PDA
View Full Version : Audi 5000 / 200 / V8 Discussion
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. 5000S cylinder head
  2. Spare Audi CS 5000 / 200 Parts
  3. need help finding a part
  4. Glovebox removal
  5. Help finding a windshield
  6. Rear Diff Lock Up
  7. 91 200q-20V Front Passenger (RT) Fender For Sale
  8. Looking for a V8 Quattro
  9. Just bought a 1981 Type 43 Audi 100 for restomod
  10. Audi 5000 / 100 C3 2.2 Quattro engine swap
  11. Just bought 1990 pearl white
  12. Valve adjustments
  13. Audi 5k high idle and hot start issue
  14. Central door lock actuator problems 91 200TQ
  15. Dash lights funky and high beams stuck on
  16. Bad Idea???
  17. WTB D11 Front Door Speaker Grills
  18. Making sure everyone sees my post in the marketplace! Giving away my 1990 200 avant!
  19. AUDI 5000S
  20. Identifying specific variant of 1990 Audi 200 Avant Quattro
  21. Audi V8 Quattro: Several OE+ questions
  22. High idle after full throttle, Audi 5k 2.3L
  23. 200 10VT FWD 5 Speed
  24. Instrument cluster gauges not working
  25. Where to find rear suspension parts for my audi 5000 CS Quattro Avant
  26. 1980 5000S A/T to manual trans swap questions
  27. Audi 5000 S Battery killer
  28. Removing ignition cylinder for 88 5000tq
  29. 1990 v8 (d11)
  30. 1986 5000s Fuel Issues/No Start
  31. Source for Bosch accumulator fuel fittings.
  32. Audi 5000 TQ wagon start/fuel issue?
  33. 1988 CD5000tq ignition help
  34. Engine Stalling Issue 1990 Audi 200
  35. Front seats
  36. WTB : Rear badge "20" for 200 20V
  37. Audi V8Q transmission swap
  38. 3b coil on plug conversion
  39. Buying
  40. Volvo V70R Turbo on a 1991 3B?
  41. Accelerator Cable Valve cover grommet alternative?
  42. Audi 200 10vt power steering connections
  43. Looking to sell my 200 20V, Exceptional unit. Located in Madrid, Spain
  44. Need help with my 1987 Audi 5000s NF engine
  45. Audi 5000 rad fan won't shut off
  46. SE: 2.3 NF engine strange behaviour
  47. Audi 5000 // Rough idle when cold, smooths out when warm.
  48. 1981 audi 5000 turbo help needed quickly!
  49. Enlighten a rookie about the D11 Quattro V8
  50. Front Axle shafts for 200Q
  51. Audi v8 d11 3.6 engine dont have power
  52. LT: Looking for Audi 200 20v 5 gears torsen
  53. 86' 5kT exhaust pipe gasket part numbers
  54. 1987 Audi 5000 CS Wagon, how much is it worth?
  55. Fuel Injector line
  56. 87 5000S swap??
