PDA
View Full Version : Audi 5000 / 200 / V8 Discussion
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. anyone have a v8 with a 5-speed for sale?
  2. So Ronny Your Boys won!
  3. What did you guys think of the Audi R8 ad during the super bowl?
  4. wiring eurolights?
  5. Crankcase breather hose
  6. thermostat question
  7. For sale: 1990 3.6 V8 Quattro
  8. Steering Rack
  9. Rear suspension bushings and such, anyone done them?
  10. Turbo Diesel
  11. "Water in running engine" questions for the braintrust...
  12. the car speaks for its self
  13. Saw this on Craigslist
  14. abs question....
  15. Uh...Houston we have a F$^#$%$%@%@n Problem!!! [rant mode on]
  16. Exhaust options for a '91 V8 Quattro
  17. spark plug wire question
  18. Audi V8 transmission options
  19. Where to buy timing belt parts
  20. Audi Issues to Diagnose
  21. Does someone have a good layout of the secondary relay panel?
  22. so you were telling me to get new rims ron and i think i found them
  23. Speedo Needle Hesitating / OK Light Shows Lines / Intermittant Power Loss
  24. Would you hit this : p
  25. got two questions...
  26. anyone know of a obd 1 reader I could get for my 92 v8?
  27. Anyone have/know of a good writeup for replacing HVAC blower motor in a 200? TIA.
  28. Clutch Maintenance or Repair Cost
  29. v8 quattro thermostat
  30. Clutch pedal is halfway pressed
  31. I found your missing pair of pliers.
  32. TSW Wheel and Package special at Achtuning, 18s and 19s available for a limited time
  33. Groan from a new steering rack when cold
  34. 1989 Audi 100 2.3 I still can't seem to figure out the problem.
  35. V8 seats into an 86 5k? Possible for front and rear?
  36. fog light placement
  37. new all metal rad needed - '91 200 20v
  38. Confirm my suspicions... Coolant leak
  39. Any of you guys in NYC
  40. Failed ignition switch?
  41. now the saga begins.... where should i start?
  42. LOL @ friends emissions
  43. Anyone w/ the 411 on the T-red 90 V8 in audifans ???
  44. x-repost: Found my pictures from when i visited the Audi Museum in Ingolstadt
  45. Looking at a 91' 200 20V sedan---is it worth it?
  46. OEM 20V Fuel Pump (Bosch) PN ?
  47. Upgraded Distributor?
  48. i don't want to blind anyone on the road with my hid where can i get projector or hid
  49. Looking for some help!
  50. New brakes came in now to the fabrication....
  51. Anyone near Portland. OR?
  52. how much would you pay for.......
  53. Wow, it's brand new!
  54. V8Q still sick...
  55. Dreaded bouncing speedo...anyone have easy access to writeup on 200 IC soldering points?
  56. Audi 200: Instrument Cluster Question
  57. Will dish wheels 01 fit Audi V8 Quattro 90 model?
  58. 5000 died
  59. Adding remote keyless entry?
  60. My New 20V
  61. Headlight saga
  62. wow, i'm posting alot these past couple days.. i'm now the proud owner of
  63. 200 Avant Cargo Cover?
  64. are the eurolights for the 87 5kt supposed to be dual square beam?
  65. Pierburg Fuel Pump
  66. Anotherr 5KTD - FS in Phoenix no less!
  67. replacing cats....????? poll....lol......<<93'V8Q>
  68. Frayed Wiring Causing Short
  69. 89 100 , brakes drag'n /locking after driving 20 mins, abs light on
  70. 2007 Forum Traffic results are up....holy crap....
  71. A deer hit my audi....
  72. Is anyone in the Miami Area willing to go and look at a car for me?
  73. 1991 200 TQA instrument cluster question....
  74. wiper switch needed
  75. interesting to see what was made in china
  76. My New 20V Turbo.
  77. '90 V8 driver door window regulator fix.
  78. Anyone have an old manifold/turbo/wastegate they'd be willing to give away/sell cheap?
  79. I posted updates/answers on some issues I posted last week
  80. Is there a source for a new rubber spacer runing between bottom of grill and bumper? Mine's fragged.
  81. v8 in seattle don't know the seller
  82. My new car came a type 44 motor
  83. So the fan that draws air for my Int temp sensor died, no heat now (V8Q)
  84. T43 question - what is this vacuum fitting?
  85. charging question
  86. Blower motor replacement
  87. so i am going to paint the front/back bumper and door trim the same white as the rest of the car.
