PDA
View Full Version : Audi 5000 / 200 / V8 Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. Ordering some stuff for the V8..
  2. does anyone know who sells the intercooler outlet pipe for a 91 200q20v?
  3. Norcal Audi meet on Saturday....
  4. Long time since I've updated bout my car and been on the forum. Long post..
  5. chinese 100
  6. Looking for a Fuch
  7. Where to find the torx type wrenches for driveshaft bolts? What are they called?
  8. I need a 3B ECU. Anyone out there have one to sell?
  9. v8: changing struts, what do i need to buy...
  10. Saw a typ43 turbo at the Stouffville flea market this weekend. Good shape.
  11. do C4 (100/S4) headlights fit into V8/200 bodies without cutting? (follow up to earlier question:)
  12. Flashing CAT problems and low low.. low gas mileage (heater box work related)
  13. anyone have 3 centercaps for fuchs?
  14. Possible Cylinder Head Donors?
  15. A little FYI for folks in the NYC area....
  16. Catch can. Where do you put it on a 200 20v?
  17. V8 I saw at the Saline, MI fairgrounds, you here?
  18. A few boost questions....5000 TQ...
  19. Also big whooosh when opening gas tank at filling
  20. Electric Fire Question
  21. jumped to this forum because it seems like you guys have the most experience on PS pumps
  22. While the transmission is out
  23. Does anyone know if AutoZone carries the Bosch W7DTC spark plugs...
  24. Mid 80's 5000s parts - FREE
  25. Boost Gauge Installed
  26. Roll Call! NorCal Audi Meet - Saturday May 5th - Santa Clara, CA
  27. can i run an mc2 engine in an mc1 car?
  28. 1990 Qv8 exhaust pipes rubbing crossmember..any good remedys?
  29. Transmission fault code reading on '92 V8 4.2
  30. no start question
  31. Mystery Miss=Flywheel RPM Sensor
  32. Long overdue update on the ol 5ktq...
  33. general info regarding fixing BOSE amps... no more crackling+hissing noises :]
  34. V8Q Coolant Temperature Sensor
  35. Where to buy a WGFV? I checked the usual, but no go.. Where are they hiding? TIA!!
  36. Anybody seen this? Thought it was really cool.....
  37. Need Throw Out Arm
  38. Strange cold start condition when not full of gas; coincidence??
  39. Anyone want a UR Sport Steering wheel ?
  40. bars leak, pour in the the expansion tank?
  41. Oh it gets better..........
  42. mc1 engine needed
  43. Question on little coin holder gizzy on 20020v... spring fix? Removal?
  44. BTW guys... got a check engine only under boost or load?...
  45. 1990 Audi V8 Quattro Gas Mileage?
  46. Spotted a sweet pearl 200 Turbo Q in Eureka, NV today. Does it belong to anyone here?
  47. Nice looking on EBay, Lister?
  48. v8: time for new injectors, advice?
  49. OT: saw a very laggggy supra turbo today!
  50. some questions. 1990 v8q
  51. '91 100 white - parts car
  52. water in headlights....any neat tricks to this fix
  53. My tips and tricks for the Shop ... enjoy
  54. Leaking gas
  55. 200 20V cold air intake, anyone have experience?
  56. good price and potential score for someone out west..
  57. Odometer rollback, possible to detect on V8 Quattro?
  58. power upgrade
  59. 87 5k tq for sale! cheap
  60. spark plugs for 5000.....
  61. Hi all.... I'm back online. Move too longer than expected...
  62. Before BBS Rim
  63. Can someone pls confirm that p/n 056 919 081E is the correct oil pres switch for 91 200 20vt?
  64. v8: removing sun visors?
  65. Mystery miss on 200 20v
  66. Looking for the speedo Sender testing instructions... Anybody have a link?
  67. Used Audi dealer in Northern Mi.
  68. Difficult 1+2 gear engagement EZ fix!
  69. hey are you guys familiar with Mike Fishers Audi V8? does any one have pics lying around somewhere?
  70. Parting '87 5000 S Quattro and '86 5000 Turbo Quattro
  71. Starting Problem
  72. My car is for sale....
  73. Help with a leak :) 89 200 TQ 10v
  74. Hmmm.....why not?
  75. stall/no start
  76. no start condition
  77. Going to the Lone Star ALMS race in Houston today
  78. Oil Temperature Gauge
  79. HIDs in 200 or V8?
  80. '91 200 20v n00b replacing alternator... any tips?
