- Brake master cylinder and hydraulic servo unit replacment help.
- Engine: What is this?
- Thermostat questions
- broken plastic component in starter motor
- Pic Request: Red v8 w/ 17's or 18's
- Stage 3 progress
- Remove Fuel Pump without Special tool?
- Which turbo to chose, and 18in wheels.
- 200 de-badged grill mod explained... Anyone speak german?
- Oil pressure gauge pegged (a little more info)...
- Anybody Going to Gathering of The Rings?
- Dilemna...
- no hot start update
- Anyone need a type 44 steering damper?
- Follow-up on my antilock issue...
- Where does this go?
- V8 Parts Needed
- 1990 V8 Throttle Cable
- Power steering leak...
- new project headache
- V8 issues to watch out for?
- came across some cheap Treser 5k body parts.
- audi 5000 turbo?..
- how lexus does a V8
- V8 won't start :-(
- Part Number for the adjusting stars for A/C Comp and Alternator?
- In need of a belly pan for a V8q...
- Factory wheel options?
- Thinking of selling my 200TQ 10V. Opinions on price?
- CAT light blink non-stop??
- Instrument cluster question
- Finally fixed that airbag light.....
- seafoam
- Goodbye to old friend
- how do i trick the cold start injector?
- AC/Main Vents Shutting on Increased Acceleration
- Delayed Transmission Shift 2nd to 3rd Gear
- So the V8 has arrived and now the timing belt sage starts..
- Anyone have a nice, clean, working instrument cluster...
- Having wiring issues
- I finally own a 20V 200TQ.
- Bad MC?
- V8 dyno results with other newer audi V8's to compare
- 1993 100CS dies on occasion
- 91 200TQ 20V, intermittant blower fan, any ideas?
- v8q purchase dillema:Choices,choices,choices..help
- so my battery went dead
- idle
- v8 sooty exhaust situation....
- smog test prep
- Where to get W7DTC Plugs and Which Thermostat for Florida, and O2 Sesnor ?
- Hard to put in reverse?
- And so it begins. The end of the 10v, and the beginning of the twin turbo V8
- Anybody here still using VWTOOL? (yes, I'm a dinosaur...)
- I have some stuff on Ebay. Search 5000 Turbo
- What kind of fuel pressure is at the cold start valve?
- Audi 200 -87 (MC1) rich idle
- Anyone in need of a good V8 Auto trans?
- Solved my 1100-3000 RPM High Idle problem Now it's too low.
- Stereo: Replace Bose with Non Bose? 1990?
- Back again with a blink code 2121 :=( '91 200 20v TQ
- new flik ftd wheels delivered. Can't remove old wheels.
- leaking brake master cylinder/hydraulic servo union
- Where is the "OXS Control Unit?"
- V8 question
- Hesitation, Stumbling. Jerky.
- threads being deleted???
- Another wood door trim question...
- Looking for wood door trim...
- V8 starter not engaging
- Growly Wiper Motor.
- aftermarket stereo problem
- 5ktqa Cold Starting
- Overheating 1986 5000s, please help!
- Boost problems
- great company good products
- headlights
- Ebay headlights any good? will they work with a turbo? anybody purchased them?
- front wheel bearing replacement
- price?
- Window replacment
- Propeller Shaft Question
- Just a silly question to ponder on...
- 1989 200Q - The Dreaded Battery Cable Splice
- Does anyone have a used chipped ecu with spring for sale?
- S-Fest West thanks, shout outs and a few pictures...
- Does nobody want 10v Turbo Quattros anymore?
- anyone done 275-35-18 tires on a V8Q?
- What about Outside Axle Boot Replacements-1990 V8Q
- 200 automatic
- Market value on a 91 200 20V
- Still have this 200 20v for sale....price now $2300!!!
- Posted my car for sale on audifans incase anyone is interested 91 200 20vtq
- 320,000 miles on 1991 200QT
- Non running '88 5KTQ - Where to start...
- Suggestions for best price on CV replacemnts for 200 20V???.......
- I need help with car accelerating by itself.
- I have a steering rack emergency...
- the clutch slave bleed went well ....
- AllData opinion on V8 Quattro
- If anyone knows how to contact the owner of the 200TQ avant that was for sale in DC please email me
- Quick vaccum related question.....
- Were HP/TQ levels published on 20V T (3B) engines conservative or were Audi numbers accurate?
- IS it just me or are brakes for the 5ktq expensive?
- Looking for 200 20v Avant
- Anyone need these oddball parts for their 5000??
- steady water leak
- Totally Impressed with performance...finally.....But (Kinda Long but I have a ???)
- Warmup regulator question
- axle
- High Idle in the Cooler Weather
- audi 89 500 se (South Africa)
- Aftermarket Stereo Installation
- Heated seats
- My Brake pedal Hard as a rock, then normal.
- remove headlight glass
- Bad BOMB
- Power Windows
- bleeding Clutch
- HOW? - Changing Brake Pads in the UFO 90V8Q
- broken window
- 1990 200 TQ AVANT DRIVESHAFT VIBRATION
- Boost question
- 3.6L V8 High fuel consumption
- I know there's a thousand post on it, but what kind of spark plugs
- Wheel bearing question?
- changing UFOs
- Speedo Sensor...
- Should boost fall off from 1.9BAR under load in the mid RPM band to 1.5 BAR at Redline?
- Any suggestions on oil pan removal? It seems like I removed about 1000
- Antilock question *update*
- V8 Poor Acceleration
- What's the hex key size...
- where to buy the euro lighs?
- where can i get a crankcase breather hose?
- Here's a crazy glove box question...