  88. would a cel that only comes on with acceleration be a knock sensor?
  89. maybe someone...
  90. 1990 100Q brake problem
  91. Where the heck do I add washer fluid on an 86 5000?
  92. Brake light flashing on dash - 2 possible reasons...
  93. 5000 troubles
  94. Overheating ! - Thermostat ?
  95. how much can i get
  96. What's the 0-60 specs on late model Run of the Mill VW GTI''s? Got my clock cleaned the other day;+(
  97. V8Q/UrS4 Urethane Rear Differential Bushing solution FOUND!
  98. Anyone here need a seat memory module?
  99. Is this Siemens alternator capacitor really needful ???
  100. nOOb on the 5k forum with curiousity question: 200q turbo wagon 5 speed ...how many were sold in US?
  101. audi 100 C3 dimension
  102. Ideas on problems needed
  103. parts
  104. Anyone still up? Sunvisor q
  105. 1990 v8 oil leak
  106. headlight question
  107. horrible mileage '91 200 20v ?!?! suggestions please.
  108. 1990 V8 - Bose Radio not working.. won't power on but will get dash lights..
  109. How hard would it be to...
  110. Sedan back window trim wanted.
  111. driving / fog light switch
  112. How to pull engine codes?
  113. I thought i filled up with enough winterized mix
  114. Time to move on - 89 200 TQA FS 750$
  115. 10v turbo ignition coil
  116. '89 200 Vent question...
  117. Howdy folks. Anyone know where I can find a flex bellows tube? (goes between wastegate and Downpipe)
  118. Pics of the motor under construction...
  119. Is a 10V waste gate assembley the same as a 20V(i.e. are they interchangeable?)
  120. Lights on!!!!!!! chime....i need anyone know what part #
  121. CHEAP 200 20v on eBay, this guy doesnt know what he has...
  122. good running 200 20v avant
  123. Any interest in parts?
  124. Says there is plenty of gas left in the V8 but.. Studder studder.. *loss of power*
  125. thinking about selling 1986 AUDI 5ktq... amazing shape...
  126. Got splitter?
  127. On the road, Limping home?
  128. 1989 Audi 100 Hesitation
  129. GTG?
  130. HELP!!!!!!!!!!!!!!!!
  131. Autocheck Shenanigans.
  132. R8 Sighting....enjoy
  133. Audi Dealership
  134. Was there someone on here in Mass. or Ct. that had a Silver 100/200 T44 they were parting?
  135. V8 '90 3.6 automatic & '93 4.2 automatic drive shafts
  136. Well changed my waste gate diaphragm and still get 1.9 BAR of boost
  137. itsav8 has been challenged in a test of automotive strength
  138. 20V/V8 Brake M/C
  139. What is this part?
  140. tool chest?
  141. Anyone ever thought about Diesel?
  142. Audi V8 tribute vid
  143. how affective are hid replacement foglights compaired to factory ones?
  144. Anyone know which PIAA model this light is?
  145. Can I change my waste gate diaphragm without removing the entire WG from the exhaust Manifold?
  146. Silver RS8 sighting
  147. Are stick V8Q's always the 4.2? BTW who remembers me??
  148. 1990 Audi 100 Quattro...