  81. coworker is looking for a factory repair manual for his '90 V8 - what is the best source?
  82. Strange things happening to the turbo gauge..It fluctuates on ignition!!
  83. Delta radio codes-please give me some quick responses-
  84. v8: what type of relay goes in 'burgular alarm relay' spot?
  85. What's a 3B engine worth?
  86. Diff lock troubles. Easy fix?
  87. V8: spark plug wire resistance...
  88. More... "What is it" questions.
  89. Quick question - where does the 10v cam gear line up for timing?
  90. Call me crazy.....
  91. Lots of MegaSquirt Questions
  92. Parts, again: 1991 200 quattro 20-v turbo 5-spd
  93. 5000 wagon tires
  94. v8: seafoam?
  95. 3 questions? 1. battery drain 2. Locate mechanic
  96. Anyone have a set of child restraint anchors
  97. Anyone have a throttle valve for an 87 5000 Quattro non turbo....
  98. Beautiful V8 5spd
  99. Anyone know this early 5000 avant?
  100. ok guy's 90-91 V8q 5spd role call...
  101. grey -> black interior swap - is this crazy?
  102. v8 head gasket question
  103. 91 200 20V at mechanic who "states" that with plug change they need to ck timing and fuel mix? I did
  104. New screen name......
  105. Audi 5kTQ just purchased! Lots of little problems! Help!
  106. Anyone here located in or around El paso TX??
  107. VEHICLE FOR SALE
  108. Brand new radiator 5ktq Must go 75 takes it!
  109. 5ks look alot like cop cars at night with sqare lights and all,
  110. still have a clunk in the rear..done almost everything to stop it
  111. prolly get baleeted...
  112. MC2 Software
  113. what's the going rate for a 3.6 motor? any help is appreciated
  114. Need part number...
  115. Underbody Brace?
  116. v8: regarding my bouncy idle + surging...
  117. 1990 200 tq wagon
  118. Hey guys..........</gulp>
  119. Should I buy this '86 5000s wagon? First foray in Audis!
  120. Audi 100 cargo?
  121. 90 V8 will not idle, needs a jump to start. Any ideas where to begin?
  122. Will the front subframe from a 1986 5000tq interchange with a 90 200?
  123. Maybe a stupid question: DO Audis 200 ( 10V and 20V ) have any sort of cabin filter for A/C system?
  124. Does anyone use Bilstein Comfort Struts? I am looking for a compliant non harsh ride similar Boge TG
  125. 91 20V pulls strong EXCEPT on full throttle on long uphills it jerks from the rear with what feels
  126. V8: where is the carbon canister located?
  127. how often if at all should you flush hyd system? Have 101k now..
  128. wiper blades slapping what brand do you use
  129. Has anyone heard from Boxerfan in the last 30 days...?
  130. suspension question , where to access upper strut mount passenger rear
  131. V8: "Routing Hole"???
  132. WOW!
  133. After-Run Relay ?
  134. 1991 200 Quattro 20-valve turbo 5-spd PARTS
  135. Mystified
  136. Good bargain on MAC11 ecu on ebay. No affiliation, etc...
  137. V8: new FPR installed, feels better, but bouncy idle+surging still there :(
  138. steering rack boot
  139. 467,680km and she finally left me stranded!!
  140. Quattro v8 octane ratings..whats better?
  141. would a faulty ecu temp sensor cause no spark?
  142. 1987 5000 SQ
  143. Orifice Tube?
  144. Anybody ever do biz with autopartauctions.com???
  145. 1988 5000tq Blue smoke/diff lights
  146. V8 alternator install
  147. V8 suddenly dieing while driving down the road!
  148. Shared 93 South with a nice 200 20v today... anyone on here?
  149. Little Red Fuse by Battery on V8q
  150. Check out the ram air 5000TQ
  151. I forgot how nice a chipped I5 20vt motor feels...
  152. anybody got an A/C compressor/evap/accum replacement walkthrough?
  153. What is the exact explanation on why a TYP44 Turbo should stall opening the oil cap???
  154. changing strut inserts on v8?
  155. Boost questions
  156. I have found my new favourite tool :)
  157. V8Q A/C compressor pulley TU
  158. whats the best way to change strut bearings on a Qv8?
  159. using home depot hoses as breather hoses on the v8?
  160. Dash lights on 1990 200T
  161. about to give up
  162. Tell me about the 83 5kt
  163. 1990 Qv8 oil cooler pressure line..where to get?
