- Blower motor rebulding
- Maintenance - changing "ignition components"
- Power Steering/Brake question ... help needed!
- door handle
- 5000 turbo quattro broke down in PA...
- Hey, New to the Audi scene, Vacuum Problem.
- Sunroof Removal 88 5000S
- V8 Timing Belt Tools for Rent
- I don't think we came back unscathed...???
- Hay ya'll...we're back
- Parts catalogue for audi
- A note on Intercoolers from Corky Bell
- Audi 200 for sale in Allentown, PA
- check engine light
- Radiator Leak 86 5KCSTQ
- YES ! pictures of the 84
- What's it worth?
- Need Audi 100 Engine Pics
- Emergency- Need Body Panels
- Need help determining bolt size
- Parting out 100
- Starting
- How do I fix my adjustment screws!?
- So what ever came of the V8 rear tails Group Purchase?
- I am having the worst time trying to score some 17's for my V8!
- My 200 is for sale - how much should I ask?
- Need some input on a decision
- Not the metering plate
- Hall sensor died?
- its a shame
- good/bad assumption...
- hahah the fun continues, more problems
- quattrofest this weekend
- Remember my mystery warning light?
- does anyone here have a contact in germany?
- Audi V8 auto transmission
- Engine issue
- Heater/AC problems continue!
- Have 00 code on climate control, still no joy from front vents....
- Soooo....my next question is...
- No heat??
- intake modification idea
- Heads off! Here's what caused my engine problem...
- 9/85 Type 44 NF Trip/Mileage Computer Wiring Diagram?
- Where are the bolts that loosen the AC compressor?
- Body Mod to Rear Fender
- 5000SQ Addition Set of Wheels/Studs - Value?
- Do you guys recommend putting heet in the gas tank?
- This car is awsome!!!!!!
- Central locking
- Opinions on Racing fuel
- Audi 100 quattro for sale
- UFO Brake Upgrade
- HELP!!! Huge starting issues
- heater core install
- Excellent, snow season is just around the corner.
- Some thoughts on timing belts (only for beginners at this...)
- How do I install/tension the AC belt on my 87 5KSQ NF?
- Is this for real? Can this be hooked up to KZ Engine?
- What is smoking?
- Superchicken strikes again!
- New 5ktq Avant and V8 engine.
- Started dismantling my 5ktq....Some questions....
- Steve Jensen: is your old 5ktqa for sale again?
- how many 5000's
- no heater or defrost fan!
- WTB: 1984-92 Audi Quattro
- 5000/200 Burnout Videos! Nice!
- anyone know info: Peter coulter audi only? what about Nolan or gigi?
- Audi 200 fuel pump, pump housing and 3214 tool for sale.
- Looking to buy!
- burned up wiper/washer control in my 200 20v TQ
- Gauge project
- hydraulic pump rebuild
- Fuelsystem Cleaning...
- Wanted: 5kt camshaft.
- Question from pic!
- What is this button?
- Volvo Intercoolers
- Audi vs Peugeot
- '87 5000tq problems and questions
- wtb Pearl BBS center cap
- 91 20v problems
- Bolt Size question
- It was the battery.
- A 6 gauge RED wire was connected to the ground under the fuse box!
- Does anybody here have any first-hand experience with the $400 3B ECU from tap1.com?
- Winter is here and my vents dont work......ideas?
- 200tq vs. 325i
- Looking at getting a 86' 5ktq, some ???'s
- Stupid bolt = frustrated owner
- Can I use a stiffer wastegate spring without an ecu change?
- Hey V8ers, cheap springs on Ebay...
- Is this a distributor problem?
- Short Shifter (If you're from Chicago please read too)
- Airbox Question...
- Did a little test of my starter tonight...
- I checked the ecu codes using the procedure on sjmautotechnik...
- need new shift knob
- Cold out! And no heat in my 200!
- How do i take off my starter with that stupid bolt?
- This is about the Hyperboost diverter. Got it off the Webpage...
- I'm about to replace the front struts in my 200 20v with older non-UFO style ones; will my Eibach...
- Attn: Steve Ankeny
- who would rent out tool #2084
- Tapping from Distributor Cap
- What is this sound?
- 91 200 Turbo Boost and Fuel Cut Off
- On the way to work this morning...
- HOW many people interested in V8 rear lights purchase?
- Awesome! on the a/c code check it gives 00 for channel '01!!!
- Drove it at 90mph down this road...as steady as a bird..
- Exhaust for the 5ktq?
- Where's the best place online to buy a rear caliper?
- DanA100, all you Audi 100 Guys
- Anyone know if 17x8.5" wheels will fit on a 200 20v? (I'll use spacers if I have to...)
- Has anyone dealt with Scott Bennett in IL for parts?
- I understand how to check AC codes now, how about ECU codes?
- Vibrations
- Radiator fan shouldn't turn on with the heater, right?
- Door lock connecting rod help
- I checked AC codes on my quattro...