  149. Shokan???
  150. Anyone have pics of blue leather from a 200?
  151. LED Question-
  152. Hissing sound from the fuel pump?
  153. My friend needs buying help
  154. So it broke. But is there any way to find out WHY it broke?
  155. Wanted to borrow/rent: VAG 3117 tool
  156. Guess who's hand I shook today? Not Audi but definitely "sports car/racing" related!
  157. oil oddness
  158. Anyone ever add a nitrous bottle to your ride??
  159. Climate control Q
  160. 91 Audi 100 won't hold charge with new battery / alternator
  161. Newest addition to my 200 20v TQ interior!
  162. No Start - Ignition Switch Failure?
  163. headlight adjuster
  164. Fuel Pressure Regulator
  165. 93 V8 Quattro no air to footwells
  166. $995 18" TSW and Falken 912 A/S tire package special at Achtuning
  167. Brake regulator Spring
  168. OBD 1/OBD 2 for V8Q?????
  169. headlight Adj. screw
  170. V8 Driving very sickly
  171. No spark issue solved.
  172. 10VT exh mani
  173. '94 V8 - $5395
  174. I was told Barrett- Jackson sold a Sport Quattro over the weekend.....
  175. 1st time with warmed- up start concern
  176. so there is this coupe on audifans for sale and it has a digital guage
  177. HELP Please.87 5000cs qt ...Stutters & Stalls when accelerating from start
  178. Audi, Hella, Siemens Relays on Ebay -CHEAP!
  179. Quick question about a '90 100 sedan
  180. To all of you parts seekers.....
  181. Need left rear turn signal assembly. Got one Ron?
  182. can i go 80 watt on high bean in my 92 v8 on stock wiring? bulb code is 9006 right?
  183. 91 100 trunk amp wiring
  184. My new v8 ADJ FPR
  185. anyone know a good place for how to manuels on v8 quattros
  186. 1991 V8Q Front End Vibration Under Power
  187. Power Steering Fluid Febi M 6162
  188. Power Antenna wiring / testing
  189. Anyone here live in Alberta? I've got a bunch of extra front brake bits I could do without.
  190. I need help from someone with an MC2 MAC14 car... Please...
  191. Another year.
  192. V8 Brakes - occasional failure
  193. Engine start problem.
  194. where is fuse and relay for diff switch?
  195. Just watched Top Gear...
  196. Inexpensive used towing hitch
  197. What is he thinking
  198. back glass for 1990 100
  199. I wonder if I need a new cold start injector.....
  200. '89 200qa: Speedo good but odo/trip/computer/cruise not functional?
  201. Differences between a 5000 CD and 5000 CS ?
  202. DIY air/oil separator
  203. just for giggles
  204. follow up on check engine light
  205. got codes.. but.. I still need help!
  206. 1990 100 speedo jumps at any speed. HELP!
  207. wtf.. idling at 4k rpm
  208. '87 TQM and '91 20V front struts interchangable?
  209. intake air temp sensor
  210. source for euro lens?
  211. thermostat orientation?
  212. Lights in trunk lid not getting power '86 5000
  213. 91 200 20v Rear Diff Lock Cut-Off Override
  214. 1991 V8 3.6l engine bloc are made of aluminium or cast iron?
  215. 1991 V8Q Front End Vibration
  216. Possible new 5000 owner, should I buy?
  217. Anyone ever bought 1 of these code readers?
  218. Hoilday Cheers to my Friends
  219. Paint Availability
  220. Happy Holidays too all of the "four Golden Rings"
  221. Side dumps
  222. Front of the pack, as it should be.
  223. will lowering springs/shocks from a v8 fit a 200q?
  224. Looking for master cylinder rebuild kit for my 5k turbo
  225. Dear Santa! Should you happen to have a MC 10V Turbo engine in your Sack then Please drop it right
  226. Need help closing door on audi200
  227. Looking For "Audi 5000 S Diesel" badge for the trunk of my 81. where to look?
  228. removing valve cover?
  229. stripped allen bolt removing throttle body. options?
  230. diff lock 200q
  231. New Project...
  232. Well figured I'd say Happy Holidays to one & all!
  233. Major Headlight Modification (Not for the squeamish)
  234. Just got the Avant back together...
  235. Anyone have pictures of stories of things thay have done to their v8
  236. where to find new valve cover bolts?
  237. Why is it that the left wiper is always the one that freezes and smears right at eye level?
  238. Alright, well, bad news is shes decided to get rid of the 100...
  239. CEL 2231 ISV problem
  240. how to replace a fuel pump
  241. OMG LOOK WHAT IS FOR SALE
  242. 20 year old Audi and 40+ cms of snow
  243. V8 Bank 2 Knock Sensor CEL
  244. A little morning humor
  245. Skaking with Acceleration
  246. recaro type front seats from S6 avant ' 96 into V8 ' 93
  247. looking for exaust valve for 87 5kcs 10 valve turbo
  248. $700 '90 V8
  249. 89 TQ 200 No start
  250. Anyone interested in wheel stud conversions?
