PDA
View Full Version : Audi 5000 / 200 / V8 Discussion
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. how much can stock 2.2 10vt 5000 handle?
  2. 5th gear boost surge 12psi-15psi
  3. V8 Wiper parking
  4. Who's 4.2 V8, Ohio plate FMZ 3694
  5. Coilovers or strut and spring?
  6. Check engine while in boost. '90 200 quattro
  7. Help with 5000 Shifter
  8. 89 100 Fuel pump number?
  9. 500TQ/200 20V springs/struts
  10. Clicking in steering colomn when audi 100 is completely off
  11. Brake Accumulator Questions
  12. Window regulator rubber mounts
  13. Replacing TPS
  14. Rotors....
  15. Strange things while bleeding clutch
  16. Floormats
  17. CV Boot book time
  18. Crank Case vaccum line
  19. Crank Case vaccum line
  20. Audi 5000S
  21. 1990 100 part numbers
  22. Turbo Removal?
  23. 100 Quattro shifter socket
  24. heater/idle ? and diff locks mod
  25. Looking for a good 1990 V8 RF CV Joint & Trans
  26. Cashing Out
  27. Yttrium spark plugs
  28. Clutch Replacement - Fault Codes?
  29. Pearl 5000 Quatto Avant in Northern Mass.
  30. Toyo Versado LX touring 205/55/16 T rated 80.000 mile tires
  31. 1990 100 fuel pump replacement
  32. 1988 audi 5000s quattro random no spark issue
  33. Door Not Opening with key
  34. WANTED: 5000 quattro wagon
  35. quick ignition lock question
  36. The "Door Ajar" open sound keeps playing while I drive
  37. Blower motor runs, but only on "high"
  38. pop goes...
  39. shift lever replacement
  40. 91-93 v8 quattro worth?
  41. Low mileage 1990 v8Q for sale
  42. 3spd autotmatic tranny, have anybody installed oil cooler?
  43. MFTS
  44. Audi 100 1990 3spd autotrans, changed valve body, still doesn't work correctly??
  45. Audi V8 webasto thermo top T / BW50 install
  46. First Few Days
  47. Need 17" wheels for '90 V8
  48. Introduction:
  49. Problem with Dash Lights
  50. 1989 100 power window problem
  51. FS: D11 V8 tail light set
  52. 1991 Audi 200 20V TQ Cruise Control Question
  53. Type 44 brochure/manual PDF resource
  54. 1990 audi 100 just won't run right
  55. high Idle
  56. 89 Audi 200 Turbo not running any ideas?
  57. loose steering column 1990 v8
  58. Euro Lights :-) V8
  59. My 91 V8 has no power above 4000 rpm.
  60. New and used Parts for Audi Typ 44 from Germany
  61. selling a audi v8 motor
  62. '86 5ktq---no heat
  63. Audi 200 Quattro 5 speed Front CV
  64. 1990 Audi 200 Turbo auto
  65. looking for DIY coil over write up and some other info
  66. bypass knock sensor?
  67. 200 20v intercooler problems
  68. 1990 Audi 100 Air Intake Hose Fix
  69. Clutch Kit Advice for Audi 200?
  70. Rail / Holder for Spark Plug wires for 1990 Audi 100
  71. Vacuum line for seafoam?
  72. Springs for 1989 200q sedan
  73. Can anyone tell me what these are?
  74. My Audi is Toast!
  75. surging at 1800 rpm.
  76. Strabgest behavior. Engines stumps at 4K rpm
  77. How do you ID a CA 1990 V8?
  78. The 3-4week project.
  79. knock sensor location? 5000cs tq
  80. 1991 V8 - Suggestion needed to find a new home for that wonderful car
  81. 1990 V8 FPR - R&R Starter & Cleaning Idle or Throttle Position
  82. Starts Hard
  83. Wastegate tuning?
  84. WTB: USED UFO ROTORS
  85. engine color?
  86. Audi issue in a haystack!
  87. 1990 V8 Wants To Occasionally Die
  88. dead spot between 1K and 2K
  89. Easy Final Drive Differential Fluid Change
  90. Audi V8 3.6 1989 fitting newer type climate control
  91. vaccum routing scheme/picture
  92. Hood Support Broke The Fuel Injection!
  93. Can anyone confirm the following
  94. how to tied down on a trailer
  95. Will not go above 3500 rpm
  96. 200 qt
  97. central lock pump
  98. I think I blew my gauge cluster on my 200 20v
  99. V8 Quattro instrument cluster question
  100. 14" 5000 Wheel Centre Caps
  101. ABS issues
  102. 5000cstq ACC servo motor/potentiometer "open"
  103. Fuse 13 Unlucky Number,,,,,,
  104. Weird noise 89200QT
  105. Besides this site, what site has more active posters?
  106. Deceleration Valve electrical connector?
  107. Stripped O2 Sensor X-Pipe - 90 V8 3.6
  108. Seat Heater Swap not Working
  109. :: ECS Tuning :: 7th Annual Sale And Holiday Giveway!!!
  110. V8 Quattro subframe bushing - help!
  111. Rear end slid into a curb recently need some help
  112. a8 instrument cluster in V8, cant get outside temp to be shown on display
  113. 3 spd auto trans doesnt engage reverse when hot? Any tips?
  114. 200q20v rear suspension squeaky.
  115. Saving a 200TQM from the crusher
  116. Info for DTM 3.6 V8 (PT) engine..
  117. V8 Quattro transmission questions
  118. 1990 MC2-engine is giving me the irrits (running lean)
  119. 90V8Quattro odometer quit/cluster removal
  120. timing belt questions for V8 quatrro 3,6
  121. 89 200QT Tires
  122. 89 200qt diff lock question
  123. haha rear seat removal this time...
