PDA
View Full Version : Audi 5000 / 200 / V8 Discussion
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. Please help! About to try fixing.....but is this 86 5000S worth it?
  2. brakes grabbing ?
  3. Parting out 87 5000 fwd/auto
  4. 100/200 vital parts availability
  5. Clutch problem
  6. Engine swap questions (I searched)
  7. v8 timing belt question......part #'s
  8. Fuel pump removal.
  9. Sound treating a 5000's trunklid
  10. 91 Audi 100 driver side lock off track
  11. what does everyone here think of this for a aux lighting setup
  12. New member with a couple 200 Avant questions
  13. Does anyone have brochure PDF of '89-91 100 Quattro line?
  14. Fuel Pump reset Button ?
  15. 5000cs quattro brake conversion
  16. Miscellaneous on fuel system parts
  17. Help fast plese 1990 audi v8 wont start
  18. Experts desperataly needed
  19. rear speakers not working...where's the rear amp?
  20. 1986 Audi 5000s Idle Stabilization Issue
  21. V8 5 Speed Swap
  22. Audi/Bose Gamma CC on ebay (my listing)
  23. 92 V8 Q starts and dies - Not the crank sensor.
  24. 91 200 20V Fuel Leak
  25. Trip computer problem/speed signal
  26. 90 V8 dies unless I pump it..
  27. 5ktq parrrrrrrrrrrrrrrts...gotta move some.
  28. 1991 audi 200 tq avant brake issues and manual
  29. "Krazy Fast" idle
  30. Audi 5000 engine questions
  31. Selling my BBS RXs
  32. couple of things for sale from my 5000:
  33. Perhaps off topic - Ose Apparel.. What happened to them?
  34. V8 & 5000CDqt Rambling
  35. Trying to understand my strange idle behavior
  36. those of you that were following my avant project....
  37. Spring Clean
  38. Tail light / brake light / blinker
  39. V8Q accelerator (gas) pedal detail
  40. A few more questions bout my 1986 Audi 5000S
  41. Would anyone have an spare isv stab. Relay? for 200t Aut MC1? Idle prob.
  42. SMOke
  43. rear upper control arm
  44. O2 Sensor
  45. Rear Diff Lock Actuator --> Toast
  46. ABS Relay Fuse Keeps Popping
  47. ok well, updates and q's on the new avant
  48. turbo gone
  49. FINALLY Installed new injectors 86 5KTQ -Its worse!
  50. brakes hesitate and stutter till anti-lock warning light comes on
  51. outer cv joint, broken circlip?
  52. CV Shaftes 20vquattro
  53. Sticky ignition
  54. Door lock/handle removal questions.
  55. Tranny fluid
  56. 200 20v avant brake issue
  57. The 5000 is getting put for sale soon....
  58. Audi manual download..
  59. Problem Really Big One
  60. megasquirt maps...
  61. New Audi V8 owner..
  62. 200 20V Avant?
  63. Rattle / Grinding noise coming from distributor. Is it the good one?
  64. Strange ( really strange!!!) problem. No start, turbo gage showing 2.1 bar!! Mc-1 eng
  65. V8 Leaking Somewhere
  66. strange brake pedal behavior
  67. WG diaphragm, among other things
  68. Audi service in Ontario Canada
  69. Shift linkage re-do
  70. Coule someone please help me with my 86 Audi 5000S?
  71. 1991 200 TQ front drivers fender
  72. 5000 part out
  73. turbo swap
  74. I'm absolutely nuts
  75. Can fuel pressure be adjusted on an 87 MC-1?
  76. Wheel fit question
  77. Looking for filler pipe
  78. Slush Box numpty
  79. Auto trans....
  80. 200 20v - alignment or steering issues?
  81. Fuel Accumulator
  82. I'm contemplating replacing CIS with EFI
  83. speakers
  84. 200 propeller shaft CV joint
  85. I am looking to buy a '89-'91 100 Quattro.
  86. Oil...
  87. Looking for injectors
  88. I am selling set of smoked tail lights
  89. Found a 4.2L chip on ebay. Input?
  90. 1991 200 10v turbo with a BROKEN TURBO
  91. Looking for water hose coming from aux. water pump. NLA in dealer. Any good source?
  92. Any 91 Audi 200 20V owners in the Philly or NJ area?
  93. Gear Heads
  94. crank lock tool
  95. Alternator rebuild/ Bentley 5k/V8
  96. Anti-theft
  97. Can't open trunk
  98. climate control q's
  99. "new" site i'm working on getting up and running
  100. Best place to get mufflers/exhaust systems
  101. I think I have an exhaust leak
  102. audi v8 200 model front disc's ?!?
  103. New to V8
  104. Smoked tail lights
  105. Clicking Speedo
  106. window switch
  107. Passenger Window
  108. front passenger side cv joint v8q
  109. Idle Control Problems please help me!
  110. Speaker Wires
  111. Trip computer
  112. Headlights-
  113. 20020VT exhaust issue
  114. 89 quattro 200 turbo - sunroof issue?
  115. brake proportioning valve v8
  116. 90 V8Q- Alarm issues
  117. Head removal
  118. 1989 Quattro 200 - where to find new headlight assembly?
  119. 200QT Heater question
  120. Looking for manual transmission part for 86 5000CS TQ
  121. 1989 Audi 200TQ for Sale/Parts Car
  122. Another Axle replacement question (94 V8 Quattro)
  123. "The V8 List"
  124. Audi Bose Stereo and CD changer
  125. parting out 5k
  126. Okey, fuel consumption is OK but seems to surge while driving at idle OK and misfires
  127. How much for an auto trans for a 1990 Audi 100?
  128. 90 V8Q Speed/Revs...