  57. AC Belt snapped on 1987 Audi 5000
  58. V8 all gears on lit up on indicator. Limp mode?
  59. Heater Flow Control Valve
  60. 1990 v8 3.6 hard start won’t rev past 3k
  61. Odometer correction
  62. 1989 Audi 3.6 V8 timing marks
  63. 1980 Audi 5000 [A50;22u/23u] | Electrical Wiring & Current Flow Diagrams
  64. 1990 Audi 200 20v - Vacuum questions
  65. SE: 1990 Audi 200 20v - Wiring issues!
  66. Audi 200 rally specs
  67. driveshaft support bearing
  68. Audi 5000CS turbo ignition control module
  69. HELP! Headlights failed! 1988 Audi 5000S Quattro
  70. HELP! 1990 200 Quattro hall sensor
  71. MC turbo running rich when it's cold outside
  72. WTB 1983 5000 Turbo Wheels
  73. 1990 Audi 200 20v
  74. 10 valve engine internals
  75. Audi V8 Quattro with no power when loaded
  76. 1991 100 a/c oddity
  77. Fuch Centers
  78. V8 Computer Chip
  79. 1990 Audi V8 parts car
  80. 40mpg Quattro
  81. Audi 200 clutch
  82. Actual weight of 200/V8?
  83. Finally : My Audi 200 20V ( almost ) done!!! and many things because of your help!
  84. Whining/Grinding Noise New Clutch?
  85. '83 5000 Trunk Latch
  86. Removing Audi 5000S 10v turbo (type 43 or 44)
  87. Low Beams Don't Work, High Beams Do!
  88. 86 5000CS Broken Speed Sensor
  89. Audi 5000 Turbo FWD auto
  90. Replace Clutch Line
  91. Desperate for brake calipers for 86 5000cs turbo wagon
  92. Need a old trick with the bonnet latch
  93. WTB: 1986 5000CS Clutch kit or Pressure Plate
  94. 100 Quattro Turbo project
  95. WTB UFO Rotors
  96. 1991 avant roof rails
  97. WTB: Euro/ German front plate mount
  98. Best Android Bluetooth OD2 scanner?
  99. Best source/eshop/ebay seller for vag 2x2 adapter cable?
  100. Does Anyone Recall Seeing?
  101. 3b water manifold
  102. Audi 5000 Quattro won't start
  103. 200 20v no start
  104. Part Out: 1987 Audi 5000 CS
  105. parts necessary to convert a 1991 V8Q with UFOs to G60s
  106. 5000cs quattro won’t stay started
  107. 1986 5000cs clutch not disengaging
  108. 10vt distributor
  109. 200 avant headliner
  110. How to get to Water Pump on 89 200 Avant 10v
  111. 5000 cs parts car
  112. 1987 5000 Turbo won't start when the engine is warmed up
  113. 1990 - 10v 200 Mechanical Fuel Distributor - replacement or rebuild?
  114. Type 43 Interior
  115. 1986 Audi 5000 CS Wagon Manual Starting Problems
  116. 1987 audi 5000 turbo
  117. Hydraulic Valve Lifters for 1991 V8 Quattro
  118. 1987 Audi 5000CSTQ Knock issues
  119. Getting out of vintage Audis. Parting out 200 Avant
  120. How to decode options sticker in trunk - 1990 Audi 100 Quattro
  121. Looking for the Blower Motor resistor and heat sink
  122. How hard is it to find '81 USA spec 5000 S C2 nowadays?
  123. V8 parts
  124. Instrument Cluster Fix
  125. Wiring source
  126. Knock sensor missing?
  127. 1989 audi 100 sensor question.
  128. Stash of *FREE* 200 20v/200/5000 parts in NH
  129. 1983 Audi 5000 Turbo
  130. Idle speed sensor question 1986 5000cs quattro 5spd
  131. rebuilt rack does not fit!
  132. Issue reinstalling big reds!
  133. I5 Engine Differences Between Models
  134. Bbk caliper question
  135. Front BBK brackets? Where to get.
  136. toml99 | Tom Laplante | 1963 - 2019
  137. Need help with 200 10vtq electrics
  138. Anyone have a few abs sensor clip?
  139. Question about Koni front struts
  140. '90 200T Automatic to manual swap + Quattro swap
  141. Vag 2069
  142. Threaded Hole in Water Pump for Timing Belt Tensioner
  143. Does anyone have this fuse lying around?
  144. 1987 Audi 5000 - Jumped Timing
  145. 1987 Audi 5000CSTQ - Clutch Replacement
  146. Audi 200 20V fuel cell
  147. Audi 200 Turbo KG - need help
  148. AUDI Parts Motherload
  149. Audi 5000 Battery Drain
  150. part number and source for lower intake manifold o-rings
  151. Central Locking System 875kTQ
  152. Need help front end sqweek squealing
  153. 49-state/California emissions
  154. 1987 Audi 5000 CSTQ - Instrument Cluster Lighting Questions
  155. 1987 Audi 5000CS Alternator Questions..
  156. Turbo identification
  157. Alternator cooling parts?
  158. Shokan Coach woks?
  159. Need shifter boot parts
  160. Autometer 20020? For VW jetta
  161. 200 Quattro e-brake parts needed
  162. Anyone have a extra a pillar trim
  163. Drive shaft cv joint
  164. Project thread reviving a 1991 Avant
  165. Whose driving a 200 in PA?
  166. Central locking pump?
  167. Rear big brakes?
  168. Need info on ecu part#
  169. Ben Swan ecu needs repair?
  170. 1991 20v ecu tuning who's left?