  124. How to repair 3 speed auto transmission?
  125. 89 200QT aftermarket radio
  126. Several issues with 86 Audi 5000CS TQ
  127. I do not like car alarms,
  128. lube blower motor
  129. Help needed on front seat removal
  130. 1989 200 QT...temp sensor out?
  131. 91 Audi 200 20v Ignition Coil
  132. Fenco power steering rack
  133. Car is foggin up..Hopefully fixed?
  134. 1990 V8 Front Swaybar Bushing Source
  135. looking for audi 100/5000 <88 gauge pod
  136. Odd intermittent brake issue
  137. 10v running for sale
  138. What must I do to mount a V8 sunshade in my 5000TQ?
  139. Calling all 200q20v AVANT owers
  140. auto trans fluid
  141. 1989 100Q How to replace the fuel pump
  142. 88 5000 idle control unit
  143. 200 20v 3b engine parts
  144. Have a tranny out of 91' 200 20v if interested?
  145. Bomb replacement tips/tricks?
  146. 1991 200 20v QT Tie Rod Assembly
  147. 89 100 Workshop Manual-Need One
  148. Typ44 switches
  149. how to make a V8Q power steering hose
  150. Idle issues
  151. Intermittant stalling problem (1990 V8)
  152. 1991 Audi V8 quattro 5 speed clutch pedal stuck on floor
  153. 1990 V8 problem
  154. 1989 100 Trans problem
  155. Sunroof out...Now what?? How to access headliner parts?
  156. 1989 100 Wipers just quit
  157. Stalling 20v... Need help!
  158. Need a Starter for '90 V8Q
  159. Squeeling 1990 V8 Breaks
  160. How to remove sunroof?
  161. Headliner replacement thread...Some advice needed..
  162. Power Steering Connection
  163. My alternator belt saga may have been resolved
  164. Any G60 sets collecting dust out there?
  165. Useful parts from climate c / heater box ?
  166. 1990 200QT 10v
  167. hy
  168. 1991 100 battery cable
  169. WTB: Quattro rear bearing hub / carriers
  170. New tailights...
  171. Not going beyond 3500 rpm
  172. V8 Quattro crank and speed sensor testing
  173. Intermitten on/off air cond compressor
  174. ECU
  175. 88 5000 S no fuel out of the distributor
  176. 89 200 Quattro Stalling problems.
  177. Stebro SS Exhaust System
  178. Auto Check display reset knob
  179. My first audi
  180. 91 V8 Quattro overheating issues
  181. v8 quattro heater core r+r
  182. Replaced blower motor, now I only have hot air
  183. Instrument Panel Lights Gone Dead All At Once on 1990 V8 Quattro
  184. 1990 V8 Quattro Need Power Steering Pressure Hose
  185. who uses cam holding tools
  186. Anybody have UFO rotor's for sale
  187. 5000 parts
  188. 20v Turbo burning oil
  189. C4 Spring Rates? - looking to sink the Bismarck...
  190. Fuel accumulator part number Audi 200
  191. cold engine running issue
  192. Worthwhile to pull out the windscreen ?
  193. feeler- 10vt 6th injector kit
  194. Remove steering but keep power braking?
  195. Video: just for fun!
  196. new 200 quattro owner.. need some help please
  197. 1989 100 quattro fuel problem
  198. Inner CV joints
  199. 90 V8 climate control
  200. rear suspension bushings 90 100q
  201. 1988 Audi 5000 Bentley question
  202. Looking for a trim piece...
  203. 200 TQA Rear Brake Woes
  204. ISV unit input signal from A/C for the ISV to raise rpm's when ON
  205. Thinking about picking up this car
  206. Name this Part on '90 V8
  207. 90 V8 Q auto trans trouble.
  208. replacing Trans. mounts on 1990 100Q
  209. :: ECS Tuning :: V8 Quattro OEM Air Filters $1.48!!!
  210. Transmission Filter / Flush
  211. I think my tranny is toast. (Another V8Q Horror Story)
  212. 1989 audi v8..cel came on but no codes..
  213. Audi 200t boost questions??
  214. '93 Audi S4/100 engine computer
  215. Cruise control diaphragm cooked....
  216. *bay 200 20v's
  217. My 5th Audi
  218. Anti-Lock Light
  219. Wiring around brake fluid reservoir
  220. boost vs fuel cutoff
  221. Dash Kit
  222. Cabin Air Filter
  223. Dash Light Bulbs
  224. Electric Seats - Issue
  225. Can`t start
  226. Parting out 5000
  227. Oil Filter Dilema
  228. Need V8 help.. Ohio
  229. V8 rear brake lines
  230. V8 Chip Tuning
  231. 1990 Audi 100 Turbo Quattro (MC2-engine) misfiring
  232. V8 Engine Codes
  233. V8 Rear Brake Caliper Removal
  234. Maintenance and Modification finished on the 93V8‏
  235. Rims / UFO brakes fitment
  236. braided gas line replacement
  237. Back in the Audi family
  238. '91 200 20v brake swap parts and tips?
  239. Gas & Temp Gauges drop out, weird
  240. 1990 parts V8q has to go...
  241. 83 TD question
  242. Turn signal modification
  243. 1990 200QA starting intermittent problem
  244. Complete engine overhaul done. Hard start, cold or hot
  245. Rims
  246. 5000cs quattro fuel injection help
  247. Rear Brakes
  248. part # for PS/Booster Resvervoir Cap Gasket
  249. Adams gymK video
  250. Power Steering hose