  129. 1986 5000CS TQ - Drivers side window regualtor replacement
  130. Brake Booster bad on 86 5000CS TQ?
  131. Does anyone rebuild brake bombs (accumilator)? 1986 5000CS TQ
  132. 90 V8 steering rack removal (again)
  133. 84-88 Audi 5000 Bentley Includes TQ
  134. changinh steering wheels
  135. Bilstein Standard HD vs. Sport HD
  136. Big 90 v8 problem HELP!!!!!!!!!!!!!
  137. Are aftermarket crank sensors junk?
  138. 90 V8q Auto Trans
  139. In need of a engine
  140. 90 V8Q- Chip anyone?
  141. Quattro 200 20v Cooling Fan / Radiator Fan Not Working???
  142. audi 5000 rpm cut out
  143. 90 V8
  144. 90 V8Q- Code reader
  145. oil pressure problems need some help plz
  146. V8 quattro stuck throttle
  147. Audi 200 Quattro-good buy?
  148. Head light switch
  149. 94 Audi V8 Front wheel bearing replacement - HELP!!
  150. 92 Quattro V8 - Fuel pump?
  151. 1990 V8 quattro transmission
  152. What from the interior of an S4/S6 fits the T44 (V8) cars?
  153. Is this problem common
  154. lets talk carlisle...
  155. 87 5000cs turbo quattro
  156. Factory Towing Package
  157. Damn v8 Issues
  158. amazing things happens sometimes.....
  159. Lets talk headliners on a type 44
  160. 91 200 20V codes
  161. passed inspection :)
  162. anyone know what the symptoms of a torn wastegate diaphragm are?
  163. Ignition Coil Needed
  164. 1990 V8Q- Stock alarm system
  165. Computer, Chip or no chip???
  166. 1991 audi 200 timing belt/front main seal
  167. Best car pic thread ever have fun
  168. In need of turbo oil lines
  169. Running a '90 200tq in the 24 Hours of Lemons - suggestions?
  170. Euro Lights - bulb replacement
  171. 86 5000S Speedometer
  172. Bucking Issues
  173. Regarding the infamous V8 hot start issue
  174. 5000cs quattro fuel injection help
  175. v8q vs 5000 fuel pump
  176. 0.5 BAR
  177. 1990 V8 steering rack
  178. 1990 V8Q Code reader.
  179. Boost Gauge Reads 0.0
  180. Fault Code 2113
  181. Audi 4.2 V8 big fuel consumption and other questions.
  182. 1989 200 audi for $600 on craigslist needs wiring harness - good deal?
  183. 90 V8Q--no start
  184. Check Engine Light
  185. 90 V8Q---white smoke...
  186. V8 reference/speed sensor replacement - help?
  187. OFOs - Warped
  188. Rear alignment arm
  189. OIL LIGHT KEEPS FLASHING?????????
  190. Brake accumulator warning light switch
  191. oil line problem
  192. just a friendly reminder to go register for carlisle this year
  193. V8 chip question for you guys
  194. my heater fan is confusing me
  195. FS link?
  196. timing belt
  197. thought you guys might wanna see the results of my "emissions" test today
  198. Erratic Idle
  199. Mileage on a V8Q?
  200. Fault Code 2113
  201. bunch of new pics from me
  202. crankcase breather hose
  203. '89 200 won't start affter accident
  204. Increase Idle Speed 89 Audi 200
  205. switchblade keys for a V8Q
  206. V8Q Automatic trans repair manual?
  207. coolant level/temp. light warning error 1990 100Q
  208. For social networking only! :P does pretain to a V8
  209. Is Sachs Pro Gas OEM on a 91 200 20V? Boge and Sachs merged?
  210. help me evaluate possible v8 purchase
  211. Need CVs!!
  212. Foggy
  213. V8 Failed Emissions.....Again
  214. 91 200 Climate control not blowing any air(heat or a/c).
  215. V8 timing Belt and Oil Pump Seal
  216. will 95.5 urs6 rims fit on ufo brakes for a 91 v8 5 speed?
  217. 200 20V intake
  218. 20V breather hose
  219. audi for me?
  220. Interesting tranny swap 82 5000 turbo
  221. 90 V8Q Heater Issue
  222. V8Q Knock Sensors...
  223. Hlelp with no-start, V8q
  224. 90 audi v8 Instrument Cluster
  225. Let's all watch this video of my car starting (how entertaining LOL)
  226. 1990 V8Q no power in gear
  227. v8 quattro SMOKE FROM ENGINE
  228. Audi 5000s
  229. 90 v8 Quattro Lights
  230. Water pump and Thermostat 20V TQ 200
  231. Disabling ABS on V8Q '93
  232. V8 power steering hose
  233. 83 200 5T / 5000 turbo !
  234. am I screwed?
  235. 91 200 20V wheel fitment
  236. Major engine problem need help!!! (kinda long)
  237. Repair manual/ diagrams Audi 200
  238. HELP!!!!
  239. Power Steering
  240. wheel bearing and some other fun stuff
  241. CIS surges at an idle
  242. 91 100 parts needed (see pic)
  243. My Other Car
  244. Audi 5000 trans in a Porshe shifter options?
  245. Hi/Low beam switch
  246. Have a great Christmas !
  247. Changing diff oil ? (V8 quattro)
  248. Need some stuff for mods...
  249. one thing after another, please help.
  250. OK what are 200 20v cars selling for these days?