- Timing belt-crankshaft question
- Anyone have pictures of nekkid quattro transmissions???
- Anybody else watch that bidfest on the '88 TQW on Ebay?
- Attn: Stephen Ankney - parts for sale
- Bumper piece from Blau
- The bumper mod for the 4000...
- Updating 60mm fuel pump to 44mm fuel pump with new housing.
- Ya know...
- I think my afterrun pump is about to go.
- Emergency 200 TQ Fuel Pump Questions please help!!!!!!!!!!!!
- Can I manually fix the fan speed resistor?
- Lighting question...
- I believe we mentioned dual exhaust earlier. here it is.
- feels like the brakes are binding????????
- 3B engine on ebay (not mine)...
- "Hi, my name is Steve and I'm addicted to turbo Audis"
- AC Programmer Code
- Rear Alignment on Front wheel drive car??
- Bad battery perhaps?
- thermostat question
- It's tough to bring myself to sell it now.
- Eurolight Group Purchase on the Quattro List.
- How to align wheels?
- Road Trip coming up...
- Flushing the coolant
- FS or FT: 88 5k turbo
- Seat back interchange
- new clutch in my 5000S !
- Anyone ever heard of a 'A8 rotor + Boxter caliper' front-brake upgrade for Type44's?
- looking for a new or used valve cover trim piece that covers the plug wires
- Stuff for sale. Let me know before it goes to Ebay!
- For Eric(Coop) 10 valve header pics...
- oil pressure & clutch ??'s
- Camshaft Pulley
- An update...
- looking for a 20v turbo engine
- How to time the engine?
- Besides Bosch, what are acceptible brands of engine oil filter (NF)?
- Good deal alert on ebay. H4 euro's...
- Oil filter for the turbo?
- My NEW tires ...
- Hydraulic Oil HELP where to find it at 10 pm in michigan
- pictures !! , yeah now that the car is sold
- 200q20v Pics
- TDC marks messed up ...
- Aftermarket exhaust systems
- What causes overboost?
- getting there...
- Need advice, Battery
- What kind of coolant do I use...
- This is helpful for those doing timing belts
- It's like the ten plagues or something...
- A smooth Audi that's far from dowdy
- Wheel size and shifter questions
- audi 100 brake accumalator--Hard BRAKE PEDAL
- One of my head lights is very low powered on 89 200. Any thoughts?
- broken hood latch cable
- my 3B arrived on saturday...
- Need advice on Power steering pump.
- Inside Diameter of heater hose?
- What size is the bolt on the vibration damper (NF Engine)?
- OK, the tranny is taking a dump
- V8 q'
- Who, what and where is Lehman?
- HUD Boost gauge
- Looks like the Audi 5000 5 spd is the hot ticket for the kit car crowd.
- 200T warm idle problems
- Anyone in Seattle got a windshield for a 5ks?
- The car......
- Late upshift 87 5ks 2.3
- Hey Audi 100 Guys
- Damnit! (!@#& Auto!)
- Indiglo gauges
- WTD: Type 44 parts or cars!!!
- replaced my bomb today...
- Un(expletive deleted)believable
- Fun with Pro/E...
- How to stop paint fade/oxydation?
- 89 200TQ Faulty Oil Pressure Warning
- Whats holding my engine?
- Timing belt removal...
- I hear some knocking under the drivers 's seats.
- Windows down.
- Bizzarre thought of the day: What if Audi entered a V-8 in Nascar? Discuss...
- parting out various audi's1984-1988
- 1991 200 turbo check engine light
- Daily driver?
- Okay, pics of my current Audi collection.
- What is the starting post?
- 87 or 80C Thermostat?
- Ignition switch and central locking system
- Audi 84 5000s heater blower
- Ignition switch??
- V8 differential
- Audi 200? Turbo or N/A?
- Damn audi must build their water pumps with preset timers...
- 5000S Water Pump
- Drop in a 3B engine?!?!?!
- I smell gas...
- Leaky trasmission? 91 200 20V
- how high can you go?
- Another Metering Plate question...
- Help dash lights/climate control
- goodbye 5KTQ.......hello 100cs quattro!!!
- Drove a real neat car the other day...
- I found where my AntiFreeze leak.
- Engine help
- Timing belt tools
- What is the metering plate...
- need help ASAP!!
- Swap question...is it possible??
- Time for new tires again!!! Please, share experience ...
- Mystery warning light...HELP!
- Opened a can of worms today...
- WANTED: 15" BBS mesh wheels with 4x108...
- Speaking of Coolant Leak... Just got mine checked. Tell me what you think.
- Tomorrow I get the coolant leak checked out.
- Clear corners for 89 audi 200
- What's the most likely thing causing my 10v turbo to take a while to start now that it's cold out?
- How many 5kt 5spd fwd versions are there?
- Dark speedo at night
- Key blanks...
- Help aligning my steering column Please! 1987 5000SQ
- Using a MC motor from an automatic...
- power seat switch
- windshield wiper ejectors
- Clock on 87 5KSQ
