists please read...
  125. holy-moly and then there was a spring!
  126. anybody know how to take the pully off ?
  127. **SOLD** Have a new, in box smoked rear tail lights for 5000/200 Avant. $100 plus ship. LMK.
  128. smoke test
  129. Windsheild washer squirters
  130. power steering leak
  131. DAMMIT!! Had a family member back into my V8 last night.
  132. intake temp sensor
  133. Car is back and much more badass than ever...clutch, rebuild, LWFW...
  134. 200 20v power steering question after rack replacement
  135. replacement coil springs/ 1990 200TQ 10v
  136. No heat :(
  137. Low boost?
  138. Hard brake pedal and steering???
  139. 19875000S Q non starting until 1 plug removed
  140. So after talking with Salisbury Motor Car .....
  141. Boost leak check/replaced intercooler...few questions '89 200TQ
  142. I need an analog dash clock
  143. alternator removal, what size bolts and where are they located ?
  144. LWFW install in 5k cstq-question
  145. 1987 5000S Q
  146. Need Help Please....
  147. Wheel shakes left and right when in nuetral..
  148. Anybody run into a problem like this before during a cam swap?
  149. etka 7 & demonoid invite request
  150. All T-44s are around 20 years old....SURVEY TIME....what will your replacement car be???
  151. Transmission Identification questions...
  152. front passengers side axle......
  153. Donny S...you still in my neck of the woods? Your email isn't working. Drop me a line if you can.
  154. its amazing how a good alignment completely restores my faith
  155. Need some directions...
  156. Anyone have clean V8q with black interior they want to sell?
  157. removing engine speed sensor
  158. interior lights.....
  159. If my insurance didnt cover towing, I'd be twice as unhappy as I am right now.
  160. Handmedown - 1990 Audi 100 (auto) - Bad pentosin leak
  161. Thinking about a V8, thoughts?
  162. cat for 20v
  163. Neu Avant home, tested. Props to nb::
  164. Exhausted
  165. Temp Gauge not working...what sender/sensor needs to be changed?
  166. is driving with a worn out brake bomb dangerous?
  167. please help will 100 non quattro brake parts swap to 100 quattro what parts interchange ?
  168. Anyone have a picture that they could post of the Stock 1990 v8 quattro exhaust?
  169. Tips on changing timing belt.....
  170. For those who like to talk about what cars are in what movies
  171. Avant purchase with "s" motor?
  172. Clutch Help? Shop installed new sachs clutch bought at Blau parts and it engages fairly high up and
  173. I say we all start a petition and get Audi of America to recall all cars with cis and convert them
  174. front fenders
  175. Can I get some help?
  176. 20v bronze dizzy gear group buy.
  177. Just took the radiator out of my 87' 5000 turbo, should I get new hoses or reuse
  178. Who needs some pearl white wheel centers?
  179. Sunday afternoon videogame.
  180. maybe selling 90 200 TQ 150 k lotsa new parts..........
  181. boost question...
  182. New arrival 200 20vTQ... Nothing like an old audi
  183. RPM, Speed and gear ratios...
  184. Dose the Speedometer and the RPM gauge share a sensor?
  185. little help: Starter or battery problems?
  186. i cant believe im asking this but how do you adjust the headlights on a 91 100
  187. Injectors.
  188. Well, I'm certainly fed up with that!
  189. say, is it just my imagination or what...I disconected the cold start valve and my car started
  190. Possibly selling the v8
  191. Where to buy a tap to retread the threads on my oil pan 87' 5000 turbo
  192. 200TQ 20V for sale
  193. Auto check system
  194. Saturday Night humor... Ad campaigns
  195. what brake components interchange
  196. brake tools ? who sells a kit so i can turn my caliper back in cheap please
  197. Best mod ever: 1.95 bar WG spring!
  198. any experience with azevedomotorsport, linden nj?
  199. Alright dumb question, where is the ignition switch?
  200. As much as I hate small civilized SUVs..
  201. Found a 20v bronze distributor gear source
  202. I need help following power steering rack and pump r&r
  203. Fuel filter recommendations?
  204. Audi 100S 1992, 68,000 miles
  205. turn signal relay....?
  206. how difficult is it to take out the exhaust manifold? Mine is leaking bad, but I dont' know why,
  207. 1991 V8 Quattro SPARK PLUGS
  208. 2 Questions......
  209. Paging: nb:: Can you email me? I have a question for you.
  210. Trying to fing Fuel Pressure Accumulator...
  211. Dumb question: What's the torque split on the older cars with the manual diffs unlocked?
  212. No start and No IC '90 200TQ
  213. Im Looking for the Warm air deflector plate 87 5000 quattro
  214. Car dies less frequently...but still...WTF
  215. Regarding the HID headlight discussion.....
  216. More Info on Broken 3b
  217. Door lock rod clips
  218. need help with correct HVAC symptom
  219. 87 5000S Q running too rich
  220. 5k->v8 suspension swap?
  221. Radiator fan switch going in and out
  222. intercooler hose
  223. 1991 100 Parts Availability
  224. Headlight upgrade options for 91 200 20v?
  225. anyone know where to get a downpipe ( exhaust manifold to cat con)
  226. Don't drive you Audi for a week and then you'll realize
  227. Clear euro side marker for 1989 200q
  228. where can I get this grill?
  229. will 200 quattro grille rings work on B4 quattro grille?
  230. sillicon intercooler hose
  231. 1.6 bar and mabey 1.7 if the car feels like it
  232. Hey everyone take a look at this...clear headlights for the 200
  233. inner CV joint to axle flange bolt size?
  234. Liquid graphite for frozen (not temp wise) door lock?
  235. 4ktq running issues?
  236. Hey V8ers... what kinds a mileage are you getting from the 4.2s?
  237. Transmission woes
  238. A bit confused on CO % mixture ranges...can anyone help? Audi 200 '89
  239. Do I have the right part number? For the E.M. stud...
  240. 200 20V Avant owners, Let's see some pictures. For wacky reason,...
  241. puzzle update, or distributor pickup...doh!
  242. puzzle update, or distributor pickup...doh!
  243. shock strut cartridge install
  244. Cutout problem believed to be with Aluminum Flywheel and Crank sensor.....
  245. As luck would have it. I need a blower fan (Soon)
  246. Got blown motor out of car. Pic of damage is rough!!
  247. Anybody in RI need a parts 5ktq? eng/tranny good
  248. Anyone have a good working drivers rear caliper for a V8?
  249. hard start problem...pulled codes
  250. need oil pan for 1987 5000cs turbo quattro
