- ECU Light
- Steve Ankey!
- Cuatrokoop...
- How to ?
- Made it home with the 100 Avant!! HOORAY!!!
- 5000CSTQ Center Differential Wont Engage
- Please help with 91 200 20V brake issue. I am purchasing a 91 200 20V that has had a brake failure.
- Is there a difference between K24s?
- unhappy '87 5000 TQ
- if you had a choice - Cdrom or paper bentley?
- ABS light finally fixed
- What kind of spark plugs do you guys use on a 86 5kTQ?
- It wont start....AGAIN!!!
- 90 100 Hard Start
- Hey Twisted 5000, that wasn't you on the side of RT 84 with that tow truck...
- It doesn't look like much but this IS the BADDEST 5kqt out there...
- Help: 087 Automatic transaxle diff code
- OK, last chance for fuel rail.....ordering tuesday morning
- Someone please lie to me and tell me this is'nt a serious problem!
- Junkyard stuff
- Is the Audifans mailing list down?
- What's a 125K mile V8q automatic tranny worth?
- qatro convertion
- Treser 5000 on ebay
- Toxcheap...
- I Will be saying "good bye" to the old Audi 100....sad
- has anyone here ......
- Five in a Quattro
- loud pop that happens when i start the car.
- TOX TOX TOX TOX TOX TOX TOX TOX TOX,...click this...
- Airbag Light Always On
- Time for new front brakes tomorrow...
- auto trans to man trans conversion
- Another V8 Quattro with 5spd
- '87 Audi 5000 CS turbo quattro questions
- Great, just fixed the H2O pump and now, dun,dun daaa...
- Poor guy......
- 91 200TQ 20V--Down on Power--suggestions
- How much power is the fuel pump from a stock 5ktq good for?
- Temp readings
- Noise...Again...
- V8 Day one ( questions )
- V8 Pics
- Lighting question....
- what are UFO calipers?
- Fuel pump -sequence of events
- found this link on the S4/S6 forum......mmmm dualing BPV's, got boost?
- Sail cloth on an Avant?????
- What should the correct CO duty cycle be for an mc-1 that is 1.8 chipped?
- Bad clicking right behind the dash - sounds like the flasher relay is going bad
- 20V and V8 injectors...
- looking for wood trim part
- anyone want to trade their 5000 ligths for aurope ligths??
- MAC-14 CUSTOM PROGRAMING
- Dyno Comparison:This is how a chipped 2.2L compares to the chipped 2001 S4 2.7L
- Let's make the thurs. the 13th. meet @ Starbucks 9:00pm in Woodland hills
- Dyno comparison Riff's S6 (MTM 1+ K24 22psi boost) / TOXCHP IA 1 K24 21 psi boodt
- Dyno comparison, stock 5ktq, Urq w/MC-1 conversion with K24, 15 psi, toxchp 21psi
- Toxcheap dyno comparision to STI (stock) &STI w/3" exhaust
- Mixture
- Also....Ignition wires with chipped cars - 8mm or 7mm?
- Having stumbling problems..... what is the best octane booster?
- Need to get this solved before I do the chip and spring next week....
- Need technical help with the map idea
- V8 Euro Headlamp Install
- No start
- Just got an Audi, have a few questions
- bomb/booster/mc problem
- how to remove p/s pump on 90 v8Q
- Need a head count for the GTG this Saturday...
- need a small part!
- I mailed my ecu to Ben Swann today:)
- Drilled Rear Rotors?
- Fuel pressure on a 20V 3b engine.
- V8 93 UFO convertion.
- 2 questions on the Audi V8 Quattro 1990
- My forge BPV
- Hey Cialowicz...
- What does a "decent" prep/paint job cost for a car of this size?
- Anybody from here going to the GTG this Saturday?
- VAG Tool
- Group buy on fuel rail for EFI swap......
- Ok EVERYONE this is going to be a big project but hey it will give me something to do:)
- Adam, please respond to dashpot question earlier on forum, thx.
- New Haven GTG info...
- A Picture of my Old 91 200q
- I always find it really suspicious when......
- finally got pics!
- deer damage (continued)
- out of context question
- rear sail panel ( D panel )
- Seat heater question
- East Coast GTG event this Saturday, here's the info...
- 1.8 bar ECU by force5
- transmission noise - advice would be great
- exhaust stuff on 100
- Boy, these cars are nimble
- This may be a silly idea but I'll run it by you guys.....
- OK....looking for more thoughts on the noise problem
- Anyone from MA, CT, VT, NH, NY, LI, NJ, ME into a East Coast Audi World GTG???...
- 0-60 in 2.37 seconds!!!
- Dashpot maybe?
- Best looking Wagon...
- To you 20V turbo owners.....
- Cone filter on 5k
- Could a rattling heat sheild in the rear exhaust cause the ECU light
- Need desperate help - Audi 200 Turbo air filter replacement... bah..
- WAHoooooooooooooooooo
- V8 on Ebay needing Transmission
- Pedal palpitation
- Update on 5ktqw wagon
- Anyone gotten noisy V-belts from the local auto parts store?
- Went pic crazy! look inside!
- Wheel bearing??
- old readings...BPV......shortyq
- Anyone know what the price is like on a used center diff?
- Coolant...boiling sound
- what kind of fuel pressure does the MC push in stock form?
- Hmmmmmmmm.....................