  171. Audi 100/5000 Brake Pedal Hard To Push
  172. I keep finding expensive mods
  173. RS2 EM? Can anyone tell me?
  174. 200 20v stock MAF and air box
  175. Looking for a good used modded ecu
  176. Saw an Audi 5000 wagon in Elma, Iowa
  177. Overboosting: need help wrapping my head around this
  178. 1990 quattro v8 hvac wiring
  179. Intro Root Beer Brown Avant 20v PO you here?
  180. Audi 200 20v Turbo Restoration
  181. 1987 Audi 5000 cs Quattro Turbo
  182. 1991 V8Q 5-speed needs a section of frame rail
  183. A picture of my '87 when it was barely a year old....
  184. 1990 10v Audi 200 TQ; Turbo questions.
  185. 1990 Audi 200 QA for sale- good condition. $4k
  186. I just tried to start my 1985 Audi 5000 S. The gas pump lights up and a yellow circle
  187. What can I get for a 1990 Audi 200 Turbo...???
  188. looking for radiator support and drivers side headlight support
  189. Chipping an 87 5000 TQ
  190. Cooling fan constantly running
  191. v6 to v8 swap
  192. Engine Bay Stickers
  193. 1988 5000CS - Looking for replacement carpet set black
  194. remove distributor to check drive gear
  195. 2001 cv axle situation
  196. Audi 5000 S Quattro Temp Gauge
  197. Audi 5000 S Quattro Performance parts
  198. 1991 Audi V8q PARTOUT
  199. THE yard ...
  200. Audi 100/200 C3 2.2l Reliability/maintenance?
  201. Bose Delta SQUEAL
  202. 2018 Grassroots Motorsports Challenge Help
  203. Hard cold start. Very hard hot start. Strange idle. Sputters up to 1800 rpm. WUR??
  204. Which Audis have Sunroof parts compatible with Audi V8's?
  205. New Guy Question
  206. LED Instrument Cluster Lights Audi V8
  207. V8 timing belts normally 4 pieces? I used the Search..
  208. Is your car truly luxurious without these?
  209. 1987 Audi 5000S Steering Rack Installation ?
  210. Push Pins
  211. Misfire at 5000rpm V8 Quattro
  212. A/c Programmer
  213. Looking for 200 Quattro Avant rear glass
  214. Audi B2 tuning compilation video!
  215. Question Regarding 1980 Audi 200 5T
  216. My 1990 v8 quattro. What is this part?
  217. 1986 5kCS Turbo -AC/Heater Programmer
  218. need info on 5k treser
  219. 88 audi 5000s quattro sedan headlights
  220. GPS Speedometer Conversion.
  221. In search of an "Audi" emblem...
  222. 1984 Audi 5000s spits and sputters
  223. Audi 5000 10v GLCC Chip and socket?
  224. 20v turbo bypass valve okay to use on 10v?
  225. '90 200 10V turbo coolant return hose info sought
  226. 1987 coupe Quattro 10v won't start
  227. 200 10V and 20V instrument cluster swap possible ?
  228. 1990 200 switch to LED headlights ?
  229. Fluid on the floor - '87 5kqt - HELP!
  230. Intercooler piping v crossmember 1990 200TQA 10v
  231. Low rpm misfiring ( or missing?) Can an Ignition module just be half dead?
  232. Interchange 200 20v and 10v BBS basketweave wheels
  233. 1988 Audi 5000 CD Turbo Idle Stabilizer Valve
  234. Climate Control 1990 200 turbo avant
  235. Want to tow 2001tt roadster awd 5spd manual 4down
  236. Flat towing 2001 TT roadster awd manual transmission
  237. New Audi 200tq Avant! Questions...
  238. 1990 200 10v exhaust manifold, engine mounts, injectors, instruments, light switch
  239. 4.2l v8 abh
  240. Found a great deal on Audi V8, Unsure about quality...
  241. Audi V8 Gepenzert (Armored B6) 1991
  242. Fuel problem
  243. 02 Audi A4 1.8T
  244. a8 rear fog
  245. Blown Head Gasket....ANything to do "while I am there"?
  246. need emissions sticker with or without radiator shroud
  247. Looking for a clean 5000 CS Quattro Turbo
  248. 1991 Audi 200 20v Fuel Filter issue?
  249. 87 5000SQ Throttlebody rebuild
  250. 1993 Audi V8 Quattro transmission issues