- Anyone know where I can get platinum dye...
- Question about '89 200 front seats
- Or... buy mine. $4,000
- Nice 200 20v for sale in Mass... 100k... no affiliation...
- S-Fest West Registration is still open. Have a chance at winning a $1400 FMIC!
- Good deal for somebody in Washington State (no affiliation, etc. etc.)
- defrost/heater fan
- Steering Rack-Glutton For Punishment-Can I do it?
- Quick rant......
- WTB: 200/20v UFO Strut housing. I intend to make some carriers
- Done with vaccum issues..Thanks to everyone who participated....now another interesting thing...
- pictures from "old school" audi meeting in Mainz Germany
- Clarification on "Center Bearing" (86 5kCS Q)
- Need Driver's Side Window Switches for 200
- Public Service Message: Craigslist Washington, D.C. - 1991 Audi 200 Quattro Turbo Wagon 89K Miles
- 1978 5000 specs
- Redoing my 84, I'm looking for a drivers seat with the blue cloth..
- Audi 100 Wiring
- I know this is a toughie but...
- Car stopped on me again!!!!!!! :(
- 1986 5ks cold start problem
- Wheel Bearing Time - Anyone have one of these from Harbor Freight?
- 89 200 tq(long)stalling and low boost
- 83 Audi 5000 Automatic For Sale Western Pa.
- Anyone know what type of paint was originally on the 89-91 audi 200's?
- anyone have or know where to get a stock wastegate spring
- Anyone know where to get the best price on...
- New owner of an old transaxle!
- 90 200TQ What causes the AC Compressor to shut off at 2750-3000 RPM???
- What would happen if I use the wrong knock sensor?? Am I using the wrong one??
- Can anyone help with parking light flash on alarm?
- need help with oil pressure switch
- advice on buying 86' 5000cd quattro?
- FS Roof Rack for a 200 avant!!
- Electronic gurus: Car alarm going off for no reason
- Urgent advice needed!!
- VWoA Announces Relocation of Headquarters to Northern Virginia, job cuts and New Direction
- Door window glue?
- I've gone and done it now... bought a 4runner
- Engine mounts
- Brake gurus: Are all of the 200 Quattro Hub assemblies the same? Can the
- I think my audi is sick.
- OH....MYGOD That RS-6 Avant w/IMSA fenders flairs, How many personal body parts do I have to sell
- Time to say goodbye :(
- My next used car in about 5 or 6 years. . .
- Is there an electrical connection on the A/C compressor that.....
- Just came cross-country in the 200...
- engine speed sensor, rpm sensor, reference sensor, crank position sensor;
- engine ground strap
- Anyone interested in a working Gamma head unit?
- Any caring soul willing to help me install my intercooler with bypass valve
- Can anyone tell me what this part is?
- What happened to the old threads?
- Idle question on 200 TQ
- OK, another weird one about my 200 ;o)
- OK, weird question about 200 seats
- FS: 1990 200 TQ Avant
- Blower motor
- FS: 91 100 Quattro
- I finally got around to taking some pictures of...
- What motors can this ignition distributor be used on?
- Transmission mounts
- Good ISV from 1991 200 20V 3B available
- Heater Core / Blower motor complete, getting a whistling sound. (long post)
- She Works again.
- Heater Core / Blower Motor Rebuild with pictures.
- What did I do wrong now?
- electrical surge / head lights
- idle sputters on startup
- how to remove front struts on 1989 200q?
- Question about removing foam from heater core box.
- Stage 2 complete ;-)
- Rough Diesel Morning Start (81 5000s)
- Who wants a $1400 Apikol FMIC?
- parting out 1991 200 turbo (10v, NQ)
- Stupid question maybe but what does Ur and Urs refer to when speaking of series of cars?
- Parts Parts Parts, mods, all sorts of stuff to unload... will consider selling whole...
- any parts commonality between 87 5k CSTQ and V8Q?
- last call for wheels and tires
- WTB 5000 sway bar
- Anybody going to Germany anytime soon?
- digital clock on dash
- Anyone can tell me about these parts?? 200 10V Mc1 Aut '89
- V8 intermittant starting problem - will fire up, then die unless gas is given...
- Should I bother updating the rear stock brakes...
- Door panel/sport seat/Delta radio for my early '89 200TQ sedan
- Additional question about my '89 200TQ
- I can't believe it's been over a year and a half...
- strange website.
- window removal
- oil cap removal & stall
- Timing belt change on 87 5000CSTQ. Advice? Tips?
- well you dont see this everyday.....
- Continuing Window Trouble
- Watkins Glen Audi event: Who ran the Luxo-barge?
- Photos of my $150 81 5000
- On the topic of the "Goldmember" Audi 5000....
- FOR SALE: 1986 Audi 5000CS quattro turbo wagon
- HP2 brakes ...Need help from the old Audi community again...PLEASE TAKE THIS SERIOUS!!
- Pulled the engine on the V8 today
- Solution to X-pipe on the exhaust
- I knoww that this was posted earlier, but I need a new clutch and I want something that will handle
- Picked up a 81 5000S, have a few questions..
- Need some help here!!!!!
- Anybody Interested in a Montana V8 Parts Car?
- S-Fest West Registration Web Site - Only 3 Days Left to Register! Let's get some 200's and V8's
- Someone near Indy to check out audi for me?
- Someone save my V8 from early winter long storage
- S/4 STEERING WHEEL & Air bag ASS
- Where should these go?
- Going through blower motor replacement -- 5KCS Turbo
- '87 5KTQM front passenger lower control arm - interchangable with.....(fill in the models please)?