- deer damage
- headlights
- Maybe a silly question....
- v8 dash
- Check This out!!
- eh....
- I'm pretty excited.... "Today was a good day"
- Tranny: Another one bites the dust ... but this wasn't Audi's fault!(m)
- Does anyone here use the V8 list at Audifans.com???
- Question about Door lock and Window regulator
- Paging Cbpldc......
- Well guys..........
- Warped dash
- My first Audi, my first problem, and my first road trip! So it begins... (3 pics)
- I found a fairly nice black leather interior out of a 89 100... will it fit in my 85 5000?
- 7A 20v head on a 10v turbo block. Feasible?
- Fuel/Air Mix
- v8q running crapy
- New Collector
- Audi 5000 tranny not shifting
- Sure they don't include Audi...
- how do you check transmission fluid
- UFO brake replaced with what?
- Dennis H, or his brother (in NH) - did you happen to get video of my 12.3@114 at NED?
- Removing center console switches
- Getting more fuel... Ahem...Toxcheap?
- Audi200T5000S climate control head unit
- 90 V8 ?s
- any body here an audi tech?
- Strange ABS 'Antilock Off' light problem...
- i swear these cars a psychic!!!!
- Sorry for all the questions.....
- Older Climate Control Are You Tired Of The Fan Blowing Fast On ECON
- What is that damn smell?
- wipers alignment
- Where to hook up power?
- V8 Question
- 5kq questions...
- Speaking of quattro and snow tires, found this old Pic
- On the topic of exhaust, anybody purchased a stebro exhaust for their 5K? or v8?
- Newbie: 87 5000 Turbo Quattro-trouble with reverse.
- k so no one is helping me out much-
- How come V8's are so cheap
- Liquid solder or conductive paint a fix for circuit boards ...
- the hose between the IM and Cylinder head...
- do all quattro's have a front LSD ?
- Climate Control Head
- how do you make turbo cars make the cool chirping sounds like race cars
- Will 14" wheels fit on a 5000 with G60 front brakes?
- anyone here have the MC with straight pipe exhaust?
- '87 5kq.....won't start
- timing belt kit for $76?
- Hey Devils's Advocate (HVAC fix)
- how easy or hard is it to change the blinker arm on a 88' 5ktq?
- Changing axles on 86 CSTurbo
- leaking rack 90v8
- bose radio 90v8 buyer
- Brake sticking other prob?
- fluctuating RPMs on 3b 20V?
- Got my snow tires today:)
- V8 manual swap info
- Anyone have any images/info about the '79 5000? I'm desparate...
- HELP - LIGHTS OUT: 4 front markers, 2 taillights, all dash, all console, glove box, etc.
- Cleaning injectors?
- climate control
- 90v8 Rpm sensor...Issue
- Gear shift adjustment
- 100
- change spark plugs and wires on a 200 turbo
- Imsa header
- Reliability of 5000 turbo motor?
- for all you engine lovers....
- Heated mirrors
- does the transmision from a 1992 100 fits a200 turbo
- Something's fishy about this auction!
- Ongoing Quattro - Ford 5.0 conversion
- found a cool website....another audi enthusiast! you guys seen this one?
- Rad Flush on type 44
- How tossable is a type 44? Ask the deer i almost hit tonight...
- 2nd post- any btdt on windshield swaps?
- questions about engine codes...
- Look what I got in the mail...
- 100 front pad question - (o) is on . . .
- Neighbor's fuel pump works!
- Good car repair advice site
- new 1991 200TQ wagon owner here!:-0
- New Brakes...Finally, but...
- Looking for some 200 advice.
- Manual V8 quattro on ebay.
- insurance questions 200TQ
- It must be that monthly thing again...
- Fuse 14 not blown, but circuit lights are out ...
- Fuel Pump Check Valve
- Cold Weather Protection?
- Power Steering Pump rebuild ...
- How can I tell if one of my injectors is leaking?
- I'm getting new rubbers on tuesday:)
- Disabling running lights
- I owe Javad an apology, he did reply back but my e-mail properties were wrong..
- corner light bulb connectors.....
- I'm worried about first gear........
- Tox...any more vids?
- I can't believe my Dad stole another Audi...(long)
- What to do?
- looking for tool no.3076
- Installed new V belts and.....
- is castrol 5-30 good for colorado winter ?
- wanting to install new front and rear struts/springs on my 88' 5ktq.
- Javad's First Post, Addressing the "Autronic?" Thread...
- Hello all...It's been a long time since you all heard from me...
- Anyone know where the thermo time switch goes in a '87 5k Quattro
- Blower fan dying?
- various wheels for sale in northeast
- Tale of new valve stem seals, etc. and disaster averted
- its official!
- how hard is it to replace a fuel pump on a 200TQ ?
- 1991 200 speaker install
- bought a 1991 200 turbo last weekend
- Audi 200 parts on 5000?
- self leveling???? (Adam you will know)
- Speedometer Help
- All this EFI talk, I hate to rehash, but...
- my second post of the night, hey mr. ankney...
- ya know for as much as i love winter, the first day of it really crapped on me and my audi! :( LONG
- X post from B5 ('04 S4)
- Door Panel Removal
- Airbag lamp
- does anybody know where the people on javad's site are getting their custom intake manifolds?
- How to get window up?
- Need Autozone part number for metal heater valve.