  164. PS leak ?
  165. Tachometer issues
  166. Stange clicking strange idle??
  167. 1990 Audi 200 troubles starting, high idle?
  168. Wheel Bearings, instrument cluster, and door panel questions...
  169. Boost question
  170. SUCCESS! 3 birds with one stone...
  171. 1991 100 5cyl
  172. Found some awesome videos!
  173. Stupid question.....
  174. 86 5000 CS turbo Wagon Turbo Lag???
  175. The Beast is back on the road. Sorry for the delayed update.....
  176. no spark, no check engine light, no fault codes, no start
  177. Type 43 opinions?
  178. Anybody know where to run wires through the firewall 5ktq?
  179. audi v8 - changing atf fluid via syphon pump?
  180. chmnyboy where are you?
  181. 1990 qv8 control arm ball joint qusetion
  182. thinking about buying a 5000tq
  183. audi v8 - 3rd temp sensor near top radiator hose...?
  184. This 43T would fit the bill nicely...Shipping may cost a <few> Euro's although..
  185. good mechanic
  186. Ok..time to do my "fix it list"
  187. Devil's advocate...Who has a type 44 with no issues?
  188. So relay 21 under hood melted, if i cant fit the new relay in the sockets how do get 2nd fan speed?
  189. needin' an ignition dizzy for 91 100
  190. now she's dying when I roll to a stop?!?
  191. V8 power dropouts
  192. I think I found the air leak...Can you guys tell if I'm right?
  193. just bought a 1990 Audi 200 Turbo
  194. COST: V8 Quattro motor/tranny mounts!!!
  195. To S or not to S, that is the question....
  196. 87 5000cs TQ...picture in Bently manual shows 2 oil filters
  197. V8 - Fan speed temperatures?
  198. Blo-Stein
  199. hard start/shutoff problem.
  200. Just put some 17" wheels and summer tires on Craig's list
  201. Can Sears or the like handle a Audi 4 wheel alignment?
  202. Quick 'V8 Battle / Hot+Cold Start Issue' update...
  203. broken driver side mirror
  204. Need help to diagnostic failure in cooling fan... 89-200 10vtqa
  205. You would think being 70 out I could put my summer tires on...
  206. Idle issues...
  207. <sigh> Map pockets behind the front seats
  208. Buying parts online US -> Canada, anyone done this before?
  209. shift linkage kaput
  210. IT RUNNNNNNSSSSS 86 CS Turbo Quattro Wagon
  211. hard start
  212. V8 quattro in a salvage yard in Baltimore, MD
  213. cis question
  214. V8: Testing CTS / Vacume Diagram?
  215. Replacing injectors and valve cover....?
  216. newbie here with a question.
  217. Anybody know an easy way to change the bearing on the radiator fan 875k cs
  218. help me find a source!
  219. V8 Battle - I think my mechanic f**ked me over...
  220. fuel sender and banjo bolt 1990 Qv8
  221. Daytime running lights for Canada
  222. sunroof gasket
  223. My V8 battle continues :(
  224. Found a late model 5000Q for sale today.
  225. WTB one or two center caps for stock 91 200 20v wheels
  226. Looking at a V8 - Steering Rack question
  227. V8 for sale.
  228. 1990 V8 - Diagnostic Code 4343?
  229. Worst Noise Ever
  230. Do Fuel Pressure Regulators deteriorate over time or suddenly die?
  231. 91 100 changed coil and amplifier car started right up later on no spark again?
  232. So, do all your friends give you a hard time cuz you drive a 5000?
  233. Any 134a conversion success?
  234. Temp Gauge Not Working - Update
  235. Blinking codes on the V8 using fuel relay 'jumper'?
  236. Hard starts, hot or cold: Fault V8 FPR?
  237. Fuel pump Check Valve
  238. Some more Bling (Under Hood) for spring
  239. so what happened to the Dremel Tool Heater core write up?
  240. Looking for a small part
  241. Spring suggestions
  242. Testing Fuel Pressure Regulator?
  243. driveshaft carrier bearing replacement
  244. Changing V8 struts?
  245. 87 5KTQ Clutch Woes
  246. New Bling :-)
  247. Motherload of VW/Audi parts listed and orderable by p/n, check this out
  248. additional info on the problem i've been having.
  249. Exhaust system for 91' 200 Q
  250. odd after run behavior
